  3. Sensor node problem after gateway reset
3 Posts 2 Posters 1.1k Views 3 Watching
  • N
    N
    nucutza
    I have built an MQTT gateway (Mysensors 2.2.0, openhab 2.2.0,mosquitto RFM69HW radio - running on RPi3)and a wattmeter node(PZEM004t with arduino pro mini), both of them working properly in normal circumstances.
    This is the arduino sketch :
    #include <SoftwareSerial.h>
    #include <PZEM004T.h>
    #define MY_RADIO_RFM69
    #define MY_RFM69_NEW_DRIVER
    #define MY_RFM69_FREQUENCY RFM69_433MHZ
    #define MY_IS_RFM69HW
    #define MY_TRANSPORT_WAIT_READY_MS 1
    // Object Node
    #define MY_NODE_ID 5
    // initialisation du PZEM004T
    PZEM004T pzem(4,5);  // RX,TX
    IPAddress ip(192,168,1,1);
    //V_VOLTAGE S_MULTIMETER
    //V_CURRENT S_MULTIMETER
    //V_WATT    S_POWER
    //V_KWH     S_POWER
    #define CHILD_ID_VOLTAGE 1
    #define CHILD_ID_CURRENT 2
    #define CHILD_ID_WATT 3
    #define CHILD_ID_KWH 4
    #define SLEEP_NODE true // True to activate Sleep Mode
    unsigned long SLEEP_TIME = 30 * 1000; // Sleep time between reads (in milliseconds)
    MyMessage msgVolt(CHILD_ID_VOLTAGE, V_VOLTAGE);
    MyMessage msgIntensite(CHILD_ID_CURRENT, V_CURRENT);
    MyMessage msgWatt(CHILD_ID_WATT,  V_WATT);
    MyMessage msgKwh(CHILD_ID_KWH, V_KWH);
    void presentation()  {
      sendSketchInfo("PZEM 004T ", "1.0");
      // Déclaration des capteurs attachés au noeud
      present(CHILD_ID_VOLTAGE, S_MULTIMETER);
      present(CHILD_ID_CURRENT, S_MULTIMETER);
      present(CHILD_ID_WATT,  S_POWER);
      present(CHILD_ID_KWH, S_POWER);
      pzem.setAddress(ip);
      float v = pzem.voltage(ip);
      if (v < 0.0) v = 0.0;
      Serial.print(v);Serial.print("V; ");
      delay(10);
      float i = pzem.current(ip);
      if(i >= 0.0){ Serial.print(i);Serial.print("A; "); }
      delay(10);
      float p = pzem.power(ip);
      if(p >= 0.0){ Serial.print(p);Serial.print("W; "); }
      delay(10);
      float e = pzem.energy(ip);
      if(e >= 0.0){ Serial.print(e);Serial.print("Wh; "); }
      Serial.println();
      send(msgVolt.set(v, 1));
      send(msgIntensite.set(i, 1));
      send(msgWatt.set(p, 1));
      send(msgKwh.set(e, 1));
      if (SLEEP_NODE) {
        Serial.println("Sleep");
        sleep(SLEEP_TIME);
      } else {
        delay (SLEEP_TIME);
    If I power cycle the node, all is OK and the node reconnect to the gateway.
    But when I power cycle the gateway, the gateway itself starts up properly but the node freeze.
    The serial output of the node looks like this:
     __  __       ____
            |___/                      2.2.0
    16 MCO:BGN:INIT NODE,CP=RPNNA---,VER=2.2.0
    26 TSM:INIT
    28 TSF:WUR:MS=1
    36 !TSM:INIT:TSP FAIL
    38 TSM:FAIL:CNT=1
    40 TSM:FAIL:DIS
    43 TSF:TDI:TSL
    43 MCO:BGN:STP
    1054 MCO:BGN:INIT OK,TSP=0
    0.00V; 0.00A; 0.00W; 93.00Wh;
    3891 !MCO:SND:NODE NOT REG
    3895 !MCO:SND:NODE NOT REG
    3897 !MCO:SND:NODE NOT REG
    3899 !MCO:SND:NODE NOT REG
    Sleep
    3903 MCO:SLP:MS=30000,SMS=0,I1=255,M1=255,I2=255,M2=255
    3909 !MCO:SLP:TNR
    10045 TSM:FAIL:RE-INIT
    10047 TSM:INIT
    10049 TSM:INIT:TSP OK
    10051 TSM:INIT:STATID=5
    10055 TSF:SID:OK,ID=5
    10057 TSM:FPAR
    10061 TSF:MSG:SEND,5-5-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    10491 TSF:MSG:READ,0-0-5,s=255,c=3,t=8,pt=1,l=1,sg=0:0
    10496 TSF:MSG:FPAR OK,ID=0,D=1
    12072 TSM:FPAR:OK
    12075 TSM:ID
    12075 TSM:ID:OK
    12077 TSM:UPL
    12093 TSF:MSG:SEND,5-5-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
    12103 TSF:MSG:READ,0-0-5,s=255,c=3,t=25,pt=1,l=1,sg=0:1
    12109 TSF:MSG:PONG RECV,HP=1
    12111 TSM:UPL:OK
    12113 TSM:READY:ID=5,PAR=0,DIS=1
    12126 TSF:MSG:SEND,5-5-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
    12136 TSF:MSG:READ,0-0-5,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
    12161 TSF:MSG:SEND,5-5-0-0,s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=OK:2.2.0
    12183 TSF:MSG:SEND,5-5-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0
    14198 TSF:MSG:SEND,5-5-0-0,s=255,c=3,t=11,pt=0,l=10,sg=0,ft=0,st=OK:PZEM 004T
    14221 TSF:MSG:SEND,5-5-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=OK:1.0
    14243 TSF:MSG:SEND,5-5-0-0,s=1,c=0,t=30,pt=0,l=0,sg=0,ft=0,st=OK:
    14268 TSF:MSG:SEND,5-5-0-0,s=2,c=0,t=30,pt=0,l=0,sg=0,ft=0,st=OK:
    14290 TSF:MSG:SEND,5-5-0-0,s=3,c=0,t=13,pt=0,l=0,sg=0,ft=0,st=OK:
    14313 TSF:MSG:SEND,5-5-0-0,s=4,c=0,t=13,pt=0,l=0,sg=0,ft=0,st=OK:
    14319 MCO:REG:REQ
    14336 TSF:MSG:SEND,5-5-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
    14346 TSF:MSG:READ,0-0-5,s=255,c=3,t=27,pt=1,l=1,sg=0:1
    14352 MCO:PIM:NODE REG=1
    14354 MCO:SLP:MS=19557
    14358 TSF:TDI:TSL
    14360 MCO:SLP:WUP=-1
    14362 TSF:TRI:TSB
    223.20V; 0.11A; 3.00W; 93.00Wh;
    16216 TSF:MSG:SEND,5-5-0-0,s=1,c=1,t=38,pt=7,l=5,sg=0,ft=0,st=OK:223.2
    16474 TSF:MSG:SEND,5-5-0-0,s=2,c=1,t=39,pt=7,l=5,sg=0,ft=0,st=OK:0.1
    16496 TSF:MSG:SEND,5-5-0-0,s=3,c=1,t=17,pt=7,l=5,sg=0,ft=0,st=OK:3.0
    16519 TSF:MSG:SEND,5-5-0-0,s=4,c=1,t=18,pt=7,l=5,sg=0,ft=0,st=OK:93.0
    Sleep
    16527 MCO:SLP:MS=30000,SMS=0,I1=255,M1=255,I2=255,M2=255
    16533 TSF:TDI:TSL
    16535 MCO:SLP:WUP=-1
    16537 TSF:TRI:TSB
    223.70V; 0.11A; 3.00W; 93.00Wh;
    18290 TSF:MSG:SEND,5-5-0-0,s=1,c=1,t=38,pt=7,l=5,sg=0,ft=0,st=OK:223.7
    18313 TSF:MSG:SEND,5-5-0-0,s=2,c=1,t=39,pt=7,l=5,sg=0,ft=0,st=OK:0.1
    18335 TSF:MSG:SEND,5-5-0-0,s=3,c=1,t=17,pt=7,l=5,sg=0,ft=0,st=OK:3.0
    18360 TSF:MSG:SEND,5-5-0-0,s=4,c=1,t=18,pt=7,l=5,sg=0,ft=0,st=OK:93.0
    Sleep
    18366 MCO:SLP:MS=30000,SMS=0,I1=255,M1=255,I2=255,M2=255
    18374 TSF:TDI:TSL
    18376 MCO:SLP:WUP=-1
    18378 TSF:TRI:TSB
    224.00V; 0.11A; 3.00W; 93.00Wh;
    20361 TSF:MSG:SEND,5-5-0-0,s=1,c=1,t=38,pt=7,l=5,sg=0,ft=0,st=OK:224.0
    20383 TSF:MSG:SEND,5-5-0-0,s=2,c=1,t=39,pt=7,l=5,sg=0,ft=0,st=OK:0.1
    20406 TSF:MSG:SEND,5-5-0-0,s=3,c=1,t=17,pt=7,l=5,sg=0,ft=0,st=OK:3.0
    20428 TSF:MSG:SEND,5-5-0-0,s=4,c=1,t=18,pt=7,l=5,sg=0,ft=0,st=OK:93.0
    Sleep
    20436 MCO:SLP:MS=30000,SMS=0,I1=255,M1=255,I2=255,M2=255
    20443 TSF:TDI:TSL
    20445 MCO:SLP:WUP=-1
    20447 TSF:TRI:TSB
    223.30V; 0.11A; 3.00W; 93.00Wh;
    22429 TSF:MSG:SEND,5-5-0-0,s=1,c=1,t=38,pt=7,l=5,sg=0,ft=0,st=OK:223.3
    22454 TSF:MSG:SEND,5-5-0-0,s=2,c=1,t=39,pt=7,l=5,sg=0,ft=0,st=OK:0.1
    22470 TSF:MSG:SEND,5-5-0-0,s=3,c=1,t=17,pt=7,l=5,sg=0,ft=0,st=OK:3.0
    22491 TSF:MSG:SEND,5-5-0-0,s=4,c=1,t=18,pt=7,l=5,sg=0,ft=0,st=OK:93.0
    Sleep
    22499 MCO:SLP:MS=30000,SMS=0,I1=255,M1=255,I2=255,M2=255
    22505 TSF:TDI:TSL
    22507 MCO:SLP:WUP=-1
    22509 TSF:TRI:TSB
    224.90V; 0.11A; 3.00W; 93.00Wh;
    24506 TSF:MSG:SEND,5-5-0-0,s=1,c=1,t=38,pt=7,l=5,sg=0,ft=0,st=OK:224.9
    24522 TSF:MSG:SEND,5-5-0-0,s=2,c=1,t=39,pt=7,l=5,sg=0,ft=0,st=OK:0.1
    24545 TSF:MSG:SEND,5-5-0-0,s=3,c=1,t=17,pt=7,l=5,sg=0,ft=0,st=OK:3.0
    24567 TSF:MSG:SEND,5-5-0-0,s=4,c=1,t=18,pt=7,l=5,sg=0,ft=0,st=OK:93.0
    Sleep
    24573 MCO:SLP:MS=30000,SMS=0,I1=255,M1=255,I2=255,M2=255
    24582 TSF:TDI:TSL
    24584 MCO:SLP:WUP=-1
    24586 TSF:TRI:TSB
    225.40V; 0.11A; 3.00W; 93.00Wh;
    26585 TSF:MSG:SEND,5-5-0-0,s=1,c=1,t=38,pt=7,l=5,sg=0,ft=0,st=OK:225.4
    26609 TSF:MSG:SEND,5-5-0-0,s=2,c=1,t=39,pt=7,l=5,sg=0,ft=0,st=OK:0.1
    26632 TSF:MSG:SEND,5-5-0-0,s=3,c=1,t=17,pt=7,l=5,sg=0,ft=0,st=OK:3.0
    26654 TSF:MSG:SEND,5-5-0-0,s=4,c=1,t=18,pt=7,l=5,sg=0,ft=0,st=OK:93.0
    Sleep
    26662 MCO:SLP:MS=30000,SMS=0,I1=255,M1=255,I2=255,M2=255
    26669 TSF:TDI:TSL
    26671 MCO:SLP:WUP=-1
    26675 TSF:TRI:TSB
    224.40V; 0.11A; 3.00W; 93.00Wh;
    28663 TSF:MSG:SEND,5-5-0-0,s=1,c=1,t=38,pt=7,l=5,sg=0,ft=0,st=OK:224.4
    28688 TSF:MSG:SEND,5-5-0-0,s=2,c=1,t=39,pt=7,l=5,sg=0,ft=0,st=OK:0.1
    28715 TSF:MSG:SEND,5-5-0-0,s=3,c=1,t=17,pt=7,l=5,sg=0,ft=0,st=OK:3.0
    28739 TSF:MSG:SEND,5-5-0-0,s=4,c=1,t=18,pt=7,l=5,sg=0,ft=0,st=OK:93.0
    Sleep
    28745 MCO:SLP:MS=30000,SMS=0,I1=255,M1=255,I2=255,M2=255
    28751 TSF:TDI:TSL
    28755 MCO:SLP:WUP=-1
    28758 TSF:TRI:TSB
    30738 TSF:MSG:SEND,5-5-0-0,s=1,c=1,t=38,pt=7,l=5,sg=0,ft=0,st=OK:224.9
    30760 TSF:MSG:SEND,5-5-0-0,s=2,c=1,t=39,pt=7,l=5,sg=0,ft=0,st=OK:0.1
    30783 TSF:MSG:SEND,5-5-0-0,s=3,c=1,t=17,pt=7,l=5,sg=0,ft=0,st=OK:3.0
    30808 TSF:MSG:SEND,5-5-0-0,s=4,c=1,t=18,pt=7,l=5,sg=0,ft=0,st=OK:93.0
    Sleep
    30816 MCO:SLP:MS=30000,SMS=0,I1=255,M1=255,I2=255,M2=255
    30822 TSF:TDI:TSL
    30824 MCO:SLP:WUP=-1
    30826 TSF:TRI:TSB
    225.70V; 0.11A; 3.00W; 93.00Wh;
    34189 !TSF:MSG:SEND,5-5-0-0,s=1,c=1,t=38,pt=7,l=5,sg=0,ft=0,st=NACK:225.7
    35549 !TSF:MSG:SEND,5-5-0-0,s=2,c=1,t=39,pt=7,l=5,sg=0,ft=1,st=NACK:0.1
    I tried to add the followings lines to the sketch :
    #define MY_TRANSPORT_SANITY_CHECK
    #define MY_TRANSPORT_SANITY_CHECK_INTERVAL_MS (60*1000ul)
    but no luck , the node is not freezing anymore but it doesnn't reconnect.
    This is the new output :
     __  __       ____
            |___/                      2.2.0
    26 TSM:INIT
    28 TSF:WUR:MS=1
    38 TSM:FAIL:CNT=1
    40 TSM:FAIL:DIS
    43 TSF:TDI:TSL
    43 MCO:BGN:STP
    0.00V; 0.00A; 0.00W; 96.00Wh;
    3901 !MCO:SND:NODE NOT REG
    3903 !MCO:SND:NODE NOT REG
    Sleep
    3905 MCO:SLP:MS=30000,SMS=0,I1=255,M1=255,I2=255,M2=255
    3911 !MCO:SLP:TNR
    10047 TSM:INIT
    10057 TSM:FPAR
    10637 TSF:MSG:READ,0-0-5,s=255,c=3,t=8,pt=1,l=1,sg=0:0
    10643 TSF:MSG:FPAR OK,ID=0,D=1
    12072 TSM:FPAR:OK
    12075 TSM:ID
    12075 TSM:ID:OK
    12077 TSM:UPL
    12089 TSF:MSG:SEND,5-5-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
    12099 TSF:MSG:READ,0-0-5,s=255,c=3,t=25,pt=1,l=1,sg=0:1
    12105 TSF:MSG:PONG RECV,HP=1
    12109 TSM:UPL:OK
    12111 TSM:READY:ID=5,PAR=0,DIS=1
    12124 TSF:MSG:SEND,5-5-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
    13359 TSF:MSG:READ,0-0-5,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
    14454 TSF:MSG:SEND,5-5-0-0,s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=OK:2.2.0
    14477 TSF:MSG:SEND,5-5-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0
    16502 TSF:MSG:SEND,5-5-0-0,s=255,c=3,t=11,pt=0,l=10,sg=0,ft=0,st=OK:PZEM 004T
    16525 TSF:MSG:SEND,5-5-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=OK:1.0
    16547 TSF:MSG:SEND,5-5-0-0,s=1,c=0,t=30,pt=0,l=0,sg=0,ft=0,st=OK:
    16570 TSF:MSG:SEND,5-5-0-0,s=2,c=0,t=30,pt=0,l=0,sg=0,ft=0,st=OK:
    16592 TSF:MSG:SEND,5-5-0-0,s=3,c=0,t=13,pt=0,l=0,sg=0,ft=0,st=OK:
    16615 TSF:MSG:SEND,5-5-0-0,s=4,c=0,t=13,pt=0,l=0,sg=0,ft=0,st=OK:
    16623 MCO:REG:REQ
    16637 TSF:MSG:SEND,5-5-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
    17840 TSF:MSG:READ,0-0-5,s=255,c=3,t=27,pt=1,l=1,sg=0:1
    17846 MCO:PIM:NODE REG=1
    17850 MCO:SLP:MS=16063
    17852 TSF:TDI:TSL
    17854 MCO:SLP:WUP=-1
    17856 TSF:TRI:TSB
    221.20V; 0.11A; 3.00W; 96.00Wh;
    19482 TSF:MSG:SEND,5-5-0-0,s=1,c=1,t=38,pt=7,l=5,sg=0,ft=0,st=OK:221.2
    19505 TSF:MSG:SEND,5-5-0-0,s=2,c=1,t=39,pt=7,l=5,sg=0,ft=0,st=OK:0.1
    19527 TSF:MSG:SEND,5-5-0-0,s=3,c=1,t=17,pt=7,l=5,sg=0,ft=0,st=OK:3.0
    19546 TSF:MSG:SEND,5-5-0-0,s=4,c=1,t=18,pt=7,l=5,sg=0,ft=0,st=OK:96.0
    Sleep
    19554 MCO:SLP:MS=30000,SMS=0,I1=255,M1=255,I2=255,M2=255
    19560 TSF:TDI:TSL
    19562 MCO:SLP:WUP=-1
    19566 TSF:TRI:TSB
    220.70V; 0.11A; 3.00W; 96.00Wh;
    21516 TSF:MSG:SEND,5-5-0-0,s=1,c=1,t=38,pt=7,l=5,sg=0,ft=0,st=OK:220.7
    21538 TSF:MSG:SEND,5-5-0-0,s=2,c=1,t=39,pt=7,l=5,sg=0,ft=0,st=OK:0.1
    21559 TSF:MSG:SEND,5-5-0-0,s=3,c=1,t=17,pt=7,l=5,sg=0,ft=0,st=OK:3.0
    21583 TSF:MSG:SEND,5-5-0-0,s=4,c=1,t=18,pt=7,l=5,sg=0,ft=0,st=OK:96.0
    Sleep
    21592 MCO:SLP:MS=30000,SMS=0,I1=255,M1=255,I2=255,M2=255
    21598 TSF:TDI:TSL
    21602 MCO:SLP:WUP=-1
    21604 TSF:TRI:TSB
    221.00V; 0.11A; 3.00W; 96.00Wh;
    23562 TSF:MSG:SEND,5-5-0-0,s=1,c=1,t=38,pt=7,l=5,sg=0,ft=0,st=OK:221.0
    23584 TSF:MSG:SEND,5-5-0-0,s=2,c=1,t=39,pt=7,l=5,sg=0,ft=0,st=OK:0.1
    23609 TSF:MSG:SEND,5-5-0-0,s=3,c=1,t=17,pt=7,l=5,sg=0,ft=0,st=OK:3.0
    23631 TSF:MSG:SEND,5-5-0-0,s=4,c=1,t=18,pt=7,l=5,sg=0,ft=0,st=OK:96.0
    Sleep
    23638 MCO:SLP:MS=30000,SMS=0,I1=255,M1=255,I2=255,M2=255
    23646 TSF:TDI:TSL
    23648 MCO:SLP:WUP=-1
    23650 TSF:TRI:TSB
    220.60V; 0.11A; 3.00W; 96.00Wh;
    25618 TSF:MSG:SEND,5-5-0-0,s=1,c=1,t=38,pt=7,l=5,sg=0,ft=0,st=OK:220.6
    25634 TSF:MSG:SEND,5-5-0-0,s=2,c=1,t=39,pt=7,l=5,sg=0,ft=0,st=OK:0.1
    25657 TSF:MSG:SEND,5-5-0-0,s=3,c=1,t=17,pt=7,l=5,sg=0,ft=0,st=OK:3.0
    25679 TSF:MSG:SEND,5-5-0-0,s=4,c=1,t=18,pt=7,l=5,sg=0,ft=0,st=OK:96.0
    Sleep
    25688 MCO:SLP:MS=30000,SMS=0,I1=255,M1=255,I2=255,M2=255
    25694 TSF:TDI:TSL
    25696 MCO:SLP:WUP=-1
    25698 TSF:TRI:TSB
    220.20V; 0.11A; 3.00W; 96.00Wh;
    29003 !TSF:MSG:SEND,5-5-0-0,s=1,c=1,t=38,pt=7,l=5,sg=0,ft=0,st=NACK:220.2
    30363 !TSF:MSG:SEND,5-5-0-0,s=2,c=1,t=39,pt=7,l=5,sg=0,ft=1,st=NACK:0.1
    36687 !TSF:MSG:SEND,5-5-0-0,s=3,c=1,t=17,pt=7,l=5,sg=0,ft=2,st=NACK:3.0
    43980 !TSF:MSG:SEND,5-5-0-0,s=4,c=1,t=18,pt=7,l=5,sg=0,ft=3,st=NACK:96.0
    Sleep
    43988 MCO:SLP:MS=30000,SMS=0,I1=255,M1=255,I2=255,M2=255
    43995 TSF:TDI:TSL
    43997 MCO:SLP:WUP=-1
    43999 TSF:TRI:TSB
    219.60V; 0.11A; 4.00W; 96.00Wh;
    54110 !TSF:MSG:SEND,5-5-0-0,s=1,c=1,t=38,pt=7,l=5,sg=0,ft=4,st=NACK:219.6
    62173 !TSF:MSG:SEND,5-5-0-0,s=2,c=1,t=39,pt=7,l=5,sg=0,ft=5,st=NACK:0.1
    70236 !TSF:MSG:SEND,5-5-0-0,s=3,c=1,t=17,pt=7,l=5,sg=0,ft=6,st=NACK:4.0
    78301 !TSF:MSG:SEND,5-5-0-0,s=4,c=1,t=18,pt=7,l=5,sg=0,ft=7,st=NACK:96.0
    Sleep
    78309 MCO:SLP:MS=30000,SMS=0,I1=255,M1=255,I2=255,M2=255
    78315 TSF:TDI:TSL
    78317 MCO:SLP:WUP=-1
    78319 TSF:TRI:TSB
    78372 !TSM:READY:UPL FAIL,SNP
    78374 TSM:FPAR
    79478 TSF:MSG:SEND,5-5-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=8,st=OK:
    79484 !TSF:SAN:FAIL
    79489 TSM:FAIL:CNT=1
    79491 TSM:FAIL:DIS
    79493 TSF:TDI:TSL
    220.30V; 0.11A; 4.00W; 96.00Wh;
    81475 !TSF:SND:TNR
    81477 !TSF:SND:TNR
    81479 !TSF:SND:TNR
    81481 !TSF:SND:TNR
    Sleep
    81483 MCO:SLP:MS=30000,SMS=0,I1=255,M1=255,I2=255,M2=255
    81489 !MCO:SLP:TNR
    89497 TSM:FAIL:RE-INIT
    89499 TSM:INIT
    89602 !TSM:INIT:TSP FAIL
    89604 TSM:FAIL:CNT=2
    89606 TSM:FAIL:DIS
    89608 TSF:TDI:TSL
    91492 MCO:SLP:MS=19999
    91494 TSF:TDI:TSL
    91496 MCO:SLP:WUP=-1
    91498 TSF:TRI:TSB
    93249 !TSF:SND:TNR
    93251 !TSF:SND:TNR
    93253 !TSF:SND:TNR
    93255 !TSF:SND:TNR
    Sleep
    93257 MCO:SLP:MS=30000,SMS=0,I1=255,M1=255,I2=255,M2=255
    93263 !MCO:SLP:TNR
    99612 TSM:FAIL:RE-INIT
    99614 TSM:INIT
    99717 !TSM:INIT:TSP FAIL
    99719 TSM:FAIL:CNT=3
    99721 TSM:FAIL:DIS
    99723 TSF:TDI:TSL
    103266 MCO:SLP:MS=19999
    103268 TSF:TDI:TSL
    103270 MCO:SLP:WUP=-1
    103272 TSF:TRI:TSB
    219.30V; 0.11A; 4.00W; 96.00Wh;
    105019 !TSF:SND:TNR
    105021 !TSF:SND:TNR
    105023 !TSF:SND:TNR
    105027 !TSF:SND:TNR
    Sleep
    105029 MCO:SLP:MS=30000,SMS=0,I1=255,M1=255,I2=255,M2=255
    105035 !MCO:SLP:TNR
    109727 TSM:FAIL:RE-INIT
    109729 TSM:INIT
    109834 !TSM:INIT:TSP FAIL
    109836 TSM:FAIL:CNT=4
    109838 TSM:FAIL:DIS
    109840 TSF:TDI:TSL
    115038 MCO:SLP:MS=19999
    115040 TSF:TDI:TSL
    115042 MCO:SLP:WUP=-1
    115044 TSF:TRI:TSB
    219.90V; 0.11A; 4.00W; 96.00Wh;
    116787 !TSF:SND:TNR
    116789 !TSF:SND:TNR
    116793 !TSF:SND:TNR
    116795 !TSF:SND:TNR
    Sleep
    116797 MCO:SLP:MS=30000,SMS=0,I1=255,M1=255,I2=255,M2=255
    116803 !MCO:SLP:TNR
    119844 TSM:FAIL:RE-INIT
    119846 TSM:INIT
    119949 !TSM:INIT:TSP FAIL
    119951 TSM:FAIL:CNT=5
    119953 TSM:FAIL:DIS
    119955 TSF:TDI:TSL
    126806 MCO:SLP:MS=19999
    126808 TSF:TDI:TSL
    126810 MCO:SLP:WUP=-1
    126812 TSF:TRI:TSB
    220.10V; 0.11A; 4.00W; 96.00Wh;
    128550 !TSF:SND:TNR
    128555 !TSF:SND:TNR
    128557 !TSF:SND:TNR
    128559 !TSF:SND:TNR
    Sleep
    128561 MCO:SLP:MS=30000,SMS=0,I1=255,M1=255,I2=255,M2=255
    128567 !MCO:SLP:TNR
    129959 TSM:FAIL:RE-INIT
    129961 TSM:INIT
    130066 !TSM:INIT:TSP FAIL
    130068 TSM:FAIL:CNT=6
    130070 TSM:FAIL:DIS
    130072 TSF:TDI:TSL
    138569 MCO:SLP:MS=20000
    138571 TSF:TDI:TSL
    138573 MCO:SLP:WUP=-1
    138575 TSF:TRI:TSB
    219.70V; 0.11A; 4.00W; 96.00Wh;
    140316 !TSF:SND:TNR
    140318 !TSF:SND:TNR
    140320 !TSF:SND:TNR
    140322 !TSF:SND:TNR
    Sleep
    140324 MCO:SLP:MS=30000,SMS=0,I1=255,M1=255,I2=255,M2=255
    140333 !MCO:SLP:TNR
    140335 TSM:FAIL:RE-INIT
    140337 TSM:INIT
    140441 !TSM:INIT:TSP FAIL
    140443 TSM:FAIL:CNT=7
    140445 TSM:FAIL:DIS
    140447 TSF:TDI:TSL
    150335 MCO:SLP:MS=20000
    150337 TSF:TDI:TSL
    150339 MCO:SLP:WUP=-1
    150341 TSF:TRI:TSB
    220.20V; 0.11A; 4.00W; 96.00Wh;
    152078 !TSF:SND:TNR
    152082 !TSF:SND:TNR
    152084 !TSF:SND:TNR
    152086 !TSF:SND:TNR
    Sleep
    152088 MCO:SLP:MS=30000,SMS=0,I1=255,M1=255,I2=255,M2=255
    152094 !MCO:SLP:TNR
    162097 MCO:SLP:MS=19999
    162099 TSF:TDI:TSL
    162101 MCO:SLP:WUP=-1
    162103 TSF:TRI:TSB
    220.60V; 0.11A; 4.00W; 96.00Wh;
    163840 !TSF:SND:TNR
    163842 !TSF:SND:TNR
    163844 !TSF:SND:TNR
    163846 !TSF:SND:TNR
    Sleep
    163848 MCO:SLP:MS=30000,SMS=0,I1=255,M1=255,I2=255,M2=255
    163854 !MCO:SLP:TNR
    173858 MCO:SLP:MS=20000
    173860 TSF:TDI:TSL
    173862 MCO:SLP:WUP=-1
    173864 TSF:TRI:TSB
    175599 !TSF:SND:TNR
    175601 !TSF:SND:TNR
    175603 !TSF:SND:TNR
    175605 !TSF:SND:TNR
    Sleep
    175609 MCO:SLP:MS=30000,SMS=0,I1=255,M1=255,I2=255,M2=255
    175616 !MCO:SLP:TNR
    185618 MCO:SLP:MS=20000
    185620 TSF:TDI:TSL
    185622 MCO:SLP:WUP=-1
    185624 TSF:TRI:TSB
    219.10V; 0.11A; 3.00W; 96.00Wh;
    187357 !TSF:SND:TNR
    187359 !TSF:SND:TNR
    187363 !TSF:SND:TNR
    187365 !TSF:SND:TNR
    Sleep
    187367 MCO:SLP:MS=30000,SMS=0,I1=255,M1=255,I2=255,M2=255
    187373 !MCO:SLP:TNR
    197376 MCO:SLP:MS=19999
    197378 TSF:TDI:TSL
    Anybody has a solution ?
    Is it anything wrong in the sketch ?
    • N nucutza
      // Object Node
      //V_WATT    S_POWER
      //V_KWH     S_POWER
        delay(10);
        delay(10);
        delay(10);
        Serial.println();
        if (SLEEP_NODE) {
          sleep(SLEEP_TIME);
        } else {
          delay (SLEEP_TIME);
       __  __       ____
              |___/                      2.2.0
      26 TSM:INIT
      28 TSF:WUR:MS=1
      38 TSM:FAIL:CNT=1
      40 TSM:FAIL:DIS
      43 TSF:TDI:TSL
      43 MCO:BGN:STP
      Sleep
      3909 !MCO:SLP:TNR
      10047 TSM:INIT
      10057 TSM:FPAR
      12072 TSM:FPAR:OK
      12075 TSM:ID
      12075 TSM:ID:OK
      12077 TSM:UPL
      12111 TSM:UPL:OK
      14319 MCO:REG:REQ
      14358 TSF:TDI:TSL
      14362 TSF:TRI:TSB
      Sleep
      16533 TSF:TDI:TSL
      16537 TSF:TRI:TSB
      Sleep
      18374 TSF:TDI:TSL
      18378 TSF:TRI:TSB
      Sleep
      20443 TSF:TDI:TSL
      20447 TSF:TRI:TSB
      Sleep
      22505 TSF:TDI:TSL
      22509 TSF:TRI:TSB
      Sleep
      24582 TSF:TDI:TSL
      24586 TSF:TRI:TSB
      Sleep
      26669 TSF:TDI:TSL
      26675 TSF:TRI:TSB
      Sleep
      28751 TSF:TDI:TSL
      28758 TSF:TRI:TSB
      Sleep
      30822 TSF:TDI:TSL
      30826 TSF:TRI:TSB
       __  __       ____
              |___/                      2.2.0
      26 TSM:INIT
      28 TSF:WUR:MS=1
      38 TSM:FAIL:CNT=1
      40 TSM:FAIL:DIS
      43 TSF:TDI:TSL
      43 MCO:BGN:STP
      Sleep
      3911 !MCO:SLP:TNR
      10047 TSM:INIT
      10057 TSM:FPAR
      12072 TSM:FPAR:OK
      12075 TSM:ID
      12075 TSM:ID:OK
      12077 TSM:UPL
      12109 TSM:UPL:OK
      16623 MCO:REG:REQ
      17852 TSF:TDI:TSL
      17856 TSF:TRI:TSB
      Sleep
      19560 TSF:TDI:TSL
      19566 TSF:TRI:TSB
      Sleep
      21598 TSF:TDI:TSL
      21604 TSF:TRI:TSB
      Sleep
      23646 TSF:TDI:TSL
      23650 TSF:TRI:TSB
      Sleep
      25694 TSF:TDI:TSL
      25698 TSF:TRI:TSB
      Sleep
      43995 TSF:TDI:TSL
      43999 TSF:TRI:TSB
      Sleep
      78315 TSF:TDI:TSL
      78319 TSF:TRI:TSB
      78374 TSM:FPAR
      79484 !TSF:SAN:FAIL
      79491 TSM:FAIL:DIS
      79493 TSF:TDI:TSL
      81475 !TSF:SND:TNR
      81477 !TSF:SND:TNR
      81479 !TSF:SND:TNR
      81481 !TSF:SND:TNR
      Sleep
      81489 !MCO:SLP:TNR
      89499 TSM:INIT
      89606 TSM:FAIL:DIS
      89608 TSF:TDI:TSL
      91494 TSF:TDI:TSL
      91498 TSF:TRI:TSB
      93249 !TSF:SND:TNR
      93251 !TSF:SND:TNR
      93253 !TSF:SND:TNR
      93255 !TSF:SND:TNR
      Sleep
      93263 !MCO:SLP:TNR
      99614 TSM:INIT
      99721 TSM:FAIL:DIS
      99723 TSF:TDI:TSL
      103268 TSF:TDI:TSL
      103272 TSF:TRI:TSB
      105019 !TSF:SND:TNR
      105021 !TSF:SND:TNR
      105023 !TSF:SND:TNR
      105027 !TSF:SND:TNR
      Sleep
      105035 !MCO:SLP:TNR
      109729 TSM:INIT
      109838 TSM:FAIL:DIS
      109840 TSF:TDI:TSL
      115040 TSF:TDI:TSL
      115044 TSF:TRI:TSB
      116787 !TSF:SND:TNR
      116789 !TSF:SND:TNR
      116793 !TSF:SND:TNR
      116795 !TSF:SND:TNR
      Sleep
      116803 !MCO:SLP:TNR
      119846 TSM:INIT
      119953 TSM:FAIL:DIS
      119955 TSF:TDI:TSL
      126808 TSF:TDI:TSL
      126812 TSF:TRI:TSB
      128550 !TSF:SND:TNR
      128555 !TSF:SND:TNR
      128557 !TSF:SND:TNR
      128559 !TSF:SND:TNR
      Sleep
      128567 !MCO:SLP:TNR
      129961 TSM:INIT
      130070 TSM:FAIL:DIS
      130072 TSF:TDI:TSL
      138571 TSF:TDI:TSL
      138575 TSF:TRI:TSB
      140316 !TSF:SND:TNR
      140318 !TSF:SND:TNR
      140320 !TSF:SND:TNR
      140322 !TSF:SND:TNR
      Sleep
      140333 !MCO:SLP:TNR
      140337 TSM:INIT
      140445 TSM:FAIL:DIS
      140447 TSF:TDI:TSL
      150337 TSF:TDI:TSL
      150341 TSF:TRI:TSB
      152078 !TSF:SND:TNR
      152082 !TSF:SND:TNR
      152084 !TSF:SND:TNR
      152086 !TSF:SND:TNR
      Sleep
      152094 !MCO:SLP:TNR
      162099 TSF:TDI:TSL
      162103 TSF:TRI:TSB
      163840 !TSF:SND:TNR
      163842 !TSF:SND:TNR
      163844 !TSF:SND:TNR
      163846 !TSF:SND:TNR
      Sleep
      163854 !MCO:SLP:TNR
      173860 TSF:TDI:TSL
      173864 TSF:TRI:TSB
      175599 !TSF:SND:TNR
      175601 !TSF:SND:TNR
      175603 !TSF:SND:TNR
      175605 !TSF:SND:TNR
      Sleep
      175616 !MCO:SLP:TNR
      185620 TSF:TDI:TSL
      185624 TSF:TRI:TSB
      187357 !TSF:SND:TNR
      187359 !TSF:SND:TNR
      187363 !TSF:SND:TNR
      187365 !TSF:SND:TNR
      Sleep
      187373 !MCO:SLP:TNR
      197378 TSF:TDI:TSL
      @nucutza !TSM:INIT:TSP FAIL means that the microcontroller failed to communicate with the radio. Since it works sometimes and not other times, there is probably a bad connection somewhere, or the power supply could be inadequate.
      • N
        N
        nucutza
        wrote on last edited by nucutza
        You were right ! I changed the sensor radio and it's working now !
        But only if I have these lines in my sketch :
