  3. Everything nRF52840
Everything nRF52840
323 Posts 28 Posters 177.3k Views 33 Watching
  • alowhumA
    alowhumA
    alowhum
    #161
    You can now buy the USB-stick version for $22 on Aliexpress without shipping.
    http://www.aliexpress.com/item/NRF52840-Dongle/32946349826.html
    For $15 there is an expansion-less USB-stick:
    http://www.aliexpress.com/item/Nordic-nRF52840-BLE-dongle-bluetooth-4-0-bluetooth-5-0-for-computer/32951812498.html
    Little dev boards for $30:
    http://www.aliexpress.com/item/NRF52840-Development-board-Bluetooth-5-Bluetooth-low-power-consumption/32935228197.html
    And this interesting dev board for $33:
    http://www.aliexpress.com/item/Nrf52840-development-board/32921005555.html
    And a larger one with integrated ESP32 for $42:
    http://www.aliexpress.com/item/Nrf52840-development-board-ESP32-development-board-Mini/32921001572.html
    • Sergio RiusS
      Sergio RiusS
      Sergio Rius
      @NeverDie Thanks for your time and good work! :+1:
      I was thinking on start fiddling with the nrf52, but after the reading I don't know if I would handle it.
      • NeverDieN
        NeverDieN
        I tried platformio and indeed it seems very nice. It supports the nRF52840.
        NeverDieN 1 Reply Last reply
        • Sergio RiusS
          Sergio RiusS
          Sergio Rius
          Do you think this board could be used for a wifi gateway?
          https://es.aliexpress.com/store/product/Nrf52840-development-board-ESP32-development-board-Mini/2956052_32921001572.html
          • Sergio RiusS Sergio Rius
            NeverDieN
            NeverDieN
            #165
            @sergio-rius Assuming they're connected, I'd like to say yes, but I don't know how they're wired, so if that's all there is to go on... it's a cat in a bag.
            • NeverDieN NeverDie
              NeverDieN
              NeverDieN
              For those who haven't yet tried it, platformio has an "arduino" mode where it can program an nRF52840 very much along the lines that you would an arduino. Since it supports the nRF52840, I'd say it's a natural upgrade from the Sandeep Mistry library, which you don't really need to use anymore if you don't want to (though maybe it's still relevant for mySensor's compatability). At least to me, platformio seems much easier to use and much less of a learning curve than Segger Embedded Systems, Eclipse, or MBed. For anyone used to Arduino, it will seem very familiar.
              Sergio RiusS X 2 Replies Last reply
              • NeverDieN
                NeverDieN
                #167
                Has anyone been able to send a packet with a payload of greater than 85 bytes using an nRF52832/nRF52840? According to the datasheet, a 255 byte payload should be possible. Yet, even if I set MAXLEN to 255, the payload seems to be truncated at 85 bytes. So, I'm curious as to why I'm not able to get a larger payload transmitted, and thus I'm wondering whether anyone else here has succeeded at it.
                Anyone?
                • H
                  H
                  hugob
                  Sorry for cross-posting.
                  I started with nRF52 a few days ago. I have the Nordic nRF52 SDK board (PCA10056) with a nRF52840 operational as a MySensors serial gateway together with Home Assistant on a RaspberryPI (with Hass.io). I am using the Arduino nRF5 and the sandeepmistry nRF5 board libraries.
                  Some issues:
                  - It looks like it only works in debug mode. But in debug mode, both debug messages and gateway messages appear on the usb port. Homes Assistant is not confused by the debug messages.
                  - Leds are not working.
                  - The programmer on the Arduino IDE is not working for me ("No J-Link" error, while there is a J-Link interface available), so I export a HEX fle form Arduino IDE and program the board with the nRFConnect tool from Nordic.
                  In order to solve the issues above, I installed the Segger environment. With the board you get a free license from Nordic and you can do some fancy debugging. I also looked at Keil but that is a no-go for me. With Segger, I can upload a simple Blink example from Nordic to the board an debug it. I am now struggling with importing the MySensors library sources in Segger. If someone did this before, please let me know (!). Once this is done, I can debug the code on the hardware. May be I could fix the issues, like non blinking leds, by inspecting the code and watch for configuration issues of the ports (the addressing of the ports seems to be OK). But being able to debug would be a big plus in future development.
                  Off course, once the gateway is working with blinking leds, I want to replace the development board with something cheaper from E-Bay et al. I want to give this one a try:
                  https://www.aliexpress.com/item/Nordic-nRF52840-module-Bluetooth-low-energy-long-range-500-meters-bluetooth-5-0-PCB-IPX-Antenna/32953759053.html
                  The plus of this board is that you can use an external 2.4 Ghz antenna. And it has the newest 52840. If you are creating a gateway, I suppose your budget will not depend on $3 price difference.
                  Once all that is done, I want to turn my Nordic Thingy (https://www.nordicsemi.com/eng/Products/Nordic-Thingy-52) into a MySensors device. Seems like doable. But someone has to do it.
                    Guys, let's move on from this tempest in a teapot. The way I see it: at this point in history what we individually want or don't want won't make any difference to the ultimate outcome in the big picture, because there are now much larger forces at work. Our best bet is to help each other identify the best trend to ride. If that's mysensors, then great, but if not, let's try to figure out just exactly what else might reasonably win so that we can avoid dead-ends and hopefully ride the trends with the wind at our backs. :)
                    To my mind, the following have traction (in no particular order)
                    1. LoRa (because it's simple and it just plain works)
                    2. Bluetooth 5 Long Range (because smart phones, eventually, will make it so) with an integrated ARM MCU. That said, bluetooth per se has always seemed cumbersome to me, and I never really liked it. I'd probably be happier using a barebones version of it.
                    3. MQTT
                    Maybe Thread will happen or maybe it won't. I'm not sure what will catalyze it, so I'd have to see meaningful uptake before I bet on Thread.
                    wassfilaW
                    wassfilaW
                    wassfila
                    wrote on last edited by wassfila
                    #169
                    @neverdie Bluetooth and zigbee have different scopes and different business models. Zigbee is targeting automation networks such as devices that are permanently available and collecting in a server, while Bluetooth is only user centric in its pairing mechanism (it's funning those bluetooth devices that collect a certain amount of data locally for download with the user's phone, they are not scalable for big systems). Zigbee is evolving towards more structured networks capabilities and I predict that the Thread is sooner or later going to replace Zigbee without users loosing functional products as the alliance is already preparing a common zigbee and Thread top layer (dot dot) that would provide a smooth transition. Thread will provide a standardised routing between the sensors local network and the internet, and that is very competitive compared to any Bluetooth or zigbee solution where every one has to reinvent the wheel for a different way of mapping the local network to global, vendor specific or custom gateways would finally tend to disappear. Even if you do not want your sensor to be shared with the world, the smooth transition from low power wireless network to ethernet (and the raspr) is something I would apreciate. Now add to that the MQTT-SN that is designed for low power wireless networks, and you get an out of the box MQTT layer for your low power wireless sensor. I do not know, but if I would bet, I'd bet on that to gain interest in the future.
                    And by the way, I do not think that these fancy standards compete with MySesnors, because the SW that is simple and you know is 100 times more practicle to work with, port and adapt to corner cases than a huge stack such as BT or zigbee.
                    • wassfilaW wassfila
                      NeverDieN
                      NeverDieN
                      #170
                      @wassfila Who knows?The nRF52 chips are multi-protocol, which I suppose is one way to hedge your bets. Thread is one of them.
                      • NeverDieN
                        NeverDieN
                        #171
                        As of today, uLisp now works on the nRF52840. I posted a repository and build instructions on github: https://github.com/rabbithat/uLisp_nRF52840 I have moved from uPython to uLisp to facilitate over-the-air code upates.
                        • NeverDieN
                          NeverDieN
                          #172
                          An interesting benchmark I just did on the nRF52840: I'm able to transmit (and receive) the entire Declaration of Indepdence (roughly 8KB of text) in under 35 milliseconds. So, with that as a reference, I expect OTA code updates can be fairly low power. :)
                            Sergio RiusS
                            Sergio RiusS
                            Sergio Rius
                            wrote on last edited by Sergio Rius
                            #173
                            @neverdie On platformio, what do you use for programming? A black magic probe?
                            And about the 255 payload, have you looked for a wrong sized variable or type? If you want me to give it a go on visual studio+resharper just send me a sample. I still don't have a programmer and still haven't received my nrfs so I would only look for programming errors.
                              NeverDieN
                              NeverDieN
                              @sergio-rius
                              I use the nrf52840-DK as the programmer.
                              Regarding the 255 payload, I'm able to get it if I send static length payloads, so that's what I'm doing now. However, variable length acts very strangely in that the maximum length before truncation seems to vary depending upon what the actual payload content is. It's 100% repeatable for the same payload content, but changing the content generally leads to a different maximum length. So, I'm not sure what's up with that. It definitely shouldn't be that way.
                              Sergio RiusS 1 Reply Last reply
                                @sergio-rius
                                Sergio RiusS
                                Sergio RiusS
                                Sergio Rius
                                #175
                                @neverdie Does it have compression or checksum of the payload? I'm not used to that library, but it seems some processing is done. First try with plain repeating characters or numbers to discard encoding issues.
                                • alowhumA
                                  alowhumA
                                  alowhum
                                  @neverdie https://www.youtube.com/watch?v=m1miwCJtxeM
                                  • alowhumA alowhum
                                    NeverDieN
                                    NeverDieN
                                    #177
                                    @alowhum Thanks. Not sure if you saw this: https://forum.mysensors.org/topic/9889/anyone-here-tried-mercrisp-forth-for-programming-arm-cortex-m-i-e-blue-pill-nrf5-stm32-etc
                                    Looks as though there will be a mecrisp-stellaris FORTH release for the nRF52840 within about a week, or maybe sooner. Because of its built-in optimizing compiler to native machine code, I'll probably settle on mecrisp-stellaris.
                                    • alowhumA
                                      alowhumA
                                      alowhum
                                      Yes I saw it. Very hardcore.
                                      • NeverDieN
                                        NeverDieN
                                        You can now run mecrisp-stellaris FORTH on the nRF52840-DK: https://github.com/rabbithat/FORTH_NRF52840-DK
                                        • rozpruwaczR
                                          rozpruwaczR
                                          rozpruwacz
                                          @NeverDie did You compared somehow the range of the nrf52840 dongle with other nrf52840/nrf52832/nrf51822 modules ? I'm asking because after first test it appears that the nrf52840 dongle has worse range than core51822 module using the same radio settings.
