  3. Everything nRF52840
Everything nRF52840
323 Posts 28 Posters 164.8k Views 33 Watching
    #171
    As of today, uLisp now works on the nRF52840. I posted a repository and build instructions on github: https://github.com/rabbithat/uLisp_nRF52840 I have moved from uPython to uLisp to facilitate over-the-air code upates.
      #172
      An interesting benchmark I just did on the nRF52840: I'm able to transmit (and receive) the entire Declaration of Indepdence (roughly 8KB of text) in under 35 milliseconds. So, with that as a reference, I expect OTA code updates can be fairly low power. :)
        For those who haven't yet tried it, platformio has an "arduino" mode where it can program an nRF52840 very much along the lines that you would an arduino. Since it supports the nRF52840, I'd say it's a natural upgrade from the Sandeep Mistry library, which you don't really need to use anymore if you don't want to (though maybe it's still relevant for mySensor's compatability). At least to me, platformio seems much easier to use and much less of a learning curve than Segger Embedded Systems, Eclipse, or MBed. For anyone used to Arduino, it will seem very familiar.
        Sergio RiusS
        Sergio RiusS
        Sergio Rius
        #173
        @neverdie On platformio, what do you use for programming? A black magic probe?
        And about the 255 payload, have you looked for a wrong sized variable or type? If you want me to give it a go on visual studio+resharper just send me a sample. I still don't have a programmer and still haven't received my nrfs so I would only look for programming errors.
        • Sergio RiusS Sergio Rius
          @sergio-rius
          I use the nrf52840-DK as the programmer.
          Regarding the 255 payload, I'm able to get it if I send static length payloads, so that's what I'm doing now. However, variable length acts very strangely in that the maximum length before truncation seems to vary depending upon what the actual payload content is. It's 100% repeatable for the same payload content, but changing the content generally leads to a different maximum length. So, I'm not sure what's up with that. It definitely shouldn't be that way.
            @sergio-rius
            Sergio RiusS
            Sergio RiusS
            Sergio Rius
            #175
            @neverdie Does it have compression or checksum of the payload? I'm not used to that library, but it seems some processing is done. First try with plain repeating characters or numbers to discard encoding issues.
            • alowhumA
              alowhumA
              alowhum
              @neverdie https://www.youtube.com/watch?v=m1miwCJtxeM
              • alowhumA alowhum
                #177
                @alowhum Thanks. Not sure if you saw this: https://forum.mysensors.org/topic/9889/anyone-here-tried-mercrisp-forth-for-programming-arm-cortex-m-i-e-blue-pill-nrf5-stm32-etc
                Looks as though there will be a mecrisp-stellaris FORTH release for the nRF52840 within about a week, or maybe sooner. Because of its built-in optimizing compiler to native machine code, I'll probably settle on mecrisp-stellaris.
                • alowhumA
                  alowhumA
                  alowhum
                  Yes I saw it. Very hardcore.
                    You can now run mecrisp-stellaris FORTH on the nRF52840-DK: https://github.com/rabbithat/FORTH_NRF52840-DK
                    • rozpruwaczR
                      rozpruwaczR
                      rozpruwacz
                      @NeverDie did You compared somehow the range of the nrf52840 dongle with other nrf52840/nrf52832/nrf51822 modules ? I'm asking because after first test it appears that the nrf52840 dongle has worse range than core51822 module using the same radio settings.
                      • rozpruwaczR rozpruwacz
                        @rozpruwacz No, I hadn't noticed that. Do note though that you can increase the tx power on the nRF52840 dongle to 8db, whereas 4db is the max for the nRF51822.
                          rozpruwaczR
                          rozpruwaczR
                          rozpruwacz
                          @neverdie said in Everything nRF52840:
                          Yes, but with the same settings I would expect at least the same range. I will keep testing.
                            @rozpruwacz The nRF52840 chip itself should be better because of its greater receive sensitivity.You didn't say exactly what you're comparing it against (aside from it being an nRF51822), but the dongle has a smallish antenna and a small ground plane. Usually those don't have as good a range. It's one of the trade-offs that comes with smaller size. It may also be more directional that what you're expecting, so try rotating it and see if that makes a difference.
                              rozpruwaczR
                              rozpruwaczR
                              rozpruwacz
                              @neverdie i'm comparing it with core51822 module which also has pcb antenna
                                I just now posted a much easier mecrisp-starellis FORTH for the nRF52840-DK: https://github.com/rabbithat/nRF52840-DK_easy/blob/master/README.md
                                On this one, all you need do is upload the hex file located in that repository and you're done. :-)
                                H 1 Reply Last reply
                                  H
                                  H
                                  heinzv
                                  @neverdie interesting research and ideas. Have you tried to get BLE 5.0 running (the S140 SD) or using the nrf52840 radio features (best with long range) so that we can consider a sensor node/actor and does the sleep properly work? There are some basic features which have to work before switching the development/runtime env.
                                  • H heinzv
                                    @heinzv
                                    I haven't been working on that per se, but I do have a REPL over radio working: https://github.com/rabbithat/nRF52_wireless_Forth_REPL
                                    which can also be used for doing OTA code updates.
                                      @heinzv
                                      H
                                      H
                                      heinzv
                                      @NeverDie You doing a great research! I have quickly checked your REPL code and the radio lib.
                                      So you have implemented a OSI Layer 3+4 (Transport Layer with IP/TCP Stack).
                                      I'm wondering if/how this can be used to complay to BLE 5.0 (long range), ZigBee and Threads which the new Nordic SDK (Zigbee and Threads 2.0) offers? Are they also using the Softdevice S140 (6.1) libs or ...?
                                      There is a ZigBee OTA update example provided by Nordic (but I have not yet enogh time to test it).
                                      Currently, I'm still using MySensors and the NRF5_ESP (Nordic private) protocol which works. IT would be also interesting to use a more industry standard protocol like ZigBee or THREADS which seem to be also supported by OpenHAB.
                                      I'll certainly do further investigations in this direction. I have tried to test it with Segger Embedded studio and also with IAR Studio for ARM (the second requires some newer 32Bit version libs from Nordic and an internat request for that was raised already). Segger works fine with the J-Link adapters.
                                      • H heinzv
                                        @heinzv said in Everything nRF52840:
                                        If you specifically want those protocols, then at present the Nordic SDK is the only existing library I know of that will get you them.
                                          It appears that Fanstel is now selling the amplified nRF52840 modules:
                                          https://www.fanstel.com/bt840f-nrf52840-ble-5-module-secure-iot-802154-thread-zigbee-1
