  3. can't get DHT22 sensor to work with home assistant via mqtt gateway
4 Posts 2 Posters 1.3k Views 2 Watching
  • B
    B
    bereska
    pi@bereskapi-ha:~/MySensors $ sudo ./bin/mysgw
    Nov 04 06:26:41 INFO  Starting gateway...
    Nov 04 06:26:41 INFO  Protocol version - 2.3.1-beta
    Nov 04 06:26:41 DEBUG MCO:BGN:INIT GW,CP=RNNGL---,VER=2.3.1-beta
    Nov 04 06:26:41 DEBUG TSF:LRT:OK
    Nov 04 06:26:41 DEBUG TSM:INIT
    Nov 04 06:26:41 DEBUG TSF:WUR:MS=0
    Nov 04 06:26:41 DEBUG TSM:INIT:TSP OK
    Nov 04 06:26:41 DEBUG TSM:INIT:GW MODE
    Nov 04 06:26:41 DEBUG TSM:READY:ID=0,PAR=0,DIS=0
    Nov 04 06:26:41 DEBUG MCO:REG:NOT NEEDED
    Nov 04 06:26:41 DEBUG MCO:BGN:STP
    Nov 04 06:26:41 DEBUG MCO:BGN:INIT OK,TSP=1
    Nov 04 06:26:41 DEBUG GWT:RMQ:MQTT RECONNECT
    Nov 04 06:26:41 DEBUG connected to 127.0.0.1
    Nov 04 06:26:41 DEBUG GWT:RMQ:MQTT CONNECTED
    Nov 04 06:26:41 DEBUG GWT:TPS:TOPIC=mygateway1-out/0/255/0/0/18,MSG SENT
    Nov 04 06:26:41 DEBUG TSM:READY:NWD REQ
    Nov 04 06:26:41 DEBUG TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=20,pt=0,l=0,sg=0,ft=0,st=OK:
    Nov 04 06:27:16 DEBUG TSF:MSG:READ,1-1-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
    Nov 04 06:27:16 DEBUG TSF:MSG:BC
    Nov 04 06:27:16 DEBUG TSF:MSG:FPAR REQ,ID=1
    Nov 04 06:27:16 DEBUG TSF:PNG:SEND,TO=0
    Nov 04 06:27:16 DEBUG TSF:CKU:OK
    Nov 04 06:27:16 DEBUG TSF:MSG:GWL OK
    Nov 04 06:27:16 DEBUG !TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=NACK:0
    Nov 04 06:27:18 DEBUG TSF:MSG:READ,1-1-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
    Nov 04 06:27:18 DEBUG TSF:MSG:BC
    Nov 04 06:27:18 DEBUG TSF:MSG:FPAR REQ,ID=1
    Nov 04 06:27:18 DEBUG TSF:CKU:OK,FCTRL
    Nov 04 06:27:18 DEBUG TSF:MSG:GWL OK
    Nov 04 06:27:18 DEBUG !TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=NACK:0
    Nov 04 06:27:20 DEBUG TSF:MSG:READ,1-1-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
    Nov 04 06:27:20 DEBUG TSF:MSG:BC
    Nov 04 06:27:20 DEBUG TSF:MSG:FPAR REQ,ID=1
    Nov 04 06:27:20 DEBUG TSF:CKU:OK,FCTRL
    Nov 04 06:27:20 DEBUG TSF:MSG:GWL OK
    Nov 04 06:27:20 DEBUG !TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=NACK:0
    Nov 04 06:27:22 DEBUG TSF:MSG:READ,1-1-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
    Nov 04 06:27:22 DEBUG TSF:MSG:BC
    Nov 04 06:27:22 DEBUG TSF:MSG:FPAR REQ,ID=1
    Nov 04 06:27:22 DEBUG TSF:CKU:OK,FCTRL
    Nov 04 06:27:22 DEBUG TSF:MSG:GWL OK
    Nov 04 06:27:22 DEBUG !TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=NACK:0
    my DHT22 sketch:
    #include <DHT.h>
    #define MY_NODE_ID 22
    #define CHILD_ID_TEMP 0
    #define CHILD_ID_HUM 1
    #define DHT_DATA_PIN 3
    #define SENSOR_TEMP_OFFSET 0
    /****************** CONSTANTS *********************/
    static const uint64_t UPDATE_INTERVAL = 10000;
    /****************** VARIABLES *********************/
    float lastTemp;
    float lastHum;
    float temperature;
    float humidity;
    uint8_t nNoUpdatesTemp;
    uint8_t nNoUpdatesHum;
    /****************** MESSAGES **********************/
    DHT dht;
      sendSketchInfo("DHT22", "1.0");
      present(CHILD_ID_HUM, S_HUM);
      delay(2000); //Wait 2 seconds before starting sequence
      if (UPDATE_INTERVAL <= dht.getMinimumSamplingPeriod())
      dht.setup(DHT_DATA_PIN);
      sendTemperatureHumiditySensor();
      wait(UPDATE_INTERVAL);
    /**************** AUX. FUNCTIONS ******************/
    void sendTemperatureHumiditySensor()
      dht.readSensor(true);
      temperature = dht.getTemperature();
      humidity = dht.getHumidity();
      if (isnan(temperature))
      } else if (temperature != lastTemp || nNoUpdatesTemp == FORCE_UPDATE_N_READS)
        lastTemp = temperature;
        nNoUpdatesTemp = 0;
    #ifdef MY_DEBUG
        Serial.print("T: ");
        Serial.println(temperature);
      } else
        nNoUpdatesTemp++;
      if (isnan(humidity))
      } else if (humidity != lastHum || nNoUpdatesHum == FORCE_UPDATE_N_READS)
        lastHum = humidity;
        nNoUpdatesHum = 0;
    #ifdef MY_DEBUG
        Serial.print("H: ");
        Serial.println(humidity);
      } else
        nNoUpdatesHum++;
    • B bereska
      my DHT22 sketch:
      #include <DHT.h>
      float lastTemp;
      float lastHum;
      float temperature;
      float humidity;
      DHT dht;
          nNoUpdatesTemp = 0;
      #ifdef MY_DEBUG
        } else
          nNoUpdatesTemp++;
          lastHum = humidity;
          nNoUpdatesHum = 0;
      #ifdef MY_DEBUG
        } else
          nNoUpdatesHum++;
      Hi @bereska, welcome to the MySensors community :-)
      For next time, could you put the code in a code box? Instructions are available here. I took the liberty to fix it for you this time. Please also use the Auto format (ctrl/cmd+T) feature in the Arduino IDE, which makes it much easier to read the code.
      https://forum.mysensors.org/topic/666/debug-faq-and-how-ask-for-help/ has information on the most common problems, and how to troubleshoot them.
      The log parser can help understand the log messages.
      The log you posted shows that the gateway is receiving messages from node 1, but there is nothing from node 22. The deubg log from node22 will probably give information on why it is having trouble.
      • B
        B
        bereska
        Hi @mfalkvidd
        thank you for your prompt reply
        I promise i will follow the rules
        i'm very new to this, please bear with me)
        I've spent all this time studying logs and trying different nrf24 radios (standard & LNA), but no dice(
        please help
        here is the last log from the Arduino serial read:
        14:57:02.641 ->  __  __       ____
        14:57:02.641 -> |  \/  |_   _/ ___|  ___ _ __  ___  ___  _ __ ___
        14:57:02.641 -> | |\/| | | | \___ \ / _ \ `_ \/ __|/ _ \| `__/ __|
        14:57:02.641 -> | |  | | |_| |___| |  __/ | | \__ \  _  | |  \__ \
        14:57:02.674 -> |_|  |_|\__, |____/ \___|_| |_|___/\___/|_|  |___/
        14:57:02.674 ->         |___/                      2.3.0
        14:57:02.674 ->
        14:57:02.674 -> 16 MCO:BGN:INIT NODE,CP=RNNNA---,VER=2.3.0
        14:57:02.674 -> 25 TSM:INIT
        14:57:02.674 -> 26 TSF:WUR:MS=0
        14:57:02.674 -> 33 TSM:INIT:TSP OK
        14:57:02.674 -> 35 TSM:INIT:STATID=22
        14:57:02.674 -> 37 TSF:SID:OK,ID=22
        14:57:02.674 -> 39 TSM:FPAR
        75 TSF:MSG:SEND,22-22-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
        2082 !TSM:FPAR:NO REPLY
        14:57:04.710 -> 2084 TSM:FPAR
        2120 TSF:MSG:SEND,22-22-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
        4128 !TSM:FPAR:NO REPLY
        14:57:06.751 -> 4130 TSM:FPAR
        4166 TSF:MSG:SEND,22-22-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
        6174 !TSM:FPAR:NO REPLY
        14:57:08.807 -> 6176 TSM:FPAR
        6212 TSF:MSG:SEND,22-22-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
        8220 !TSM:FPAR:FAIL
        14:57:10.863 -> 8221 TSM:FAIL:CNT=1
        14:57:10.863 -> 8223 TSM:FAIL:DIS
        14:57:10.863 -> 8225 TSF:TDI:TSL
        18227 TSM:FAIL:RE-INIT
        14:57:20.837 -> 18229 TSM:INIT
        14:57:20.837 -> 18236 TSM:INIT:TSP OK
        14:57:20.837 -> 18238 TSM:INIT:STATID=22
        14:57:20.871 -> 18240 TSF:SID:OK,ID=22
        14:57:20.871 -> 18242 TSM:FPAR```
        • B
          B
          bereska
          hi again
          I got it working
          Insex00|⸮⸮E⸮V⸮U⸮
          23:24:18.693 ->  __  __       ____
          23:24:18.693 -> |  \/  |_   _/ ___|  ___ _ __  ___  ___  _ __ ___
          23:24:18.693 -> | |\/| | | | \___ \ / _ \ `_ \/ __|/ _ \| `__/ __|
          23:24:18.693 -> | |  | | |_| |___| |  __/ | | \__ \  _  | |  \__ \
          23:24:18.728 -> |_|  |_|\__, |____/ \___|_| |_|___/\___/|_|  |___/
          23:24:18.728 ->         |___/                      2.3.0
          23:24:18.728 ->
          23:24:18.728 -> 16 MCO:BGN:INIT NODE,CP=RNNNA---,VER=2.3.0
          23:24:18.728 -> 25 TSM:INIT
          23:24:18.728 -> 26 TSF:WUR:MS=0
          23:24:18.728 -> 33 TSM:INIT:TSP OK
          23:24:18.728 -> 35 TSM:INIT:STATID=22
          23:24:18.728 -> 37 TSF:SID:OK,ID=22
          23:24:18.728 -> 39 TSM:FPAR
          880 TSF:MSG:READ,0-0-22,s=255,c=3,t=8,pt=1,l=1,sg=0:0
          23:24:19.581 -> 885 TSF:MSG:FPAR OK,ID=0,D=1
          2082 TSM:FPAR:OK
          23:24:20.765 -> 2083 TSM:ID
          23:24:20.765 -> 2084 TSM:ID:OK
          23:24:20.800 -> 2086 TSM:UPL
          23:24:20.800 -> 2089 TSF:MSG:SEND,22-22-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
          23:24:20.800 -> 2096 TSF:MSG:READ,0-0-22,s=255,c=3,t=25,pt=1,l=1,sg=0:1
          23:24:20.800 -> 2101 TSF:MSG:PONG RECV,HP=1
          23:24:20.800 -> 2104 TSM:UPL:OK
          23:24:20.800 -> 2105 TSM:READY:ID=22,PAR=0,DIS=1
          23:24:20.800 -> 2110 TSF:MSG:SEND,22-22-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
          23:24:20.800 -> 2116 TSF:MSG:READ,0-0-22,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
          23:24:20.833 -> 2126 TSF:MSG:SEND,22-22-0-0,s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=OK:2.3.0
          23:24:20.833 -> 2135 TSF:MSG:SEND,22-22-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0
          4142 TSF:MSG:SEND,22-22-0-0,s=255,c=3,t=11,pt=0,l=5,sg=0,ft=0,st=OK:DHT22
          23:24:22.854 -> 4151 TSF:MSG:SEND,22-22-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=OK:1.0
          23:24:22.854 -> 4159 TSF:MSG:SEND,22-22-0-0,s=1,c=0,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
          23:24:22.854 -> 4166 TSF:MSG:SEND,22-22-0-0,s=0,c=0,t=6,pt=0,l=0,sg=0,ft=0,st=OK:
          23:24:22.854 -> 4172 MCO:REG:REQ
          23:24:22.854 -> 4176 TSF:MSG:SEND,22-22-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
          23:24:22.890 -> 4183 TSF:MSG:READ,0-0-22,s=255,c=3,t=27,pt=1,l=1,sg=0:1
          23:24:22.890 -> 4188 MCO:PIM:NODE REG=1
          23:24:22.890 -> 4190 MCO:BGN:STP
          6192 MCO:SLP:MS=2000,SMS=0,I1=255,M1=255,I2=255,M2=255
          23:24:24.891 -> 6197 TSF:TDI:TSL
          6199 MCO:SLP:WUP=-1
          23:24:27.107 -> 6200 TSF:TRI:TSB
          6207 MCO:BGN:INIT OK,TSP=1
          23:24:27.142 -> Failed reading temperature from DHT!
          23:24:27.142 -> Failed reading humidity from DHT
          16218 TSF:MSG:SEND,22-22-0-0,s=0,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:24.9
          23:24:37.137 -> T: 24.90
          23:24:37.137 -> 16227 TSF:MSG:SEND,22-22-0-0,s=1,c=1,t=1,pt=7,l=5,sg=0,ft=0,st=OK:51.7
          23:24:37.137 -> H: 51.70
          26242 TSF:MSG:SEND,22-22-0-0,s=0,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:24.8
          23:24:47.138 -> T: 24.80
          23:24:47.138 -> 26251 TSF:MSG:SEND,22-22-0-0,s=1,c=1,t=1,pt=7,l=5,sg=0,ft=0,st=OK:51.9
          23:24:47.138 -> H: 51.90
          rt Code Here
          but the sensor fails to show up in home assistant dashboard(
          afrter restarting homeassistant I found this in homeassistant log:
          018-11-06 05:40:14 INFO (MainThread) [mysensors] Stopping gateway
          Config directory: /config
          starting version 3.2.5
          2018-11-06 05:40:34 INFO (MainThread) [homeassistant.loader] Loaded websocket_api from homeassistant.components.websocket_api
          2018-11-06 05:40:34 INFO (MainThread) [homeassistant.bootstrap] Home Assistant core initialized
          2018-11-06 05:40:34 INFO (MainThread) [homeassistant.loader] Loaded history from homeassistant.components.history
          2018-11-06 05:40:34 INFO (MainThread) [homeassistant.loader] Loaded recorder from homeassistant.components.recorder
          2018-11-06 05:40:34 INFO (MainThread) [homeassistant.loader] Loaded http from homeassistant.components.http
          2018-11-06 05:40:34 INFO (MainThread) [homeassistant.loader] Loaded mqtt from homeassistant.components.mqtt
          2018-11-06 05:40:34 INFO (MainThread) [homeassistant.setup] Setting up mqtt
          2018-11-06 05:40:34 INFO (MainThread) [homeassistant.setup] Setup of domain mqtt took 0.0 seconds.
          2018-11-06 05:40:34 INFO (MainThread) [homeassistant.loader] Loaded logger from homeassistant.components.logger
          2018-11-06 05:40:34 INFO (MainThread) [homeassistant.setup] Setting up logger
          2018-11-06 05:40:34 ERROR (MainThread) [homeassistant.components.mqtt] Failed to connect due to exception: [Errno 111] Connection refused
          2018-11-06 05:40:40 WARNING (MainThread) [homeassistant.components.mysensors] debug option for mysensors is deprecated. Please remove debug from your configuration file
          2018-11-06 05:40:40 DEBUG (SyncWorker_0) [mysensors.persistence] Loading sensors from persistence file /config/mysensors1.pickle
          2018-11-06 05:40:41 DEBUG (SyncWorker_1) [mysensors.persistence] Saving sensors to persistence file /config/mysensors1.pickle
          2018-11-06 05:40:42 INFO (MainThread) [mysensors.gateway_mqtt] Setting up initial MQTT topic subscription
          2018-11-06 05:40:42 DEBUG (MainThread) [mysensors.gateway_mqtt] Subscribing to: mygateway1-out/+/+/0/+/+, qos: 0
          2018-11-06 05:40:42 DEBUG (MainThread) [mysensors.gateway_mqtt] Subscribing to: mygateway1-out/+/+/3/+/+, qos: 0
          2018-11-06 05:40:42 DEBUG (MainThread) [mysensors.gateway_mqtt] Subscribing to: mygateway1-out/0/+/4/+/+, qos: 0
          2018-11-06 05:40:42 DEBUG (MainThread) [homeassistant.components.mqtt] Subscribing to mygateway1-out/+/+/0/+/+
          2018-11-06 05:40:42 DEBUG (MainThread) [homeassistant.components.mqtt] Subscribing to mygateway1-out/+/+/3/+/+
          2018-11-06 05:40:42 DEBUG (MainThread) [homeassistant.components.mqtt] Subscribing to mygateway1-out/0/+/4/+/+
          2018-11-06 05:40:43 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
          Traceback (most recent call last):
            File "/usr/local/lib/python3.6/site-packages/homeassistant/components/mqtt/__init__.py", line 279, in async_subscribe
              topic, msg_callback, qos, encoding)
            File "/usr/local/lib/python3.6/site-packages/homeassistant/components/mqtt/__init__.py", line 659, in async_subscribe
              await self._async_perform_subscription(topic, qos)
            File "/usr/local/lib/python3.6/site-packages/homeassistant/components/mqtt/__init__.py", line 694, in _async_perform_subscription
              _raise_on_error(result)
            File "/usr/local/lib/python3.6/site-packages/homeassistant/components/mqtt/__init__.py", line 779, in _raise_on_error
              'Error talking to MQTT: {}'.format(mqtt.error_string(result_code)))
          homeassistant.exceptions.HomeAssistantError: Error talking to MQTT: The client is not currently connected.
          2018-11-06 05:40:50 ERROR (MainThread) [homeassistant.core] Timer got out of sync. Resetting
          2018-11-06 05:40:54 WARNING (SyncWorker_9) [netdisco.ssdp] Error fetching description at http://192.168.1.68:49152/wps_device.xml
          any help is much appreciated
          thank you
