  3. Another nrf24l01+ fake or..?
4 Posts 2 Posters 1.3k Views 2 Watching
  • alexsh1A Offline
    alexsh1A Offline
    alexsh1
    Hi
    I have noticed higher than usual battery consumption on a few nodes. Further investigation discovered that several nrf24l01+, which were tested for mA/uA consumption and were fit in the beginning, were consuming 700uA and 1.8mA while sleeping (all sensors were disconnected and void loop () contained only sleep (60000); function).
    These nrf24l01+ were working fine for many months. RX/TX is working ok and the range is fine. Just sleeping consumption is way too high. I tried these modules with different nodes and similar current consumption.
    Anyone had such problem please?
    Is it curable or shall I just bin nrf24l01+?
    I feel like I’m going to ditch all nrf24l01+ in favour of its SMD version or rfm69.
    Alex
    Y 1 Reply Last reply
    • alexsh1A alexsh1
      Hi
      Alex
      Y Offline
      Y Offline
      @alexsh1 said in Another nrf24l01+ fake or..?:
      Why? Sleep current will mainly be influence by the nrf chip and the crystal. Why do you assume smd versions use genuine nrf chips?
      Smd resonators (the small rectangular ones with 4 connections) have slightly lower power consumption than the crystals used on most modules (hc-49 package).
      alexsh1A 1 Reply Last reply
      • Y Yveaux
        alexsh1A Offline
        alexsh1A Offline
        alexsh1
        @yveaux SMD version has got a better assembly and better range in my view and generally speaking personally I never had issues with the SMD chips, but had various issues with a normal nrf24l01+.
        My concern is that the high consumption nrf24l01+ modules were perfectly working for a long time. What a setback....
        Do you know if this is repairable? Changing resonator, chip or both?
        Probably not worth spending time
        • alexsh1A alexsh1
          Y Offline
          Y Offline
          When power usage increases over time it would be interesting to know what is causing it...
