  3. Nrf52 gateway crashes
30 Posts 5 Posters 5.9k Views 4 Watching
  • A Offline
    A Offline
    Anticimex
    Please remember that the simple security flags use software implementation for signing (encryption as well unless the radio has native support), so they claim more resources. This is noticible on resource limited devices such as the atmega328p.
    Nowadays, running both software encryption and softare signing on atmega328p at the same time is almost doomed to fail due to the heap and stack colliding.
    alowhumA 1 Reply Last reply
    • A Anticimex
      alowhumA Offline
      alowhumA Offline
      alowhum
      @anticimex I've become quite good at saving memory precisely because I anticipated that I wanted to enable full security. Are you saying that's a fools errand?
      I was hoping that future versions of the security functionality might save some memory too?
      • alowhumA alowhum
        A Offline
        A Offline
        Anticimex
        @alowhum security v3 will most likely not be less resource intensive. The aim there is to make it more secure and less complicated to use.
        However, I am currently in a stage in life where I simply do not have the time to actively work on that so someone else have to look into it, details for the plans are on github, or it has to wait for now.
        There is still the option to use hw accelerated signing so atmega328p users at least in theory can still use it. And if you do manage to squeeze out enough ram to avoid the arduino environment to warn about it you should be fine.
        If the environment do give warnings on memory usage, it might still work, but that is less guaranteed and light very well lead to crashes.
        • alowhumA Offline
          alowhumA Offline
          alowhum
          @anticimex said in Nrf52 gateway crashes:
          Interesting, I didn't know there was hardware acceleration in the Arduino for encryption type things.
          I've built all my nodes to leave about 20% memory for security, as you said. I believe 20% should be quite doable for most uses, as some of my most outrageous nodes still have enough available. I've come to love progmem, use byte instead of int, etc. For me the Arduino Nano is still the most beginner friendly device out there, bar perhaps the Micro:bit (NRf51), and I believe there's still some life left in her.
          Talking about which: glad to hear usability is a focus for the next version, and I'm sorry to hear you won't have much time to work on it. I totally get it though. Life always has priority :-)
          • alowhumA alowhum
            A Offline
            A Offline
            Anticimex
            @alowhum I never said there was hw acceleration in atmega328p for encryption. There is hw acceleration for signing with atsha204a. And some radios have hw acceleration for encryption such as rfm69.
            I don't recall that I have stated 20% ram for security either. I do not have a % for security at all. But I do recommend you follow the build environments warnings on memory usage where it states stability problems might occur.
            • A Anticimex
              alowhumA Offline
              alowhumA Offline
              alowhum
              @anticimex The Arduino IDE always gives a warning at 80%? Or is that actually variable?
              I was wondering why I had never heard of hardware acceleration on the nano ;-)
              • alowhumA alowhum
                A Offline
                A Offline
                Anticimex
                #27
                @alowhum the arduino IDE is not very clever and I believe the 20% left when it starts to warn is the % of ram available for the stack. So depending on your sketch, and the libraries you use, the functions you call and the order they are called has an impact in how much stack is claimed and if the stack needs more than what is left of the ram, bad and strange things start to happen.
                The 20% is just a PUMA (PUlled out of My Ass) number the arduino folks came up with for what the think is a reasonable stack usage for an average user. And so, if they see that you use more ram after linking your sketch, they think you should be warned that you might get into trouble.
                • A Anticimex
                  alowhumA Offline
                  alowhumA Offline
                  alowhum
                  Ah, I assumed this referred to the Arduino IDE's warning message. Which environment do you mean?
                  • alowhumA alowhum
                    A Offline
                    A Offline
                    Anticimex
                    @alowhum the environment known as the arduino IDE ;)
                    • O Offline
                      O Offline
                      Omemanti
                      wrote on last edited by Omemanti
                      #30
                      After a year of nearly having no problems, I got nodes that started crashing.
                      I let my repeater up for the night and monitored his behavour.
                      I got this again:
                      08:47:27.607 -> 22440 NRF5:SND:TO=0,LEN=16,PID=0,NOACK=0
                      08:47:27.641 -> 22447 NRF5:SND:END=1,ACK=1,RTRY=2,RSSI=-45,WAKE=8
                      08:47:27.641 -> 22452 TSF:MSG:SEND,78-78-0-0,s=1,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:24.3
                      08:47:27.707 -> 22508 NRF5:SND:TO=0,LEN=16,PID=1,NOACK=0
                      08:47:27.707 -> 22515 NRF5:SND:END=1,ACK=1,RTRY=2,RSSI=-45,WAKE=7
                      08:47:27.707 -> 22520 TSF:MSG:SEND,78-78-0-0,s=0,c=1,t=1,pt=7,l=5,sg=0,ft=0,st=OK:45.2
                      08:47:28.435 -> 23226 NRF5:SND:TO=0,LEN=16,PID=2,NOACK=0
                      08:47:28.435 -> 23233 NRF5:SND:END=1,ACK=1,RTRY=2,RSSI=-45,WAKE=7
                      08:47:28.435 -> 23237 TSF:MSG:SEND,78-78-0-0,s=2,c=1,t=16,pt=1,l=1,sg=0,ft=0,st=OK:1
                      08:47:28.766 -> Si7021 Found
                      08:47:29.331 -> 24145 NRF5:SND:TO=0,LEN=16,PID=3,NOACK=0
                      08:47:29.331 -> 24152 NRF5:SND:END=1,ACK=1,RTRY=2,RSSI=-45,WAKE=7
                      08:47:29.331 -> 24157 TSF:MSG:SEND,78-78-0-0,s=1,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:24.3
                      08:47:29.397 -> 24213 NRF5:SND:TO=0,LEN=16,PID=0,NOACK=0
                      08:47:29.397 -> 24220 NRF5:SND:END=1,ACK=1,RTRY=2,RSSI=-45,WAKE=7
                      08:47:29.397 -> 24225 TSF:MSG:SEND,78-78-0-0,s=0,c=1,t=1,pt=7,l=5,sg=0,ft=0,st=OK:45.2
                      08:47:32.310 -> 27131 NRF5:SND:TO=0,LEN=16,PID=1,NOACK=0
                      anyone got an Idea what this message means,
                      it crashes after the last line.
