  3. Range improved with delay
3 Posts 2 Posters 863 Views 2 Watching
  • SnyfirS
    SnyfirS
    Snyfir
    I use an arduino pro mini 3V 8mhz and a nrf24l01+ to send temperature with a DALAS sensor.
    I notice that when i add a delay(1) or a wait(1) before sending the value the range is much better.
    Am i the only one who needed to do this ? if y use sleep(1) it doesn't work.
    • SnyfirS Snyfir
      @snyfir could it be that you're affected by the same problem discussed in https://forum.mysensors.org/topic/9655/delay-after-tsf-tri-tsb/14 ?
      If so, there is a fix in the development version of MySensors.
      SnyfirS 1 Reply Last reply
        SnyfirS
        SnyfirS
        Snyfir
        @mfalkvidd
        I don't know i will try when the next release will get out
