  3. ds18b20 on 2xAAA battery
34 Posts 10 Posters 7.4k Views 8 Watching
  • B
    B
    buxtronix
    Confirming also, I have about a dozen nodes around the place, all running off 2xAA batteries and all of the DS18B20 devices have no problems with this supply voltage, even when they are down to 2.8V they're still reporting reliably.
    • pihomeP
      pihomeP
      pihome
      i must admit you are lucky or your sensors dont care about voltage but at this stage after reading your comments i have tried 3 different sensors and all the same result
      may be something is in my sketch ?
      //  _____    _   _    _
      // |  __ \  (_) | |  | |
      // | |__) |  _  | |__| |   ___    _ __ ___     ___
      // |  ___/  | | |  __  |  / _ \  | |_  \_ \   / _ \
      // | |      | | | |  | | | (_) | | | | | | | |  __/
      // |_|      |_| |_|  |_|  \___/  |_| |_| |_|  \___|
      //    S M A R T   H E A T I N G   C O N T R O L
      // *       Battery Powered OneWire DS18B20 Temperature Sensor      *
      // *           Version 0.31 Build Date 06/11/2017                  *
      // *            Last Modification Date 09/05/2019                  *
      // *                                          Have Fun - PiHome.eu *
      #define MY_RADIO_RF24
      //#define MY_RADIO_NRF5_ESB
      //#define MY_RADIO_RFM95
      // #define MY_RF24_PA_LEVEL RF24_PA_LOW
      // RF24_PA_MIN RF24_PA_LOW RF24_PA_HIGH RF24_PA_MAX RF24_PA_ERROR
      #define MY_RF24_PA_LEVEL RF24_PA_MIN
      // RF channel for the sensor net, 0-127 Default is 76
      #define MY_RF24_CHANNEL	76
      //PiHome - Make Sure you change Node ID, for each temperature sensor. 21 for Ground Floor, 20 for First Floor, 30 for Domastic Hot Water.
      #define MY_NODE_ID 33
      // Set baud rate to same as optibot
      //#define MY_BAUD_RATE 9600
      //set how long to wait for transport ready in milliseconds
      //#define MY_TRANSPORT_WAIT_READY_MS 3000
      //#include <SPI.h>
      #include <OneWire.h>
      #define ledpin 4 // LED for one Blink Power On, Solid LED for No sensors, 5 Blinks for no Radio (this settings is in MySensors.cpp) and three blinks for low battery
      // Define sensor node childs
      #define CHILD_ID_BATT 1
      #define CHILD_ID_TEMP 0
      #define COMPARE_BVOLT 1 // Send battery voltage only if changed? 1 = Yes 0 = No
      #define MAX_ATTACHED_DS18B20 2
      unsigned long SLEEP_TIME = 56000; // Sleep time between reads (in milliseconds)
      // Battery related init
      float oldBatteryV = 0;
      MyMessage msgBatt(CHILD_ID_BATT, V_VOLTAGE);
      // Dallas Temperature related init
      int numSensors=0;
      bool receivedConfig = false;
      bool metric = true;
      MyMessage msg(CHILD_ID_TEMP, V_TEMP);
      void before(){
        sensors.begin();
      void setup(){
      	//This is LED pin set to output and turn it on for short while
      	pinMode(ledpin, OUTPUT);
      	digitalWrite(ledpin, HIGH);
      	delay(60);
      	digitalWrite(ledpin, LOW);
        // needed for battery soc
            analogReference(INTERNAL1V1);
            analogReference(INTERNAL);
          // disable ADC
        //ADCSRA = 0;
        //power_usart0_disable();// Serial (USART)
        //power_adc_disable(); // ADC converter
        //power_twi_enable(); // TWI (I2C)
      	sendSketchInfo("Temperature Sensor", "0.31");
      	//Blink LED as number of sensors attached
      	blink_led(numSensors, ledpin);
      	//check if attached sensors number is grater then 0 if no then put led on solid
      	#if numSensors > 0
           present(i, S_TEMP);
      void loop(){
      	// get the battery Voltage
      	//ref http://www.ohmslawcalculator.com/voltage-divider-calculator
      	// 1M, 100K divider across battery and using internal ADC ref of 1.1V
      	// ((1e6+100e3)/100e3)*1.1 = Vmax = 12.1 Volts
      	// 12.1/1023 = Volts per bit = 0.011828
      	//R1 820k, R2 220k
      	//((820e3+220e3)/220e3)*1.1 = Vmax = 5.2 Volts
      	//5.2/1023 = Volts per bit = 0.005083089
      	int battSensorValue = analogRead(BATTERY_SENSE_PIN);
      	//float batteryV  = battSensorValue * 0.005083089; //R1 820k, R2 220k divider across battery and using internal ADC ref of 1.1v
      	float batteryV  = battSensorValue * 0.011828;    //R1 1M, R2 100K divider across battery and using internal ADC ref of 1.1v
      	//int batteryPcnt = ( ( batteryV - 2.9 ) / ( ( 4.2 - 2.9 ) / 100 ) ); // for 18650 Battery Powred
      	int batteryPcnt = ( ( batteryV - 2.1 ) / ( ( 3.0 - 2.1 ) / 100 ) ); // for AAA Battery Powered
      	#ifdef MY_DEBUG
      		Serial.print("Pin Reading: ");
      		Serial.println(battSensorValue);
      		Serial.print(batteryV);
      		Serial.println(" v");
      		//Print Battery Percentage
      		Serial.print(batteryPcnt);
      		Serial.println(" %");
      	#if COMPARE_BVOLT == 1
      		if (oldBatteryV != batteryV) {
      			send(msgBatt.set(batteryV, 2));
      			oldBatteryV = batteryV;
      	//sleep() call can be replaced by wait() call if node need to process incoming messages (or if node is repeater)
      	sleep(conversionTime);
      		#if COMPARE_TEMP == 1
      		//Condition to check battery levell is lower then minimum then blink led 3 times
      		//if (batteryV < 2.9) { //for 18650 Battery Powered Sensor
      		if (batteryV < 2.0) { //for AAA Battery Powered Sensor
      			blink_led(3, ledpin);
      			//Serial.print("Low Voltage");
      	//go to sleep for while
      	//smartSleep(SLEEP_TIME);
      	sleep(SLEEP_TIME);
      //Blink LED function, pass ping number and number of blinks usage: blink_led(variable or number of time blink, ledpin);
      void blink_led(int count, int pin){
      	for(int i=0;i<count;i++){
      		digitalWrite(pin, HIGH);
      		delay(700);
      		digitalWrite(pin, LOW);
      		delay(700);
      PiHome - Smart Heating Control
      • pihomeP pihome
        //  _____    _   _    _
        //#include <SPI.h>
        int numSensors=0;
        bool metric = true;
        void before(){
          sensors.begin();
        void setup(){
        	delay(60);
            // disable ADC
          //ADCSRA = 0;
        	#if numSensors > 0
             present(i, S_TEMP);
        void loop(){
        	//R1 820k, R2 220k
        	#ifdef MY_DEBUG
        	sleep(SLEEP_TIME);
        		delay(700);
        		delay(700);
        zboblamontZ
        zboblamontZ
        zboblamont
        #21
        @pihome Not sure why you are looking for a sketch problem if the issues don't arise >=3v?
        That some folks have ds18b20 working below the specified minimum of 3v is pure luck, but even were you to source devices which could work down to say 2.8v, it still does not address their certain disfunction below it, particularly down to the 1.9v drop off voltage of your radio, which was your objective?
        Your options are limited to swapping to a sensor (?) which works down to 1.9v, switch on/off a separate supply for the ds18b20, or run a full-time booster for the entire assembly to suck all life from your batteries. It is this latter scenario here, but designed and built by folks clever than I.
        Very tempted after this to look at switching on/off the ds18b20 array's power and see how long it lasts on batteries aloe, perhaps a rainy day or winter project.
        • pihomeP
          pihomeP
          pihome
          @zboblamont,
          yes you are right it is pure luck, i just wanted to check i m not doing anything stupid and said pair of eyes are always good. i have ordered the parts and i m going to work on two version: one with boost convert for sensor and second 3xAAA with voltage regulator and probably 3rd version (may be in future when i get some free time) with boost converter with shutdown, may be some one already have done this and my search string isnt very good to dig that out.
          • pihomeP
            pihomeP
            pihome
            further update:
            while playing with 1mhz bootloader and feeding arduino to raw pin from 18650 battery, sensors is successfully sending battery voltage and battery percentage but no temperature sensor reading. to prove that something isnt right with 1mhz bootloader i burned 8mhz default bootloader i get battery voltage, battery percentage and temperature reading. can not think of something obvious :(
            Link to 1mhz bootloader
            • pihomeP pihome
              further update:
              zboblamontZ
              zboblamontZ
              zboblamont
              @pihome No expert, but recall these one-wire devices have a digital communications protocol. As such they rely on accurate timing, hence your clock speed disrupts it?
              • zboblamontZ zboblamont
                #25
                @zboblamont might be on the right track. See https://github.com/arduino/Arduino/issues/7181 for a discussion on timing problems, especially at 1MHz
                • pihomeP
                  pihomeP
                  pihome
                  Life is never easy and definitely not straight, there is always something wrong :( perhaps back to educating myself...
                  • bjacobseB
                    bjacobseB
                    bjacobse
                    It appears that you during runtime can change prescale, so you should be able to change clock frequency to 8MHz when reading DS18B20 and after reading change clock back to 1MHz
                    https://forum.arduino.cc/index.php?topic=223771.0
                    • pihomeP
                      pihomeP
                      pihome
                      @bjacobse
                      reason behind 1mhz mcu is to run it on lower voltage but switching between speed still need higher voltage. if i m not wrong!!!
                      mfalkviddM bjacobseB 2 Replies Last reply
                      • pihomeP pihome
                        @bjacobse
                        @pihome yes that’s correct
                        • pihomeP pihome
                          @bjacobse
                          bjacobseB
                          bjacobseB
                          bjacobse
                          #30
                          @pihome yes nothing is free;-)
                          • bjacobseB
                            bjacobseB
                            bjacobse
                            #31
                            Well then another approach is not to use DS18B20 :-)
                            Have you checked TMP117 price seems to be 2USD in higher qty, and supply range: 1.8 V to 5.5 V
                            http://www.ti.com/product/TMP117
                            https://www.digikey.com/products/en/sensors-transducers/temperature-sensors-analog-and-digital-output/518?FV=ffe00206&quantity=0&ColumnSort=1000011&page=1&k=TMP117&pageSize=25
                            And someone have made a lib to Arduino: https://github.com/NilsMinor/TMP117-Arduino
                            • A
                              avelo
                              Hi, I'm on a somehow "comparable" (but very different scenario) project in terms of using same DS18B20 and arduino 3.3V, a mkr SAMD21 in my case, and trying to get the longer autonomy I can.
                              The best option I've seen so far seems to be to use the (best option) TPS61291 or (alternate option) TPS61221, as the first seems to be designed for this use cases, and the second has enable option to switch it off. All those seemed to me (newbie here) better than the TPS you indicate.
                              For my use case, the "low tech" option indicated by @mfalkvidd could fit very nicely, so I'll dig into that option.
                              • pihomeP
                                pihomeP
                                pihome
                                @avelo
                                thank you for suggestion, i have made prototype based on MIC5219-3.3
                                but sure TPS61291 / TPS61221 are good options. once i get pcb delivered i'll you know here.
                                • tbowmoT
                                  tbowmoT
                                  tbowmo
                                  #34
                                  just for reference, 4 out of 5 sensebender micros is still running strong, after 4 years on the same set of AA batteries, that they where deployed with.
                                  The 5th sensebender is my outdoor sensor, that one eats a set of batteries within 48 hours.. But i suspect that it's the air humidity that has destroyed it.
                                  I opted to use a Si7021 instead (there might be others that are better suited now), as it was better suited for low power operation, and runs down to 1.2V supply (if I remember right).
