  3. 💬 MySensors Low-power Multi-function node on CR2032
nodenrf24l01+si7021atsha204amysensorsat25df512c
15 Posts 5 Posters 5.1k Views 3 Watching
  • pihomeP
    pihomeP
    pihome
    @Fanfan
    what is battery life like running uC at 1Mhz?
    PiHome - Smart Heating Control
    FanfanF 1 Reply Last reply
    • pihomeP pihome
      @Fanfan
      FanfanF
      FanfanF
      Fanfan
      @pihome I don't know yet, I'm still waiting for the PCB. I should receive them this week. From the mysensors site, 1Mhz vs 8Mhz does not make a huge difference. I'll try them both. What I can say is that 1Mhz as other constraints (I had to compile my own bootloader, then it is difficult to have reliable serial communication faster than 9600bauds, including for uploading sketches, meaning an update in the boards.txt file). Anyway, for sure, I'll build the board and make tests very soon. In the worst scenario, I may switch to CR123 batteries or LS14250.
      pihomeP 1 Reply Last reply
      • FanfanF Fanfan
        pihomeP
        pihomeP
        pihome
        @fanfan
        I been using temperature sensors with 8Mhz without any custom bootloader or any other modifications on 18650 battery for over 2 years, sensor read temperature once every minute and go to sleep, haven’t done any battery consumption calculations, i m switching from 18650 battery to AAA or AA batteries hence need for power saving
        • FanfanF
          FanfanF
          Fanfan
          @pihome I finally built it. There will still be some adjustments (routing for cutting castelized holes, diode protections removal, ...), but it works. Be careful, it is designed to have 2V-3.6V for power AND signals (double check your ICSP and FTDI programmers). The battery duration depends on your sketch (sleep time, transmission power, encryption ...), your battery (mAh), your sensors (I only have BME280 connected) and your gateway distance. I can tell you that it uses 13mA during transmissions at PA_MAX.
          • FanfanF
            FanfanF
            Fanfan
            @pihome A simple wakeup cycle lasts 1.2s at 20mA. In theory, I should have 10 hours of wakeup time.0_1560173350621_SDS00014.png
            • pihomeP
              pihomeP
              pihome
              @Fanfan 20mA during transmission is higher then mine but then i have cheap chines version of multimeter may be its not very accurate as yours. are you using any low clock bootloader?
              Power consumption with onboard regulator and onboard LEDs removed without any further modification:
              18.11 mA startup
              66.9 uA during sleeping
              3.01 mA during Transmission
              Pro mini with 1mhz bootloader and on board regulator/LEDs removed:
              14.42 mA startup
              7.50 uA during sleeping
              1.40 mA during Transmission
              • FanfanF
                FanfanF
                Fanfan
                @pihome I did compile my own dualoptiboot for 1Mhz support. My board does not use any LDO (I am supposed to only plug 3V power supply, not more). The LED is not a "power LED" but a LED connected to A2 to be used (or not) by the sketch. I might have more current consumption because I use PA_MAX as transmission power. or because my sketch does not put BME280 in sleep mode (yet). I still need to rework on the schema and PCB to tune/optimize it (no need for the zener, the schottky and the FTDI connector), but the proof of concept for my very first real design works.
                rvendrameR 1 Reply Last reply
                • FanfanF Fanfan
                  rvendrameR
                  rvendrameR
                  rvendrame
                  wrote on last edited by rvendrame
                  @fanfan , not sure if that may help you, but in my case I discovered that even in sleep mode the BME280 still drawing current (up to 1mA). The only solution I found was to bring down the SCL and SDA pins before entering in the sleep mode.
                  Something like this:
                  digitalWrite( A4 , LOW );
                  digitalWrite( A5 , LOW );
                  sleep( 60000 );
                  wait(200);
                  weather_sensor.begin();
                  wait(200);
                  Not sure if this is best way but it worked for me...
                  ESP8266 GW + mySensors 2.3.2
                  Alexa / Google Home
                  • pihomeP
                    pihomeP
                    pihome
                    it would be interesting to see what sleep function does, may be need to read library code to understand this in more detailed.
                    • rvendrameR rvendrame
                      sleep( 60000 );
                      wait(200);
                      wait(200);
                      FanfanF
                      FanfanF
                      Fanfan
                      @rvendrame Thanks a lot, I'm currently working on another project (electronic load). But I keep your idea in mind and will investigate when I'll continue this sensors project.
                      • FanfanF
                        FanfanF
                        Fanfan
                        @rvendrame sorry, I did not see your comment. Yes, it is VERY valuable. Thanks a lot
