  3. [Solved] Device and gateway see each other, but not regestering
15 Posts 4 Posters 2.3k Views 2 Watching
  • magpernM Offline
    magpernM Offline
    magpern
    wrote on last edited by tekka
    I have no idea where to look. I have a device (The device) and a Sensebender Gateway.
    They are on the same network (76) and on the same bitrate (1MBPS).
    I have altered the device sketch to just have the bare minimum. The gateway works with other devices.
    When the device starts, I see movement in the Gateway trace files and the leds blink. So some kind of connection is present.
    This is the trace file from the device
    0 MCO:BGN:INIT NODE,CP=RNNNA---,FQ=8,REL=6,VER=2.3.2-beta
    4 MCO:BGN:BFR
    6 TSM:INIT
    8 TSF:WUR:MS=0
    14 TSM:INIT:TSP OK
    16 TSM:FPAR
    18 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    2027 !TSM:FPAR:NO REPLY
    2029 TSM:FPAR
    2031 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    4040 !TSM:FPAR:NO REPLY
    4042 TSM:FPAR
    4044 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    6053 !TSM:FPAR:NO REPLY
    6055 TSM:FPAR
    6057 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    8067 !TSM:FPAR:FAIL
    8069 TSM:FAIL:CNT=1
    8071 TSM:FAIL:DIS
    8073 TSF:TDI:TSL
    This is from the Gateway
    0;255;3;0;9;479819 TSF:MSG:READ,255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
    0;255;3;0;9;479819 TSF:MSG:BC
    0;255;3;0;9;479820 TSF:MSG:FPAR REQ,ID=255
    0;255;3;0;9;479820 TSF:PNG:SEND,TO=0
    0;255;3;0;9;479820 TSF:CKU:OK
    0;255;3;0;9;479820 TSF:MSG:GWL OK
    0;255;3;0;9;480439 TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
    0;255;3;0;9;481794 TSF:MSG:READ,255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
    0;255;3;0;9;481795 TSF:MSG:BC
    0;255;3;0;9;481795 TSF:MSG:FPAR REQ,ID=255
    0;255;3;0;9;481795 TSF:CKU:OK,FCTRL
    0;255;3;0;9;481796 TSF:MSG:GWL OK
    0;255;3;0;9;482341 TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
    0;255;3;0;9;483770 TSF:MSG:READ,255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
    0;255;3;0;9;483770 TSF:MSG:BC
    0;255;3;0;9;483771 TSF:MSG:FPAR REQ,ID=255
    0;255;3;0;9;483771 TSF:CKU:OK,FCTRL
    0;255;3;0;9;483771 TSF:MSG:GWL OK
    0;255;3;0;9;484243 TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
    0;255;3;0;9;485745 TSF:MSG:READ,255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
    0;255;3;0;9;485745 TSF:MSG:BC
    0;255;3;0;9;485746 TSF:MSG:FPAR REQ,ID=255
    0;255;3;0;9;485746 TSF:CKU:OK,FCTRL
    0;255;3;0;9;485746 TSF:MSG:GWL OK
    0;255;3;0;9;486145 TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
    What next?
    • magpernM magpern
      4 MCO:BGN:BFR
      6 TSM:INIT
      8 TSF:WUR:MS=0
      14 TSM:INIT:TSP OK
      16 TSM:FPAR
      2029 TSM:FPAR
      4042 TSM:FPAR
      6055 TSM:FPAR
      8067 !TSM:FPAR:FAIL
      8069 TSM:FAIL:CNT=1
      8071 TSM:FAIL:DIS
      8073 TSF:TDI:TSL
      What next?
      @magpern strange. The node sends FPAR request a node acknowledges the message. The GW responds and (a) node acknowledges. But the node then says it didn't see the response.
      Could you post your sketch?
      Do you have any repeater(s)? If so, getting the debug log from the repeater will help a lot.
      Running the cleareeprom sketch on the node might help, in case there is something in the eeprom that confuses the node.
      magpernM 3 Replies Last reply
        magpernM Offline
        magpernM Offline
        magpern
        wrote on last edited by magpern
        @mfalkvidd
        Sketch is almost as the original, but I think it I have adopted it to the development branch (not sure). Original code had mGetAck, now it is message.isEcho in the Recieve method
        I have no repeters, the gateway is at the moment connected to the computer and so is the device. There are currently no other active devices in the network. Just a gateway and the InWall device. All other devices are physically turned off.
        I have run the clear eeprom sketch on the device. Before it had node id 10, but after clear eeprom the id was removed.
         * Version 1.0 - Henrik Ekblad
         * Version 2.0 - dpressle
         * Version 3.0 - Stormy
         * Sketch for a "light switch" where you can control light or something
         * else from both HA controller and a local physical button
        #define DEBUG
        #define SKETCH_NAME "LightSwitch InWallCan"
        #define SKETCH_VERSION "1.1"
        //#define MY_NODE_ID 10
        //#define MY_PARENT_NODE_ID 0
        //#define MY_TRANSPORT_WAIT_READY_MS 3000  // start without gateway after 3 seconds
        #define DWELL_TIME 40                    // this allows for radio to come back to power after a transmission, ideally 0.
        #define MY_RADIO_RF24                    // enable and select radio type attached
        #define MY_SPLASH_SCREEN_DISABLED        // disable splash screen - This saves 120 bytes of flash.
        //#define MY_DISABLED_SERIAL               // enable this in sketch if you want to use TX(1), RX(0) as normal I/O pin
        //#define MY_RF24_PA_LEVEL RF24_PA_MAX
        #define MY_RF24_DATARATE RF24_1MBPS
        //#define MY_SIGNAL_REPORT_ENABLED
        #define MY_SIGNING_ATSHA204_PIN A4
        #define BUTTON_PIN1 A5 // Arduino Digital I/O pin number for button
        #define BUTTON_PIN2 2  // Arduino Digital I/O pin number for button
        #define RELAY_PIN1  4  // Arduino Digital I/O pin number for relay
        #define RELAY_PIN2  3  // Arduino Digital I/O pin number for relay
        #define CHILD_ID1 0   // Id of the sensor child
        #define CHILD_ID2 1   // Id of the sensor child
        #define RELAY_ON 1
        #define RELAY_OFF 0
        Bounce debouncer1 = Bounce();
        Bounce debouncer2 = Bounce();
        int oldValue1 = 0;
        int oldValue2 = 0;
        int stateRel1;
        int stateRel2;
        bool initialStateSent = false;
        MyMessage msg1(CHILD_ID1, V_STATUS);
        MyMessage msg2(CHILD_ID2, V_STATUS);
        void changeState(int childId, int newState) {
          switch(childId){
            case CHILD_ID1:
              digitalWrite(RELAY_PIN1, newState);
              send(msg1.set(newState), true);
              wait(DWELL_TIME);
              stateRel1 = newState;
            case CHILD_ID2:
              digitalWrite(RELAY_PIN2, newState);
              send(msg2.set(newState), true);
              wait(DWELL_TIME);
              stateRel2 = newState;
            default:
        void before() {
          // Setup the button
          pinMode(BUTTON_PIN1, INPUT_PULLUP);
          pinMode(BUTTON_PIN2, INPUT_PULLUP);
          // Activate internal pull-up
          digitalWrite(BUTTON_PIN1, HIGH);
          digitalWrite(BUTTON_PIN2, HIGH);
          debouncer1.attach(BUTTON_PIN1);
          debouncer1.interval(5);
          debouncer2.attach(BUTTON_PIN2);
          debouncer2.interval(5);
          digitalWrite(RELAY_PIN1, RELAY_OFF);
          digitalWrite(RELAY_PIN2, RELAY_OFF);
          pinMode(RELAY_PIN1, OUTPUT);
          pinMode(RELAY_PIN2, OUTPUT);
        void setup()  {
        void presentation()  {
          sendSketchInfo(SKETCH_NAME, SKETCH_VERSION, true);
          wait(DWELL_TIME);
          present(CHILD_ID1, S_BINARY);
          wait(DWELL_TIME);
          present(CHILD_ID2, S_BINARY);
          wait(DWELL_TIME);
          if (!initialStateSent) {
            send(msg1.set(RELAY_OFF), true);
            wait(DWELL_TIME);
            send(msg2.set(RELAY_OFF), true);
            wait(DWELL_TIME);
            initialStateSent = true;
          debouncer1.update();
          int value = debouncer1.read();
          if (value != oldValue1 && value==0) {
        	  changeState(CHILD_ID1, stateRel1 ? RELAY_OFF : RELAY_ON);
        #ifdef DEBUG
             Serial.println("Relay #1 state change from button #1");
          oldValue1 = value;
          debouncer2.update();
          value = debouncer2.read();
          if (value != oldValue2 && value==0) {
        	  changeState(CHILD_ID2, stateRel2 ? RELAY_OFF : RELAY_ON);
        #ifdef DEBUG
             Serial.println("Relay #2 state change from button #2");
          oldValue2 = value;
          //sendHeartbeat();
          if (message.isAck()) {
        #ifdef DEBUG
          if (message.type == V_STATUS && !message.isEcho()) {
        #ifdef DEBUG
            changeState(message.sensor, message.getBool() ? RELAY_ON : RELAY_OFF);
          magpernM Offline
          magpernM Offline
          magpern
          @mfalkvidd Any idea?
          I have now tested like this:
          All sketches are original MySensors sketches only added #define MY_RF24_DATARATE RF24_1MBPS and they run the development branch
          Sensebender Gateway (the original) with NRF24L01 Long Range (the one with the antenna) and the SensebenderSerialGateway sketch
          Arduino Nano with a NRF24L01 and the SerialGateway sketch
          Ikea Molgan Hack hardware with default MotionSenser sketch (only added #define MY_RF24_DATARATE RF24_1MBPS)
          MySensors InCan double light switch hardware with default RelayActuator sketch (and the 1MBPS)
          One gateway was active at a time. I have cleared eeprom on the devices. They all give the same result. device sends, gateway responds, device say no gateway (or something like that. See previous log. They all look the same).
          I have also the EFEKTA Temp&Hum sensor(ver. nRF52832 )+E-Ink display and gateway, both of them respond to this and I see the device presenting itself and I see the text in the gateway log file (it also shows up in Domoticz)
          I have googled !TSM:FPAR:FAIL and get multiple hits on the problem, but many refer to very old versions of MySensors. Some say downgrade the Arduino IDE or the tool chain.
          Is there a preferred tool chain for building MySensors?
          Why is it working with NRF52832 and nor NRF24L01? (the NRF52832 are #define MY_PASSIVE_NODE if that makes a differance)
          This is the output of the build of one of the devices (the MotionSensor)
          C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\eu1391\AppData\Local\Arduino15\packages -hardware D:\development\Arduino\hardware -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\eu1391\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries D:\development\Arduino\libraries -fqbn=arduino:avr:pro:cpu=8MHzatmega328 -vid-pid=0403_6001 -ide-version=10809 -build-path C:\Users\eu1391\AppData\Local\Temp\arduino_build_934684 -warnings=none -build-cache C:\Users\eu1391\AppData\Local\Temp\arduino_cache_700673 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avrdude.path=C:\Users\eu1391\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino14 -prefs=runtime.tools.avrdude-6.3.0-arduino14.path=C:\Users\eu1391\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino14 -prefs=runtime.tools.avr-gcc.path=C:\Users\eu1391\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\5.4.0-atmel3.6.1-arduino2 -prefs=runtime.tools.avr-gcc-5.4.0-atmel3.6.1-arduino2.path=C:\Users\eu1391\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\5.4.0-atmel3.6.1-arduino2 -prefs=runtime.tools.arduinoOTA.path=C:\Users\eu1391\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.2.1 -prefs=runtime.tools.arduinoOTA-1.2.1.path=C:\Users\eu1391\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.2.1 -verbose C:\Users\eu1391\AppData\Local\Temp\arduino_modified_sketch_140208\MotionSensor.ino
          C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\eu1391\AppData\Local\Arduino15\packages -hardware D:\development\Arduino\hardware -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\eu1391\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries D:\development\Arduino\libraries -fqbn=arduino:avr:pro:cpu=8MHzatmega328 -vid-pid=0403_6001 -ide-version=10809 -build-path C:\Users\eu1391\AppData\Local\Temp\arduino_build_934684 -warnings=none -build-cache C:\Users\eu1391\AppData\Local\Temp\arduino_cache_700673 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avrdude.path=C:\Users\eu1391\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino14 -prefs=runtime.tools.avrdude-6.3.0-arduino14.path=C:\Users\eu1391\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino14 -prefs=runtime.tools.avr-gcc.path=C:\Users\eu1391\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\5.4.0-atmel3.6.1-arduino2 -prefs=runtime.tools.avr-gcc-5.4.0-atmel3.6.1-arduino2.path=C:\Users\eu1391\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\5.4.0-atmel3.6.1-arduino2 -prefs=runtime.tools.arduinoOTA.path=C:\Users\eu1391\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.2.1 -prefs=runtime.tools.arduinoOTA-1.2.1.path=C:\Users\eu1391\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.2.1 -verbose C:\Users\eu1391\AppData\Local\Temp\arduino_modified_sketch_140208\MotionSensor.ino
          Using board 'pro' from platform in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr
          Using core 'arduino' from platform in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr
          Detecting libraries used...
          "C:\\Users\\eu1391\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\5.4.0-atmel3.6.1-arduino2/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=8000000L -DARDUINO=10809 -DARDUINO_AVR_PRO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\variants\\eightanaloginputs" "C:\\Users\\eu1391\\AppData\\Local\\Temp\\arduino_build_934684\\sketch\\MotionSensor.ino.cpp" -o nul
          "C:\\Users\\eu1391\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\5.4.0-atmel3.6.1-arduino2/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=8000000L -DARDUINO=10809 -DARDUINO_AVR_PRO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\variants\\eightanaloginputs" "-ID:\\development\\Arduino\\libraries\\MySensors" "C:\\Users\\eu1391\\AppData\\Local\\Temp\\arduino_build_934684\\sketch\\MotionSensor.ino.cpp" -o nul
          "C:\\Users\\eu1391\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\5.4.0-atmel3.6.1-arduino2/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=8000000L -DARDUINO=10809 -DARDUINO_AVR_PRO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\variants\\eightanaloginputs" "-ID:\\development\\Arduino\\libraries\\MySensors" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\SPI\\src" "C:\\Users\\eu1391\\AppData\\Local\\Temp\\arduino_build_934684\\sketch\\MotionSensor.ino.cpp" -o nul
          Using cached library dependencies for file: D:\development\Arduino\libraries\MySensors\MyASM.S
          Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI\src\SPI.cpp
          Generating function prototypes...
          "C:\\Users\\eu1391\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\5.4.0-atmel3.6.1-arduino2/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=8000000L -DARDUINO=10809 -DARDUINO_AVR_PRO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\variants\\eightanaloginputs" "-ID:\\development\\Arduino\\libraries\\MySensors" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\SPI\\src" "C:\\Users\\eu1391\\AppData\\Local\\Temp\\arduino_build_934684\\sketch\\MotionSensor.ino.cpp" -o "C:\\Users\\eu1391\\AppData\\Local\\Temp\\arduino_build_934684\\preproc\\ctags_target_for_gcc_minus_e.cpp"
          "C:\\Program Files (x86)\\Arduino\\tools-builder\\ctags\\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\\Users\\eu1391\\AppData\\Local\\Temp\\arduino_build_934684\\preproc\\ctags_target_for_gcc_minus_e.cpp"
          Compiling sketch...
          "C:\\Users\\eu1391\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\5.4.0-atmel3.6.1-arduino2/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=8000000L -DARDUINO=10809 -DARDUINO_AVR_PRO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\variants\\eightanaloginputs" "-ID:\\development\\Arduino\\libraries\\MySensors" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\SPI\\src" "C:\\Users\\eu1391\\AppData\\Local\\Temp\\arduino_build_934684\\sketch\\MotionSensor.ino.cpp" -o "C:\\Users\\eu1391\\AppData\\Local\\Temp\\arduino_build_934684\\sketch\\MotionSensor.ino.cpp.o"
          Compiling libraries...
          Compiling library "MySensors"
          Using previously compiled file: C:\Users\eu1391\AppData\Local\Temp\arduino_build_934684\libraries\MySensors\MyASM.S.o
          Compiling library "SPI"
          Using previously compiled file: C:\Users\eu1391\AppData\Local\Temp\arduino_build_934684\libraries\SPI\SPI.cpp.o
          Compiling core...
          Using precompiled core: C:\Users\eu1391\AppData\Local\Temp\arduino_cache_700673\core\core_arduino_avr_pro_cpu_8MHzatmega328_0c812875ac70eb4a9b385d8fb077f54c.a
          "C:\\Users\\eu1391\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\5.4.0-atmel3.6.1-arduino2/bin/avr-gcc" -w -Os -g -flto -fuse-linker-plugin -Wl,--gc-sections -mmcu=atmega328p -o "C:\\Users\\eu1391\\AppData\\Local\\Temp\\arduino_build_934684/MotionSensor.ino.elf" "C:\\Users\\eu1391\\AppData\\Local\\Temp\\arduino_build_934684\\sketch\\MotionSensor.ino.cpp.o" "C:\\Users\\eu1391\\AppData\\Local\\Temp\\arduino_build_934684\\libraries\\MySensors\\MyASM.S.o" "C:\\Users\\eu1391\\AppData\\Local\\Temp\\arduino_build_934684\\libraries\\SPI\\SPI.cpp.o" "C:\\Users\\eu1391\\AppData\\Local\\Temp\\arduino_build_934684/..\\arduino_cache_700673\\core\\core_arduino_avr_pro_cpu_8MHzatmega328_0c812875ac70eb4a9b385d8fb077f54c.a" "-LC:\\Users\\eu1391\\AppData\\Local\\Temp\\arduino_build_934684" -lm
          "C:\\Users\\eu1391\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\5.4.0-atmel3.6.1-arduino2/bin/avr-objcopy" -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0 "C:\\Users\\eu1391\\AppData\\Local\\Temp\\arduino_build_934684/MotionSensor.ino.elf" "C:\\Users\\eu1391\\AppData\\Local\\Temp\\arduino_build_934684/MotionSensor.ino.eep"
          "C:\\Users\\eu1391\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\5.4.0-atmel3.6.1-arduino2/bin/avr-objcopy" -O ihex -R .eeprom "C:\\Users\\eu1391\\AppData\\Local\\Temp\\arduino_build_934684/MotionSensor.ino.elf" "C:\\Users\\eu1391\\AppData\\Local\\Temp\\arduino_build_934684/MotionSensor.ino.hex"
          Using library MySensors at version 2.3.2-beta in folder: D:\development\Arduino\libraries\MySensors
          Using library SPI at version 1.0 in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI
          "C:\\Users\\eu1391\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\5.4.0-atmel3.6.1-arduino2/bin/avr-size" -A "C:\\Users\\eu1391\\AppData\\Local\\Temp\\arduino_build_934684/MotionSensor.ino.elf"
          Sketch uses 13682 bytes (44%) of program storage space. Maximum is 30720 bytes.
          Global variables use 454 bytes (22%) of dynamic memory, leaving 1594 bytes for local variables. Maximum is 2048 bytes.```
            magpernM Offline
            magpernM Offline
            magpern
            @mfalkvidd @tekka Major break through! Please investigate!
            I was 9 commits behind, so I updated, but that did not improve the result. Result was still the same.
            So, I was thinking, what is the major differances between the NRF52832 sketch and the NRF24L01. The differance is that the NRF52 was passive. So, I put this into the MotionActuator sketch
            Now the device registers/communicates with the gateway.
            See the new log files, with the above lines
            Gateway
            Opening port
            Port open
            0;255;3;0;9;0 MCO:BGN:INIT GW,CP=RNNGA---,FQ=16,REL=7,VER=2.3.2-beta
            0;255;3;0;9;6 TSM:INIT
            0;255;3;0;9;8 TSF:WUR:MS=0
            0;255;3;0;9;15 TSM:INIT:TSP OK
            0;255;3;0;9;18 TSM:INIT:GW MODE
            0;255;3;0;9;21 TSM:READY:ID=0,PAR=0,DIS=0
            0;255;3;0;9;24 MCO:REG:NOT NEEDED
            0;255;0;0;18;2.3.2-beta
            0;255;3;0;9;29 MCO:BGN:STP
            0;255;3;0;9;35 MCO:BGN:INIT OK,TSP=1
            0;255;3;0;9;39 TSM:READY:NWD REQ
            0;255;3;0;9;45 ?TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=20,pt=0,l=0,sg=0,ft=0,st=OK:
            0;255;3;0;9;8570 TSF:MSG:READ,10-10-0,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
            0;255;3;0;9;8606 !TSF:MSG:SEND,0-0-10-10,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=NACK:0100
            0;255;3;0;9;10559 TSF:MSG:READ,10-10-0,s=255,c=0,t=17,pt=0,l=10,sg=0:2.3.2-beta
            10;255;0;0;17;2.3.2-beta
            0;255;3;0;9;10570 TSF:MSG:READ,10-10-0,s=255,c=3,t=6,pt=1,l=1,sg=0:255
            10;255;3;0;6;255
            0;255;3;0;9;12558 TSF:MSG:READ,10-10-0,s=255,c=3,t=11,pt=0,l=13,sg=0:Motion Sensor
            10;255;3;0;11;Motion Sensor
            0;255;3;0;9;12570 TSF:MSG:READ,10-10-0,s=255,c=3,t=12,pt=0,l=3,sg=0:1.0
            10;255;3;0;12;1.0
            0;255;3;0;9;12580 TSF:MSG:READ,10-10-0,s=1,c=0,t=1,pt=0,l=0,sg=0:
            10;1;0;0;1;
            0;255;3;0;9;12598 TSF:MSG:READ,10-10-0,s=1,c=1,t=16,pt=0,l=1,sg=0:0
            10;1;1;0;16;0
            Port closed
            The motionActuator
            Port open
             __  __       ____
                    |___/                      2.3.2-beta
            18 MCO:BGN:INIT NODE,CP=RNNPA---,FQ=8,REL=7,VER=2.3.2-beta
            28 TSM:INIT
            30 TSF:WUR:MS=0
            36 TSM:INIT:TSP OK
            38 TSM:INIT:TSP PSM
            40 TSM:INIT:STATID=10
            43 TSF:SID:OK,ID=10
            45 TSM:FPAR
            47 TSM:FPAR:STATP=255
            49 TSM:ID
            51 TSM:ID:OK
            51 TSM:UPL:DISABLED
            53 TSM:READY:ID=10,PAR=255,DIS=1
            59 ?TSF:MSG:SEND,10-10-255-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
            2070 ?TSF:MSG:SEND,10-10-255-0,s=255,c=0,t=17,pt=0,l=10,sg=0,ft=0,st=OK:2.3.2-beta
            2082 ?TSF:MSG:SEND,10-10-255-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:255
            4093 ?TSF:MSG:SEND,10-10-255-0,s=255,c=3,t=11,pt=0,l=13,sg=0,ft=0,st=OK:Motion Sensor
            4106 ?TSF:MSG:SEND,10-10-255-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=OK:1.0
            4116 ?TSF:MSG:SEND,10-10-255-0,s=1,c=0,t=1,pt=0,l=0,sg=0,ft=0,st=OK:
            4124 MCO:REG:NOT NEEDED
            4126 MCO:BGN:STP
            4128 MCO:BGN:INIT OK,TSP=1
            4134 ?TSF:MSG:SEND,10-10-255-0,s=1,c=1,t=16,pt=0,l=1,sg=0,ft=0,st=OK:0
            4141 MCO:SLP:MS=120000,SMS=0,I1=1,M1=1,I2=255,M2=255
            4147 TSF:TDI:TSL
            Port closed
            Is there a bug in the code?
            • magpernM magpern
              Gateway
              Opening port
              Port open
              10;255;3;0;6;255
              10;255;3;0;12;1.0
              10;1;0;0;1;
              10;1;1;0;16;0
              Port closed
              The motionActuator
              Port open
               __  __       ____
                      |___/                      2.3.2-beta
              28 TSM:INIT
              30 TSF:WUR:MS=0
              36 TSM:INIT:TSP OK
              38 TSM:INIT:TSP PSM
              43 TSF:SID:OK,ID=10
              45 TSM:FPAR
              49 TSM:ID
              51 TSM:ID:OK
              51 TSM:UPL:DISABLED
              4126 MCO:BGN:STP
              4147 TSF:TDI:TSL
              Port closed
              T Offline
              T Offline
              tekka
              @magpern The issue is still the same: GW seems ok (based on the log and your report that it communicates with other nodes), but the actuator node does not receive a single message.
              Please upload this sketch to your node, run it for 10s and post the full debug log of GW & node.
              #define MY_DEBUG_VERBOSE_TRANSPORT_HAL
              #define MY_DEBUG_VERBOSE_RF24
              MyMessage msgGeneral(0, V_VAR1);
              uint32_t counter = 0, lastSend = 0;
              	DEBUG_OUTPUT(PSTR("L=0x%" PRIx8 ", H=0x%" PRIx8 ", E=0x%" PRIx8 "\n"),
              		boot_lock_fuse_bits_get(GET_LOW_FUSE_BITS),
              		boot_lock_fuse_bits_get(GET_HIGH_FUSE_BITS),
              		boot_lock_fuse_bits_get(GET_EXTENDED_FUSE_BITS));
                sendSketchInfo("Testnode", "1");
                if (millis() - lastSend > 1000) {
                  send(msgGeneral.set(millis()));
                  Serial.println(counter);
                  counter = 0;
                  lastSend = millis();
                counter++;
              magpernM 1 Reply Last reply
              • T tekka
                    counter = 0;
                  counter++;
                magpernM Offline
                magpernM Offline
                magpern
                @tekka
                I actually don't think the device and the gateway actively talk. It is more like the Gateway is listening, but not talking.
                When I tried to set the RelayActuator to passive mode, it showed up in Domoticz, but I could not change the state of the relay from domoticz. However, if I physically altered the state of the relay (with button) domoticz got updated. It's like a one-way communication
                I uploaded the sketch you posted and here are the results
                This is the log from the device
                Port open
                 __  __       ____
                        |___/                      2.3.2-beta
                18 MCO:BGN:INIT NODE,CP=RNNNA---,FQ=8,REL=7,VER=2.3.2-beta
                28 TSM:INIT
                30 TSF:WUR:MS=0
                32 THA:INIT
                32 RF24:INIT:PIN,CE=9,CS=10
                36 RF24:SBY
                36 RF24:WBR:REG=0,VAL=14
                45 RF24:WBR:REG=3,VAL=3
                47 RF24:WBR:REG=4,VAL=95
                49 RF24:WBR:REG=5,VAL=76
                53 RF24:WBR:REG=6,VAL=7
                55 RF24:WBR:REG=29,VAL=4
                57 RF24:RBR:REG=29,VAL=4
                59 RF24:RBR:REG=6,VAL=7
                63 RF24:RBR:REG=5,VAL=76
                65 RF24:WBR:REG=2,VAL=2
                67 RF24:WBR:REG=1,VAL=0
                69 RF24:WBR:REG=28,VAL=3
                73 RF24:FRX
                73 RF24:FTX
                75 RF24:WBR:REG=7,VAL=112
                77 TSM:INIT:TSP OK
                79 TSM:FPAR
                81 THA:SND:MSG=FFFFFF020307FF
                86 RF24:SPL
                86 RF24:WBR:REG=0,VAL=14
                90 RF24:OWP:RCPT=255
                92 RF24:WBR:REG=10,VAL=255
                94 RF24:WBR:REG=16,VAL=255
                98 RF24:TXM:TO=255,LEN=7
                100 RF24:FTX
                102 RF24:WBR:REG=4,VAL=80
                104 RF24:WBR:REG=7,VAL=112
                106 RF24:WBR:REG=4,VAL=95
                110 RF24:STL
                112 RF24:WBR:REG=0,VAL=15
                114 THA:SND:MSG LEN=7,RES=1
                116 ?TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                2125 !TSM:FPAR:NO REPLY
                2127 TSM:FPAR
                2129 THA:SND:MSG=FFFFFF020307FF
                2131 RF24:SPL
                2134 RF24:WBR:REG=0,VAL=14
                2136 RF24:OWP:RCPT=255
                2140 RF24:WBR:REG=10,VAL=255
                2142 RF24:WBR:REG=16,VAL=255
                2146 RF24:TXM:TO=255,LEN=7
                2148 RF24:FTX
                2150 RF24:WBR:REG=4,VAL=80
                2152 RF24:WBR:REG=7,VAL=112
                2156 RF24:WBR:REG=4,VAL=95
                2158 RF24:STL
                2160 RF24:WBR:REG=0,VAL=15
                2164 THA:SND:MSG LEN=7,RES=1
                2166 ?TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                4175 !TSM:FPAR:NO REPLY
                4177 TSM:FPAR
                4179 THA:SND:MSG=FFFFFF020307FF
                4182 RF24:SPL
                4184 RF24:WBR:REG=0,VAL=14
                4186 RF24:OWP:RCPT=255
                4190 RF24:WBR:REG=10,VAL=255
                4192 RF24:WBR:REG=16,VAL=255
                4196 RF24:TXM:TO=255,LEN=7
                4198 RF24:FTX
                4200 RF24:WBR:REG=4,VAL=80
                4202 RF24:WBR:REG=7,VAL=112
                4206 RF24:WBR:REG=4,VAL=95
                4208 RF24:STL
                4210 RF24:WBR:REG=0,VAL=15
                4214 THA:SND:MSG LEN=7,RES=1
                4216 ?TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                6227 !TSM:FPAR:NO REPLY
                6230 TSM:FPAR
                6232 THA:SND:MSG=FFFFFF020307FF
                6234 RF24:SPL
                6236 RF24:WBR:REG=0,VAL=14
                6238 RF24:OWP:RCPT=255
                6242 RF24:WBR:REG=10,VAL=255
                6244 RF24:WBR:REG=16,VAL=255
                6248 RF24:TXM:TO=255,LEN=7
                6250 RF24:FTX
                6252 RF24:WBR:REG=4,VAL=80
                6254 RF24:WBR:REG=7,VAL=112
                6258 RF24:WBR:REG=4,VAL=95
                6260 RF24:STL
                6262 RF24:WBR:REG=0,VAL=15
                6266 THA:SND:MSG LEN=7,RES=1
                6268 ?TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                8278 !TSM:FPAR:FAIL
                8280 TSM:FAIL:CNT=1
                8282 TSM:FAIL:DIS
                8284 TSF:TDI:TSL
                8284 RF24:SLP
                8286 RF24:WBR:REG=0,VAL=12
                18292 TSM:FAIL:RE-INIT
                18294 TSM:INIT
                18296 THA:INIT
                18296 RF24:INIT:PIN,CE=9,CS=10
                18300 RF24:SBY
                18302 RF24:WBR:REG=0,VAL=14
                18311 RF24:WBR:REG=3,VAL=3
                18313 RF24:WBR:REG=4,VAL=95
                18315 RF24:WBR:REG=5,VAL=76
                18319 RF24:WBR:REG=6,VAL=7
                18321 RF24:WBR:REG=29,VAL=4
                18325 RF24:RBR:REG=29,VAL=4
                18327 RF24:RBR:REG=6,VAL=7
                18331 RF24:RBR:REG=5,VAL=76
                18333 RF24:WBR:REG=2,VAL=2
                18337 RF24:WBR:REG=1,VAL=0
                18339 RF24:WBR:REG=28,VAL=3
                18341 RF24:FRX
                18343 RF24:FTX
                18345 RF24:WBR:REG=7,VAL=112
                18350 TSM:INIT:TSP OK
                18352 TSM:FPAR
                18354 THA:SND:MSG=FFFFFF020307FF
                18356 RF24:SPL
                18358 RF24:WBR:REG=0,VAL=14
                18362 RF24:OWP:RCPT=255
                18364 RF24:WBR:REG=10,VAL=255
                18368 RF24:WBR:REG=16,VAL=255
                18370 RF24:TXM:TO=255,LEN=7
                18374 RF24:FTX
                18376 RF24:WBR:REG=4,VAL=80
                18378 RF24:WBR:REG=7,VAL=112
                18382 RF24:WBR:REG=4,VAL=95
                18384 RF24:STL
                18386 RF24:WBR:REG=0,VAL=15
                18391 THA:SND:MSG LEN=7,RES=1
                18393 ?TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                20402 !TSM:FPAR:NO REPLY
                20404 TSM:FPAR
                20406 THA:SND:MSG=FFFFFF020307FF
                20408 RF24:SPL
                20410 RF24:WBR:REG=0,VAL=14
                20414 RF24:OWP:RCPT=255
                20416 RF24:WBR:REG=10,VAL=255
                20420 RF24:WBR:REG=16,VAL=255
                20422 RF24:TXM:TO=255,LEN=7
                20426 RF24:FTX
                20428 RF24:WBR:REG=4,VAL=80
                20430 RF24:WBR:REG=7,VAL=112
                20434 RF24:WBR:REG=4,VAL=95
                20436 RF24:STL
                20439 RF24:WBR:REG=0,VAL=15
                20443 THA:SND:MSG LEN=7,RES=1
                20445 ?TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                22454 !TSM:FPAR:NO REPLY
                22456 TSM:FPAR
                22458 THA:SND:MSG=FFFFFF020307FF
                22460 RF24:SPL
                22462 RF24:WBR:REG=0,VAL=14
                22466 RF24:OWP:RCPT=255
                22468 RF24:WBR:REG=10,VAL=255
                22472 RF24:WBR:REG=16,VAL=255
                22474 RF24:TXM:TO=255,LEN=7
                22478 RF24:FTX
                22480 RF24:WBR:REG=4,VAL=80
                22482 RF24:WBR:REG=7,VAL=112
                22487 RF24:WBR:REG=4,VAL=95
                22489 RF24:STL
                22491 RF24:WBR:REG=0,VAL=15
                22493 THA:SND:MSG LEN=7,RES=1
                22497 ?TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                24506 !TSM:FPAR:NO REPLY
                24508 TSM:FPAR
                24510 THA:SND:MSG=FFFFFF020307FF
                24512 RF24:SPL
                24514 RF24:WBR:REG=0,VAL=14
                24518 RF24:OWP:RCPT=255
                24520 RF24:WBR:REG=10,VAL=255
                24524 RF24:WBR:REG=16,VAL=255
                24526 RF24:TXM:TO=255,LEN=7
                24530 RF24:FTX
                24532 RF24:WBR:REG=4,VAL=80
                24535 RF24:WBR:REG=7,VAL=112
                24539 RF24:WBR:REG=4,VAL=95
                24541 RF24:STL
                24543 RF24:WBR:REG=0,VAL=15
                24545 THA:SND:MSG LEN=7,RES=1
                24549 ?TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                26558 !TSM:FPAR:FAIL
                26560 TSM:FAIL:CNT=2
                26562 TSM:FAIL:DIS
                26564 TSF:TDI:TSL
                26566 RF24:SLP
                26568 RF24:WBR:REG=0,VAL=12
                36571 TSM:FAIL:RE-INIT
                36573 TSM:INIT
                36575 THA:INIT
                36575 RF24:INIT:PIN,CE=9,CS=10
                36579 RF24:SBY
                36581 RF24:WBR:REG=0,VAL=14
                36589 RF24:WBR:REG=3,VAL=3
                36591 RF24:WBR:REG=4,VAL=95
                36593 RF24:WBR:REG=5,VAL=76
                36597 RF24:WBR:REG=6,VAL=7
                36599 RF24:WBR:REG=29,VAL=4
                36603 RF24:RBR:REG=29,VAL=4
                36605 RF24:RBR:REG=6,VAL=7
                36610 RF24:RBR:REG=5,VAL=76
                36612 RF24:WBR:REG=2,VAL=2
                36616 RF24:WBR:REG=1,VAL=0
                36618 RF24:WBR:REG=28,VAL=3
                36620 RF24:FRX
                36622 RF24:FTX
                36624 RF24:WBR:REG=7,VAL=112
                36628 TSM:INIT:TSP OK
                36630 TSM:FPAR
                36632 THA:SND:MSG=FFFFFF020307FF
                36634 RF24:SPL
                36636 RF24:WBR:REG=0,VAL=14
                36640 RF24:OWP:RCPT=255
                36642 RF24:WBR:REG=10,VAL=255
                36646 RF24:WBR:REG=16,VAL=255
                36648 RF24:TXM:TO=255,LEN=7
                36653 RF24:FTX
                36655 RF24:WBR:REG=4,VAL=80
                36657 RF24:WBR:REG=7,VAL=112
                36661 RF24:WBR:REG=4,VAL=95
                36663 RF24:STL
                36665 RF24:WBR:REG=0,VAL=15
                36669 THA:SND:MSG LEN=7,RES=1
                36671 ?TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                38680 !TSM:FPAR:NO REPLY
                38682 TSM:FPAR
                38684 THA:SND:MSG=FFFFFF020307FF
                38686 RF24:SPL
                38688 RF24:WBR:REG=0,VAL=14
                38692 RF24:OWP:RCPT=255
                38694 RF24:WBR:REG=10,VAL=255
                38699 RF24:WBR:REG=16,VAL=255
                38701 RF24:TXM:TO=255,LEN=7
                38705 RF24:FTX
                38707 RF24:WBR:REG=4,VAL=80
                38709 RF24:WBR:REG=7,VAL=112
                38713 RF24:WBR:REG=4,VAL=95
                38715 RF24:STL
                38717 RF24:WBR:REG=0,VAL=15
                38719 THA:SND:MSG LEN=7,RES=1
                38723 ?TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                40732 !TSM:FPAR:NO REPLY
                40734 TSM:FPAR
                40736 THA:SND:MSG=FFFFFF020307FF
                40738 RF24:SPL
                40740 RF24:WBR:REG=0,VAL=14
                40744 RF24:OWP:RCPT=255
                40747 RF24:WBR:REG=10,VAL=255
                40751 RF24:WBR:REG=16,VAL=255
                40753 RF24:TXM:TO=255,LEN=7
                40757 RF24:FTX
                40759 RF24:WBR:REG=4,VAL=80
                40761 RF24:WBR:REG=7,VAL=112
                40765 RF24:WBR:REG=4,VAL=95
                40767 RF24:STL
                40769 RF24:WBR:REG=0,VAL=15
                40771 THA:SND:MSG LEN=7,RES=1
                40775 ?TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                42784 !TSM:FPAR:NO REPLY
                42786 TSM:FPAR
                42788 THA:SND:MSG=FFFFFF020307FF
                42790 RF24:SPL
                42792 RF24:WBR:REG=0,VAL=14
                42797 RF24:OWP:RCPT=255
                42799 RF24:WBR:REG=10,VAL=255
                42803 RF24:WBR:REG=16,VAL=255
                42805 RF24:TXM:TO=255,LEN=7
                42809 RF24:FTX
                42811 RF24:WBR:REG=4,VAL=80
                42813 RF24:WBR:REG=7,VAL=112
                42817 RF24:WBR:REG=4,VAL=95
                42819 RF24:STL
                42821 RF24:WBR:REG=0,VAL=15
                42823 THA:SND:MSG LEN=7,RES=1
                42827 ?TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                Port closed
                This is the log from the gateway
                Port open
                0;255;3;0;9;4503 MCO:BGN:INIT GW,CP=RNNGS---,FQ=48,REL=7,VER=2.3.2-beta
                0;255;3;0;9;4532 TSF:LRT:OK
                0;255;3;0;9;4532 TSM:INIT
                0;255;3;0;9;4533 TSF:WUR:MS=0
                0;255;3;0;9;4534 THA:INIT
                0;255;3;0;9;4534 RF24:INIT:PIN,CE=34,CS=29
                0;255;3;0;9;4534 RF24:SBY
                0;255;3;0;9;4534 RF24:WBR:REG=0,VAL=14
                0;255;3;0;9;4539 RF24:WBR:REG=3,VAL=3
                0;255;3;0;9;4540 RF24:WBR:REG=4,VAL=95
                0;255;3;0;9;4540 RF24:WBR:REG=5,VAL=76
                0;255;3;0;9;4540 RF24:WBR:REG=6,VAL=7
                0;255;3;0;9;4540 RF24:WBR:REG=29,VAL=4
                0;255;3;0;9;4541 RF24:RBR:REG=29,VAL=4
                0;255;3;0;9;4541 RF24:RBR:REG=6,VAL=7
                0;255;3;0;9;4541 RF24:RBR:REG=5,VAL=76
                0;255;3;0;9;4542 RF24:WBR:REG=2,VAL=2
                0;255;3;0;9;4542 RF24:WBR:REG=1,VAL=0
                0;255;3;0;9;4542 RF24:WBR:REG=28,VAL=3
                0;255;3;0;9;4543 RF24:FRX
                0;255;3;0;9;4543 RF24:FTX
                0;255;3;0;9;4543 RF24:WBR:REG=7,VAL=112
                0;255;3;0;9;4543 TSM:INIT:TSP OK
                0;255;3;0;9;4544 TSM:INIT:GW MODE
                0;255;3;0;9;4544 THA:SAD:ADDR=0
                0;255;3;0;9;4544 RF24:WBR:REG=2,VAL=3
                0;255;3;0;9;4544 RF24:WBR:REG=1,VAL=1
                0;255;3;0;9;4545 RF24:STL
                0;255;3;0;9;4545 RF24:WBR:REG=0,VAL=15
                0;255;3;0;9;4545 RF24:WBR:REG=10,VAL=0
                0;255;3;0;9;4545 TSM:READY:ID=0,PAR=0,DIS=0
                0;255;3;0;9;4546 MCO:REG:NOT NEEDED
                0;255;3;0;9;4546 MCO:BGN:STP
                0;255;3;0;9;4546 RF24:RBR:REG=6,VAL=7
                0;255;3;0;9;4547 RF24:RBR:REG=5,VAL=76
                0;255;3;0;9;4547 THA:SAN:RES=1
                0;255;3;0;9;4547 MCO:BGN:INIT OK,TSP=1
                0;255;3;0;9;4547 TSM:READY:NWD REQ
                0;255;3;0;9;4548 THA:SND:MSG=0000FF020314FF
                0;255;3;0;9;4548 RF24:SPL
                0;255;3;0;9;4548 RF24:WBR:REG=0,VAL=14
                0;255;3;0;9;4549 RF24:OWP:RCPT=255
                0;255;3;0;9;4549 RF24:WBR:REG=10,VAL=255
                0;255;3;0;9;4549 RF24:WBR:REG=16,VAL=255
                0;255;3;0;9;4549 RF24:TXM:TO=255,LEN=7
                0;255;3;0;9;4550 RF24:FTX
                0;255;3;0;9;4550 RF24:WBR:REG=4,VAL=80
                0;255;3;0;9;4552 RF24:WBR:REG=7,VAL=112
                0;255;3;0;9;4552 ?RF24:TXM:MAX_RT
                0;255;3;0;9;4553 RF24:FTX
                0;255;3;0;9;4553 RF24:WBR:REG=4,VAL=95
                0;255;3;0;9;4553 RF24:STL
                0;255;3;0;9;4553 RF24:WBR:REG=0,VAL=15
                0;255;3;0;9;4554 RF24:WBR:REG=10,VAL=0
                0;255;3;0;9;4554 THA:SND:MSG LEN=7,RES=1
                0;255;3;0;9;4554 ?TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=20,pt=0,l=0,sg=0,ft=0,st=OK:
                0;255;3;0;9;10212 THA:DATA:AVAIL
                0;255;3;0;9;10212 RF24:RXM:LEN=7
                0;255;3;0;9;10212 RF24:WBR:REG=7,VAL=64
                0;255;3;0;9;10213 THA:RCV:MSG=FFFFFF020307FF
                0;255;3;0;9;10213 THA:RCV:MSG LEN=7
                0;255;3;0;9;10213 TSF:MSG:READ,255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
                0;255;3;0;9;10214 TSF:MSG:BC
                0;255;3;0;9;10214 TSF:MSG:FPAR REQ,ID=255
                0;255;3;0;9;10214 TSF:PNG:SEND,TO=0
                0;255;3;0;9;10214 TSF:CKU:OK
                0;255;3;0;9;10215 TSF:MSG:GWL OK
                0;255;3;0;9;11214 THA:SND:MSG=0000FF0A2308FF00
                0;255;3;0;9;11214 RF24:SPL
                0;255;3;0;9;11215 RF24:WBR:REG=0,VAL=14
                0;255;3;0;9;11215 RF24:OWP:RCPT=255
                0;255;3;0;9;11215 RF24:WBR:REG=10,VAL=255
                0;255;3;0;9;11216 RF24:WBR:REG=16,VAL=255
                0;255;3;0;9;11216 RF24:TXM:TO=255,LEN=8
                0;255;3;0;9;11216 RF24:FTX
                0;255;3;0;9;11216 RF24:WBR:REG=4,VAL=80
                0;255;3;0;9;11219 RF24:WBR:REG=7,VAL=112
                0;255;3;0;9;11219 ?RF24:TXM:MAX_RT
                0;255;3;0;9;11219 RF24:FTX
                0;255;3;0;9;11220 RF24:WBR:REG=4,VAL=95
                0;255;3;0;9;11220 RF24:STL
                0;255;3;0;9;11221 RF24:WBR:REG=0,VAL=15
                0;255;3;0;9;11221 RF24:WBR:REG=10,VAL=0
                0;255;3;0;9;11221 THA:SND:MSG LEN=8,RES=1
                0;255;3;0;9;11222 ?TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
                0;255;3;0;9;12235 THA:DATA:AVAIL
                0;255;3;0;9;12236 RF24:RXM:LEN=7
                0;255;3;0;9;12236 RF24:WBR:REG=7,VAL=64
                0;255;3;0;9;12236 THA:RCV:MSG=FFFFFF020307FF
                0;255;3;0;9;12236 THA:RCV:MSG LEN=7
                0;255;3;0;9;12237 TSF:MSG:READ,255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
                0;255;3;0;9;12237 TSF:MSG:BC
                0;255;3;0;9;12237 TSF:MSG:FPAR REQ,ID=255
                0;255;3;0;9;12237 TSF:CKU:OK,FCTRL
                0;255;3;0;9;12238 TSF:MSG:GWL OK
                0;255;3;0;9;13212 THA:SND:MSG=0000FF0A2308FF00
                0;255;3;0;9;13212 RF24:SPL
                0;255;3;0;9;13213 RF24:WBR:REG=0,VAL=14
                0;255;3;0;9;13213 RF24:OWP:RCPT=255
                0;255;3;0;9;13213 RF24:WBR:REG=10,VAL=255
                0;255;3;0;9;13213 RF24:WBR:REG=16,VAL=255
                0;255;3;0;9;13214 RF24:TXM:TO=255,LEN=8
                0;255;3;0;9;13214 RF24:FTX
                0;255;3;0;9;13214 RF24:WBR:REG=4,VAL=80
                0;255;3;0;9;13216 RF24:WBR:REG=7,VAL=112
                0;255;3;0;9;13217 ?RF24:TXM:MAX_RT
                0;255;3;0;9;13217 RF24:FTX
                0;255;3;0;9;13217 RF24:WBR:REG=4,VAL=95
                0;255;3;0;9;13218 RF24:STL
                0;255;3;0;9;13218 RF24:WBR:REG=0,VAL=15
                0;255;3;0;9;13218 RF24:WBR:REG=10,VAL=0
                0;255;3;0;9;13219 THA:SND:MSG LEN=8,RES=1
                0;255;3;0;9;13219 ?TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
                0;255;3;0;9;14259 THA:DATA:AVAIL
                0;255;3;0;9;14259 RF24:RXM:LEN=7
                0;255;3;0;9;14259 RF24:WBR:REG=7,VAL=64
                0;255;3;0;9;14259 THA:RCV:MSG=FFFFFF020307FF
                0;255;3;0;9;14260 THA:RCV:MSG LEN=7
                0;255;3;0;9;14260 TSF:MSG:READ,255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
                0;255;3;0;9;14260 TSF:MSG:BC
                0;255;3;0;9;14261 TSF:MSG:FPAR REQ,ID=255
                0;255;3;0;9;14261 TSF:CKU:OK,FCTRL
                0;255;3;0;9;14261 TSF:MSG:GWL OK
                0;255;3;0;9;15212 THA:SND:MSG=0000FF0A2308FF00
                0;255;3;0;9;15212 RF24:SPL
                0;255;3;0;9;15212 RF24:WBR:REG=0,VAL=14
                0;255;3;0;9;15213 RF24:OWP:RCPT=255
                0;255;3;0;9;15213 RF24:WBR:REG=10,VAL=255
                0;255;3;0;9;15213 RF24:WBR:REG=16,VAL=255
                0;255;3;0;9;15214 RF24:TXM:TO=255,LEN=8
                0;255;3;0;9;15214 RF24:FTX
                0;255;3;0;9;15214 RF24:WBR:REG=4,VAL=80
                0;255;3;0;9;15217 RF24:WBR:REG=7,VAL=112
                0;255;3;0;9;15217 ?RF24:TXM:MAX_RT
                0;255;3;0;9;15217 RF24:FTX
                0;255;3;0;9;15217 RF24:WBR:REG=4,VAL=95
                0;255;3;0;9;15218 RF24:STL
                0;255;3;0;9;15218 RF24:WBR:REG=0,VAL=15
                0;255;3;0;9;15218 RF24:WBR:REG=10,VAL=0
                0;255;3;0;9;15218 THA:SND:MSG LEN=8,RES=1
                0;255;3;0;9;15219 ?TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
                0;255;3;0;9;16282 THA:DATA:AVAIL
                0;255;3;0;9;16283 RF24:RXM:LEN=7
                0;255;3;0;9;16283 RF24:WBR:REG=7,VAL=64
                0;255;3;0;9;16284 THA:RCV:MSG=FFFFFF020307FF
                0;255;3;0;9;16284 THA:RCV:MSG LEN=7
                0;255;3;0;9;16285 TSF:MSG:READ,255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
                0;255;3;0;9;16285 TSF:MSG:BC
                0;255;3;0;9;16286 TSF:MSG:FPAR REQ,ID=255
                0;255;3;0;9;16286 TSF:CKU:OK,FCTRL
                0;255;3;0;9;16287 TSF:MSG:GWL OK
                0;255;3;0;9;17214 THA:SND:MSG=0000FF0A2308FF00
                0;255;3;0;9;17214 RF24:SPL
                0;255;3;0;9;17215 RF24:WBR:REG=0,VAL=14
                0;255;3;0;9;17215 RF24:OWP:RCPT=255
                0;255;3;0;9;17215 RF24:WBR:REG=10,VAL=255
                0;255;3;0;9;17215 RF24:WBR:REG=16,VAL=255
                0;255;3;0;9;17216 RF24:TXM:TO=255,LEN=8
                0;255;3;0;9;17216 RF24:FTX
                0;255;3;0;9;17216 RF24:WBR:REG=4,VAL=80
                0;255;3;0;9;17218 RF24:WBR:REG=7,VAL=112
                0;255;3;0;9;17219 ?RF24:TXM:MAX_RT
                0;255;3;0;9;17219 RF24:FTX
                0;255;3;0;9;17219 RF24:WBR:REG=4,VAL=95
                0;255;3;0;9;17219 RF24:STL
                0;255;3;0;9;17219 RF24:WBR:REG=0,VAL=15
                0;255;3;0;9;17220 RF24:WBR:REG=10,VAL=0
                0;255;3;0;9;17220 THA:SND:MSG LEN=8,RES=1
                0;255;3;0;9;17220 ?TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
                0;255;3;0;9;28242 THA:DATA:AVAIL
                0;255;3;0;9;28243 RF24:RXM:LEN=7
                0;255;3;0;9;28243 RF24:WBR:REG=7,VAL=64
                0;255;3;0;9;28243 THA:RCV:MSG=FFFFFF020307FF
                0;255;3;0;9;28244 THA:RCV:MSG LEN=7
                0;255;3;0;9;28244 TSF:MSG:READ,255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
                0;255;3;0;9;28244 TSF:MSG:BC
                0;255;3;0;9;28245 TSF:MSG:FPAR REQ,ID=255
                0;255;3;0;9;28245 TSF:PNG:SEND,TO=0
                0;255;3;0;9;28245 TSF:CKU:OK
                0;255;3;0;9;28245 TSF:MSG:GWL OK
                0;255;3;0;9;28844 THA:SND:MSG=0000FF0A2308FF00
                0;255;3;0;9;28844 RF24:SPL
                0;255;3;0;9;28844 RF24:WBR:REG=0,VAL=14
                0;255;3;0;9;28845 RF24:OWP:RCPT=255
                0;255;3;0;9;28845 RF24:WBR:REG=10,VAL=255
                0;255;3;0;9;28846 RF24:WBR:REG=16,VAL=255
                0;255;3;0;9;28846 RF24:TXM:TO=255,LEN=8
                0;255;3;0;9;28846 RF24:FTX
                0;255;3;0;9;28847 RF24:WBR:REG=4,VAL=80
                0;255;3;0;9;28849 RF24:WBR:REG=7,VAL=112
                0;255;3;0;9;28849 ?RF24:TXM:MAX_RT
                0;255;3;0;9;28850 RF24:FTX
                0;255;3;0;9;28850 RF24:WBR:REG=4,VAL=95
                0;255;3;0;9;28850 RF24:STL
                0;255;3;0;9;28851 RF24:WBR:REG=0,VAL=15
                0;255;3;0;9;28851 RF24:WBR:REG=10,VAL=0
                0;255;3;0;9;28851 THA:SND:MSG LEN=8,RES=1
                0;255;3;0;9;28851 ?TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
                0;255;3;0;9;30269 THA:DATA:AVAIL
                0;255;3;0;9;30269 RF24:RXM:LEN=7
                0;255;3;0;9;30270 RF24:WBR:REG=7,VAL=64
                0;255;3;0;9;30270 THA:RCV:MSG=FFFFFF020307FF
                0;255;3;0;9;30270 THA:RCV:MSG LEN=7
                0;255;3;0;9;30270 TSF:MSG:READ,255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
                0;255;3;0;9;30271 TSF:MSG:BC
                0;255;3;0;9;30271 TSF:MSG:FPAR REQ,ID=255
                0;255;3;0;9;30271 TSF:CKU:OK,FCTRL
                0;255;3;0;9;30272 TSF:MSG:GWL OK
                0;255;3;0;9;30848 THA:SND:MSG=0000FF0A2308FF00
                0;255;3;0;9;30848 RF24:SPL
                0;255;3;0;9;30849 RF24:WBR:REG=0,VAL=14
                0;255;3;0;9;30849 RF24:OWP:RCPT=255
                0;255;3;0;9;30849 RF24:WBR:REG=10,VAL=255
                0;255;3;0;9;30850 RF24:WBR:REG=16,VAL=255
                0;255;3;0;9;30850 RF24:TXM:TO=255,LEN=8
                0;255;3;0;9;30850 RF24:FTX
                0;255;3;0;9;30850 RF24:WBR:REG=4,VAL=80
                0;255;3;0;9;30853 RF24:WBR:REG=7,VAL=112
                0;255;3;0;9;30853 ?RF24:TXM:MAX_RT
                0;255;3;0;9;30853 RF24:FTX
                0;255;3;0;9;30853 RF24:WBR:REG=4,VAL=95
                0;255;3;0;9;30854 RF24:STL
                0;255;3;0;9;30854 RF24:WBR:REG=0,VAL=15
                0;255;3;0;9;30854 RF24:WBR:REG=10,VAL=0
                0;255;3;0;9;30855 THA:SND:MSG LEN=8,RES=1
                0;255;3;0;9;30855 ?TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
                0;255;3;0;9;32295 THA:DATA:AVAIL
                0;255;3;0;9;32296 RF24:RXM:LEN=7
                0;255;3;0;9;32296 RF24:WBR:REG=7,VAL=64
                0;255;3;0;9;32296 THA:RCV:MSG=FFFFFF020307FF
                0;255;3;0;9;32297 THA:RCV:MSG LEN=7
                0;255;3;0;9;32297 TSF:MSG:READ,255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
                0;255;3;0;9;32297 TSF:MSG:BC
                0;255;3;0;9;32298 TSF:MSG:FPAR REQ,ID=255
                0;255;3;0;9;32298 TSF:CKU:OK,FCTRL
                0;255;3;0;9;32298 TSF:MSG:GWL OK
                0;255;3;0;9;32854 THA:SND:MSG=0000FF0A2308FF00
                0;255;3;0;9;32854 RF24:SPL
                0;255;3;0;9;32855 RF24:WBR:REG=0,VAL=14
                0;255;3;0;9;32855 RF24:OWP:RCPT=255
                0;255;3;0;9;32855 RF24:WBR:REG=10,VAL=255
                0;255;3;0;9;32855 RF24:WBR:REG=16,VAL=255
                0;255;3;0;9;32856 RF24:TXM:TO=255,LEN=8
                0;255;3;0;9;32856 RF24:FTX
                0;255;3;0;9;32856 RF24:WBR:REG=4,VAL=80
                0;255;3;0;9;32858 RF24:WBR:REG=7,VAL=112
                0;255;3;0;9;32859 ?RF24:TXM:MAX_RT
                0;255;3;0;9;32859 RF24:FTX
                0;255;3;0;9;32859 RF24:WBR:REG=4,VAL=95
                0;255;3;0;9;32859 RF24:STL
                0;255;3;0;9;32860 RF24:WBR:REG=0,VAL=15
                0;255;3;0;9;32860 RF24:WBR:REG=10,VAL=0
                0;255;3;0;9;32860 THA:SND:MSG LEN=8,RES=1
                0;255;3;0;9;32860 ?TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
                0;255;3;0;9;34321 THA:DATA:AVAIL
                0;255;3;0;9;34322 RF24:RXM:LEN=7
                0;255;3;0;9;34322 RF24:WBR:REG=7,VAL=64
                0;255;3;0;9;34322 THA:RCV:MSG=FFFFFF020307FF
                0;255;3;0;9;34323 THA:RCV:MSG LEN=7
                0;255;3;0;9;34323 TSF:MSG:READ,255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
                0;255;3;0;9;34323 TSF:MSG:BC
                0;255;3;0;9;34323 TSF:MSG:FPAR REQ,ID=255
                0;255;3;0;9;34324 TSF:CKU:OK,FCTRL
                0;255;3;0;9;34324 TSF:MSG:GWL OK
                0;255;3;0;9;34856 THA:SND:MSG=0000FF0A2308FF00
                0;255;3;0;9;34857 RF24:SPL
                0;255;3;0;9;34857 RF24:WBR:REG=0,VAL=14
                0;255;3;0;9;34857 RF24:OWP:RCPT=255
                0;255;3;0;9;34858 RF24:WBR:REG=10,VAL=255
                0;255;3;0;9;34858 RF24:WBR:REG=16,VAL=255
                0;255;3;0;9;34858 RF24:TXM:TO=255,LEN=8
                0;255;3;0;9;34858 RF24:FTX
                0;255;3;0;9;34859 RF24:WBR:REG=4,VAL=80
                0;255;3;0;9;34861 RF24:WBR:REG=7,VAL=112
                0;255;3;0;9;34861 ?RF24:TXM:MAX_RT
                0;255;3;0;9;34861 RF24:FTX
                0;255;3;0;9;34861 RF24:WBR:REG=4,VAL=95
                0;255;3;0;9;34862 RF24:STL
                0;255;3;0;9;34862 RF24:WBR:REG=0,VAL=15
                0;255;3;0;9;34862 RF24:WBR:REG=10,VAL=0
                0;255;3;0;9;34863 THA:SND:MSG LEN=8,RES=1
                0;255;3;0;9;34863 ?TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
                0;255;3;0;9;46289 THA:DATA:AVAIL
                0;255;3;0;9;46289 RF24:RXM:LEN=7
                0;255;3;0;9;46290 RF24:WBR:REG=7,VAL=64
                0;255;3;0;9;46290 THA:RCV:MSG=FFFFFF020307FF
                0;255;3;0;9;46290 THA:RCV:MSG LEN=7
                0;255;3;0;9;46290 TSF:MSG:READ,255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
                0;255;3;0;9;46291 TSF:MSG:BC
                0;255;3;0;9;46291 TSF:MSG:FPAR REQ,ID=255
                0;255;3;0;9;46291 TSF:PNG:SEND,TO=0
                0;255;3;0;9;46292 TSF:CKU:OK
                0;255;3;0;9;46292 TSF:MSG:GWL OK
                0;255;3;0;9;46504 THA:SND:MSG=0000FF0A2308FF00
                0;255;3;0;9;46504 RF24:SPL
                0;255;3;0;9;46505 RF24:WBR:REG=0,VAL=14
                0;255;3;0;9;46505 RF24:OWP:RCPT=255
                0;255;3;0;9;46505 RF24:WBR:REG=10,VAL=255
                0;255;3;0;9;46506 RF24:WBR:REG=16,VAL=255
                0;255;3;0;9;46506 RF24:TXM:TO=255,LEN=8
                0;255;3;0;9;46506 RF24:FTX
                0;255;3;0;9;46506 RF24:WBR:REG=4,VAL=80
                0;255;3;0;9;46509 RF24:WBR:REG=7,VAL=112
                0;255;3;0;9;46509 ?RF24:TXM:MAX_RT
                0;255;3;0;9;46509 RF24:FTX
                0;255;3;0;9;46509 RF24:WBR:REG=4,VAL=95
                0;255;3;0;9;46510 RF24:STL
                0;255;3;0;9;46510 RF24:WBR:REG=0,VAL=15
                0;255;3;0;9;46510 RF24:WBR:REG=10,VAL=0
                0;255;3;0;9;46510 THA:SND:MSG LEN=8,RES=1
                0;255;3;0;9;46511 ?TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
                0;255;3;0;9;48315 THA:DATA:AVAIL
                0;255;3;0;9;48316 RF24:RXM:LEN=7
                0;255;3;0;9;48316 RF24:WBR:REG=7,VAL=64
                0;255;3;0;9;48316 THA:RCV:MSG=FFFFFF020307FF
                0;255;3;0;9;48317 THA:RCV:MSG LEN=7
                0;255;3;0;9;48317 TSF:MSG:READ,255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
                0;255;3;0;9;48317 TSF:MSG:BC
                0;255;3;0;9;48318 TSF:MSG:FPAR REQ,ID=255
                0;255;3;0;9;48318 TSF:CKU:OK,FCTRL
                0;255;3;0;9;48318 TSF:MSG:GWL OK
                0;255;3;0;9;48508 THA:SND:MSG=0000FF0A2308FF00
                0;255;3;0;9;48509 RF24:SPL
                0;255;3;0;9;48509 RF24:WBR:REG=0,VAL=14
                0;255;3;0;9;48510 RF24:OWP:RCPT=255
                0;255;3;0;9;48510 RF24:WBR:REG=10,VAL=255
                0;255;3;0;9;48510 RF24:WBR:REG=16,VAL=255
                0;255;3;0;9;48510 RF24:TXM:TO=255,LEN=8
                0;255;3;0;9;48511 RF24:FTX
                0;255;3;0;9;48511 RF24:WBR:REG=4,VAL=80
                0;255;3;0;9;48513 RF24:WBR:REG=7,VAL=112
                0;255;3;0;9;48513 ?RF24:TXM:MAX_RT
                0;255;3;0;9;48514 RF24:FTX
                0;255;3;0;9;48514 RF24:WBR:REG=4,VAL=95
                0;255;3;0;9;48514 RF24:STL
                0;255;3;0;9;48514 RF24:WBR:REG=0,VAL=15
                0;255;3;0;9;48515 RF24:WBR:REG=10,VAL=0
                0;255;3;0;9;48515 THA:SND:MSG LEN=8,RES=1
                0;255;3;0;9;48515 ?TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
                0;255;3;0;9;50342 THA:DATA:AVAIL
                0;255;3;0;9;50342 RF24:RXM:LEN=7
                0;255;3;0;9;50343 RF24:WBR:REG=7,VAL=64
                0;255;3;0;9;50343 THA:RCV:MSG=FFFFFF020307FF
                0;255;3;0;9;50343 THA:RCV:MSG LEN=7
                0;255;3;0;9;50343 TSF:MSG:READ,255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
                0;255;3;0;9;50344 TSF:MSG:BC
                0;255;3;0;9;50344 TSF:MSG:FPAR REQ,ID=255
                0;255;3;0;9;50344 TSF:CKU:OK,FCTRL
                0;255;3;0;9;50344 TSF:MSG:GWL OK
                0;255;3;0;9;50513 THA:SND:MSG=0000FF0A2308FF00
                0;255;3;0;9;50513 RF24:SPL
                0;255;3;0;9;50513 RF24:WBR:REG=0,VAL=14
                0;255;3;0;9;50514 RF24:OWP:RCPT=255
                0;255;3;0;9;50514 RF24:WBR:REG=10,VAL=255
                0;255;3;0;9;50514 RF24:WBR:REG=16,VAL=255
                0;255;3;0;9;50514 RF24:TXM:TO=255,LEN=8
                0;255;3;0;9;50515 RF24:FTX
                0;255;3;0;9;50515 RF24:WBR:REG=4,VAL=80
                0;255;3;0;9;50517 RF24:WBR:REG=7,VAL=112
                0;255;3;0;9;50517 ?RF24:TXM:MAX_RT
                0;255;3;0;9;50518 RF24:FTX
                0;255;3;0;9;50518 RF24:WBR:REG=4,VAL=95
                0;255;3;0;9;50518 RF24:STL
                0;255;3;0;9;50518 RF24:WBR:REG=0,VAL=15
                0;255;3;0;9;50519 RF24:WBR:REG=10,VAL=0
                0;255;3;0;9;50519 THA:SND:MSG LEN=8,RES=1
                0;255;3;0;9;50519 ?TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
                0;255;3;0;9;52369 THA:DATA:AVAIL
                0;255;3;0;9;52370 RF24:RXM:LEN=7
                0;255;3;0;9;52370 RF24:WBR:REG=7,VAL=64
                0;255;3;0;9;52370 THA:RCV:MSG=FFFFFF020307FF
                0;255;3;0;9;52371 THA:RCV:MSG LEN=7
                0;255;3;0;9;52371 TSF:MSG:READ,255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
                0;255;3;0;9;52371 TSF:MSG:BC
                0;255;3;0;9;52372 TSF:MSG:FPAR REQ,ID=255
                0;255;3;0;9;52372 TSF:CKU:OK,FCTRL
                0;255;3;0;9;52372 TSF:MSG:GWL OK
                0;255;3;0;9;52522 THA:SND:MSG=0000FF0A2308FF00
                0;255;3;0;9;52522 RF24:SPL
                0;255;3;0;9;52523 RF24:WBR:REG=0,VAL=14
                0;255;3;0;9;52523 RF24:OWP:RCPT=255
                0;255;3;0;9;52523 RF24:WBR:REG=10,VAL=255
                0;255;3;0;9;52523 RF24:WBR:REG=16,VAL=255
                0;255;3;0;9;52524 RF24:TXM:TO=255,LEN=8
                0;255;3;0;9;52524 RF24:FTX
                0;255;3;0;9;52524 RF24:WBR:REG=4,VAL=80
                0;255;3;0;9;52526 RF24:WBR:REG=7,VAL=112
                0;255;3;0;9;52527 ?RF24:TXM:MAX_RT
                0;255;3;0;9;52527 RF24:FTX
                0;255;3;0;9;52527 RF24:WBR:REG=4,VAL=95
                0;255;3;0;9;52528 RF24:STL
                0;255;3;0;9;52528 RF24:WBR:REG=0,VAL=15
                0;255;3;0;9;52528 RF24:WBR:REG=10,VAL=0
                0;255;3;0;9;52528 THA:SND:MSG LEN=8,RES=1
                0;255;3;0;9;52529 ?TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
                Port closed
                T 2 Replies Last reply
                • magpernM magpern
                  @tekka
                  Port open
                   __  __       ____
                          |___/                      2.3.2-beta
                  28 TSM:INIT
                  30 TSF:WUR:MS=0
                  32 THA:INIT
                  36 RF24:SBY
                  73 RF24:FRX
                  73 RF24:FTX
                  77 TSM:INIT:TSP OK
                  79 TSM:FPAR
                  86 RF24:SPL
                  100 RF24:FTX
                  110 RF24:STL
                  2127 TSM:FPAR
                  2131 RF24:SPL
                  2148 RF24:FTX
                  2158 RF24:STL
                  4177 TSM:FPAR
                  4182 RF24:SPL
                  4198 RF24:FTX
                  4208 RF24:STL
                  6230 TSM:FPAR
                  6234 RF24:SPL
                  6250 RF24:FTX
                  6260 RF24:STL
                  8278 !TSM:FPAR:FAIL
                  8280 TSM:FAIL:CNT=1
                  8282 TSM:FAIL:DIS
                  8284 TSF:TDI:TSL
                  8284 RF24:SLP
                  18294 TSM:INIT
                  18296 THA:INIT
                  18300 RF24:SBY
                  18341 RF24:FRX
                  18343 RF24:FTX
                  18352 TSM:FPAR
                  18356 RF24:SPL
                  18374 RF24:FTX
                  18384 RF24:STL
                  20404 TSM:FPAR
                  20408 RF24:SPL
                  20426 RF24:FTX
                  20436 RF24:STL
                  22456 TSM:FPAR
                  22460 RF24:SPL
                  22478 RF24:FTX
                  22489 RF24:STL
                  24508 TSM:FPAR
                  24512 RF24:SPL
                  24530 RF24:FTX
                  24541 RF24:STL
                  26562 TSM:FAIL:DIS
                  26564 TSF:TDI:TSL
                  26566 RF24:SLP
                  36573 TSM:INIT
                  36575 THA:INIT
                  36579 RF24:SBY
                  36620 RF24:FRX
                  36622 RF24:FTX
                  36630 TSM:FPAR
                  36634 RF24:SPL
                  36653 RF24:FTX
                  36663 RF24:STL
                  38682 TSM:FPAR
                  38686 RF24:SPL
                  38705 RF24:FTX
                  38715 RF24:STL
                  40734 TSM:FPAR
                  40738 RF24:SPL
                  40757 RF24:FTX
                  40767 RF24:STL
                  42786 TSM:FPAR
                  42790 RF24:SPL
                  42809 RF24:FTX
                  42819 RF24:STL
                  Port closed
                  Port open
                  Port closed
                  T Offline
                  T Offline
                  tekka
                  @magpern said in Device and gateway see each other, but not regestering:
                  @tekka
                  In your first post you mentioned:
                  So you can confirm that the sensebender GW communicates with other nodes? I'd like to narrow down the issue to the actual node.
                  • magpernM magpern
                    @tekka
                    Port open
                     __  __       ____
                            |___/                      2.3.2-beta
                    28 TSM:INIT
                    30 TSF:WUR:MS=0
                    32 THA:INIT
                    36 RF24:SBY
                    73 RF24:FRX
                    73 RF24:FTX
                    77 TSM:INIT:TSP OK
                    79 TSM:FPAR
                    86 RF24:SPL
                    100 RF24:FTX
                    110 RF24:STL
                    2127 TSM:FPAR
                    2131 RF24:SPL
                    2148 RF24:FTX
                    2158 RF24:STL
                    4177 TSM:FPAR
                    4182 RF24:SPL
                    4198 RF24:FTX
                    4208 RF24:STL
                    6230 TSM:FPAR
                    6234 RF24:SPL
                    6250 RF24:FTX
                    6260 RF24:STL
                    8278 !TSM:FPAR:FAIL
                    8280 TSM:FAIL:CNT=1
                    8282 TSM:FAIL:DIS
                    8284 TSF:TDI:TSL
                    8284 RF24:SLP
                    18294 TSM:INIT
                    18296 THA:INIT
                    18300 RF24:SBY
                    18341 RF24:FRX
                    18343 RF24:FTX
                    18352 TSM:FPAR
                    18356 RF24:SPL
                    18374 RF24:FTX
                    18384 RF24:STL
                    20404 TSM:FPAR
                    20408 RF24:SPL
                    20426 RF24:FTX
                    20436 RF24:STL
                    22456 TSM:FPAR
                    22460 RF24:SPL
                    22478 RF24:FTX
                    22489 RF24:STL
                    24508 TSM:FPAR
                    24512 RF24:SPL
                    24530 RF24:FTX
                    24541 RF24:STL
                    26562 TSM:FAIL:DIS
                    26564 TSF:TDI:TSL
                    26566 RF24:SLP
                    36573 TSM:INIT
                    36575 THA:INIT
                    36579 RF24:SBY
                    36620 RF24:FRX
                    36622 RF24:FTX
                    36630 TSM:FPAR
                    36634 RF24:SPL
                    36653 RF24:FTX
                    36663 RF24:STL
                    38682 TSM:FPAR
                    38686 RF24:SPL
                    38705 RF24:FTX
                    38715 RF24:STL
                    40734 TSM:FPAR
                    40738 RF24:SPL
                    40757 RF24:FTX
                    40767 RF24:STL
                    42786 TSM:FPAR
                    42790 RF24:SPL
                    42809 RF24:FTX
                    42819 RF24:STL
                    Port closed
                    Port open
                    Port closed
                    T Offline
                    T Offline
                    tekka
                    @magpern One more thing - please re-run the test with my sketch uploaded to your node and adding
                    #define MY_NODE_ID 100
                    before the MySensors include, and an unmodified GW serial sketch from the example folder. Please post again both logs here.
                    • T tekka
                      @tekka
                      magpernM Offline
                      magpernM Offline
                      magpern
                      @tekka said in Device and gateway see each other, but not regestering:
                      @tekka
                      Yes, that was 3 days ago. I have been trying for 3 days. I don't have many MySensors devices. But, three days ago, I was finished with the temp sensor device this and they all worked fine.
                      However, a temp sensor in passive mode with a set node id and it is giving the gateway data, data that shows up in eg. Domoticz. At that time I thought the gateway and device worked fine.
                      I continued to build two more devices, regular atmega328 devices. One is a relay with buttons. The relay is not passive and one should be able to alter its state from eg. Domoticz. So it requires two-way communication.
                      And it is this part that fail.
                      • T tekka
                        magpernM Offline
                        magpernM Offline
                        magpern
                        Device
                        Opening port
                        Port open
                         __  __       ____
                                |___/                      2.3.2-beta
                        28 TSM:INIT
                        30 TSF:WUR:MS=0
                        32 THA:INIT
                        36 RF24:SBY
                        73 RF24:FRX
                        73 RF24:FTX
                        77 TSM:INIT:TSP OK
                        79 TSM:INIT:STATID=100
                        83 THA:SAD:ADDR=100
                        86 RF24:WBR:REG=2,VAL=3
                        88 RF24:WBR:REG=1,VAL=1
                        90 RF24:STL
                        92 RF24:WBR:REG=0,VAL=15
                        94 RF24:WBR:REG=10,VAL=100
                        96 TSF:SID:OK,ID=100
                        100 TSM:FPAR
                        100 THA:SND:MSG=6464FF020307FF
                        104 RF24:SPL
                        106 RF24:WBR:REG=0,VAL=14
                        108 RF24:OWP:RCPT=255
                        110 RF24:WBR:REG=10,VAL=255
                        114 RF24:WBR:REG=16,VAL=255
                        116 RF24:TXM:TO=255,LEN=7
                        118 RF24:FTX
                        120 RF24:WBR:REG=4,VAL=80
                        124 RF24:WBR:REG=7,VAL=112
                        129 ?RF24:TXM:MAX_RT
                        131 RF24:FTX
                        133 RF24:WBR:REG=4,VAL=95
                        135 RF24:STL
                        137 RF24:WBR:REG=0,VAL=15
                        139 RF24:WBR:REG=10,VAL=100
                        141 THA:SND:MSG LEN=7,RES=1
                        145 ?TSF:MSG:SEND,100-100-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                        2154 !TSM:FPAR:NO REPLY
                        2156 TSM:FPAR
                        2158 THA:SND:MSG=6464FF020307FF
                        2160 RF24:SPL
                        2162 RF24:WBR:REG=0,VAL=14
                        2164 RF24:OWP:RCPT=255
                        2168 RF24:WBR:REG=10,VAL=255
                        2170 RF24:WBR:REG=16,VAL=255
                        2174 RF24:TXM:TO=255,LEN=7
                        2177 RF24:FTX
                        2179 RF24:WBR:REG=4,VAL=80
                        2183 RF24:WBR:REG=7,VAL=112
                        2187 ?RF24:TXM:MAX_RT
                        2189 RF24:FTX
                        2191 RF24:WBR:REG=4,VAL=95
                        2193 RF24:STL
                        2195 RF24:WBR:REG=0,VAL=15
                        2197 RF24:WBR:REG=10,VAL=100
                        2201 THA:SND:MSG LEN=7,RES=1
                        2203 ?TSF:MSG:SEND,100-100-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                        4212 !TSM:FPAR:NO REPLY
                        4214 TSM:FPAR
                        4216 THA:SND:MSG=6464FF020307FF
                        4218 RF24:SPL
                        4220 RF24:WBR:REG=0,VAL=14
                        4222 RF24:OWP:RCPT=255
                        4227 RF24:WBR:REG=10,VAL=255
                        4229 RF24:WBR:REG=16,VAL=255
                        4233 RF24:TXM:TO=255,LEN=7
                        4235 RF24:FTX
                        4237 RF24:WBR:REG=4,VAL=80
                        4241 RF24:WBR:REG=7,VAL=112
                        4245 ?RF24:TXM:MAX_RT
                        4247 RF24:FTX
                        4249 RF24:WBR:REG=4,VAL=95
                        4251 RF24:STL
                        4253 RF24:WBR:REG=0,VAL=15
                        4255 RF24:WBR:REG=10,VAL=100
                        4259 THA:SND:MSG LEN=7,RES=1
                        4261 ?TSF:MSG:SEND,100-100-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                        6273 !TSM:FPAR:NO REPLY
                        6275 TSM:FPAR
                        6277 THA:SND:MSG=6464FF020307FF
                        6279 RF24:SPL
                        6281 RF24:WBR:REG=0,VAL=14
                        6283 RF24:OWP:RCPT=255
                        6287 RF24:WBR:REG=10,VAL=255
                        6289 RF24:WBR:REG=16,VAL=255
                        6293 RF24:TXM:TO=255,LEN=7
                        6295 RF24:FTX
                        6297 RF24:WBR:REG=4,VAL=80
                        6301 RF24:WBR:REG=7,VAL=112
                        6305 ?RF24:TXM:MAX_RT
                        6307 RF24:FTX
                        6309 RF24:WBR:REG=4,VAL=95
                        6311 RF24:STL
                        6313 RF24:WBR:REG=0,VAL=15
                        6316 RF24:WBR:REG=10,VAL=100
                        6320 THA:SND:MSG LEN=7,RES=1
                        6322 ?TSF:MSG:SEND,100-100-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                        8331 !TSM:FPAR:FAIL
                        8333 TSM:FAIL:CNT=1
                        8335 TSM:FAIL:DIS
                        8337 TSF:TDI:TSL
                        8337 RF24:SLP
                        8339 RF24:WBR:REG=0,VAL=12
                        18345 TSM:FAIL:RE-INIT
                        18348 TSM:INIT
                        18350 THA:INIT
                        18350 RF24:INIT:PIN,CE=9,CS=10
                        18354 RF24:SBY
                        18356 RF24:WBR:REG=0,VAL=14
                        18364 RF24:WBR:REG=3,VAL=3
                        18366 RF24:WBR:REG=4,VAL=95
                        18368 RF24:WBR:REG=5,VAL=76
                        18372 RF24:WBR:REG=6,VAL=7
                        18374 RF24:WBR:REG=29,VAL=4
                        18378 RF24:RBR:REG=29,VAL=4
                        18380 RF24:RBR:REG=6,VAL=7
                        18384 RF24:RBR:REG=5,VAL=76
                        18386 RF24:WBR:REG=2,VAL=2
                        18391 RF24:WBR:REG=1,VAL=0
                        18393 RF24:WBR:REG=28,VAL=3
                        18395 RF24:FRX
                        18397 RF24:FTX
                        18399 RF24:WBR:REG=7,VAL=112
                        18403 TSM:INIT:TSP OK
                        18405 TSM:INIT:STATID=100
                        18407 THA:SAD:ADDR=100
                        18409 RF24:WBR:REG=2,VAL=3
                        18413 RF24:WBR:REG=1,VAL=1
                        18415 RF24:STL
                        18417 RF24:WBR:REG=0,VAL=15
                        18421 RF24:WBR:REG=10,VAL=100
                        18423 TSF:SID:OK,ID=100
                        18425 TSM:FPAR
                        18427 THA:SND:MSG=6464FF020307FF
                        18432 RF24:SPL
                        18434 RF24:WBR:REG=0,VAL=14
                        18436 RF24:OWP:RCPT=255
                        18440 RF24:WBR:REG=10,VAL=255
                        18442 RF24:WBR:REG=16,VAL=255
                        18446 RF24:TXM:TO=255,LEN=7
                        18448 RF24:FTX
                        18450 RF24:WBR:REG=4,VAL=80
                        18456 RF24:WBR:REG=7,VAL=112
                        18458 ?RF24:TXM:MAX_RT
                        18460 RF24:FTX
                        18462 RF24:WBR:REG=4,VAL=95
                        18466 RF24:STL
                        18466 RF24:WBR:REG=0,VAL=15
                        18470 RF24:WBR:REG=10,VAL=100
                        18475 THA:SND:MSG LEN=7,RES=1
                        18477 ?TSF:MSG:SEND,100-100-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                        20486 !TSM:FPAR:NO REPLY
                        20488 TSM:FPAR
                        20490 THA:SND:MSG=6464FF020307FF
                        20492 RF24:SPL
                        20494 RF24:WBR:REG=0,VAL=14
                        20498 RF24:OWP:RCPT=255
                        20500 RF24:WBR:REG=10,VAL=255
                        20504 RF24:WBR:REG=16,VAL=255
                        20506 RF24:TXM:TO=255,LEN=7
                        20510 RF24:FTX
                        20512 RF24:WBR:REG=4,VAL=80
                        20516 RF24:WBR:REG=7,VAL=112
                        20518 ?RF24:TXM:MAX_RT
                        20523 RF24:FTX
                        20525 RF24:WBR:REG=4,VAL=95
                        20527 RF24:STL
                        20529 RF24:WBR:REG=0,VAL=15
                        20531 RF24:WBR:REG=10,VAL=100
                        20535 THA:SND:MSG LEN=7,RES=1
                        20537 ?TSF:MSG:SEND,100-100-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                        22546 !TSM:FPAR:NO REPLY
                        22548 TSM:FPAR
                        22550 THA:SND:MSG=6464FF020307FF
                        22552 RF24:SPL
                        22554 RF24:WBR:REG=0,VAL=14
                        22558 RF24:OWP:RCPT=255
                        22560 RF24:WBR:REG=10,VAL=255
                        22564 RF24:WBR:REG=16,VAL=255
                        22566 RF24:TXM:TO=255,LEN=7
                        22571 RF24:FTX
                        22573 RF24:WBR:REG=4,VAL=80
                        22577 RF24:WBR:REG=7,VAL=112
                        22579 ?RF24:TXM:MAX_RT
                        22583 RF24:FTX
                        22585 RF24:WBR:REG=4,VAL=95
                        22587 RF24:STL
                        22589 RF24:WBR:REG=0,VAL=15
                        22591 RF24:WBR:REG=10,VAL=100
                        22595 THA:SND:MSG LEN=7,RES=1
                        22597 ?TSF:MSG:SEND,100-100-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                        24608 !TSM:FPAR:NO REPLY
                        24610 TSM:FPAR
                        24612 THA:SND:MSG=6464FF020307FF
                        24614 RF24:SPL
                        24616 RF24:WBR:REG=0,VAL=14
                        24621 RF24:OWP:RCPT=255
                        24623 RF24:WBR:REG=10,VAL=255
                        24627 RF24:WBR:REG=16,VAL=255
                        24629 RF24:TXM:TO=255,LEN=7
                        24633 RF24:FTX
                        24635 RF24:WBR:REG=4,VAL=80
                        24639 RF24:WBR:REG=7,VAL=112
                        24641 ?RF24:TXM:MAX_RT
                        24645 RF24:FTX
                        24647 RF24:WBR:REG=4,VAL=95
                        24649 RF24:STL
                        24651 RF24:WBR:REG=0,VAL=15
                        24653 RF24:WBR:REG=10,VAL=100
                        24657 THA:SND:MSG LEN=7,RES=1
                        24659 ?TSF:MSG:SEND,100-100-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                        26671 !TSM:FPAR:FAIL
                        26673 TSM:FAIL:CNT=2
                        26675 TSM:FAIL:DIS
                        26677 TSF:TDI:TSL
                        26679 RF24:SLP
                        26681 RF24:WBR:REG=0,VAL=12
                        Port closed
                        Gateway
                        Opening port
                        Port open
                        0;255;3;0;9;56706 MCO:BGN:INIT GW,CP=RNNGS---,FQ=48,REL=7,VER=2.3.2-beta
                        0;255;3;0;9;56735 TSF:LRT:OK
                        0;255;3;0;9;56736 TSM:INIT
                        0;255;3;0;9;56737 TSF:WUR:MS=0
                        0;255;3;0;9;56742 TSM:INIT:TSP OK
                        0;255;3;0;9;56743 TSM:INIT:GW MODE
                        0;255;3;0;9;56743 TSM:READY:ID=0,PAR=0,DIS=0
                        0;255;3;0;9;56743 MCO:REG:NOT NEEDED
                        0;255;3;0;9;56744 MCO:BGN:STP
                        0;255;3;0;9;56744 MCO:BGN:INIT OK,TSP=1
                        0;255;3;0;9;56744 TSM:READY:NWD REQ
                        0;255;3;0;9;56747 ?TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=20,pt=0,l=0,sg=0,ft=0,st=OK:
                        0;255;3;0;9;71425 TSF:MSG:READ,100-100-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
                        0;255;3;0;9;71425 TSF:MSG:BC
                        0;255;3;0;9;71425 TSF:MSG:FPAR REQ,ID=100
                        0;255;3;0;9;71426 TSF:PNG:SEND,TO=0
                        0;255;3;0;9;71426 TSF:CKU:OK
                        0;255;3;0;9;71426 TSF:MSG:GWL OK
                        0;255;3;0;9;72225 !TSF:MSG:SEND,0-0-100-100,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=NACK:0
                        0;255;3;0;9;73459 TSF:MSG:READ,100-100-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
                        0;255;3;0;9;73459 TSF:MSG:BC
                        0;255;3;0;9;73459 TSF:MSG:FPAR REQ,ID=100
                        0;255;3;0;9;73460 TSF:CKU:OK,FCTRL
                        0;255;3;0;9;73460 TSF:MSG:GWL OK
                        0;255;3;0;9;74245 !TSF:MSG:SEND,0-0-100-100,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=NACK:0
                        0;255;3;0;9;75493 TSF:MSG:READ,100-100-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
                        0;255;3;0;9;75493 TSF:MSG:BC
                        0;255;3;0;9;75494 TSF:MSG:FPAR REQ,ID=100
                        0;255;3;0;9;75494 TSF:CKU:OK,FCTRL
                        0;255;3;0;9;75494 TSF:MSG:GWL OK
                        0;255;3;0;9;76265 !TSF:MSG:SEND,0-0-100-100,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=NACK:0
                        0;255;3;0;9;77529 TSF:MSG:READ,100-100-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
                        0;255;3;0;9;77530 TSF:MSG:BC
                        0;255;3;0;9;77530 TSF:MSG:FPAR REQ,ID=100
                        0;255;3;0;9;77530 TSF:CKU:OK,FCTRL
                        0;255;3;0;9;77530 TSF:MSG:GWL OK
                        0;255;3;0;9;78291 !TSF:MSG:SEND,0-0-100-100,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=NACK:0
                        0;255;3;0;9;89535 TSF:MSG:READ,100-100-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
                        0;255;3;0;9;89536 TSF:MSG:BC
                        0;255;3;0;9;89536 TSF:MSG:FPAR REQ,ID=100
                        0;255;3;0;9;89536 TSF:PNG:SEND,TO=0
                        0;255;3;0;9;89537 TSF:CKU:OK
                        0;255;3;0;9;89537 TSF:MSG:GWL OK
                        0;255;3;0;9;90015 !TSF:MSG:SEND,0-0-100-100,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=NACK:0
                        0;255;3;0;9;91572 TSF:MSG:READ,100-100-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
                        0;255;3;0;9;91572 TSF:MSG:BC
                        0;255;3;0;9;91573 TSF:MSG:FPAR REQ,ID=100
                        0;255;3;0;9;91574 TSF:CKU:OK,FCTRL
                        0;255;3;0;9;91574 TSF:MSG:GWL OK
                        0;255;3;0;9;92042 !TSF:MSG:SEND,0-0-100-100,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=NACK:0
                        0;255;3;0;9;93608 TSF:MSG:READ,100-100-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
                        0;255;3;0;9;93609 TSF:MSG:BC
                        0;255;3;0;9;93609 TSF:MSG:FPAR REQ,ID=100
                        0;255;3;0;9;93609 TSF:CKU:OK,FCTRL
                        0;255;3;0;9;93609 TSF:MSG:GWL OK
                        0;255;3;0;9;94065 !TSF:MSG:SEND,0-0-100-100,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=NACK:0
                        0;255;3;0;9;95647 TSF:MSG:READ,100-100-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
                        0;255;3;0;9;95647 TSF:MSG:BC
                        0;255;3;0;9;95648 TSF:MSG:FPAR REQ,ID=100
                        0;255;3;0;9;95648 TSF:CKU:OK,FCTRL
                        0;255;3;0;9;95648 TSF:MSG:GWL OK
                        0;255;3;0;9;96093 !TSF:MSG:SEND,0-0-100-100,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=NACK:0
                        Port closed
                        • magpernM Offline
                          magpernM Offline
                          magpern
                          [SOLVED]
                          After a one-on-one with @tekka we found that the problem was a very simple one.
                          The default channel 76 was noisy. I change channel to 90 and the Gateway and device could talk two-way communication
                          I did a WIFI scan an see that wifi 2.4g channel 11 is used by someone close to me (I am channel 2)
                          Wifi Channel 11 is almost in the mid of channel 76 (nRF24)
                          J 1 Reply Last reply
                          • magpernM magpern
                            [SOLVED]
                            J Offline
                            J Offline
                            Jens Jensen
                            @magpern glad to see you got it fixed, however I don't think wifi channel 11 interferes with channel 76, which is at 2476 MHz.
                            Maybe there are some other sources of interference on nrf channel 76 in your environment?
                            • J Jens Jensen
                              magpernM Offline
                              magpernM Offline
                              magpern
                              @jens-jensen said in [Solved] Device and gateway see each other, but not regestering:
                              I don't know. Wifi channel 12 is in the channel 76 nrf rage though, maybe they bleed?
                              Except from getting a Mesh network and three pairs of bluetooth headphones there is nothing new.
                              • magpernM magpern
                                J Offline
                                J Offline
                                Jens Jensen
                                wrote on last edited by Jens Jensen
                                @magpern
                                for others trying to find a good channel, I found this useful showing Wifi and BLE channels. (Orange are BLE advertising channels, which should always be reserved/unoccupied by NRF stuff):
                                wifi-bluetooth-channels
                                Yes I think wifi channels >11 (like 12,13,14 overlap to 2476).
                                So sometimes nrf channel 1 is a good choice, but as always, depends on your environment ;)
                                Do you have wireless mice, keyboards, etc - many of these use NRF24 or similar 2.4GHz ISM? Are you sure the other 2.4GHz devices are really bluetooth and not proprietary?
