  3. Soil Moisture Sensor / analog value
18 Posts 3 Posters 2.9k Views 3 Watching
  • alowhumA
    alowhumA
    alowhum
    I take it you modified the code, right?
    For example, the code I shared has encryption built in, etc.
    • k5austriaK
      k5austriaK
      k5austria
      I have not changed anything. I'm not so good with code. Which part should I change?
      • alowhumA
        alowhumA
        alowhum
        remove:
        #define HAS_SCREEN            // Have you connected a screen?
        #define MY_SECURITY_SIMPLE_PASSWD "changeme"        // Be aware, the length of the password has an effect on memory use.
        And change #define NUMBER_OF_SENSORS 6 to the number of sensors you have attached to pin A0, A1, A2, etc.
        • k5austriaK
          k5austriaK
          k5austria
          I changed code but it still does not work.
           * This node can measure the moisture of 6 different plants. It uses the cheap 'capacitive analog
           * moisture sensor' that you can get for about 3 dollars an Aliexpress or eBay. For example:
           * https://www.aliexpress.com/item/Analog-Capacitive-Soil-Moisture-Sensor-V1-2-Corrosion-Resistant-Z09-Drop-ship/32858273308.html
           * Each plant' moisture value can also be responded to individually, either by turning on an LED (wire that to the plan, and you can see which one is thirsty) or, if you want, per-plant automated irrigation by connecting a little solenoid..
           * SETTINGS */
          #define NUMBER_OF_SENSORS 1   // How many moisture sensors are connected?
          #define SLEEPTIME 100         // How many seconds should pass between checking on the plants? Don't make this less than 15 or more than 255.
           /* END OF SETTINGS
          // Enable MySensors debug prints to serial monitor
          #define MY_RADIO_RF24
          //#define MY_RADIO_NRF5_ESB
          //#define MY_RADIO_RFM95
          // Set LOW transmit power level as default, if you have an amplified NRF-module and power your radio separately with a good regulator you can turn up PA level. Choose one:
          //#define MY_RF24_PA_LEVEL RF24_PA_MIN
          //#define MY_RF24_PA_LEVEL RF24_PA_MAX
          // Easy to use security, yay!
          //#define MY_SIGNING_SOFT_RANDOMSEED_PIN A7         // setting a pin to pickup noise makes encryption more secure.
          // Advanced features
          #define MY_TRANSPORT_WAIT_READY_MS 10000            // try connecting for 10 seconds. Otherwise just continue.
          //#define MY_RF24_CHANNEL 100                       // in EU the default channel 76 overlaps with wifi.
          //#define MY_RF24_DATARATE RF24_1MBPS               // slower datarate makes the network more stable?
          //#define MY_NODE_ID 13                             // giving a node a manual ID can in rare cases fix connection issues.
          //#define MY_PARENT_NODE_ID 0                       // fixating the ID of the gatewaynode can in rare cases fix connection issues.
          //#define MY_PARENT_NODE_IS_STATIC                  // Used together with setting the parent node ID. Daking the controller ID static can in rare cases fix connection issues.
          //#define MY_SPLASH_SCREEN_DISABLED                   // saves a little memory.
          //#define MY_DISABLE_RAM_ROUTING_TABLE_FEATURE      // saves a little memory.
          // FURTHER SETTINGS
          #define IRRIGATION_RELAYS 6                         // How many irrigation relays are connected?
          #define SLEEPTIME 100                               // In seconds, how often should a measurement be made and sent to the server? The maximum delay between measurements is once every 254 seconds, but if you change "byte" to "int" further down in the code you could create more time between each loop.
          #define LOOPDURATION 5000                           // The main loop runs every x milliseconds. This main loop starts the modem, and from then on periodically requests the password.
          #define RF_DELAY 100                                // Milliseconds betweeen radio signals during the presentation phase.
          // Do you want this node to also be a repeater?
          #define MY_REPEATER_FEATURE                         // Just add or remove the two slashes at the beginning of this line to select if you want this sensor to act as a repeater for other sensors. If this node is on battery power, you probably shouldn't enable this. Otherwise it's smart to make every node also a repeater.
          // Do not change below this line
          #ifdef HAS_SCREEN
          #include <SoftwareSerial.h>
          SoftwareSerial mySerial(7,6);                       // RX, TX
          static const uint8_t analog_pins[] = {A0,A1,A2,A3,A4,A5};
          byte moistureLevels[6] = {1, 2, 3, 4, 5, 6};
          byte moistureThresholds[6] = {35, 35, 35, 35, 35, 35}; // for each plant we can have a unique moisture level to compare against.
          MyMessage thresholdMsg(0, V_PERCENTAGE);            // used to create a dimmer on the controller that controls the mosture threshold;
          MyMessage msg(0, V_LEVEL);                          // used to send moisture level data to the gateway
          //const char xxxx = "hello";
          //const char ids[7] = "112233445566";
          void before()
            //for (byte i = 3; i < NUMBER_OF_SENSORS + 3; i++){ // Set the LED (or irrigation vales) to their initial position. Because Mysensors uses pin 2, we use pin 3 till 8 as output.
            //  pinMode(i, OUTPUT);
            //  digitalWrite(i, LOW);
            sendSketchInfo(F("Plant Health"), F("1.3"));  wait(RF_DELAY);
            // Present the sensors
            //for (byte i=0; i<NUMBER_OF_SENSORS*2 ; i=i+2) {
              present(0, S_MOISTURE, "1");  wait(RF_DELAY);       // present all the sensors
              present(1, S_DIMMER, "1");  wait(RF_DELAY);       // present the dimmers to set the level with.
              present(2, S_MOISTURE, "2");  wait(RF_DELAY);       // present all the sensors
              present(3, S_DIMMER, "2");  wait(RF_DELAY);       // present the dimmers to set the level with.
              present(4, S_MOISTURE, "3");  wait(RF_DELAY);       // present all the sensors
              present(5, S_DIMMER, "3");  wait(RF_DELAY);       // present the dimmers to set the level with.
              present(6, S_MOISTURE, "4");  wait(RF_DELAY);       // present all the sensors
              present(7, S_DIMMER, "4");  wait(RF_DELAY);       // present the dimmers to set the level with.
              present(8, S_MOISTURE, "5");  wait(RF_DELAY);       // present all the sensors
              present(9, S_DIMMER, "5");  wait(RF_DELAY);       // present the dimmers to set the level with.
              present(10, S_MOISTURE, "6");  wait(RF_DELAY);       // present all the sensors
              present(11, S_DIMMER, "6");  wait(RF_DELAY);       // present the dimmers to set the level with.
            Serial.begin(115200);                             // Start serial output of data.
            while (!Serial) {}                                // Wait for serial connection to be initiated
            Serial.println(F("Hello world"));
            //Serial.print("ids-"); Serial.println(ids[1]);
            // Setup pins for input
            //for (byte i = 15; i < 21; i++) {
            for (int i = 0; i < NUMBER_OF_SENSORS; i++) { //or i <= 5
              pinMode(analog_pins[i], INPUT); // experimental new: added the pullup.
               wait(1);
          #ifdef HAS_SCREEN
            mySerial.begin(115200);
            //wait(1500);
            //mySerial.print("RESET;");
            wait(1500);
            mySerial.print("CLR(0);");
            mySerial.print("BOXF(0,0,128,18,15);");
            mySerial.print("DCV16(5,1,Plant health, 10);");
            if(isTransportReady()){
              mySerial.print("DCV16(115,1,w,0);");
            for (byte i=0; i<NUMBER_OF_SENSORS ; i++) {
              byte verticalPosition = i*18+28;
              mySerial.print("BOXF(3," + String(verticalPosition) + ",124," + String(verticalPosition + 16) + ",15);");
              mySerial.print("DCV16(5," + String(verticalPosition) + ",A" + i + ",0);");
            mySerial.println();
            wait(500);
            // load the threshold level from the built-in EEPROM memory.
              moistureThresholds[i] = loadState(i);
              if(moistureThresholds[i] > 99){moistureThresholds[i] = 35;}
              Serial.print(F("Loaded: ")); Serial.println(moistureThresholds[i]);
            Serial.println(F("Warming up the sensors (15 seconds).")); // to avoid weird measurements
            wait(15000);
            request(1, V_PERCENTAGE ); wait(RF_DELAY); // to-do: only present the actually connected number of sensors.
            request(3, V_PERCENTAGE ); wait(RF_DELAY);
            request(5, V_PERCENTAGE ); wait(RF_DELAY);
            request(7, V_PERCENTAGE ); wait(RF_DELAY);
            request(9, V_PERCENTAGE ); wait(RF_DELAY);
            request(11, V_PERCENTAGE ); wait(RF_DELAY);
            wdt_enable(WDTO_8S);                              // Starts the watchdog timer. If it is not reset once every 2 seconds, then the entire device will automatically restart.
            // MAIN LOOP
            // Runs every few seconds. By counting how often this loop has run (and resetting that counter back to zero after 250 loops), it becomes possible to schedule all kinds of things without using a lot of memory.
            // Maximum time that can be scheduled is 4s * 250 loops = 1000 seconds. So the maximum time between sending data can be 16 minutes.
            static byte loopCounter = 0;                      // Counts the loops until the SLEEPTIME value has been reached. Then new data is sent to the controller.
            static boolean loopDone = false;                  // used to make sure the 'once every millisecond' things only run once every millisecond (or 2.. sometimes the millis() function skips a millisecond.);
            // Avoid the loop running at the speed of the processor (multiple times per millisecond). This entire construction saves memory by not using a long to store the last time the loop ran.
            if( (millis() % LOOPDURATION) > LOOPDURATION - 4 && loopDone == true ) {
              loopDone = false;
            // Main loop to time actions.
            if( (millis() % LOOPDURATION) < 4 && loopDone == false ) { // the 4 is just a precaution: sometimes the milli() function skips a millisecond. This ensure the loop code still runs in that rare case.
              loopDone = true;
              //loopCounter++;
              Serial.print(F("__loop_"));Serial.println(loopCounter);
              wdt_reset(); // Reset the watchdog timer
              byte selectedSensor = loopCounter % NUMBER_OF_SENSORS;
              Serial.print(F("_modulo:_")); Serial.println(selectedSensor);
              //for (byte i=0; i<NUMBER_OF_SENSORS; i++){         // loop over all the sensors.
                int16_t moistureLevel = analogRead(analog_pins[selectedSensor]);
                Serial.print(F(" moisture level (pre): "));
                Serial.println(moistureLevel);
                if(moistureLevel > 700){moistureLevel = 700;}
                moistureLevel = map(moistureLevel,0,700,0,99); // The maximum voltage output of the capacitive sensor is 3V, so since we're measuring 0-5v about 614 is the highest value we'll ever get.
                Serial.print(selectedSensor);
                Serial.print(F(" moisture level %: "));
                //if(moistureLevels[selectedSensor] != moistureLevel){
                //byte dimmerID = selectedSensor + 1; //(selectedSensor*2)+1;
                //Serial.print(F("Requesting dimmer ")); Serial.println(dimmerID);
                // request(dimmerID, V_DIMMER ); // from now on we let the server push the value.
                moistureLevels[selectedSensor] = moistureLevel;
          #ifdef HAS_SCREEN
                drawItem(selectedSensor);
                //if(digitalRead(shiftedDigitalPin) == HIGH){  // outputs the LED/irrigation status via serial. This code can be removed.
                //  Serial.print(F("- currently watering until "));
                //  Serial.println(moistureThresholds[selectedSensor] + 10);
                // TO-DO actuator
                // byte shiftedDigitalPin = selectedSensor + 3;
                if( moistureLevel < moistureThresholds[selectedSensor] ){   // if the plant doesn' have enough water, turn on the LED/water.
                  Serial.print(F("- moisture level is below ")); Serial.println(moistureThresholds[selectedSensor]);
                  //digitalWrite(shiftedDigitalPin, HIGH);
                }else if (moistureLevel >= moistureThresholds[selectedSensor] + 10){  // turn of the water/led if the plant is wet enough.
                  //digitalWrite(shiftedDigitalPin, LOW);
                if(loopCounter == 0){
                  // Whole dealing with the first sensor we also do a check if the server is responding ok. It it doesn't respond, remove the connection icon.
                  if(send(msg.setSensor(selectedSensor*2).set(moistureLevel),1)){ // ask for a receipt
                    Serial.println(F("Connection is ok"));
          #ifdef HAS_DISPLAY
                    // add W icon
                    mySerial.print(F("DCV16(115,1,w,0);"));
                  }else {
                    Serial.println(F("Connection lost"));
          #ifdef HAS_DISPLAY
                    // remove W icon
                    mySerial.print(F("DCV16(115,1, ,0);"));
                } else if(loopCounter < NUMBER_OF_SENSORS){       // During the first few loops the script will send updated data.
                  if(loopCounter == selectedSensor){                           // It sends sensor 0 at second 0. Sensor 1 at second 1, etc. This keeps the radio happy.
                    Serial.println(F("- sending data."));
                    send(msg.setSensor(selectedSensor*2).set(moistureLevel));  // 0, 2, 4 etc
              loopCounter++;
              if(loopCounter >= SLEEPTIME){                       // If enough time has passed, the counter is reset, and new data is sent.
                loopCounter = 0;
            Serial.print(F("<- message for child #")); Serial.println(message.sensor);
            if (message.type == V_PERCENTAGE) {
              Serial.print(F("Requested level is "));
              Serial.println( requestedLevel );
              byte sensorID = (message.sensor - 1) / 2;
              // requestedLevel *= ( message.type == V_LIGHT ? 100 : 1 );
              //if(message.sensor == ROTATING_PASSWORD2_ID){
              Serial.print(F("Before clipping requested level: "));
              //requestedLevel = requestedLevel > 100 ? 100 : requestedLevel;
              //requestedLevel = requestedLevel < 0   ? 0   : requestedLevel;
              if(requestedLevel > 100){ requestedLevel = 100;}
              if(requestedLevel < 0){ requestedLevel = 0;}
              if(requestedLevel < 1 ||  requestedLevel > 99){
              }else{
                Serial.print(F("Changing level to "));
                Serial.print( byte(requestedLevel) );
                Serial.print(F(", from "));
                Serial.println( moistureThresholds[sensorID] );
                moistureThresholds[sensorID] = byte(requestedLevel);
                saveState(sensorID, moistureThresholds[sensorID]);
                //drawItem(sensorID); // Finally, update the screen.
              //send(lightMsg.set(currentLevel > 0));
              // hek comment: Is this really nessesary?
              //send( dimmerMsg.set(currentLevel) );
          #ifdef HAS_SCREEN
          void drawItem(byte selectedSensor)
            // Prepare variables to send to the screen.
            byte verticalPosition = selectedSensor*18+28;
            Serial.println(verticalPosition);
            byte color = 10;  // green
            String spacer = F("");
            if( moistureLevels[selectedSensor] < 10){spacer = F(" ");}
            if(moistureLevels[selectedSensor] <= moistureThresholds[selectedSensor]){ // set the font color. Red if the plan is thirsty.
              color = 1;      // red
            }else if(moistureLevels[selectedSensor] <= moistureThresholds[selectedSensor] + 5){ // black for normal
              color = 13;     // orange
            // Create graph
            Serial.print(F("/// Creating graph for: ")); Serial.println(selectedSensor);
            mySerial.print(F("BOXF(25,"));
            mySerial.print(String(verticalPosition + 1) + "," + String(25 + moistureLevels[selectedSensor])  + "," + String(verticalPosition + 16) + "," + String(color) + ");");
            mySerial.print("BOXF(" + String(25 + moistureLevels[selectedSensor] + 1) + ","  + String(verticalPosition + 1) + ",124," + String(verticalPosition + 16) + ",7);");
            mySerial.print("PL(" + String(25 + moistureThresholds[selectedSensor]) + "," + String(verticalPosition + 3) + "," + String(25 + moistureThresholds[selectedSensor])  + "," + String(verticalPosition + 14) + ",8);"); // Small vertical line that indicates the threshold
            mySerial.println("DCV16(5," + String(verticalPosition) + "," + String(spacer) + String(moistureLevels[selectedSensor]) + "," + String(color) + ");"); // Moisture level number on the left
            //mySerial.println();
            //String screenCommand = F("DCV16(5,");
            //screenCommand += String(verticalPosition) + F(" ,");
            //screenCommand += String(moistureLevel) + F(", ") + String(color) + F(");");
            //Serial.println(screenCommand);
            //mySerial.print(screenCommand);
            //wait(200);
          /* THANKS TO
          • k5austriaK
            k5austriaK
            k5austria
            That's from sensor:
            16 MCO:BGN:INIT REPEATER,CP=RNNRA---,REL=255,VER=2.3.1
            26 MCO:BGN:BFR
            28 TSM:INIT
            29 TSF:WUR:MS=10000
            35 !TSM:INIT:TSP FAIL
            37 TSM:FAIL:CNT=1
            39 TSM:FAIL:DIS
            40 TSF:TDI:TSL
            10030 MCO:BGN:STP
            Hello world
            Loaded: 35
            10042 TSM:FAIL:RE-INIT
            10044 TSM:INIT
            10050 !TSM:INIT:TSP FAIL
            10052 TSM:FAIL:CNT=2
            10054 TSM:FAIL:DIS
            10056 TSF:TDI:TSL
            20059 TSM:FAIL:RE-INIT
            20061 TSM:INIT
            20067 !TSM:INIT:TSP FAIL
            20069 TSM:FAIL:CNT=3
            20071 TSM:FAIL:DIS
            20073 TSF:TDI:TSL
            • k5austriaK
              k5austriaK
              k5austria
              This is from Gateway:
              0;255;3;0;9;0 MCO:BGN:INIT GW,CP=RNNGA---,REL=255,VER=2.3.1
              0;255;3;0;9;5 TSM:INIT
              0;255;3;0;9;7 TSF:WUR:MS=0
              0;255;3;0;9;14 TSM:INIT:TSP OK
              0;255;3;0;9;17 TSM:INIT:GW MODE
              0;255;3;0;9;20 TSM:READY:ID=0,PAR=0,DIS=0
              0;255;3;0;9;24 MCO:REG:NOT NEEDED
              0;255;0;0;18;2.3.1
              0;255;3;0;9;28 MCO:BGN:STP
              0;255;3;0;9;34 MCO:BGN:INIT OK,TSP=1
              0;255;3;0;9;37 TSM:READY:NWD REQ
              0;255;3;0;9;76 TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=20,pt=0,l=0,sg=0,ft=0,st=OK:
              • k5austriaK
                k5austriaK
                k5austria
                Gateway is ok. Other sensors are connected.
                • k5austriaK k5austria
                  @k5austria !TSM:INIT:TSP FAIL means that the node is unable to initialize the radio. Without radio initialization, the node cannot communicate.
                  Triple-check the radio wiring. Replace the radio module if possible. If you don't find a problem, post pictures of the wiring here and we'll help you.
                  If you haven't already, check out https://forum.mysensors.org/topic/666/debug-faq-and-how-ask-for-help/ for info on how to troubleshoot efficiently.
                  k5austriaK 1 Reply Last reply
                    k5austriaK
                    k5austriaK
                    k5austria
                    @mfalkvidd
                    Thank you for your answer !!!
                    You're right. Radio module was defective (every 3 pcs.). I got new ones today and now everything works fine. I still have some questions about code.
                    • Why do i get response from sensor every 8 minutes ?
                    • May I operate my cheap Aliexpress radio module (nRF24L01+PA+LNA) with MY_RF24_PA_LEVEL RF24_PA_MAX ? Power supply is enough.
                    k5austriaK mfalkviddM 2 Replies Last reply
                      @mfalkvidd
                      k5austriaK
                      k5austriaK
                      k5austria
                        @mfalkvidd
                        Nice work @k5austria
                        The code is a bit too complex for me to follow, so I can't guess why something happens every 8 minutes. Sorry.
                        • alowhumA
                          alowhumA
                          alowhum
                          What have you set as:
                          5000 * 1000 = 5.000.000 milliseconds between measurements = 8.33 minutes
                          Change the loopduration (how long a tick of the internal clock takes) to 1000, and then the SLEEPTIME variable is in normal seconds again.
                          • alowhumA
                            alowhumA
                            alowhum
                            @k5austria said in Soil Moisture Sensor / analog value:
                            In my experience this will fail.
                            • k5austriaK
                              k5austriaK
                              k5austria
                              Thanks guys ! Everything works fine .
