  2. Announcements
  3. 💬 Door, Window and Push-button Sensor
110 Posts 36 Posters 57.6k Views 32 Watching
  • tianaT
    tianaT
    tiana
    What will happen if i cut the power OFF of the radio after each transmission? is it needed to be initialize again before next transmission?
    • tianaT tiana
      @tiana yes.
      But don't cut the power. Use transportDisable and transportReInitialize instead.
      • tianaT
        tianaT
        tiana
        Do you know how much will be power usage in transportDisable mode?
        • tianaT tiana
          @tiana depends on which transport you are using, and if using genuine or clone chips. The nrf24 is rated for 900nA.
          • tianaT
            tianaT
            tiana
            Thanks for fast reply, actually 900nA is to big number and i prefer to use xxx_POWER_PIN to cut the power of the NRF module.
            I am building switch powered with CR2032 battery and i want to extend battery live as much as possible, for a switch is not needed to keep radio alive, i need it ON only when transmit signal
            • tianaT tiana
              #100
              @tiana 900nA on a cr2032 is 27.9 years battery life. The self discharge of a cr2032 is around 250nA.
              But yes, use the power pin setting if you want to.
              Would be interesting to see how long sleep times are needed to make up for the extra time needed to wake up the radio from power off compared to sleep. The mcu and the radio will need to be awake for 100ms longer time when starting from power off than when starting from sleep.
              • T
                Terence Faul
                Hi I notice that there is not sleep in this sketch. Is it not required for this build
                • T Terence Faul
                  @terence-faul the sketch will work as-is, as long as the node has a constant power supply. If you want a battery-powered node, you'll need sleep. See earlier discussions in this thread for ways to add sleep.
                  • pepsonP
                    pepsonP
                    pepson
                    Hi
                    Can i connect two sensor contact to this arduino ? First to pin 3 second to pin 4 ? But how modified this sketch to support two sensor contact ?
                    skywatchS 1 Reply Last reply
                    • pepsonP pepson
                      Hi
                      skywatchS
                      skywatchS
                      skywatch
                      @pepson If you need the node to sleep or want to use interrupts then only digital pins 2 and 3 will do this for uno/promini.
                      So otherwise 2 options really.
                      If you just need to know that one of the sensors triggered (but not which one) then you can add sensors in series (for normally 'closed' sensors) or parallel (for normally 'open' sensors).
                      To use interrupt and know which sensor triggered you'd have to connect both sensor to interrupt pin with blocking diodes to digital pins as well and then on interrupt you can check which digital pin activated the isr.
                      • pepsonP
                        pepsonP
                        pepson
                        I need connect two contact sensor. And i want to know from two sensor his status...
                        I need use one to door but second to door garage.
                        • pepsonP pepson
                          skywatchS
                          skywatchS
                          skywatch
                          #106
                          @pepson Then just add another sensor from ground to digital pin 2 and change the code you see in the example to accommodate the extra input.
                          You'll need to add another child id, another button, another bounce function, another presentation, another send and another bounce call.
                          pepsonP 1 Reply Last reply
                          • skywatchS skywatch
                            pepsonP
                            pepsonP
                            pepson
                            @skywatch
                            Yes but i dont know how do it.... :-(
                            I dont know programing.
                            Nca78N gohanG 2 Replies Last reply
                            • pepsonP pepson
                              @skywatch
                              @pepson said in 💬 Door, Window and Push-button Sensor:
                              @skywatch
                              Not an excuse, it's time for you to learn :)
                              • pepsonP pepson
                                @skywatch
                                @pepson then it is going to be quite difficult for you to work on DIY electronics projects if you don't how to program.
                                • I
                                  I
                                  iahim67
                                  Perhaps it would be good to update the example code. I mean the pull-up sequence:
                                  "It is recommended to set the pinMode() to INPUT_PULLUP to enable the internal pull-up resistor." - https://www.arduino.cc/reference/en/language/functions/digital-io/digitalwrite/
                                  The following seems to be obsolete:
                                  // Setup the button
                                  pinMode(BUTTON_PIN,INPUT);
                                  // Activate internal pull-up
