  3. Irrigation Controller miniboard
2 Posts 2 Posters 865 Views 2 Watching
  • J
    J
    Jesus Cataluña
    Hi everyone!! First of all thanks for all the fantastic stuff here with MySensors in general and the Irrigation Controller in particular.
    I've successfully deployed the controller in my garden with a modified version of the original project: I've added a 5V DC mini transformer and a minimal LCD. Hereunder you can see the homemade version of the pcb already installed controlling 7 sprinklers through HomeAssistant
    Now I'm in the process of creating an enhanced version of the board and the v1.0 is already ordered from a professional pcb manufacturer and must be at home in 4-5 days O_O.
    From the code point of view, I've moved to a simple state machine to make the code more easy to understand and extend. The integration between MySensors and HomeAssistant is not the best and it took a while to make them work together. My next move will be to add different programs from HomeAssitant (but I don't know when ;( )
    At the moment I'm releasing the schema and board if it's in the interest of someone:
    EasyEDA jcataluna
    Hope it helps ;)
    home made PCB
    • J Jesus Cataluña
      EasyEDA jcataluna
      Hope it helps ;)
      home made PCB
      Michał Szura
      @jesus-cataluña
      Hi great work!
      Any chance for your sketch? There isn't many working sketches (without many errors in log) for home assistant. Unfortunately I can't write code.
