  2. Bug Reports
  3. Strange value being sent from controller using mixed temp/relay node
multiple sensormqtterror
42 Posts 6 Posters 22.8k Views 3 Watching
  • gaduG
    gaduG
    gadu
    I'll get tomorrow. No worries :)
    • G
      G
      Gambituk
      Thanks! That would be really useful
      • gaduG
        gaduG
        gadu
        Here goes...
        This is the ProMini output from the monitor when I turn on and off the relay...
        send: 23-23-0-0 s=1,c=1,t=2,pt=2,l=2,st=ok:1
        read: 0-0-23 s=1,c=1,t=2,pt=2,l=2:1
        This is an ack from gateway
        Incoming change for sensor:1, New status: 1
        read: 0-0-23 s=1,c=1,t=2,pt=0,l=4:1.6r
        send: 23-23-0-0 s=1,c=1,t=2,pt=2,l=2,st=ok:0
        read: 0-0-23 s=1,c=1,t=2,pt=2,l=2:0
        Incoming change for sensor:1, New status: 0
        read: 0-0-23 s=1,c=1,t=2,pt=0,l=4:0.6r
        This what I see on the gateway when I turn on and off the relay....
        publish: MyMQTT/23/1/V_LIGHT 1
        0;0;3;0;9;send: 0-0-23-23 s=1,c=1,t=2,pt=0,l=4,st=ok:1sor
        0;0;3;0;9;read: 23-23-0 s=1,c=1,t=2,pt=2,l=2:0
        0;0;3;0;9;send: 0-0-23-23 s=1,c=1,t=2,pt=2,l=2,st=ok:0
        publish: MyMQTT/23/1/V_LIGHT 0
        0;0;3;0;9;send: 0-0-23-23 s=1,c=1,t=2,pt=0,l=4,st=ok:0sor
        0;0;3;0;9;read: 23-23-0 s=1,c=1,t=2,pt=2,l=2:1
        0;0;3;0;9;send: 0-0-23-23 s=1,c=1,t=2,pt=2,l=2,st=ok:1
        I hope it helps.
        • G
          G
          Gambituk
          wrote on last edited by Gambituk
          #31
          That's perfect, that shows clearly that the problem is coming from the gateway sketch. I assume that the r on the end of both your and my output's is a termination character, and everything between the (1/0) and the 'r' in the gateway serial output is 'debris' left over from a previous output.. (for me a previous temp reading, for you something ending in 'so' .
          With my workaround from yesterday:- (publishing something like this from openhab or wherever mysensor:MyMQTT/25/4/V_LIGHT:command:ON:1.0r <-1.0r instead of just 1) , my relay reacts really fast and accurately when triggered and continues to work. Before it was very slow and not reliable.
          I am not sure if i will find the cause and be able to correct it but at least there is a workaround.
          Thanks for your time @gadu
          • gaduG
            gaduG
            gadu
            No worries!
            • caycoC
              caycoC
              cayco
              wrote on last edited by cayco
              #33
              Hi! I'm starting to play with relay and I experiencing somethings similar. I have 3 sensors (two of them works great, just temperature, volt, light and humidity) one is relay sensor. First of all it just doesn't react to my commands:
              mosquitto_pub -p 1883 -h 10.0.0.11 -t MyMQTT/22/1/V_LIGHT -m "1"
              serial shows just this:
              connecting at 115200
              repeater started, id 22
              send: 22-22-0-0 s=255,c=0,t=18,pt=0,l=3,st=ok:1.4
              send: 22-22-0-0 s=255,c=3,t=6,pt=1,l=1,st=fail:0
              send: 22-22-0-0 s=255,c=3,t=11,pt=0,l=12,st=ok:Relay sketch
              send: 22-22-0-0 s=255,c=3,t=12,pt=0,l=3,st=ok:1.0
              send: 22-22-0-0 s=1,c=0,t=3,pt=0,l=3,st=ok:1.4
              I'm using stock http://www.mysensors.org/build/relay code, just setting node_id manually to 22.
              On the controller I have:
              0;0;3;0;9;read: 21-21-0 s=11,c=1,t=0,pt=7,l=5:23.0
              publish: MyMQTT/21/11/V_TEMP 23.0
              0;0;3;0;9;send: 0-0-21-21 s=11,c=1,t=0,pt=0,l=7,st=fail:23.0001
              0;0;3;0;9;send: 0-0-22-22 s=1,c=1,t=2,pt=0,l=7,st=fail:13.0001
              It looks like it tries to send '1' with garbage from last sensor read.
              It does this with my humidity sensor:
              publish: MyMQTT/21/12/V_VOLTAGE 5001
              0;0;3;0;9;send: 0-0-21-21 s=12,c=1,t=38,pt=0,l=4,st=ok:5001
              0;0;3;0;9;read: 21-21-0 s=10,c=1,t=1,pt=7,l=5:52.0
              publish: MyMQTT/21/10/V_HUM 52.0
              0;0;3;0;9;send: 0-0-21-21 s=10,c=1,t=1,pt=0,l=8,st=fail:52.05001
              I am also using MQTT client gateway which @gadu recommended me.
              I did not understood how does this workaround @Gambituk mention work. Do you know what is going on above? What am I doing wrong?
              P.S. Using standart EthernetGateway code also scrambles messages (please note strange sing after '1'):
              0;0;3;0;9;read: 22-22-0 s=255,c=3,t=11,pt=0,l=12:Relay sketch
              0;0;3;0;9;read: 22-22-0 s=255,c=3,t=12,pt=0,l=3:1.0
              0;0;3;0;9;read: 22-22-0 s=1,c=0,t=3,pt=0,l=3:1.4
              0;0;3;0;9;send: 0-0-22-22 s=1,c=1,t=2,pt=0,l=2,st=ok:1à
              0;0;3;0;9;read: 0-1-22 s=1,c=1,t=2,pt=0,l=2:1à
              0;0;3;0;9;read: 21-21-0 s=12,c=1,t=38,pt=4,l=4:5023
              0;0;3;0;9;send: 0-0-22-22 s=1,c=1,t=2,pt=0,l=2,st=fail:1à
              after this relay node does not accept any message (you can see st=fail on the last line - that was me retrying mosquitto_pub -p 1883 -h 10.0.0.34 -t MyMQTT/22/1/V_LIGHT -m "1").
              • G
                G
                Gambituk
                Sorry, i just saw this, do you still have the issue or is it resolved?
                • caycoC
                  caycoC
                  cayco
                  I still have it. I need to check how this is (not)working in single sensor environment. I will laso try not to set IT manually. Only if I get some tim to do it...
                  • caycoC
                    caycoC
                    cayco
                    I have reconnected it again and it did just starte to work as it should from the start. I changed nothing. Strange...
                    • G
                      G
                      Gambituk
                      #37
                      What i think happens.. in my own way of thinking!
                                            1 2 3 4 5 6 7 8
                                            B a d v a l u e      something longer than expected
                                          1 1 . 4 v a l u e        next value is 11.4 but longer value stays in a register somewhere
                                          2 1 . 6 5 7 l u e       and is mixed with the next value -
                                          1 2 . 5 5 7 l u e       until restart or overwrite -
                      So i think there is something that needs to be changed to control the length of expected values or actual values to adapt to whatever data arrives.
                      For my workaround, send 1.0 and 0.0 instead of 1 and 0 seems to force the sketch to round the value to 1 or 0 even when there is "1.0dvalue" as the received instruction.
                      • G
                        G
                        Gambituk
                        http://forum.mysensors.org/topic/524/mqtt-client-gateway/29 There is a proposed solution in the following post, i will test and see if it helps, and report back.
                        • G
                          G
                          Gambituk
                          Initial tests seem that it is now resolved with the fixed version of the mqttclient gateway as modified by fotofieber
                          • T
                            tjay4x4
                            I try this code on pro mini with Vera3 but then I implementing it I have a DOOR Switch instead of Ds18b20. So is it possile to show temperature on vera and what's wrong?
                            repeater started, id 1
                            send: 1-1-0-0 s=255,c=0,t=18,pt=0,l=5,st=ok:1.4.1
                            send: 1-1-0-0 s=255,c=3,t=6,pt=1,l=1,st=ok:0
                            send: 1-1-0-0 s=255,c=3,t=11,pt=0,l=25,st=ok:Liquid warm floore relay
                            send: 1-1-0-0 s=255,c=3,t=12,pt=0,l=3,st=ok:1.0
                            send: 1-1-0-0 s=0,c=0,t=0,pt=0,l=5,st=ok:1.4.1
                            send: 1-1-0-0 s=1,c=0,t=0,pt=0,l=5,st=ok:1.4.1
                            send: 1-1-0-0 s=2,c=0,t=0,pt=0,l=5,st=ok:1.4.1
                            send: 1-1-0-0 s=4,c=0,t=3,pt=0,l=5,st=ok:1.4.1
                            send: 1-1-0-0 s=5,c=0,t=3,pt=0,l=5,st=ok:1.4.1
                            send: 1-1-0-0 s=0,c=1,t=0,pt=7,l=5,st=ok:28.6
                            send: 1-1-0-0 s=1,c=1,t=0,pt=7,l=5,st=ok:28.2
                            send: 1-1-0-0 s=2,c=1,t=0,pt=7,l=5,st=ok:28.5
                            hekH 1 Reply Last reply
                            • T tjay4x4
                              @tjay4x4
                              We can't help you much without any code.
                              • G Gambituk
                                and here is the modified relay/temp sketch
                                // Running DS temperature sensor(s) and relay(s) on one mysensor arduino node
                                    // Combines Onewire and Relay code
                                    // 2014-10-14 Pego: Tested and Running on Uno/Clone and MQTT gateway
                                    // Example sketch showing how to send in OneWire temperature readings
                                    // Example sketch showing how to control physical relays.
                                    // This example will remember relay state even after power failure.
                                    #include <OneWire.h>presen
                                    #define RELAY_1  4  // Arduino Digital I/O pin number for first relay (second on pin+1 etc)
                                    #define NUMBER_OF_RELAYS 2 // Total number of attached relays
                                    unsigned long SLEEP_TIME = 30000; // Sleep time between reads (in milliseconds) 30000 orig
                                    int numSensors=0;
                                    boolean receivedConfig = false;
                                    boolean metric = true;
                                    MyMessage msg(0,V_TEMP);
                                      // Startup OneWire
                                      sensors.begin();
                                      // Startup and initialize MySensors library. Set callback for incoming messages.
                                      //gw.begin();
                                      gw.sendSketchInfo("Temp and Relays", "1.0");
                                         gw.present(i, V_TEMP);
                                      // Fetch relay status
                                        gw.present(sensor, S_LIGHT);
                                        pinMode(pin, OUTPUT);
                                        digitalWrite(pin, gw.loadState(sensor)?RELAY_ON:RELAY_OFF);
                                      // Process incoming messages (like config from server)
                                        float temperature = static_cast<float>(static_cast<int>((gw.getConfig().isMetric?sensors.getTempCByIndex(i):sensors.getTempFByIndex(i)) * 10.)) / 10.;
                                        // Only send data if temperature has changed more then 1 degC and no error
                                        if (int(lastTemperature[i]) != int(temperature) && temperature != -127.00) { //added integer
                                          gw.send(msg.setSensor(i).set(temperature,1));
                                      //gw.sleep(SLEEP_TIME); //no sleep for relays!!!!
                                      if (message.type==V_LIGHT) {
                                         // Change relay state
                                         // Store state in eeprom
                                tjay4x4
                                Sorry. :) Hek, I using this code. Vera3 find relay and it works, but also appears 3 door sensors instead of 3 temp sensors.
                                I try to use the my arduino board only with sd18b20 sketch and it work's and show temperature. Is it sketch suitale for vera?
                                    int numSensors=0;
                                      // Startup OneWire
                                      sensors.begin();
                                      //gw.begin();
