  3. What parts would be needed for timer with light panel indicator
lightarduino nano
12 Posts 2 Posters 1.9k Views 2 Watching
    mrhutchinsonmn
    wrote on last edited by mrhutchinsonmn
    I want to put together a little project that would be a timer with a light indicator panel (much like a mini LCD screen)
    It will have 4 buttons.
    Button 1 would turn the light panel green, button 2, yellow, button 3, red, button 4 would flash the light panel green, yellow, red.
    What hardware would be needed for this, outside of an arduino nano and momentary push buttons? Not sure what light or screen would be called that would be used.
    • M mrhutchinsonmn
      @mrhutchinsonmn what type of light panel are you thinking of?
      Something like https://www.ikea.com/us/en/catalog/products/20303063/ (60x60cm)?
      Or something smaller like https://www.aliexpress.com/item/32959082165.html ?
      Or something super easy like a single RGB diode (or one red, one green and one yellow) behind a piece of white plastic to act as a diffuser?
        mrhutchinsonmn
        I think what I would like is a Light Panel that would be about 7 or 8 cm square. I'm not sure if I would get the clean look that I want with the LEDs you mentioned but maybe you could point me in the right direction so I could consider those also.
        • M mrhutchinsonmn
          @mrhutchinsonmn just put any thin sheet of white plastic on top of a led
            mrhutchinsonmn
            @mfalkvidd I have one of these sitting around for another project you posted that I will be making soon (Parking Sensor). This should work with a lens over it: https://tinyurl.com/y6p7e3p9, correct?
            • M mrhutchinsonmn
              @mrhutchinsonmn I would probably use a diffuser instead of lens but yes that would work very well
                mrhutchinsonmn
                Here is my first prototype of a working solution for a timing light: ( neopixal timing light):https://youtu.be/b3TDGKUS05I
                Thank you for direction @mfalkvidd !
                • M mrhutchinsonmn
                  Great video @mrhutchinsonmn, thanks for sharing!
                  I really like the real-world use case.
                  For the wireless part, you might be able to reuse parts of my code for a pomodoro timer. https://youtu.be/sLEbq_pfry0
                  My code does not support remote control (it only views status remotely) but it would be easy to add en endpoint, for example
                  server.on(”/start”, start_pomodoro)
                  to start the timer. Code: https://github.com/mfalkvidd/Arduino-Datormagazin-Pomodoro/blob/datormagazin/Arduino-Datormagazin-Pomodoro.ino
                    mrhutchinsonmn
                    I like that! before your reply, I found something else that would work. I like it because a nano could power the neopxial and rf receiver, reducing complexity
                    https://tinyurl.com/y3tmvpnx
                    • mfalkviddM
                      This is what it looks like with a diffuser
                      • M mrhutchinsonmn
                        @mrhutchinsonmn sorry, I am not able to open that link. It just goes to Ali’s front page
                          mrhutchinsonmn
                          Package: YesUse: SwitchUse: Automated curtainsUse: UniversalUse: Electric DoorUse: TVUse: LightingChannel: 4Wireless Communication: RFBrand Name: QIACHIPFrequency: 433 MHzSupport APP: NoModel Number: KT16+480E*4Working Voltage: DC 3.3~5VEncoding Type: Learning EV1527Application example 1: Mandos a Distancia De Puertas De GarageApplication example 3: Garage Doors Access Control SsystemWorking Temperature: -25~75Use: Automated curtains,Universal,Switch,Electric DoReceiving Sensitivity: -108dBQuiescent Current: <5mAApplication example 2: Electronic Gates Access Control SystemApplication example 4: Electrical Appliances Control```
