Problem with BME280 Hum value
i try to create a node by the BME280 example and send them to IoBroker.
But then I get by IoBroker just the Temp and the Pressure value.
BME280 - Requesting new data from sensor module. BME280 - Sensor module has some new values ready: BME280 - Temperature = 25.69 °C BME280 - Humidity = 41.13 % BME280 - Pressure = 1023.98 hPa BME280 - Forecast = stable BME280 - Sending the new temperature to the gateway. 330804 TSF:MSG:SEND,1-1-0-0,s=0,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:25.7 BME280 - Sending the new humidity to the gateway. 330816 TSF:MSG:SEND,1-1-0-0,s=1,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:41.1 BME280 - Sending the new pressure to the gateway. 330828 TSF:MSG:SEND,1-1-0-0,s=2,c=1,t=4,pt=7,l=5,sg=0,ft=0,st=OK:1024.0 BME280 - Measurement complete. Going to wait until next measurement.And the log from IoBroker
mysensors.0 2019-09-05 18:55:48.532 info Add new object: 1.0_TEMP.V_ID - 1.0_TEMP.V_ID mysensors.0 2019-09-05 18:55:48.531 info Add new object: 1.0_TEMP.V_TEMP - 1.0_TEMP.V_TEMP mysensors.0 2019-09-05 18:55:48.530 info Add new object: 1.0_TEMP - 1.0_TEMP mysensors.0 2019-09-05 18:55:48.475 info Add new object: 1.2_BARO.V_FORECAST - 1.2_BARO.V_FORECAST mysensors.0 2019-09-05 18:55:48.475 info Add new object: 1.2_BARO.V_PRESSURE - 1.2_BARO.V_PRESSURE mysensors.0 2019-09-05 18:55:48.474 info Add new object: 1.2_BARO - 1.2_BARO mysensors.0 2019-09-05 18:55:48.416 info Version :1.1 mysensors.0 2019-09-05 18:55:48.356 warn setObject mysensors.0.1 (type=device) property native missing! mysensors.0 2019-09-05 18:55:48.353 info Name :BME280 SensorAny idea? Any help is welcome.
Check the variable type you are sending with the humidity. The log parser indicates you are sending a V_TEMP for the humidity reading instead of a V_HUM
You can find the log parser here: https://www.mysensors.org/build/parser
Much easier than trying to read the log output directly. -
You are right, I solved it. But now it looks like sending failed during presentation? Any idea?
_ __ ____ | \/ |_ _/ ___| ___ _ __ ___ ___ _ __ ___ | |\/| | | | \___ \ / _ \ `_ \/ __|/ _ \| `__/ __| | | | | |_| |___| | __/ | | \__ \ _ | | \__ \ |_| |_|\__, |____/ \___|_| |_|___/\___/|_| |___/ |___/ 2.3.1 16 MCO:BGN:INIT NODE,CP=RNNNA---,REL=255,VER=2.3.1 26 TSM:INIT 27 TSF:WUR:MS=0 33 TSM:INIT:TSP OK 35 TSF:SID:OK,ID=3 37 TSM:FPAR 73 TSF:MSG:SEND,3-3-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 587 TSF:MSG:READ,0-0-3,s=255,c=3,t=8,pt=1,l=1,sg=0:0 592 TSF:MSG:FPAR OK,ID=0,D=1 2080 TSM:FPAR:OK 2081 TSM:ID 2082 TSM:ID:OK 2084 TSM:UPL 2087 TSF:MSG:SEND,3-3-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1 2184 TSF:MSG:READ,0-0-3,s=255,c=3,t=25,pt=1,l=1,sg=0:1 2189 TSF:MSG:PONG RECV,HP=1 2192 TSM:UPL:OK 2193 TSM:READY:ID=3,PAR=0,DIS=1 2198 TSF:MSG:SEND,3-3-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100 2322 TSF:MSG:READ,0-0-3,s=255,c=3,t=15,pt=6,l=2,sg=0:0100 2329 TSF:MSG:SEND,3-3-0-0,s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=OK:2.3.1 2338 TSF:MSG:SEND,3-3-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0 4346 TSF:MSG:SEND,3-3-0-0,s=255,c=3,t=11,pt=0,l=13,sg=0,ft=0,st=OK:BME280 Sensor 4356 TSF:MSG:SEND,3-3-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=OK:1.1 4364 TSF:MSG:SEND,3-3-0-0,s=2,c=0,t=8,pt=0,l=0,sg=0,ft=0,st=OK: 4371 TSF:MSG:SEND,3-3-0-0,s=0,c=0,t=6,pt=0,l=0,sg=0,ft=0,st=OK: 4412 !TSF:MSG:SEND,3-3-0-0,s=1,c=0,t=7,pt=0,l=0,sg=0,ft=0,st=NACK: 4419 TSF:MSG:SEND,3-3-0-0,s=3,c=0,t=6,pt=0,l=0,sg=0,ft=1,st=OK: 4425 MCO:REG:REQ 4463 !TSF:MSG:SEND,3-3-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=NACK:2 6470 TSF:MSG:SEND,3-3-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=1,st=OK:2 6535 TSF:MSG:READ,0-0-3,s=255,c=3,t=27,pt=1,l=1,sg=0:1 6540 MCO:PIM:NODE REG=1 6542 MCO:BGN:STP Hello world, I am a sensor node. 6544 MCO:BGN:INIT OK,TSP=1 BME280 - Requesting new data from sensor module. BME280 - Sensor module has some new values ready: BME280 - Temperature = 25.18 °C BME280 - Humidity = 39.49 % BME280 - Pressure = 1022.52 hPa BME280 - Forecast = unknown BME280 - Sending the new temperature to the gateway. 6616 TSF:MSG:SEND,3-3-0-0,s=0,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:25.2 BME280 - Sending the new humidity to the gateway. 6627 TSF:MSG:SEND,3-3-0-0,s=1,c=1,t=1,pt=7,l=5,sg=0,ft=0,st=OK:39.5 6637 TSF:MSG:SEND,3-3-0-0,s=3,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:1.0 BME280 - Sending the new pressure to the gateway. 6645 TSF:MSG:SEND,3-3-0-0,s=2,c=1,t=4,pt=7,l=5,sg=0,ft=0,st=OK:1022.5 BME280 - Sending the latest forecast to the gateway. 6677 TSF:MSG:SEND,3-3-0-0,s=2,c=1,t=5,pt=0,l=7,sg=0,ft=0,st=OK:unknown BME280 - Measurement complete. Going to wait until next measurement. -
