  3. hi guys can anyone suggest any working controller this present days for this project thank you in advance
6 Posts 4 Posters 1.3k Views 3 Watching
  • J
    J
    Jasxvii
    wrote on last edited by Jasxvii
    Re: $8 Lamp (Outlet) "Smart Plug" Module
    • nagelcN
      nagelcN
      nagelc
      Hi. The MySensors site has a whole section on controllers with a matrix that compares the features:
      https://www.mysensors.org/controller
      Any of them should be able to control that outlet once set up.
      You will also need a gateway to connect to the controller if you don't have one already. See this section: https://www.mysensors.org/build/select_gateway
      J 1 Reply Last reply
      • nagelcN nagelc
        J
        J
        Jasxvii
        @nagelc Thank you is it okay if i uploaded the relayactuator instead of the one that pete revised ? bec. the relay actuator work when i upload it
        nagelcN 1 Reply Last reply
        • alowhumA
          alowhumA
          alowhum
          I recommend the Mozilla WebThings Gateway if you're a beginner.
          • J Jasxvii
            nagelcN
            nagelcN
            nagelc
            @jasxvii
            Yes. Makes sense. I the code in the original article was from an earlier version of MySensors.
            • I
              I
              iancu
              I have tried Domoticz, Mozilla WebThings and Home Assistant. So far the best is Home Assistant, it has many integrations and a nice UI. If you want to be able to access it outsite your network I recommend ZeroTier (had many issues trying thru the router).
              12.5k
