  3. Looking for very simple rocker switch
10 Posts 3 Posters 1.6k Views 3 Watching
  • alowhumA
    alowhumA
    alowhum
    Does anyone know if a rocker switch exists that can directly connect to Dupont wires?
    Something like:
    Right now I use these, but they are very big and expensive:
    It seems all of them are tiny and/or designed for soldered connections. They have very thin pins.
    • alowhumA
      alowhumA
      alowhum
      I found these very cheap "computer power" cables.
      https://www.aliexpress.com/item/32812421126.html
      I could connect one end to the 5V output and the other to the pin input?
      • Nca78N
        Maybe those ?
        https://lcsc.com/product-detail/Rocker-Switches_C-K_7101J1V3QE2_C-K-7101J1V3QE2_C248348.html
        https://lcsc.com/product-detail/Others_Legion-SS21-BBIWA2-R_C309181.html
        https://lcsc.com/product-detail/Others_TE-Connectivity_1-1571986-5_TE-Connectivity-1-1571986-5_C92486.html
        • alowhumA
          alowhumA
          alowhum
          Thanks! How can you tell if their pins are thick enough to fit into a Duport connector snugly?
          Nca78N 2 Replies Last reply
          • alowhumA alowhum
            @alowhum except the datasheet, I don't know :)
            I have to make a lcsc order now, if you want I can order the "legion" one to try on a breadboard. The others are too expensive for things I don't need ;)
            • alowhumA
              alowhumA
              alowhum
              Sure! If you can order just one, I'd be curious to know if it would work.
              • alowhumA
                alowhumA
                alowhum
                Turns out those ATX power switches are not latching :-(
                But in the end we decided it would also be good to use momentary buttons instead, and show the state on the display. This also allows the controller to change the state without any issue.
                • alowhumA alowhum
                  It is probably a personal preference, but I like to use non-latching, and do "software latching" instead. As you mentioned, this allows for additional features such as changing the setting from another node, or changing after a specified time has passed.
                  The big exception is power switches. These are a bit hard to use unless they really do latch ;-)
                  • alowhumA alowhum
                    @alowhum said in Looking for very simple rocker switch:
                    I finally made and receive the order, I ordered this one and it's huge. So huge that the pins are in fact way too big (0.8*1.2mm section) to fit on a breadboard or in a Dupont connector :(
                    alowhumA 1 Reply Last reply
                    • Nca78N Nca78
                      alowhumA
                      alowhumA
                      alowhum
                      @Nca78 said in Looking for very simple rocker switch:
                      Hahaha, that's hilarious :-D
                      Thanks for trying though, really appreciate it!
