  3. Sketch kills batteries in 2-3 days
8 Posts 4 Posters 1.1k Views 4 Watching
  • S Offline
    ShadeX12
    Greetings All,
    I suspect the issue I have is with my sketch and not hardware. I've had this issue on two different sensors with the same result. Also, I noticed that the status LED remains lit. I don't see this with my other sketches. I basically tried to combine a door sensor with battery metering using the examples. Perhaps someone can point out where I went wrong?
    #define MY_NODE_ID 8
    #define MY_PARENT_NODE_ID 0
    #define CHILD_ID 1
    #define BUTTON_PIN  2  // Arduino Digital I/O pin for button/reed switch
    Bounce debouncer = Bounce();
    int oldValue=-1;
    uint32_t SLEEP_TIME = 900000;  // sleep time between reads (seconds * 1000 milliseconds)
    int oldBatteryPcnt = 0;
        analogReference(INTERNAL1V1);
        analogReference(INTERNAL);
      // Setup the button
      pinMode(BUTTON_PIN,INPUT);
      // Activate internal pull-up
      debouncer.attach(BUTTON_PIN);
      debouncer.interval(5);
      present(CHILD_ID, S_DOOR);
      sendSketchInfo("Front Door", "1.0");
      debouncer.update();
      // Get the update value
      int value = debouncer.read();
      if (value != oldValue) {
         // Send in the new value
         send(msg.set(value==HIGH ? 1 : 0));
         oldValue = value;
           // get the battery Voltage
         Serial.println(sensorValue);
         oldBatteryPcnt = batteryPcnt;
    N 1 Reply Last reply
    • S ShadeX12
      Greetings All,
      #define CHILD_ID 1
      int oldValue=-1;
        // Setup the button
        debouncer.update();
           oldValue = value;
      N Offline
      N Offline
      Hello @shadex12, I don't see any call to the sleep method ?
      • S Offline
        ShadeX12
        @Nca78 Oh right!. Makes sense. If I recall correctly I think I removed that because I was having issues with door sensor not interrupting the loop to send the status update.I forgot to add it back in. I will play around tonight and see if I can get it working with sleep included again.
        I am not very experienced coding this stuff so I appreciate the help!
        • S Offline
          ShadeX12
          So this has been an interesting journey. It turns out that you cannot use bounce with sleep, or so I read. This is what I eventually came up with for the sketch. So far it seems to be working well.
          #define MY_NODE_ID 213
          #define MY_RADIO_RF24
          #define DIGITAL_INPUT_SENSOR 2   // The digital input you attached your motion sensor.  (Only 2 and 3 generates interrupt!)
          #define CHILD_ID_DOOR 1
          int oldValue=-1;
          bool metric = true;
          MyMessage msg(CHILD_ID_DOOR, V_TRIPPED);
            sendSketchInfo("Closet Door", "3.0");
            present(CHILD_ID_DOOR, S_DOOR);
            // Setup the button
            pinMode(DIGITAL_INPUT_SENSOR,INPUT);
            digitalWrite(DIGITAL_INPUT_SENSOR,HIGH);
            // Read digital motion value
              bool tripped = digitalRead(DIGITAL_INPUT_SENSOR) == HIGH;
              Serial.println(tripped);
          • S ShadeX12
            int oldValue=-1;
            bool metric = true;
              // Setup the button
            N Offline
            N Offline
            @shadex12 said in Sketch kills batteries in 2-3 days:
            If you have problem now you have removed the debouncing, you can just add a (very) short wait after waking up from interrupt, so the button has the time to settle.
            Of you can use a small capacitor in parallel to the button so whatever the bouncing looks like, voltage will increase in a progressive way on the pin and trigger the interrupt only once.
            • wahidW Offline
              wahidW Offline
              wahid
              Well.
              1. I would power A0 (ADC)through a digital pin. This way it reads voltage only when needed, not always connected to battery and draining power.
              2. Besides powering the nrf radio through a pin (transistor) is a good idea as well.
              3. Putting the mcu To sleep sure will add few more days to the life of the battery.
                Battery in correct connections should live more than couple of years, I had ultrasonic distance reader project connected with nrf and pro mini. That lived months without a noticed drop in battery
              • wahidW wahid
                Well.
                N Offline
                N Offline
                @wahid said in Sketch kills batteries in 2-3 days:
                This is only useful when in search of extra long battery life with extremely low capacity battery. Else MySensors put the nrf into sleep mode when sleeping the cpu and power consumption of the radio is in the range of 1uA.
                • T Offline
                  T Offline
                  tbowmo
                  @wahid
                  As an example, I have 4 sensebender micros, which has been deployed since june 2015, I have not changed batteries in them yet, and they still report temperature / humidity (that's more than 4 years battery life!). The batteries are cheap AA alkaline types (2 pieces)..
                  I'm not doing anything special (hardware wise) to power off the radio, or any other peripherals on the board. Only using standard software powerdown where available.
