  3. Door sensor with wifi
17 Posts 10 Posters 3.3k Views 9 Watching
    @yveaux but it does not support the 5GHz band that @rockryan asked for.
    I don't know why he wants dual band though.
    @mfalkvidd he says his wifi supports 2 bands and is looking for a sensor that is working with his setup; this sensor will work with his setup
    • YveauxY Yveaux
      @yveaux that does make much more sense than my interpretation :)
      • YveauxY Yveaux
        @rockryan Action (750+ stores in Europe) recently added the 'LSC smart connect' series.
        The 'LSC Smart Connect doorsensor' (https://www.action.com/nl-nl/p/lsc-smart-connect-deursensor/) costs less than 10 Euros.
        And the best thing, it contains an ESP8266 so it runs alternative firmware (Tasmota, ESP-Easy, Arduino, ...) :man_dancing:
        rozpruwaczR
        rozpruwaczR
        rozpruwacz
        @yveaux how frequently the battery must be replaced ? and what kind of battery it has ?
        • rozpruwaczR rozpruwacz
          @rozpruwacz I don't own it so I don't know, sorry.
          I did buy one of their smart plugs and a siren, but both are mains powered.
          • bjacobseB
            bjacobseB
            bjacobse
            Typically wifi consumes considerable energy for handshake so use wifi on battery isn't the greatest idea. but using it with mains power is quite good
            If you want to use battery operated devices, you must use a better protocol than wifi
            • mfalkviddM
              A door sensor might not get that many actuations though, so depending on how often the door is opened/closed, even wifi might get pretty good battery life.
              • YveauxY Yveaux
                R
                R
                rockryan
                @yveaux Thank You very much I will look into it.
                • K
                  K
                  kimot
                  With battery powered sleeping wifi device will be always delay after door switch sensor action and message sending.
                  Find AP, connect to it etc.
                  Couple od seconds.
                  Maybe good for alarm, but not for switch light.
                  • J
                    J
                    Jurimetrics
                    Based on how often the door is opened/closed wifi will get a good battery life.
                    K 1 Reply Last reply
                    • J Jurimetrics
                      K
                      K
                      kimot
                      wrote on last edited by kimot
                      @jurimetrics
                      Yes, good battery life time, but not good response time.
                      You open the door and receive message about it after couple of seconds.
                      With Arduino and rfm69 or NRF24 it is much better.
                      • T
                        tommies
                        @yveaux said in Door sensor with wifi:
                        how to hack door sensor...
                        https://www.letscontrolit.com/forum/viewtopic.php?t=6955
                        • T tommies
                          tommies
                          @tommies
                          looking for information about PIR and door sensors.
                          I found this
                          https://fr.aliexpress.com/item/33058098383.html?spm=a2g0o.detail.1000060.2.7a1047c2wCrUam&gps-id=pcDetailBottomMoreThisSeller&scm=1007.13339.146401.0&scm_id=1007.13339.146401.0&scm-url=1007.13339.146401.0&pvid=d970617b-6cf7-4378-b601-8f064a73faa8
                          Very very low price for a very very interesting product..
                          • D
                            dekinridoine
                            Banned
                            I have LSC Smart door sensor, it works great. Now I can't imagine my life without smart technologies.
                            Christina TrostinetscaiaC 1 Reply Last reply
                            • D dekinridoine
                              Banned
