  3. only wake on interupt..
17 Posts 4 Posters 1.6k Views 2 Watching
  • markjgabbM
    markjgabbM
    markjgabb
    Perfect. Tha is for that works great... Interesting thought though with how sensitive it is...
    I was actually just waving my hand near it. Possibly 2-3 inches away from the wires....
    Could be used as something like a plate you slap with your hand
    • markjgabbM markjgabb
      @markjgabb yes, that's exactly how touch-based buttons work (and your phone's touchscreen)
      • markjgabbM
        markjgabbM
        markjgabb
        wrote on last edited by markjgabb
        ok stuck now...
        it works once...
        it wakes up each time and send the command
        but in domoticz im using a push on button with a off delay.....
        domoticz is ignoring the sensor after the first on, because the sensor isnt available anymore to receive the command....
        do i possibly need the sensor to send an on command, wait a moment then send its own off command again?
          ok stuck now...
          it works once...
          zboblamontZ
          zboblamontZ
          zboblamont
          @markjgabb Domoticz should display a binary On/Off according to what it is sent, so suggest looking at the Domoticz log for incoming messages, I suspect the OFF is not being sent. Why you are using a Domoticz switch with an off delay I don't understand, a simple on/off is what I use.
          In your modified @skywatch sketch the loop contains battery measurement batM() which itself incorporates a half second delay and Serial.print, suggest rem that out in the loop for now leaving the main loop to work with perhaps a 5 or 10ms delay if the switch is not debounced electrically.
          A momentary rather than latching switch allows a very fast change of state in the region of milliseconds, quite different to a real world device running seconds/minutes/hours in one state or the other.
          In your case you are looking at the interrupt as CHANGE, then reporting the digital state of the pin, any old toggle or light switch would do.
          • markjgabbM
            markjgabbM
            markjgabb
            yeah i possibly havent been ecactly clear on that
            Scenario is that when i walk into a room i dont always want to ask google to turn on or off all the lights in the room.
            so i plan on having wall mounted momentary switches, which their sole purpose is to if the lights are on, turn them off and if they are off turn them on....
            so i had planned to use a momentary switch so that no one in the house became focused on if they were off or on, but just push them to get the opposite of current state
            In domoticz i was going to use a push on button with a dzvents script so that any time the push on on button became on it would toggle the opposite of whatever the state of lights in the room in...
            obviously a bit more logic is needed in case some lights are on and others off....
            As per advice i have shortened off the times for delays and have taken out the serial prints on the battery monitor
            // Enable debug prints
            #define MY_RADIO_RF24
            unsigned long SLEEP_TIME = 298000; // Sleep time between reports (in milliseconds)
            // Initialize motion message
              analogReference(INTERNAL);
              sendSketchInfo("Lounge multi button", "1.1");
              wait(100);
              present(CHILD_ID, S_LIGHT, "Lounge Light Switch", true);
              // Read digital motion value
               bool tripped = digitalRead(DIGITAL_INPUT_SENSOR);
               //Software debounce.....
               //wait(25);
               //bool tripped1 = digitalRead(DIGITAL_INPUT_SENSOR);
               //if (tripped == tripped1){}
               //send(msg.set(tripped?"1":"0"),true);  // Send tripped value to gw
               if (tripped == HIGH){
               send(msg.set(tripped = 1),true);
               wait(100);
               send(msg.set(tripped = 0),true);
              batM();
              // Sleep until interrupt on motion sensor. Send update every ten minutes.
               delay(5);
               // Battery monitoring reading
               delay(5);
               // Calculate the battery in %
               //Serial.print("Battery percent: "); Serial.print(batteryPcnt); Serial.println(" %");
               if (batLoop > 2) {
               if (batteryPcnt > 100) {
                 batteryPcnt=100;
                   batLoop = 0;
                 batLoop++;
            mfalkviddM zboblamontZ 2 Replies Last reply
                wait(100);
                 //wait(25);
                 wait(100);
                batM();
                 delay(5);
                 delay(5);
                 if (batLoop > 2) {
                   batteryPcnt=100;
                     batLoop = 0;
                   batLoop++;
              @markjgabb when the node is sleeping, it cannot receive messages from Domoticz.
                  wait(100);
                   //wait(25);
                   wait(100);
                  batM();
                   delay(5);
                   delay(5);
                   if (batLoop > 2) {
                     batteryPcnt=100;
                       batLoop = 0;
                     batLoop++;
                zboblamontZ
                zboblamontZ
                zboblamont
                @markjgabb Wasn't thinking about shortening the battery read but // it out in the loop meantime as it is only a local serial output. Whatever..
                Ok on the intent, then what you are doing is "illogical", you are reporting the state of the switch not the condition of the light.
                What you need to do is toggle a separate logic parameter on the Node for a LOW interrupt at the Node, switching ON/OFF the light, report that separate logic state to Domoticz then go to sleep... The interrupt only initiates the action, the Node reports and stores the current state until the next interrupt, Domoticz tells you the last reported state.
                Whether you control the light at at the button switch Node with a latching relay or command a separate Node is up to you, but Domoticz only reports the last known state...
                • markjgabbM
                  markjgabbM
                  markjgabb
                  @zboblamont
                  haha ok so i went right back to the begining of what you said and got it working now (code below)
                  cut back all unneccicary steps and really locked down what was going on... i can always add back battery part later
                  however now when it comes back online after 5 minutes for heart beat it keep sending a switch command to domoticz...
                  im guessing this is due to the issue where the state is being reported differently after it going to sleep as soon as action is performed....
                    sendSketchInfo("Lounge Multi", "3.0");
                    wait(100);
                    present(CHILD_ID, S_DOOR);
                     //wait(25);
                     else if (tripped == LOW){
                  skywatchS zboblamontZ 2 Replies Last reply
                    @zboblamont
                      wait(100);
                       //wait(25);
                    skywatchS
                    skywatchS
                    skywatch
                    @markjgabb I used the trigger data for a 'heartbeat' so that it looked 'normal' on a graph and the graph updated regularly (otherwise it only updated on a change and that can be a long time indeed for some windows)!
                    The solution might be to immplement the MySensors Heartbeat instead.
                    Just put " sendHeartbeat(); " without the quotes in the sketch main loop. You may still get messages about status, I am not sure as I use MyController for my set-up and never used domoticz
                    If so you can try and set a memory for the status and only send the tripped message if the status of the last_tripped_status (or whatever you want to call it) has changed.
                    I believe that the relay sketches in 'build' page use a similar approach from memory.
                    Here is a strong hint of how to do it..... :)
                     if (tripped == HIGH && last_tripped == LOW){
                    last_tripped = HIGH;
                       else if (tripped == LOW) && last_tripped==HIGH{
                    last_tripped = LOW;
                    You need to assign a type bool to last_tripped somewhere and initialise it.
                      @zboblamont
                        wait(100);
                         //wait(25);
                      zboblamontZ
                      zboblamontZ
                      zboblamont
                      @markjgabb "..cut back all unneccicary steps and really locked down what was going on.." was indeed the idea.
                      What I went on to explain is than you are reporting the state of D3 which goes HIGH/LOW/HIGH via the button, not the light. The critical difference between @skywatch and your install is movement detection maintains a value, your button does not.
                      If you create a variable before the loop, say boolean lightswitch=false; (presuming that the light is ON when you program it) this variable will be changed and reported to Domoticz in the loop.
                      Top of the loop you toggle the "lightswitch" value, first time it will switch false to true, report in the "lightswitch" value then go to sleep.
                      Bottom of the loop your " sleep(digitalPinToInterrupt(DIGITAL_INPUT_SENSOR), CHANGE, SLEEP_TIME); should trigger on a LOW, as this is the momentary state of D3 ONLY when the button is pressed.
                      Your next button press activates the loop, toggles "lightswitch", reports and goes back to sleep, at least two years on a pair of AA cells.
                      Were it I doing this there would be a mains powered indicator on the switch plate which cuts out when the light is on, A- To find the switch in the dark, B-To provide an indicator which can be used to verify the actual state of the light to ensure it stays in sync (Murphy's Law).
                      I don't see the point of using heartbeat as it is not a security device, and only fire the battery reading mosfet every X loops.
