  3. [SOLVED] MYSBootloader FOTA Update hangs on ProMini-3V-8MHz (reboot problem)
21 Posts 5 Posters 5.7k Views 4 Watching
  • R
    R
    rafael156
    wrote on last edited by rafael156
    here's what I've been trying on arduino 328P-8MHz XTAL-3v3:
    fuse settings from development branch(only to external xtal changed):
    MYSBL.menu.frequency.MYSBL8=ATmega328 8Mhz ext MYSBootloader_1.3.0-rc.1
    MYSBL.menu.frequency.MYSBL8.build.f_cpu=8000000L
    MYSBL.menu.frequency.MYSBL8.upload.speed=57600
    MYSBL.menu.frequency.MYSBL8.bootloader.low_fuses=0xFF
    MYSBL.menu.frequency.MYSBL8.bootloader.high_fuses=0xD2
    MYSBL.menu.frequency.MYSBL8.bootloader.extended_fuses=0x06
    MYSBL.menu.frequency.MYSBL8.bootloader.unlock_bits=0x3F
    MYSBL.menu.frequency.MYSBL8.bootloader.lock_bits=0x0F
    MYSBL.menu.frequency.MYSBL8.bootloader.file=MySensors/MYSBootloader_8MHz.hex
    then i burned the bootloader from https://github.com/mysensors/MySensorsBootloaderRF24/blob/development/hex/MYSBootloader_8MHz.hex
    and got warnings from arduino IDE:
    avrdude: WARNING: invalid value for unused bits in fuse "lock", should be set to 1 according to datasheet
    This behaviour is deprecated and will result in an error in future version
    You probably want to use 0xff instead of 0x3f (double check with your datasheet first).
    avrdude: WARNING: invalid value for unused bits in fuse "efuse", should be set to 1 according to datasheet
    You probably want to use 0xfe instead of 0x06 (double check with your datasheet first).
    You probably want to use 0xcf instead of 0x0f (double check with your datasheet first).
    Then the first firmware after flashing the bootloader:
    https://ibb.co/gbQ7Sd
    serial communication works, but with baud 115200. shouldn't this be 57600 at 8MHz?
    https://ibb.co/cxpqfy
    a manual restart of the node does nothing...
    https://ibb.co/e7bp7d
    after i hard-reset, the node is restarting...
    https://ibb.co/jTxMnd
    warum funktioniert der software reboot nicht? und warum hat der node eine baud rate von 115200 statt 57600 nach aktuellem dev.branch?
    tekkaT 1 Reply Last reply
    • R rafael156
      tekkaT
      tekkaT
      tekka
      wrote on last edited by tekka
      @rafael156 Please post your sketch - looks like your sketch does not process incoming messages.
      • R
        R
        rafael156
        this is the current dht-sketch from mysensors-examples:
         * Version 1.0: Henrik EKblad
         * sensor using a DHT11/DHT-22.
        // Enable debug prints
        //#define MY_RS485
        #define DHT_DATA_PIN 3
        #define SENSOR_TEMP_OFFSET 0
        static const uint64_t UPDATE_INTERVAL = 60000;
        #define CHILD_ID_HUM 0
        #define CHILD_ID_TEMP 1
        float lastTemp;
        float lastHum;
        uint8_t nNoUpdatesTemp;
        uint8_t nNoUpdatesHum;
        bool metric = true;
        DHT dht;
          sendSketchInfo("TemperatureAndHumidity", "1.1");
          present(CHILD_ID_HUM, S_HUM);
          dht.readSensor(true);
          if (isnan(temperature)) {
            lastTemp = temperature;
            if (!metric) {
            // Reset no updates counter
            nNoUpdatesTemp = 0;
            #ifdef MY_DEBUG
            Serial.print("T: ");
            nNoUpdatesTemp++;
          if (isnan(humidity)) {
            lastHum = humidity;
            nNoUpdatesHum = 0;
            #ifdef MY_DEBUG
            Serial.print("H: ");
            Serial.println(humidity);
            nNoUpdatesHum++;
          sleep(UPDATE_INTERVAL);
        • R
          R
          rafael156
          @tekka Do you have an idea what´s wrong with the code? yesterday i have changed "sleep(UPDATE_INTERVAL);" to "wait(UPDATE_INTERVAL); " but bothing changed. Fota update or software reboot doesnt work.
          Are the fuses and the bootloader options (txt) correct?
            don't you need to reboot to trigger the update?
            • R
              R
              rafael156
              Yeah, right! That's the problem! But when I click on "reboot" on myscontroller, the node does not react to any command, i.e. reboot etc.
              is there a function that takes the command from myscontroller and executes it or do I have to implement it myself in the sketch?
              SoloamS gohanG 2 Replies Last reply
              • R rafael156
                SoloamS
                SoloamS
                Soloam
                @rafael156 I had a similar problem, my node would stop responding when I tried to reboot it. The problem was in the fuse settings, have you checked if they are all set? What version are you using? (16,8 or 1)
                • R rafael156
                  @rafael156 have you tried with smartsleep instead of sleep? Of course the node would respond only when it wakes up.
                  • R
                    R
                    rafael156
                    @Soloam i have checked fuse settings several times . i use the 8 mhz version. boards.txt see above .
                    at burn process, arduino ide (1.6.13) gave me a warning about the fuses
                    which fuses do you have?
                    @gohan no, i didnt. but i have tried wait(), with no success. i will try smartsleep() today!
                    • R rafael156
                      tekkaT
                      tekkaT
                      tekka
                      @rafael156 Hmm, I don't think this is related to the fuse settings. Try again changing sleep() to wait() and upload the full logs from MYSController and the node (with MY_DEBUG enabled)
                      • R
                        R
                        rafael156
                        ok, Thanks at all!
                        You helped me find the mistake!
                        it was actually because the node could not receive commands because there was a "sleep()" hidden somewhere in each sketch. after I searched all sketches thoroughly and replaced them with "wait()", everything runs without problems:
                        //#define MY_RS485
                        float lastTemp;
                        float lastHum;
                        bool metric = true;
                        DHT dht;
                          wait(dht.getMinimumSamplingPeriod());
                            if (!metric) {
                            nNoUpdatesTemp = 0;
                            #ifdef MY_DEBUG
                            nNoUpdatesTemp++;
                            lastHum = humidity;
                            nNoUpdatesHum = 0;
                            #ifdef MY_DEBUG
                            nNoUpdatesHum++;
                          //sleep(UPDATE_INTERVAL);
                        void receive(){
                        However, I would suggest that the functions "wait()" and "smartsleep()" be mentioned in relation to the MySBootloader in a separate point under "https://www.mysensors.org/about/fota". Maybe under a chapter:
                        1. Enabling FOTA in your sketch
                          1.1 DualOptiboot only
                          --> text as before
                          1.2 MySBootloader
                          --> ... use smartsleep() and wait() instead of sleep()...
                        Summary:
                        • fuse settings 8MHz external crystal:
                        • if sensebender gateway is connected via usb, only one instance may access the gateway at a time, therefore "OpenHab" must be terminated first
                        • do not use "sleep()" in the sketches. only "smartsleep()" or "wait()".
                          use the current dev-branch from "https://github.com/mysensors/MySensorsBootloaderRF24
                        gohanG badmannenB 2 Replies Last reply
                        • R rafael156
                          ok, Thanks at all!
                          //#define MY_RS485
                          float lastTemp;
                          float lastHum;
                          bool metric = true;
                          DHT dht;
                              if (!metric) {
                              nNoUpdatesTemp = 0;
                              #ifdef MY_DEBUG
                              nNoUpdatesTemp++;
                              lastHum = humidity;
                              nNoUpdatesHum = 0;
                              #ifdef MY_DEBUG
                              nNoUpdatesHum++;
                          void receive(){
                            --> text as before
                            1.2 MySBootloader
                          Summary:
                          @rafael156 said in [SOLVED] MYSBootloader FOTA Update hangs on ProMini-3V-8MHz (reboot problem):
                          I'd use smartsleep in this case as wait will keep the MCU active and drain battery. Wait is better used in place of "delay"
                          • R rafael156
                            ok, Thanks at all!
                            //#define MY_RS485
                            float lastTemp;
                            float lastHum;
                            bool metric = true;
                            DHT dht;
                                if (!metric) {
                                nNoUpdatesTemp = 0;
                                #ifdef MY_DEBUG
                                nNoUpdatesTemp++;
                                lastHum = humidity;
                                nNoUpdatesHum = 0;
                                #ifdef MY_DEBUG
                                nNoUpdatesHum++;
                            void receive(){
                              --> text as before
                              1.2 MySBootloader
                            Summary:
                            badmannenB
                            badmannenB
                            badmannen
                            @rafael156 oh crap ... I put in that lowFuse as FF .. ( I read you had it for 8 MHz INTERNAL .. but nooo you wrote external ... ooops ... is there any way to force write it back without connecting an 8 MHz oscillator to the chip .. I only got 16 MHz oscillators .. or am I screwed for that chip until I go and get one?
                            rPi 3 - UNO R3 - Mini - Nano - custom
