  3. Solar Energy Harvesting for wireless motes
47 Posts 8 Posters 7.2k Views 8 Watching
  • zboblamontZ zboblamont
    @neverdie An interesting experiment, but can you clarify that by indoor lighting conditions you mean that harvesting is active only when lights are on, or does daylight continue to produce at say a lower rate?
    #30
    @zboblamont These particular solar cells seem to perform about the same regardless of whether the weak indoor light is sourced from indoor LED lights or from outdoor light that has leaked into the room from behind closed shades.
    That's a lot different than most solar cells, which may output no current at all from even bright indoor LED lighting but which will outperform these cells from sunlight that has leaked into the room from behind closed curtains. That's one of the two things that makes these scavanged cells interesting. The other thing is that they have a much higher voltage, even under weak lighting. Go figure. I don't know why they are that way, so I just accept it as empirical fact.
    FWIW, for testing purposes, the solar cell industry has arbitrarily defined weak indoor lighting as 200 lux, which in my book is actually fairly bright. I would estimate that these cells still perform at below 200 lux. For instance, I can get LED blinks off my charge circuit just from pointing the cell at my TV from across the room in an otherwise completely dark house late at night. Maybe later I'll dig out my lux meter and take some measurements.
      zboblamontZ
      zboblamontZ
      zboblamont
      @neverdie Thanks for that clarification, intriguing possibilities indeed, who'd have thunk...
      Not concerned over what what light levels generate which level of power rather than the principle of continuity, i.e. day/artificial light agnostic.
      It would indeed be ironic in the leap from tungsten to LED for illumination, that alongside lower energy consumption, the possibility of recycling part of that reduced energy coincides.
      Bravo..
        Bravo..
        #32
        @zboblamont I made the circuit able to withstand any input voltage because I wanted to stack of bunch of solar cells in series and thereby, if possible, manage to charge even using just moonlight. Well, after experimenting with that concept last night, it looks as though solar cells just aren't additive in that way, at least not under ultra low lighting conditions like moonlight-only.
          zboblamontZ
          zboblamontZ
          zboblamont
          #33
          @neverdie Ah, Texans - "don't the stars look purty t'night?".... "Yeah, but the moon is only producin' 2mV honey..." Romance is not dead but buried...:sweat_smile:
          Just kidding, brilliant stuff... ;)
            #34
            @zboblamont I still have hopes if that if I can just get even 1ua from moonlight, even at a mere 20mv, that I'll be able to collect it and eventually harvest it using: https://www.openhardware.io/view/732/Extreme-Energy-Harvester
            That may yet still work.... I think maybe the reason why stringing a bunch of cells in series doesn't work is that at very low light levels, the leakage currents become dominant. Except, if that's so, why does it still show a high voltage?
            Fortunately, I don't have an actual need to harvest only moonlight. It's just that if I could, then my gear would be good enough to run pretty much anywhere, other than in complete blackness.
            Of course, if anyone has ideas on how to harvest moonlight, then please do post.
              zboblamontZ
              zboblamontZ
              zboblamont
              @neverdie "I still have hopes if that if I can just get even 1ua from moonlight..."
              Sounds like a job for a parabolic concentator increasing luminance on the panel, albeit at the risk of frying at the merest hint of sunlight..
                #36
                @zboblamont said in Solar Energy Harvesting for wireless motes:
                It would be ungainly, but that could work. For instance, ultra-low-lux security cameras have a little flag that rapidly pops up (faster than you can blink) to cover an imager and protect it against overexposure in those kinds of scenarios.
                  #37
                  @zboblamont I have the Buck Energy Harvester working now: https://www.openhardware.io/view/733/Buck-Energy-Harvester#tabs-design
                  However, fresh out of the box it turns out not to be compatible with the keychain fob solar cells. Why? What's not even mentioned In the LTC3388 datasheet'S executive summary introduction page is that the active quiescent current is 150-250ua, which is enough to completely overwhelm the keychain fob solar cell output of around 10ua. I thought perhaps it would instead accumulate a charge and later do a forced conversion in a burst mode, but it doesn't appear to work that way. Such a mode could probably be configured, but I don't see anything like it discussed in the datasheet, so it would require some design and prototyping. More to the point, though, is that in such a scenario, I no longer see that there's anything special about the LTC3388 versus any other buck converter. i.e. I might as well dump the LTC3388, which is fairly expensive, and replace it with a much less expensive, highly efficient buck converter that's also highly efficient running in a burst mode.
                    #38
                    I notice that TI has a relatively new buck converter chip, the LM5164. In comparing it to other buck converters, what stands out about it is that it has high efficiency, even at a load current of just a milliamp:
                    So, at least that much is impressive. However, its active current is 600-880ua, which is through the roof compared to the LTC3388, which is what led me to search for an alternative buck converter in the first place. The only way I can see to make use of it would be in very short bursts, which it fortunately seems designed to manage.
                    http://www.ti.com/lit/ds/symlink/lm5164.pdf?HQS=TI-null-null-mousermode-df-pf-null-wwe&DCM=yes&ref_url=https%3A%2F%2Fwww.mouser.com%2F
                    So, for that reason, for now I'll stick with the LTC3388 and leave the perfecting of the buck converter as a future optimization...
                      #39
                      So, this smoking gun more or less settles it the matter regarding the LTC3388:
                      Because of low efficiency at the microamp range, neither would appear to be a good match for solar cells extracted from the key fobs. Nonetheless, it would be a good match for higher current solar cells.
                        I hadn't been aware of it until now, but apparently there do exist batteries with a very low 0.7% annual self-discharge rate, which translates into still having 70% of their original capacity a full 40 years later! http://www.tadiranbat.com/assets/white-paper-for-sensors-online-revised.pdf They're fairly pricey, but do they seem like a much simpler method for getting past the cold-start problem on most energy harvesters. Presumably nearly all motes would be obsolete after 40 years anyway, and probably even long before that.
                          #41
                          Looks as though the EM8500 solar energy harvester can still function even if fed a current of just 1ua, for a total of 1uw power, and perhaps even less: https://www.emmicroelectronic.com/sites/default/files/products/datasheets/8500-ds.pdf
                          If I'm not mistaken, that's lower power than any other chip! And if it's price really is $2.30 for quantity 1, then that would make it one of the least expensive energy harvester chips as well.
                          Unfortunately, neither digikey nor mouser carry it.
                            #42
                            Intended for TEGs instead of photovoltaic, the EM8900 is nonetheless impressive. According to its datasheet, it can both cold start and operate with an input voltage as low as 5mv. That's far and away better than the LTC3108, which before now I had thought was the world leader with its 20mv minimum operating voltage. https://www.emmicroelectronic.com/sites/default/files/products/datasheets/8900-ds.pdf
                              @NeverDie can't you order from https://www.cdiweb.com/products/detail/em8500a001lf24b-em-microelectronic/594464/ ?
                                @mfalkvidd Yup. It was when looking there for the EM-8500 that I first noticed the EM-8900 (just 79 cents, quantity one!).
                                  Sasquatch
                                  cough cough , so much dust here in the archives... ;)
                                  @NeverDie SPV1050 is what you are looking for, only Maximum Power Point Tracking IC from all IC's you mentioned/tested in both your topics. And trust me, it makes a whole world of a difference. ST even have online component calculator for matching it to solar panel and battery used. My usage scenario was outdoor rechargeable coin cell battery and calculator solar cell. Only drawback: you have to determine maximum power point of your solar cell.
                                  • S Sasquatch
                                    #46
                                    @Sasquatch Cool! How did you wire yours up? Did you use an eval board of some kind, or did you do something custom? I actually have one of these:
                                    https://media.digikey.com/pdf/Data Sheets/DFRobot PDFs/DFR0579_Web.pdf
                                    but I hadn't gotten around to testing it. So, thanks for the feedback! Now I have a reason to try it sooner rather than later.
                                    Looks as though the setting of the "MPPT" may be similar to how the LTC3105 does it:
                                    https://www.openhardware.io/view/281/Solar-Energy-Harvester
                                    It's not really MPPT, though, so Linear Technology calls it MPPC instead.
                                      Sasquatch
                                      I made pcb for it it's on the roof of my flat, will dig trough my archives to see if i have kicad project for it.
