  3. Home Assistant
  4. TypeError: '<' not supported between instances of 'str' and 'int'
4 Posts 3 Posters 693 Views 3 Watching
  • Damian ChojnaD
    Damian ChojnaD
    Damian Chojna
    The problem
    When receive messages like 0;2;1;0;2;1
    Environment
    raspberry v4
    arduino mega with lib mysensors 2.3 connected with USB to raspberry:
    Home Assistant release (hass --version):
    0.104.3
    Python release (python3 --version):
    3.7.6
    HomeAssistant Logs:
    2020-01-30 12:45:06 DEBUG (MainThread) [mysensors] Receiving 0;2;1;0;2;1
    2020-01-30 12:45:06 ERROR (MainThread) [homeassistant.core] Error doing job: Exception in callback SerialTransport._read_ready()
      File "/usr/local/lib/python3.7/asyncio/events.py", line 88, in _run
        self._context.run(self._callback, *self._args)
      File "/usr/local/lib/python3.7/site-packages/serial_asyncio/__init__.py", line 106, in _read_ready
        self._protocol.data_received(data)
      File "/usr/local/lib/python3.7/site-packages/serial/threaded/__init__.py", line 65, in data_received
        self.handle_packet(packet)
      File "/usr/local/lib/python3.7/site-packages/serial/threaded/__init__.py", line 132, in handle_packet
        self.handle_line(packet.decode(self.ENCODING, self.UNICODE_HANDLING))
      File "/usr/local/lib/python3.7/site-packages/mysensors/__init__.py", line 437, in handle_line
        self.gateway.add_job(self.gateway.logic, line)
      File "/usr/local/lib/python3.7/site-packages/mysensors/__init__.py", line 375, in add_job
        reply = self.run_job(job)
      File "/usr/local/lib/python3.7/site-packages/mysensors/__init__.py", line 151, in run_job
        reply = func(*args)
      File "/usr/local/lib/python3.7/site-packages/mysensors/__init__.py", line 72, in logic
        ret = handler(msg)
      File "/usr/local/lib/python3.7/site-packages/mysensors/handler.py", line 64, in handle_set
        msg.child_id, msg.sub_type, msg.payload)
      File "/usr/local/lib/python3.7/site-packages/mysensors/sensor.py", line 123, in set_child_value
        msg.validate(self.protocol_version)
      File "/usr/local/lib/python3.7/site-packages/mysensors/message.py", line 78, in validate
        const = get_const(protocol_version)
      File "/usr/local/lib/python3.7/site-packages/mysensors/const.py", line 25, in get_const
        ), 'mysensors.const_14')
    Arduino code:
    //#define MY_RADIO_NRF24
    // Enable serial gateway
    #define MY_GATEWAY_SERIAL
    #if F_CPU == 8000000L
    #define MY_BAUD_RATE 38400
    // Flash leds on rx/tx/err
    // #define MY_LEDS_BLINKING_FEATURE
    // Set blinking period
    // #define MY_DEFAULT_LED_BLINK_PERIOD 300
    // #define MY_WITH_LEDS_BLINKING_INVERSE
    // Enable inclusion mode
    #define MY_REPEATER_FEATURE
    #define RELAY_1  4  // Arduino Digital I/O pin number for first relay (second on pin+1 etc)
    #define RELAY_2  5
    #define NUMBER_OF_RELAYS 2 // Total number of attached relays
    #define BUTTON_PIN A1
    #define BUTTON2_PIN A2
    void before() {
        pinMode(pin, OUTPUT);
    Bounce debouncer = Bounce();
    Bounce debouncer2 = Bounce();
      delay(10000);
       // Setup the button.
      pinMode(BUTTON_PIN, INPUT_PULLUP);
      pinMode(BUTTON2_PIN, INPUT_PULLUP);
      // After setting up the button, setup debouncer.
      debouncer.attach(BUTTON_PIN);
      debouncer.interval(5);
      debouncer2.interval(5);
      //presentation();
      sendSketchInfo("Relay", "1.0");
        present(sensor, S_BINARY);
    MyMessage msg(1, V_STATUS);
    MyMessage msg2(2, V_STATUS);
      if (debouncer.update()) {
        // Get the update value.
        int value = debouncer.read();
        // Send in the new value.
        if(value == LOW){
             saveState(1, !loadState(1));
             digitalWrite(RELAY_1, loadState(1)?RELAY_ON:RELAY_OFF);
             send(msg.set(loadState(1)));
      if (debouncer2.update()) {
        if(value2 == LOW){
             saveState(2, !loadState(2));
             digitalWrite(RELAY_2, loadState(2)?RELAY_ON:RELAY_OFF);
             send(msg2.set(loadState(2)));
      if (message.type==V_STATUS) {
         // Change relay state
         // Store state in eeprom
    • mfalkviddM
      (moved from Troubleshooting to Home Assistant, since Hass users might be more active in the Hass category)
      • skywatchS
        skywatchS
        skywatch
        I am not sure what is happening but that error message seems to imply that you are trying to compare a string to an interger. That is not possible with arduino as it stands now.
        You should get the 'value' of the string into interger form to compare the values.
        Damian ChojnaD 1 Reply Last reply
        • skywatchS skywatch
          Damian ChojnaD
          Damian ChojnaD
          Damian Chojna
          @skywatch it's not me trying to compare, it happens in the mysensors library when receiving messages. It seems that mysensors is badly implemented in the home assistant, in domoticz it works very well
          12.5k
