  3. pimatic
  4. pimatic-mysensors controller plugin
Scheduled Pinned Locked Moved pimatic
controllernode idnrf24l01+mysensorsrasp
92 Posts 23 Posters 76.5k Views 11 Watching
  • R
    R
    ricardot
    I can´t make mysensors plugin works in pimatic. I added this lines at plugins session of config.json with no sucess:
    "plugin": "MySensors",
    "driver": "serialport",
    "protocols": "1.4.1",
    "driverOptions": {
    "serialDevice": "/dev/ttyUSB0", # #'/dev/ttyUSBx' if using serial Gateway
    "baudrate": 115200
    I received error messages like syntax error.
    D 2 Replies Last reply
    • R ricardot
      "driverOptions": {
      "baudrate": 115200
      Dheeraj
      @ricardot said:
      let me the exact error msg.
      R 1 Reply Last reply
      • D Dheeraj
        R
        R
        ricardot
        @Dheeraj said:
        15:16:12.055 [pimatic] Starting pimatic version 0.8.45
        15:16:15.227 [pimatic] Startup error: Error: Parse error on line 80:
        15:16:15.227 [pimatic]>..."/dev/ttyUSB0", "#" "#""/dev/ttyUSBx" "i
        15:16:15.227 [pimatic]>-----------------------^
        15:16:15.227 [pimatic]>Expecting 'EOF', '}', ':', ',', ']', got 'STRING'
        15:16:15.227 [pimatic]> at Object.parseError (/usr/local/pimatic-app/node_modules/pimatic/node_modules/cjson/node_modules/jsonlint/lib/jsonlint.js:55:11)
        15:16:15.227 [pimatic]> at Object.parse (/usr/local/pimatic-app/node_modules/pimatic/node_modules/cjson/node_modules/jsonlint/lib/jsonlint.js:132:22)
        15:16:15.227 [pimatic]> at Object.exports.parse (/usr/local/pimatic-app/node_modules/pimatic/node_modules/cjson/node_modules/jsonlint/lib/jsonlint.js:417:53)
        15:16:15.227 [pimatic]> at Object.exports.parse (/usr/local/pimatic-app/node_modules/pimatic/node_modules/cjson/index.js:88:28)
        15:16:15.227 [pimatic]> at Framework._loadConfig (/usr/local/pimatic-app/framework.coffee:96:24)
        15:16:15.227 [pimatic]> at new Framework (/usr/local/pimatic-app/framework.coffee:54:8)
        15:16:15.227 [pimatic]> at /usr/local/pimatic-app/startup.coffee:48:21
        15:16:15.227 [pimatic]> at tryCatch1 (/usr/local/pimatic-app/node_modules/pimatic/node_modules/bluebird/js/main/util.js:43:21)
        15:16:15.227 [pimatic]> at Function.Promise$_Try (/usr/local/pimatic-app/node_modules/pimatic/node_modules/bluebird/js/main/promise.js:233:11)
        15:16:15.227 [pimatic]> at Object.module.exports.startup (/usr/local/pimatic-app/startup.coffee:47:10)
        15:16:15.227 [pimatic]> at run (/usr/local/pimatic-app/node_modules/pimatic/pimatic.js:15:24)
        15:16:15.227 [pimatic]> at Object.<anonymous> (/usr/local/pimatic-app/node_modules/pimatic/pimatic.js:20:3)
        15:16:15.227 [pimatic]> at Module._compile (module.js:456:26)
        15:16:15.227 [pimatic]> at Object.Module._extensions..js (module.js:474:10)
        15:16:15.227 [pimatic]> at Module.load (module.js:356:32)
        15:16:15.227 [pimatic]> at Function.Module._load (module.js:312:12)
        15:16:15.227 [pimatic]> at Function.Module.runMain (module.js:497:10)
        15:16:15.227 [pimatic]> at startup (node.js:119:16)
        15:16:15.227 [pimatic]> at node.js:902:3
        15:16:15.274 [pimatic] exiting...
        • R
          R
          ricardot
          I removed the # #'/dev/ttyUSBx' if using serial Gateway
          So I got this:
          15:17:54.005 [pimatic] Starting pimatic version 0.8.45
          15:17:58.403 [pimatic] loading plugin: "pimatic-cron" (0.8.5)
          15:18:00.793 [pimatic] loading plugin: "pimatic-mobile-frontend" (0.8.44)
          15:18:05.848 [pimatic] loading plugin: "pimatic-mail" (0.8.2)
          15:18:08.301 [pimatic] Installing: "MySensors"
          15:18:16.958 [pimatic, npm] http GET https://registry.npmjs.org/pimatic-MySensors
          15:18:18.741 [pimatic, npm] http 404 https://registry.npmjs.org/pimatic-MySensors
          15:18:18.848 [pimatic, npm] ERR! 404 'pimatic-MySensors' is not in the npm registry.
          15:18:18.872 [pimatic, npm] ERR! 404 You should bug the author to publish it
          15:18:18.896 [pimatic, npm] ERR! 404
          15:18:18.914 [pimatic, npm] ERR! 404 Note that you can also install from a
          15:18:18.955 [pimatic, npm] ERR! 404 tarball, folder, or http url, or git url.
          15:18:18.964 [pimatic, npm] ERR! System Linux 3.12.28+
          15:18:18.986 [pimatic, npm] ERR! command "/usr/local/bin/node" "/usr/local/bin/npm" "install" "pimatic-MySensors"
          15:18:19.005 [pimatic, npm] ERR! cwd /usr/local/pimatic-app
          15:18:19.025 [pimatic, npm] ERR! node -v v0.10.24
          15:18:19.034 [pimatic, npm] ERR! npm -v 1.3.21
          15:18:19.056 [pimatic, npm] ERR! code E404
          15:18:19.161 [pimatic, npm] ERR!
          15:18:19.192 [pimatic, npm] ERR! Additional logging details can be found in:
          15:18:19.205 [pimatic, npm] ERR! /usr/local/pimatic-app/npm-debug.log
          15:18:19.213 [pimatic, npm] ERR! not ok code 0
          15:18:19.312 [pimatic] Error running "npm install pimatic-MySensors"
          15:18:20.192 [pimatic-cron] the time is: Mon Feb 16 2015 15:18:20 GMT+0000 (UTC)
          15:18:20.996 [pimatic-mobile-frontend] packing static assets
          15:18:22.251 [pimatic-mobile-frontend] packing static assets finished
          15:18:22.273 [pimatic-mobile-frontend] rendering html
          15:18:44.851 [pimatic-mobile-frontend] rendering html finished
          15:18:44.989 [pimatic] listening for http-request on port 80...
          • D
            Dheeraj
            Since i haven't register mysensors with npm. that's the reason it is giving you the error. As a work around try download & manually installing pimatic-MySensors in node_module in pimatic-app folder.. Here other plugins are also installed like Pimatic-mobile-fontend etc.. Pimatic should be able to pick it up..
            I will try to fix this issue meanwhile.
            Let me know if it's works.
            • R
              R
              ricardot
              I manually installed the pimatic-mysensors, seems it works, but I'm receiving this message:
              13:46:47.360 [pimatic] Cannot find module 'bluebird'
              Later I added two devices, a PIR and a relay-switch, and I'm receiving this message:
              13:46:49.289 [pimatic] no plugin found for device "Switch" of class "MySensorsSwitch"!
              13:46:49.305 [pimatic] no plugin found for device "PIR" of class "MySensorsPIR"!
              D 1 Reply Last reply
              • R ricardot
                Dheeraj
                give me sometime will fix this issue.
                • R ricardot
                  "driverOptions": {
                  "baudrate": 115200
                  Dheeraj
                  wrote on last edited by Dheeraj
                  @ricardot
                  I have fixed the issues, plugin published to public npm registry . now i think it should work perfectly
                  • D Dheeraj
                    @ricardot
                    R
                    R
                    ricardot
                    @Dheeraj
                    It worked now, but I had to change the ttyUSB0 to ttyACM0. I'm using the uno for the gateway.
                    • R
                      R
                      ricardot
                      Dheeraj,
                      When we can expect more variables available to mysensors plugin? I miss a simple on off switch.
                      • R ricardot
                        Dheeraj,
                        Dheeraj
                        @ricardot
                        contact/door/light mysensor add to list.. just check :)
                        upload-58e0611e-710b-4a9a-9337-60282ed10131
                        • G
                          G
                          gogomartin
                          wrote on last edited by gogomartin
                          @Dheeraj
                          This is my first try at getting MySensors to work.
                          I've connected a SerialGateway to the Pi, and configured a DHT22 sensor. But no values are recorded.
                          Logs from the pi:
                          <- I_LOG_MESSAGE 0;0;3;0;9;read: 255-255-0 s=255,c=3,t=3,pt=0,l=0:
                          <- I_ID_REQUEST 255;255;3;0;3;
                          Serial output from the sensor:
                          req node id
                          send: 255-255-0-0 s=255,c=3,t=3,pt=0,l=0,st=ok:
                          T: 22.70
                          req node id
                          H: 31.10
                          req node id
                          H: 31.00
                          What can I be doing wrong? Seems like the sensor is requesting a node ID but not getting any?
                          Thank you for any kind of response!
                          Regards, Martin
                          • G gogomartin
                            @Dheeraj
                            Logs from the pi:
                            req node id
                            T: 22.70
                            req node id
                            H: 31.10
                            req node id
                            H: 31.00
                            Regards, Martin
                            Dheeraj
                            @gogomartin
                            Currently mysensors plugin only support static node id. Try configuring static node id in sensor code. Hint.. Gw. Begin (null, node id)
                            Sebastien Vayrette-GavardS 1 Reply Last reply
                            • R
                              R
                              ricardot
                              Dheeraj,
                              Good work!
                              Is possible to send sensor battery level info?
                              • R ricardot
                                Dheeraj,
                                Good work!
                                Dheeraj
                                @ricardot
                                battery sensor visualization is WIP..
                                • R
                                  R
                                  Ralf H
                                  hey,
                                  I really like your plugin now that I finally managed to get everything working. :)
                                  But I would also like to use a BH1750 Light sensor with your plugin. I made a sensorbox with PIR to switch on lights for a minute when movement is detected, but I only want to switch on light when it's dark enough. Is it planned to add support for this?
                                  • D
                                    Dheeraj
                                    • R ricardot
                                      Dheeraj,
                                      Good work!
                                      Dheeraj
                                      @ricardot added support for battery level stats 0.8.9
                                      • R Ralf H
                                        hey,
                                        Dheeraj
                                        @Ralf-H sure will add support for light sensor
                                        • Vladut GrecuV
                                          Vladut GrecuV
                                          Vladut Grecu
                                          wrote on last edited by Vladut Grecu
                                          #24
                                          I would like to help you make a color picker for rgb leds and a slider for random pwm outputs :D
                                          -edit-
                                          deviceClasses = [
                                                  MySensorsDHT
                                                  MySensorsBMP
                                                  MySensorsPIR
                                                  MySensorsSwitch
                                                  MySensorsPulseMeter
                                                  MySensorsButton
                                                  MySensorBattery
                                                  MySensorsDevDimmer
                                          and
                                           class MySensorsDevDimmer extends env.devices.DimmerActuator
                                              constructor: (@config,lastState, @board) ->
                                                @id = config.id
                                                @name = config.name
                                                @_state = lastState?.state?.value
                                                env.logger.info "MySensorsDevDimmer" , @id , @name, @_state
                                                @board.on('rfValue', (result) =>
                                                  if result.sender is @config.nodeid and result.type is
                                                  V_LIGHT and result.sensor is @config.sensorid
                                                    state = (if parseInt(result.value) is 1 then on else off)
                                                    env.logger.info "<- MySensorDevDimmer " , result
                                                    @_setState(state)
                                                super()
                                              changeStateTo: (state) ->
                                                assert state is on or state is off
                                                if state is true then _state = 1  else _state = 0
                                                datas = {}
                                                datas =
                                                  "destination": @config.nodeid,
                                                  "sensor": @config.sensorid,
                                                  "type"  : V_LIGHT,
                                                  "value" : _state,
                                                  "ack"   : 1
                                                @board._rfWrite(datas).then ( () =>
                                                  @_setState(state)
                                          But i get :
                                          Could not initialize the plugin "mysensors": MySensorsDevDimmer is not defined
                                          I know that this won`t actually work because of the :
                                          and the :
                                          What I don't get is why does it throw me that error. (Don't go hard on me, I just learned the basics of coffee script only for this)
