  3. pimatic
  4. pimatic-mysensors controller plugin
Scheduled Pinned Locked Moved pimatic
controllernode idnrf24l01+mysensorsrasp
92 Posts 23 Posters 76.6k Views 11 Watching
  • R ricardot
    I can´t make mysensors plugin works in pimatic. I added this lines at plugins session of config.json with no sucess:
    "plugin": "MySensors",
    "driver": "serialport",
    "protocols": "1.4.1",
    "driverOptions": {
    "serialDevice": "/dev/ttyUSB0", # #'/dev/ttyUSBx' if using serial Gateway
    "baudrate": 115200
    I received error messages like syntax error.
    Dheeraj
    wrote on last edited by Dheeraj
    @ricardot
    I have fixed the issues, plugin published to public npm registry . now i think it should work perfectly
    R 1 Reply Last reply
    • D Dheeraj
      @ricardot
      R
      R
      ricardot
      @Dheeraj
      It worked now, but I had to change the ttyUSB0 to ttyACM0. I'm using the uno for the gateway.
      • R
        R
        ricardot
        Dheeraj,
        When we can expect more variables available to mysensors plugin? I miss a simple on off switch.
        D 1 Reply Last reply
        • R ricardot
          Dheeraj,
          Dheeraj
          @ricardot
          contact/door/light mysensor add to list.. just check :)
          upload-58e0611e-710b-4a9a-9337-60282ed10131
          • G
            G
            gogomartin
            wrote on last edited by gogomartin
            @Dheeraj
            This is my first try at getting MySensors to work.
            I've connected a SerialGateway to the Pi, and configured a DHT22 sensor. But no values are recorded.
            Logs from the pi:
            <- I_LOG_MESSAGE 0;0;3;0;9;read: 255-255-0 s=255,c=3,t=3,pt=0,l=0:
            <- I_ID_REQUEST 255;255;3;0;3;
            Serial output from the sensor:
            req node id
            send: 255-255-0-0 s=255,c=3,t=3,pt=0,l=0,st=ok:
            T: 22.70
            req node id
            H: 31.10
            req node id
            H: 31.00
            What can I be doing wrong? Seems like the sensor is requesting a node ID but not getting any?
            Thank you for any kind of response!
            Regards, Martin
            • G gogomartin
              @Dheeraj
              Logs from the pi:
              req node id
              T: 22.70
              req node id
              H: 31.10
              req node id
              H: 31.00
              Regards, Martin
              Dheeraj
              @gogomartin
              Currently mysensors plugin only support static node id. Try configuring static node id in sensor code. Hint.. Gw. Begin (null, node id)
              Let me know if it's works
              Sebastien Vayrette-GavardS 1 Reply Last reply
              • R
                R
                ricardot
                Dheeraj,
                Good work!
                Is possible to send sensor battery level info?
                D 2 Replies Last reply
                • R ricardot
                  Dheeraj,
                  Good work!
                  Dheeraj
                  @ricardot
                  battery sensor visualization is WIP..
                  • R
                    R
                    Ralf H
                    hey,
                    I really like your plugin now that I finally managed to get everything working. :)
                    But I would also like to use a BH1750 Light sensor with your plugin. I made a sensorbox with PIR to switch on lights for a minute when movement is detected, but I only want to switch on light when it's dark enough. Is it planned to add support for this?
                    • D
                      Dheeraj
                      • R ricardot
                        Dheeraj,
                        Good work!
                        Dheeraj
                        @ricardot added support for battery level stats 0.8.9
                        • R Ralf H
                          hey,
                          Dheeraj
                          @Ralf-H sure will add support for light sensor
                          • Vladut GrecuV
                            Vladut GrecuV
                            Vladut Grecu
                            wrote on last edited by Vladut Grecu
                            #24
                            I would like to help you make a color picker for rgb leds and a slider for random pwm outputs :D
                            -edit-
                            deviceClasses = [
                                    MySensorsDHT
                                    MySensorsBMP
                                    MySensorsPIR
                                    MySensorsSwitch
                                    MySensorsPulseMeter
                                    MySensorsButton
                                    MySensorBattery
                                    MySensorsDevDimmer
                            and
                             class MySensorsDevDimmer extends env.devices.DimmerActuator
                                constructor: (@config,lastState, @board) ->
                                  @id = config.id
                                  @name = config.name
                                  @_state = lastState?.state?.value
                                  env.logger.info "MySensorsDevDimmer" , @id , @name, @_state
                                  @board.on('rfValue', (result) =>
                                    if result.sender is @config.nodeid and result.type is
                                    V_LIGHT and result.sensor is @config.sensorid
                                      state = (if parseInt(result.value) is 1 then on else off)
                                      env.logger.info "<- MySensorDevDimmer " , result
                                      @_setState(state)
                                  super()
                                changeStateTo: (state) ->
                                  assert state is on or state is off
                                  if state is true then _state = 1  else _state = 0
                                  datas = {}
                                  datas =
                                    "destination": @config.nodeid,
                                    "sensor": @config.sensorid,
                                    "type"  : V_LIGHT,
                                    "value" : _state,
                                    "ack"   : 1
                                  @board._rfWrite(datas).then ( () =>
                                    @_setState(state)
                            But i get :
                            Could not initialize the plugin "mysensors": MySensorsDevDimmer is not defined
                            I know that this won`t actually work because of the :
                            and the :
                            What I don't get is why does it throw me that error. (Don't go hard on me, I just learned the basics of coffee script only for this)
                            • Vladut GrecuV Vladut Grecu
                              -edit-
                              deviceClasses = [
                                      MySensorsDHT
                                      MySensorsBMP
                                      MySensorsPIR
                                      MySensorsSwitch
                                      MySensorsPulseMeter
                                      MySensorsButton
                                      MySensorBattery
                                      MySensorsDevDimmer
                              and
                                    @id = config.id
                                    @name = config.name
                                        @_setState(state)
                                    super()
                                    datas = {}
                                    datas =
                                      "type"  : V_LIGHT,
                                      "value" : _state,
                                      "ack"   : 1
                                      @_setState(state)
                              But i get :
                              and the :
                              Dheeraj
                              check the pimatic-daemon.log file and what kind of error exception your are getting . not sure if you have enable the "logLevel": "debug", in config.json for pimatic.
                              Also, you need to add entry in device-config-schema.coffee schema file.
                              if nothing works share the log file with me..
                              I'm also new to coffee or nodejs and struggled a lot understanding the coffee script , basically, still in learning phase..
                              • D Dheeraj
                                @gogomartin
                                @Dheeraj, I have been looking all day for how to configure static node id , meanwhile I heard of mysensors last night so pardon me if I didn't find the doc that explain it. Can you point me in the right direction?
                                • Sebastien Vayrette-GavardS
                                  I didn't search enough, http://forum.mysensors.org/topic/753/static-node-id-and-other-unanswered-questions
                                  • Sebastien Vayrette-GavardS Sebastien Vayrette-Gavard
                                    Dheeraj
                                    follow the below instruction
                                    for pimatic installation:
                                    http://www.pimatic.org/guide/getting-started/installation/
                                    plugin instruction:
                                    https://github.com/DheerajKhajuria/pimatic-mysensors
                                    • J
                                      J
                                      jurasek
                                      Hello, I am new with controler. I already have some temperature sensors and other controls, but until now I did not use any controller,
                                      I am not familiar with linux, and I need help with instalation of controler on raspbery 2.
                                      I am done with OS instalation, I am using image NOOBS.
                                      I try to install Pimatic acording this procedure, http://pimatic.org/guide/getting-started/installation/
                                      And now I am not sure what next.
                                      Please can anybody help me?
                                      funky81F 1 Reply Last reply
                                      • J jurasek
                                        funky81F
                                        funky81F
                                        funky81
                                        @jurasek I found out that pimatic installation in the website quite general.
                                        for more details, you can use following link for the forum.
                                        it gives me clear idea and more details step by step
                                        • J
                                          J
                                          jurasek
                                          Thanks, I have a pimatic runing now. I would like connect NRF24 directly to the RPI is this possible? How can I setup mysensors plugin for this?
