  3. VS838 IR receiver led anyone got it working with mys?
25 Posts 3 Posters 2.3k Views 3 Watching
  • skywatchS
    skywatchS
    skywatch
    I just noticed a 'delay(100);' in the code above. It shouldn't be there, so will change it to 'wait(100);' and see if that was the problem - A new day a new try!
    Well that wasn't the issue and I successfully combined the IRreceive and BH1750 sketches and all worked as expected. So something is happening when MySendors is involved, the question is what? - I'll continue to think on this and see what else I can think to try.
    electrikE 1 Reply Last reply
    • skywatchS skywatch
      electrikE
      electrikE
      electrik
      @skywatch
      What is your memory usage?
      skywatchS 1 Reply Last reply
      • electrikE electrik
        @skywatch
        skywatchS
        skywatchS
        skywatch
        @electrik At compilation I get the following....
        Sketch uses 21718 bytes (70%) of program storage space. Maximum is 30720 bytes.
        Global variables use 1207 bytes (58%) of dynamic memory, leaving 841 bytes for local variables. Maximum is 2048 bytes.
        It looks OK to me, but I have been wrong before (and will be again, probably quite soon ) ; ).
        I have 2 other nodes that will also require IR Tx/Rx between them so will try and build them this weekend and see if I get the same issue.
        • electrikE
          electrikE
          electrik
          wrote on last edited by electrik
          You could also add debug prints at specific points so you find out where the code still runs.
          edit To me the memory looks fine. Only if use a lot of stack it could give trouble, but it seems enough space is available
            skywatchS
            skywatchS
            skywatch
            @electrik It seems that the IR if statement is never actioned.
            I added
            Serial.println("Enabling IRin");
              irrecv.enableIRIn(); // Start the receiver
              Serial.println("Enabled IRin");
            To setup and that seems to be OK....
            121 !MCO:SND:NODE NOT REG
            1123 MCO:REG:REQ
            1126 TSF:MSG:SEND,25-25-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
            1133 TSF:MSG:READ,0-0-25,s=255,c=3,t=27,pt=1,l=1,sg=0:1
            1138 MCO:PIM:NODE REG=1
            1140 MCO:BGN:STP
            Enabling IRin
            Enabled IRin
            1153 MCO:BGN:INIT OK,TSP=1
            1227 TSF:MSG:SEND,25-25-0-0,s=5,c=1,t=2,pt=3,l=2,sg=0,ft=0,st=OK:1
            But for some reason I can't find, it never executes the receive If code.
            Also tried input pins D2.4,6,8 and all show the same lack of doing what they should!
            Very strange!
              I added
              1123 MCO:REG:REQ
              1140 MCO:BGN:STP
              Enabling IRin
              Enabled IRin
              Very strange!
              @skywatch I found some time to rebuild your setup:
              Arduino UNO, nRF24 default connection no IRQ, TSOP1738 connected to D6, Arduino IDE 1.8.10
              Tested first with IRRecord sketch, same pinning, working fine.
              Absolute bare minimum sketch, containing MySensors (2.3.2) and IR Receiver using the same library (current version):
              #define MY_BAUD_RATE (57600)
              #define MY_RADIO_RF24
              #define MY_RF24_CE_PIN              (9)
              #define MY_RF24_CS_PIN              (10)
              #define MY_NODE_ID                  (254)
              #define MY_PARENT_NODE_ID           (0)
              #include <Arduino.h>
              #include <IRremote.h>
              const int RECV_PIN = 6;
              IRrecv irrecv(RECV_PIN);
                  Serial.println(F("-- Init MySensors"));
                  sendSketchInfo(F("IRSensor"), F("1.0"));
                  decode_results results;
                  if (irrecv.decode(&results))
                      for (int i = 0; i < results.rawlen - 1; ++i)
                          Serial.print(results.rawbuf[i], DEC);
                      Serial.println();
                      irrecv.resume();
              Added basic MySensors sketch, same pinning working fine:
              33 MCO:BGN:INIT NODE,CP=RNNNA---,FQ=16,REL=255,VER=2.3.2
              54 TSM:INIT
              56 TSF:WUR:MS=0
              64 TSM:INIT:TSP OK
              67 TSM:INIT:STATID=254
              72 TSF:SID:OK,ID=254
              75 TSM:FPAR
              77 TSM:FPAR:STATP=0
              81 TSM:ID
              82 TSM:ID:OK
              86 TSM:UPL
              89 TSF:MSG:SEND,254-254-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
              101 TSF:MSG:READ,0-0-254,s=255,c=3,t=25,pt=1,l=1,sg=0:1
              110 TSF:MSG:PONG RECV,HP=1
              115 TSM:UPL:OK
              118 TSM:READY:ID=254,PAR=0,DIS=1
              124 TSF:MSG:SEND,254-254-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
              138 TSF:MSG:READ,0-0-254,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
              149 TSF:MSG:SEND,254-254-0-0,s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=OK:2.3.2
              163 TSF:MSG:SEND,254-254-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0
              -- Init MySensors
              2177 TSF:MSG:SEND,254-254-0-0,s=255,c=3,t=11,pt=0,l=8,sg=0,ft=0,st=OK:IRSensor
              2193 TSF:MSG:SEND,254-254-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=OK:1.0
              2205 MCO:REG:REQ
              2209 TSF:MSG:SEND,254-254-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
              2223 TSF:MSG:READ,0-0-254,s=255,c=3,t=27,pt=1,l=1,sg=0:1
              2232 MCO:PIM:NODE REG=1
              2237 MCO:BGN:STP
              2240 MCO:BGN:INIT OK,TSP=1
              142892861371371371371371227137128137137137128128128128128128712271326132712812271326137132712812812713713713713271281227122713271227
              113792861371371371371281326137137137137137128128128128128128712271327122712812271327127132712812812812812812713271281227132613271227
              113692861371371371371371327127137137137137137137137128128128713261327122713713261327128122713712812812812812812271281227132712271227
              113692871281271371371371327128127137137137137137137137137128713261327122713713261327128122712813713712812812812271371326132712271326
              113692871281281271371371327128128127137137137137137128137138613271227122713713271227128122713713713713712812812271281227132712271326
              2699393861371371361461371327137137137136146137137137137137138613271326132613713271326137132613713713713713713713261371326142613261325
              113692861371371371371371326137137137137137137136146137137138614261326132713614261326137132614613713713713713713261371327132613261327
              113692861371371371371371326137137137137137137137137136146138713261326132713713261326137132713614613713713713713261461327132613251526
              113691871371281281281281227137128128128128128128127137137138712271227132712811281227137122812713712812812812812271371228122713261327
              1137898912811911911911911281281191191191191191191191010109118912271227122812811281227128112912810911911911911911291181129122712281128
              113789891371281281191281227128128128128128128128119128118128812271227122812812271227128122812811812812812812812281271228122712281227
              I suggest to try with my sketch and see if that works.
              BTW. Passing a LED pin to the constructor as status indicator doesn't seem to work, or my eyes are just too slow :smirk:
              • YveauxY Yveaux
                        Serial.println();
                        irrecv.resume();
                54 TSM:INIT
                56 TSF:WUR:MS=0
                64 TSM:INIT:TSP OK
                75 TSM:FPAR
                77 TSM:FPAR:STATP=0
                81 TSM:ID
                82 TSM:ID:OK
                86 TSM:UPL
                115 TSM:UPL:OK
                -- Init MySensors
                2205 MCO:REG:REQ
                2237 MCO:BGN:STP
                skywatchS
                skywatchS
                skywatch
                @Yveaux I cannot thank you enough for doing this to try and help me out. It is really kind of you.
                I am using 1.8.9 IDE as I had issues with 1.8.10 (as did others). Also I notice that you have forced 57600 as the baud rate in the sketch. Is this the magic bullet I wonder as I left mine at the default 115200 setting. I can't imagine why it would make a difference though.
                I will be trying it shortly and will report back with anything I find.
                I owe you a beer for sure! ;)
                  @skywatch said in VS838 IR receiver led anyone got it working with mys?:
                  Glad I could help!
                  I didn't encounter any issues with 1.8.10 so far, but I don't expect it will make a difference in your case
                  57600 is the default baud rate at 3v3 for pro mini iirr. This might be related to when using the internal oscillator and the frequency errors introduced by it. But pro mini uses an external crystal so I have to dig the datasheets to know for sure. Maybe some other forum member knows it by heart...
                  Great! That I will remember :laughing:
                  • YveauxY Yveaux
                    Glad I could help!
                    skywatchS
                    skywatchS
                    skywatch
                    @Yveaux Your code works.....until I add it to mine and then it stops working for some inexplicable reason that will drive me insane I think. ;)
                    I copied across your code line by line and still it refuses to 'see' any IR commands being received.
                    I have tried excluding the watchdog, excluding the bh1750, adding arduino.h and excluding wire.h and none of those make any difference.
                      @skywatch Maybe the cause lies outside your sketch; Are you using MySensors 2.3.2? Or do try with Arduino 1.8.10
                      skywatchS 2 Replies Last reply
                      • YveauxY Yveaux
                        skywatchS
                        skywatchS
                        skywatch
                        @Yveaux I have narrowed it down to a small section of code.....still working on it!
                        • YveauxY Yveaux
                          skywatchS
                          skywatchS
                          skywatch
                          @Yveaux Ihave 2 issues that I have identified, but can't work out the cause.
                          Issue 1 - No IR received seems to be caused by thise section of code. Commenting it out and it works as expected (but of course will never transmit).....
                           if (newcodeRX == 1 || lightrequest == 1) {
                              irsend.sendNEC(INcode, 32);
                              newcodeRX = 0;
                              lightrequest = 0;
                          Second issue, is when receiving IR is working I cannot do anything useful with it. I have tried 2 methods to get a value and perform a function with it and both fail. See the 2 methods tried here......
                            if (irrecv.decode(&results)) {
                              Serial.print("IR Received... ");
                              Serial.println(results.value, HEX);
                              IRin = (results.value, HEX);
                              Serial.print(" IRin... ");
                              Serial.println(IRin);
                               irrecv.resume(); // Receive the next value
                            if (IRin == 0xFFA25D) {
                              lights = 1;
                              Serial.print("Lights ON... ");
                            if ((results.value, HEX) == 0xFFE21D) {
                              lights = 0;
                              Serial.print("Lights OFF... ");
                          I need to eat now, will get back to this later on......
                          • skywatchS
                            skywatchS
                            skywatch
                            Second issue now solved, just the first one to investigate.... ;)
                            • skywatchS
                              skywatchS
                              skywatch
                              #22
                              Both issues now resolved! :)
                              More to follow..... ;)
                              • skywatchS
                                skywatchS
                                skywatch
                                So here is what I learned from all this....
                                Issue 1 - Was caused by the fact that IRsend was called at first boot - nothing wrong with that, but what I didn't know was that IRsend disables IR receive.
                                The solution was as simple as adding one more line to that section of code as follows.....
                                    newcodeRX = 0;
                                    lightrequest = 0;
                                This re-enables the receiver and then all is working as expected!
                                As for the second issue......Well, I'll just post the code for anyone interested.....
                                    IRin = results.value,HEX;
                                    lights = 1;
                                  if (IRin == 0xFFE21D) {
                                    lights = 0;
                                  if (lights != last_lights) {
                                    saveState(10, lights);
                                    send(msgLights.set(lights));
                                    last_lights = lights;
                                It's always soooooo easy when you know how! ;)
                                Onwards and upwards! :)
                                      newcodeRX = 0;
                                      lightrequest = 0;
                                      lights = 1;
                                      lights = 0;
                                  @skywatch great to hear you resolved your issues!
                                  • skywatchS
                                    skywatchS
                                    skywatch
                                    Many thanks @electrik and @Yveaux , some moral support is often pivotal in getting things done!
                                    @Yveaux IDE 1.8.12 is now available and working fine on win10 x64 for me :)
                                    12.5k
