  3. Everything nRF52840
Everything nRF52840
323 Posts 28 Posters 172.1k Views 33 Watching
    #292
    @orhanyor I can confirm this pcb antenna works well. I used it with 52832 a while ago. You'll certainly need to tune it to get the exact target freq though, usually to do on each new pcb design&shape (so it's not shifted too much compared to your others nodes), but it's a good antenna, easy to use, resistant to detuning. This is the recommended ant by TI for 2.4ghz.
    Here I just have one bt840xe on custom gw (dual band gw, using BLE for 2.4ghz) with good external ant, it has very good range. I didn't design the 52840+PA because I preferred to have ce/fcc for PA, and for one device only, it wasn't worth the shot. For others nodes, I don't need PA, or prefer mysensors subghz for very long range.
    For a devboard, this looks nice, but depending on the target application and sensitive sensors etc, maybe adding an rf shield could help in some cases, especially as you're planning to use a power amplifier. Spectrum analyzer (or a vna) can help to check this (bad rf emissions too, passive filtering can help) and optimize range.
    good luck for your soldering :)
    orhanyorO 1 Reply Last reply
    • scalzS scalz
      orhanyorO
      orhanyorO
      orhanyor
      @scalz thanks for the input, ive seen they tune it by cutting a length from the longer end but in order to do that i need equipment which i dont have so its going to be a hit or miss :) if it doesnt work well i can use SMA antenna but i think thats the least of my worries with that pcb. I like to experiment and see for myself so even if its wasted its ok :)
        Mishka
        So, 8dBm built-in, plus 20dBm PA, plus 12dBi for the feedhorn, plus 20dBi for the dish. Add the coded PHY on top of this. Does anybody want to set a record? =)
        • M Mishka
          Mishka
          wrote on last edited by Mishka
          #295
          In a meanwhile, here is the nRF52840 range test with Johanson 2450AT18D0100 chip-antenna and SAFFB2G45MA0F0A 1dB attenuator
          the nRF9160 range test: https://www.youtube.com/watch?v=p1_0OAlTcuY (spoiler - 14 km).
          scalzS 1 Reply Last reply
          • M Mishka
            @Mishka said in Everything nRF52840:
            In a meanwhile, here is the nRF52840 range test with Johanson 2450AT18D0100 chip-antenna and SAFFB2G45MA0F0A 1dB attenuator: https://www.youtube.com/watch?v=p1_0OAlTcuY (spoiler - 14 km).
            typo?? from the video, it seems to be nRF9160
            • scalzS scalz
              Mishka
              @scalz No. The nRF9160 DK has nRF52840 on board.
                #298
                @Mishka I meant nrf52840 does not do LTE/NB-IOT. 52840 is used as controller/bridge to bluetooth (14km range isn't for bluetooth). but yes their NB-IOT sip looks nice
                • scalzS scalz
                  Mishka
                  @scalz You're right. They did NB-IoT, not BLE. Shame on me!
                    @Mishka bah no shame, enthousiasm is good thing ;)
                      Mishka
                      @scalz Yeah, next time I just have not read, but watch the video.
                      My impression was that the snow coating acted like a mirror thus greatly extending the range. But I admit 14 km is ridiculous. So sounds like a challenge :-)
                        #302
                        Adafruit now has an alpha release nRF52840 offering in a BBC microbit form factor:
                        https://www.adafruit.com/clue
                        The listing says it's programmable from the Arduino IDE.
                        The original micro:bit seems locked in time, with no official mcu upgrades from micro:bit itself, but nonetheless by the end of 2018 over two million micro:bits had been distributed globally. Pretty amazing for such a minimalist, barebones platform.
                        J 1 Reply Last reply
                          J
                          J
                          Jon Raymond
                          @NeverDie Ya Adafruit's Clue looks great. I just wish they would have added one more button to the front so up/down/select could be used for a menu system on the display.
                          • J Jon Raymond
                            #304
                            @Jon-Raymond said in Everything nRF52840:
                            Maybe you could program one of pads #0, #1, or #2 to be a capacitive touch equivalent of the extra button you wish it had?
                              J
                              J
                              Jon Raymond
                              @NeverDie Yes that is a good option or use the accelerometer to sense an input.
                                A datasheet for the new nRF5340 is now available: https://infocenter.nordicsemi.com/pdf/nRF5340_OPS_v0.5.1.pdf
                                It has some improvements, but some of its competition seems to be much lower power.
                                • I
                                  I
                                  idanronen
                                  Reading all of this, I think I made a mistake buying the e73-2G4M08S1C and a Deb board. I doubt I have the capabilities to solder this board properly. Since I have no experience designing boards, is there any simple breakout board design available I can order from pcbway so I can at least solder the outer pins?
                                  The only board I found was this one:
                                  https://www.openhardware.io/view/745/Light-and-shock-sensor-or-nRF52840-or-MySensors-or-ZigBee
                                  • I idanronen
                                    @idanronen https://github.com/joric/nrfmicro
                                    I 1 Reply Last reply
                                      I
                                      I
                                      idanronen
                                      @NeverDie doh! I glossed over that one and just assumed it wasn't possible for me due to the pads. Now on 2nd viewing I see that the inner pads are actually through holes, so I can solder them from the other side :-)
                                      Thanks! Has anyone tried that one and has any tips?
                                      • nagelcN
                                        nagelcN
                                        nagelc
                                        I would also be interested in hearing tips for this type of soldering (thru-hole to pads)
                                        I tried the thru-hole method with the LGA pads on the back of an BT832. It wasn't very successful, I was only able to get one of the 5 holes in my pattern to connect. These look larger and more widely spaced, so it probably works better.
                                        • nagelcN nagelc
                                          #311
                                          @nagelc Not sure, but here's a guess: maybe generously tinning some braided wire so as to wick up the solder, dipping it in lots of flux, and then feeding it through the hole? Then when you apply heat from a soldering iron hopefully enough of the wicked solder would melt onto the pad to make a connection.
                                          However, I presume the better way would be to apply solder paste on the pads before sticking on the module and then reflow it in an oven.
                                          nagelcN 1 Reply Last reply
