  3. Everything nRF52840
Everything nRF52840
323 Posts 28 Posters 172.1k Views 33 Watching
  • scalzS scalz
    @Mishka said in Everything nRF52840:
    In a meanwhile, here is the nRF52840 range test with Johanson 2450AT18D0100 chip-antenna and SAFFB2G45MA0F0A 1dB attenuator: https://www.youtube.com/watch?v=p1_0OAlTcuY (spoiler - 14 km).
    typo?? from the video, it seems to be nRF9160
    Mishka
    @scalz No. The nRF9160 DK has nRF52840 on board.
      #298
      @Mishka I meant nrf52840 does not do LTE/NB-IOT. 52840 is used as controller/bridge to bluetooth (14km range isn't for bluetooth). but yes their NB-IOT sip looks nice
      • scalzS scalz
        Mishka
        @scalz You're right. They did NB-IoT, not BLE. Shame on me!
          @Mishka bah no shame, enthousiasm is good thing ;)
            Mishka
            @scalz Yeah, next time I just have not read, but watch the video.
            My impression was that the snow coating acted like a mirror thus greatly extending the range. But I admit 14 km is ridiculous. So sounds like a challenge :-)
              #302
              Adafruit now has an alpha release nRF52840 offering in a BBC microbit form factor:
              https://www.adafruit.com/clue
              The listing says it's programmable from the Arduino IDE.
              The original micro:bit seems locked in time, with no official mcu upgrades from micro:bit itself, but nonetheless by the end of 2018 over two million micro:bits had been distributed globally. Pretty amazing for such a minimalist, barebones platform.
              J 1 Reply Last reply
                J
                J
                Jon Raymond
                @NeverDie Ya Adafruit's Clue looks great. I just wish they would have added one more button to the front so up/down/select could be used for a menu system on the display.
                • J Jon Raymond
                  #304
                  @Jon-Raymond said in Everything nRF52840:
                  Maybe you could program one of pads #0, #1, or #2 to be a capacitive touch equivalent of the extra button you wish it had?
                    J
                    J
                    Jon Raymond
                    @NeverDie Yes that is a good option or use the accelerometer to sense an input.
                      A datasheet for the new nRF5340 is now available: https://infocenter.nordicsemi.com/pdf/nRF5340_OPS_v0.5.1.pdf
                      It has some improvements, but some of its competition seems to be much lower power.
                      • I
                        I
                        idanronen
                        Reading all of this, I think I made a mistake buying the e73-2G4M08S1C and a Deb board. I doubt I have the capabilities to solder this board properly. Since I have no experience designing boards, is there any simple breakout board design available I can order from pcbway so I can at least solder the outer pins?
                        The only board I found was this one:
                        https://www.openhardware.io/view/745/Light-and-shock-sensor-or-nRF52840-or-MySensors-or-ZigBee
                        • I idanronen
                          @idanronen https://github.com/joric/nrfmicro
                          I 1 Reply Last reply
                            I
                            I
                            idanronen
                            @NeverDie doh! I glossed over that one and just assumed it wasn't possible for me due to the pads. Now on 2nd viewing I see that the inner pads are actually through holes, so I can solder them from the other side :-)
                            Thanks! Has anyone tried that one and has any tips?
                            • nagelcN
                              nagelcN
                              nagelc
                              I would also be interested in hearing tips for this type of soldering (thru-hole to pads)
                              I tried the thru-hole method with the LGA pads on the back of an BT832. It wasn't very successful, I was only able to get one of the 5 holes in my pattern to connect. These look larger and more widely spaced, so it probably works better.
                              • nagelcN nagelc
                                #311
                                @nagelc Not sure, but here's a guess: maybe generously tinning some braided wire so as to wick up the solder, dipping it in lots of flux, and then feeding it through the hole? Then when you apply heat from a soldering iron hopefully enough of the wicked solder would melt onto the pad to make a connection.
                                However, I presume the better way would be to apply solder paste on the pads before sticking on the module and then reflow it in an oven.
                                nagelcN 1 Reply Last reply
                                  nagelcN
                                  nagelcN
                                  nagelc
                                  @NeverDie Of course the oven is the way it is meant to be done.
                                  I have the oven waiting to convert, but that's still ahead on my project list : )
                                    A Former User
                                    Hi everyone,
                                    I'm a bit a newbie in hardware and need your help. I'm a PHD student and I actually work on ZigBee networks. For a POC, I need to have an hardware device able to capture and send ZigBee messages from a "true" physical device. (An old philips Hue or maybe an Ikea smartbulb for example - normally, 2.4GHz).
                                    The idea is to make a false ZigBee Gateway to work on the secrurity of the enrolment in ZigBee 3.0 within software.
                                    My issue is that I'm unfortunately a bit newbie in on-board programming and thus can't be sure if it's feasible and if it's really complicated or not. I'm posting my message here because the nrf52840 seems to fit my needs with a ZigBee compatibilty.
                                    Thanks by advance for your answers !
                                      hello @TruiteCendrée :grin:
                                      yes this is possible with nrf52840, but unfortunately zigbee is not compatible with mysensors. Mysensors is a software stack like zigbee is.
                                      I think you'll get more infos if you take a look on nordic semi forums. They have a zigbee stack for nrf52840.
                                      • orhanyorO
                                        orhanyorO
                                        orhanyor
                                        wrote on last edited by orhanyor
                                        #315
                                        hey guys, i finally assembled my nrf52840 pa board. it was sitting there for quite some time but i couldn't find some spare time to get on with it but here are some experiences i had.
                                        i was worried about this aQFN footprint but it all went well, looks like everything is soldered correctly and i ordered my boards with cheapest HASL instead of ENIG.
                                        then i uploaded the adafruit feather bootloader to test the bluetooth and it all works ok. i used my iphone 6s as a central device and im not sure if my phone has LNA or PA module inside for bluetooth so it may or may not be better if i use another module like the one i did. this connection is from my module to my phone WITHOUT PA activated at tx power max(8):
                                        and this is after i activate PA chip on board :
                                        and this is with 3 solid walls in between at around 10 meters distance
                                        as you can see signal strength is massively different pa bumps up the signal from -87dbm to -30dbm which is probably day and night difference.
                                        but with this setup you manually have to enable and disable rx and tx pins in order to keep the communication. well im not really good at coding but im going to try make the whole thing automatically because nordic already has this PA assist feature buried inside its BLE core, just gotta find a way to make it work.
                                        final board, forgot to add i opted to use pcb antenna but i could switch to external antenna as well i just have to reposition the 0 ohm resistor to use that SMA on the side and then results could get even better:
                                        • orhanyorO orhanyor
                                          @orhanyor Nice! How did you manage to do the solder paste so precisely?
                                          orhanyorO 1 Reply Last reply
