[SOLVED] Need help with ESP8266 MQTT Gateway (RFM69HW radio)
This is the gateway code: (comments left out)
#define MY_DEBUG #define MY_BAUD_RATE 9600 #define MY_RADIO_RFM69 #define MY_IS_RFM69HW #define MY_RFM69_IRQ_PIN D1 #define MY_RFM69_IRQ_NUM MY_RFM69_IRQ_PIN #define MY_RFM69_CS_PIN D8 #define MY_GATEWAY_MQTT_CLIENT #define MY_GATEWAY_ESP8266 #define MY_MQTT_PUBLISH_TOPIC_PREFIX "mygateway2-out" #define MY_MQTT_SUBSCRIBE_TOPIC_PREFIX "mygateway2-in" #define MY_MQTT_CLIENT_ID "mysensors-2" #define MY_WIFI_SSID "TOUTATIS" #define MY_WIFI_PASSWORD "XXXXXXXXXXXXXX" #define MY_CONTROLLER_IP_ADDRESS 192, 168, 178, 90 #define MY_PORT 1883 #include <ESP8266WiFi.h> #include <MySensors.h> void setup() {} void presentation() {} void loop() {}This is the sensor node code:
#define MY_DEBUG #define MY_RADIO_RFM69 #define MY_IS_RFM69HW #include <MySensors.h> #include <Bounce2.h> #define CHILD_ID 3 #define BUTTON_PIN 3 Bounce debouncer = Bounce(); int oldValue=-1; MyMessage msg(CHILD_ID,V_TRIPPED); void setup() { pinMode(BUTTON_PIN,INPUT); digitalWrite(BUTTON_PIN,HIGH); debouncer.attach(BUTTON_PIN); debouncer.interval(5); } void presentation() { present(CHILD_ID, S_DOOR); } void loop() { debouncer.update(); int value = debouncer.read(); if (value != oldValue) { send(msg.set(value==HIGH ? 1 : 0)); oldValue = value; } }This is the sensor node log:
__ __ ____ | \/ |_ _/ ___| ___ _ __ ___ ___ _ __ ___ | |\/| | | | \___ \ / _ \ `_ \/ __|/ _ \| `__/ __| | | | | |_| |___| | __/ | | \__ \ _ | | \__ \ |_| |_|\__, |____/ \___|_| |_|___/\___/|_| |___/ |___/ 2.3.2 16 MCO:BGN:INIT NODE,CP=RRNNA---,FQ=8,REL=255,VER=2.3.2 28 TSM:INIT 28 TSF:WUR:MS=0 32 TSM:INIT:TSP OK 34 TSM:FPAR 38 ?TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 2048 !TSM:FPAR:NO REPLY 2050 TSM:FPAR 2054 ?TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 4063 !TSM:FPAR:NO REPLY 4065 TSM:FPAR 4069 ?TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 6078 !TSM:FPAR:NO REPLY 6080 TSM:FPAR 6084 ?TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 8093 !TSM:FPAR:FAIL 8095 TSM:FAIL:CNT=1 8097 TSM:FAIL:DIS 8099 TSF:TDI:TSL 18102 TSM:FAIL:RE-INIT 18104 TSM:INIT 18106 TSM:INIT:TSP OK 18110 TSM:FPAR 18114 ?TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 20123 !TSM:FPAR:NO REPLY 20125 TSM:FPAR 20129 ?TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 22138 !TSM:FPAR:NO REPLY 22140 TSM:FPAR 22145 ?TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 24154 !TSM:FPAR:NO REPLY 24156 TSM:FPAR 24160 ?TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 26169 !TSM:FPAR:FAIL 26171 TSM:FAIL:CNT=2 26173 TSM:FAIL:DIS 26175 TSF:TDI:TSL 36179 TSM:FAIL:RE-INIT 36182 TSM:INIT ............repeating endlesslyAnd this is the gateway log:
--- Miniterm on /dev/cu.SLAB_USBtoUART 9600,8,N,1 --- --- Quit: Ctrl+C | Menu: Ctrl+T | Help: Ctrl+T followed by Ctrl+H --- 0�~?�4�Ҷ␞��␄OA␌r��61 MCO:BGN:INIT GW,CP=RRNGE---,FQ=80,REL=255,VER=2.3.2 118 TSF:LRT:OK 134 TSM:INIT 148 TSF:WUR:MS=0 167 TSM:INIT:TSP OK scandone state: 0 -> 2 (b0) 217 TSM:INIT:GW MODE 239 TSM:READY:ID=0,PAR=0,DIS=0 state: 2 -> 3 (0) 290 MCO:REG:NOT NEEDED state: 3 -> 5 (10) add 0 aid 4 cnt 354 GWT:TPC:CONNECTING... connected with TOUTATIS, channel 2 dhcp client start... scandone 1441 MCO:BGN:STP 1459 MCO:BGN:INIT OK,TSP=1 1487 TSM:READY:NWD REQ 1515 ?TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=20,pt=0,l=0,sg=0,ft=0,st=OK: ip:192.168.178.68,mask:255.255.255.0,gw:192.168.178.1 2209 GWT:TPC:IP=192.168.178.68 2296 GWT:RMQ:CONNECTING... 2605 GWT:RMQ:OK 2622 GWT:TPS:TOPIC=mygateway2-out/0/255/0/0/18,MSG SENT pm open,type:2 0 900148 TSF:SAN:OK 1201488 TSM:READY:NWD REQ 1201519 ?TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=20,pt=0,l=0,sg=0,ft=0,st=OK: 1800148 TSF:SRT:OK 1800168 TSF:SAN:OK 2401489 TSM:READY:NWD REQ 2401520 ?TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=20,pt=0,l=0,sg=0,ft=0,st=OK:So it appears that the gateway is not hanging after all. It just takes a long time between log messages. It is doing a network discovery broadcast every 20 minutes or so.
But the gateway and sensor (1 meter distance) node do not connect... -
For comparison, I have a MQTT Gateway running on a Wemos D1 for 2 months now, with a RFM69W. Works perfect. Here is my hardware setup and code, maybe it is of any help to you. Change the networkid, MQTT broker and wifi credentials to your own setup. I use static ID's on my nodes.
// Enable debug prints to serial monitor #define MY_DEBUG // Use a bit lower baudrate for serial prints on ESP8266 than default in MyConfig.h #define MY_BAUD_RATE 9600 // Enables and select radio type (if attached) #define MY_RADIO_RFM69 //#define MY_IS_RFM69HW #define MY_RFM69_NETWORKID 83 // Own network ID, mysensors default is 100 #define MY_GATEWAY_MQTT_CLIENT #define MY_GATEWAY_ESP8266 // Set this node's subscribe and publish topic prefix #define MY_MQTT_PUBLISH_TOPIC_PREFIX "mygateway1-out" #define MY_MQTT_SUBSCRIBE_TOPIC_PREFIX "mygateway1-in" // Set MQTT client id #define MY_MQTT_CLIENT_ID "mysensors-1" // Enable these if your MQTT broker requires username/password //#define MY_MQTT_USER "username" //#define MY_MQTT_PASSWORD "password" // Set WIFI SSID and password #define MY_WIFI_SSID "xxxxxxx" #define MY_WIFI_PASSWORD "xxxxxxxx" // Set the hostname for the WiFi Client. This is the hostname // passed to the DHCP server if not static. #define MY_HOSTNAME "ESP8266_MQTT_GW" // Enable MY_IP_ADDRESS here if you want a static ip address (no DHCP) //#define MY_IP_ADDRESS 192,168,178,87 // If using static ip you can define Gateway and Subnet address as well //#define MY_IP_GATEWAY_ADDRESS 192,168,178,1 //#define MY_IP_SUBNET_ADDRESS 255,255,255,0 // MQTT broker ip address. #define MY_CONTROLLER_IP_ADDRESS 10, 0, 0, 47 //MQTT broker if using URL instead of ip address. // #define MY_CONTROLLER_URL_ADDRESS "test.mosquitto.org" // The MQTT broker port to to open #define MY_PORT 1883 // Enable inclusion mode //#define MY_INCLUSION_MODE_FEATURE // Enable Inclusion mode button on gateway //#define MY_INCLUSION_BUTTON_FEATURE // Set inclusion mode duration (in seconds) //#define MY_INCLUSION_MODE_DURATION 60 // Digital pin used for inclusion mode button //#define MY_INCLUSION_MODE_BUTTON_PIN D1 // Set blinking period #define MY_DEFAULT_LED_BLINK_PERIOD 300 // Flash leds on rx/tx/err #define MY_DEFAULT_ERR_LED_PIN D4 // Red #define MY_DEFAULT_TX_LED_PIN D3 // Yellow #define MY_DEFAULT_RX_LED_PIN D2 // Green #include <MySensors.h> void setup() { // Setup locally attached sensors } void presentation() { // Present locally attached sensors here } void loop() { // Send locally attached sensors data here }![2020-03-15 07_13_27-sPlan 7.0 - [Z__mysensors_GatewayESP8266MQTTClient_GatewayESP8266MQTT.spl7].jpg](/assets/uploads/files/1584253310143-2020-03-15-07_13_27-splan-7.0-z__mysensors_gatewayesp8266mqttclient_gatewayesp8266mqtt.spl7.jpg)
Thank you for your setup example. It is nearly identical to my setup (only I use RFM69HW's).
The only thing I can think of now is that the radio modules must be defective, but I have no means to test this) So I ordered a new batch of RFM69's and hope for the best...[Edit]
I see that you do not use the following defines as instructed in link text:#define MY_RFM69_IRQ_PIN D1 #define MY_RFM69_IRQ_NUM MY_RFM69_IRQ_PIN #define MY_RFM69_CS_PIN D8I have tried both with and without these defines, but it makes no difference.
config on WEMOS D1 gateway:
#define MY_RADIO_RFM69 #define MY_RFM69_NEW_DRIVER #define MY_DEBUG_VERBOSE_RFM69 #define MY_IS_RFM69HWlog:
--- Miniterm on /dev/cu.SLAB_USBtoUART 9600,8,N,1 --- --- Quit: Ctrl+C | Menu: Ctrl+T | Help: Ctrl+T followed by Ctrl+H --- 0�~?�4�Ҷ␞��␄OAqr��62 MCO:BGN:INIT GW,CP=RPNGE---,FQ=80,REL=255,VER=2.3.2 119 TSF:LRT:OK 135 TSM:INIT 148 TSF:WUR:MS=0 166 RFM69:INIT scandone state: 0 -> 2 (b0) state: 2 -> 3 (0) state: 3 -> 5 (10) add 0 aid 3 cnt connected with TOUTATIS, channel 2 dhcp client start... ip:192.168.178.68,mask:255.255.255.0,gw:192.168.178.1 383 RFM69:INIT:PIN,CS=15,IQP=5,IQN=5 423 RFM69:PTX:LEVEL=5 dBm 450 !RFM69:INIT:SANCHK FAIL 479 !TSM:INIT:TSP FAIL 503 TSM:FAIL:CNT=1 523 TSM:FAIL:DIS 540 TSF:TDI:TSL 557 RFM69:RSL pm open,type:2 0 10573 TSM:FAIL:RE-INIT 10597 TSM:INIT 10612 RFM69:INIT 10630 RFM69:INIT:PIN,CS=15,IQP=5,IQN=5 10673 RFM69:PTX:LEVEL=5 dBm 10702 !RFM69:INIT:SANCHK FAIL 10734 !TSM:INIT:TSP FAIL 10760 TSM:FAIL:CNT=2 10781 TSM:FAIL:DIS 10801 TSF:TDI:TSL 10820 RFM69:RSL 20838 TSM:FAIL:RE-INIT 20862 TSM:INIT 20877 RFM69:INIT 20895 RFM69:INIT:PIN,CS=15,IQP=5,IQN=5 20938 RFM69:PTX:LEVEL=5 dBm 20967 !RFM69:INIT:SANCHK FAIL 20999 !TSM:INIT:TSP FAIL 21025 TSM:FAIL:CNT=3 21047 TSM:FAIL:DIS 21066 TSF:TDI:TSL 21085 RFM69:RSL 31103 TSM:FAIL:RE-INIT 31127 TSM:INIT 31142 RFM69:INIT 31160 RFM69:INIT:PIN,CS=15,IQP=5,IQN=5 31203 RFM69:PTX:LEVEL=5 dBm 31232 !RFM69:INIT:SANCHK FAIL 31264 !TSM:INIT:TSP FAIL 31290 TSM:FAIL:CNT=4 31312 TSM:FAIL:DIS 31332 TSF:TDI:TSL 31350 RFM69:RSL 41368 TSM:FAIL:RE-INIT 41392 TSM:INIT 41407 RFM69:INIT 41425 RFM69:INIT:PIN,CS=15,IQP=5,IQN=5 41468 RFM69:PTX:LEVEL=5 dBm 41497 !RFM69:INIT:SANCHK FAIL 41529 !TSM:INIT:TSP FAIL 41555 TSM:FAIL:CNT=5 41577 TSM:FAIL:DIS 41596 TSF:TDI:TSL 41615 RFM69:RSL 51633 TSM:FAIL:RE-INIT 51657 TSM:INIT 51672 RFM69:INIT 51690 RFM69:INIT:PIN,CS=15,IQP=5,IQN=5 51733 RFM69:PTX:LEVEL=5 dBm 51762 !RFM69:INIT:SANCHK FAIL 51794 !TSM:INIT:TSP FAIL 51820 TSM:FAIL:CNT=6 51842 TSM:FAIL:DIS 51861 TSF:TDI:TSL 51880 RFM69:RSL 61898 TSM:FAIL:RE-INIT 61922 TSM:INIT 61937 RFM69:INIT 61955 RFM69:INIT:PIN,CS=15,IQP=5,IQN=5 61998 RFM69:PTX:LEVEL=5 dBm 62027 !RFM69:INIT:SANCHK FAIL 62059 !TSM:INIT:TSP FAIL 62085 TSM:FAIL:CNT=7 62107 TSM:FAIL:DIS 62126 TSF:TDI:TSL 62145 RFM69:RSL 122163 TSM:FAIL:RE-INIT 122188 TSM:INIT 122204 RFM69:INIT 122223 RFM69:INIT:PIN,CS=15,IQP=5,IQN=5 122267 RFM69:PTX:LEVEL=5 dBm 122298 !RFM69:INIT:SANCHK FAIL 122330 !TSM:INIT:TSP FAIL 122357 TSM:FAIL:CNT=7 122380 TSM:FAIL:DIS 122401 TSF:TDI:TSL 122421 RFM69:RSL 182439 TSM:FAIL:RE-INIT 182464 TSM:INIT 182480 RFM69:INIT 182499 RFM69:INIT:PIN,CS=15,IQP=5,IQN=5 182543 RFM69:PTX:LEVEL=5 dBm 182574 !RFM69:INIT:SANCHK FAIL 182606 !TSM:INIT:TSP FAIL 182633 TSM:FAIL:CNT=7 182656 TSM:FAIL:DIS 182677 TSF:TDI:TSL 182697 RFM69:RSL 242716 TSM:FAIL:RE-INIT 242741 TSM:INIT 242757 RFM69:INIT 242776 RFM69:INIT:PIN,CS=15,IQP=5,IQN=5 242820 RFM69:PTX:LEVEL=5 dBm 242851 !RFM69:INIT:SANCHK FAIL 242883 !TSM:INIT:TSP FAIL 242910 TSM:FAIL:CNT=7 242933 TSM:FAIL:DIS 242954 TSF:TDI:TSL 242974 RFM69:RSL 302992 TSM:FAIL:RE-INIT 303017 TSM:INIT 303033 RFM69:INIT 303052 RFM69:INIT:PIN,CS=15,IQP=5,IQN=5 303096 RFM69:PTX:LEVEL=5 dBm 303127 !RFM69:INIT:SANCHK FAIL 303159 !TSM:INIT:TSP FAIL 303186 TSM:FAIL:CNT=7 303209 TSM:FAIL:DIS 303230 TSF:TDI:TSL 303250 RFM69:RSLlog from Arduino Pro Mini sensor node:
__ __ ____ | \/ |_ _/ ___| ___ _ __ ___ ___ _ __ ___ | |\/| | | | \___ \ / _ \ `_ \/ __|/ _ \| `__/ __| | | | | |_| |___| | __/ | | \__ \ _ | | \__ \ |_| |_|\__, |____/ \___|_| |_|___/\___/|_| |___/ |___/ 2.3.2 16 MCO:BGN:INIT NODE,CP=RPNNA---,FQ=8,REL=255,VER=2.3.2 28 TSM:INIT 28 TSF:WUR:MS=0 30 RFM69:INIT 32 RFM69:INIT:PIN,CS=10,IQP=2,IQN=0 36 RFM69:PTX:LEVEL=5 dBm 38 TSM:INIT:TSP OK 40 TSM:INIT:STATID=42 45 TSF:SID:OK,ID=42 47 TSM:FPAR 47 RFM69:SWR:SEND,TO=255,SEQ=0,RETRY=0 53 RFM69:CSMA:RSSI=-104 59 ?TSF:MSG:SEND,42-42-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 2066 !TSM:FPAR:NO REPLY 2068 TSM:FPAR 2070 RFM69:SWR:SEND,TO=255,SEQ=1,RETRY=0 2074 RFM69:CSMA:RSSI=-107 2080 ?TSF:MSG:SEND,42-42-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 4089 !TSM:FPAR:NO REPLY 4091 TSM:FPAR 4093 RFM69:SWR:SEND,TO=255,SEQ=2,RETRY=0 4098 RFM69:CSMA:RSSI=-105 4104 ?TSF:MSG:SEND,42-42-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 6113 !TSM:FPAR:NO REPLY 6115 TSM:FPAR 6117 RFM69:SWR:SEND,TO=255,SEQ=3,RETRY=0 6121 RFM69:CSMA:RSSI=-106 6127 ?TSF:MSG:SEND,42-42-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 8136 !TSM:FPAR:FAIL 8138 TSM:FAIL:CNT=1 8140 TSM:FAIL:DIS 8142 TSF:TDI:TSL 8142 RFM69:RSL 18145 TSM:FAIL:RE-INIT 18147 TSM:INIT 18149 RFM69:INIT 18151 RFM69:INIT:PIN,CS=10,IQP=2,IQN=0 18155 RFM69:PTX:LEVEL=5 dBm 18157 TSM:INIT:TSP OK 18161 TSM:INIT:STATID=42 18163 TSF:SID:OK,ID=42 18165 TSM:FPAR 18167 RFM69:SWR:SEND,TO=255,SEQ=0,RETRY=0 18173 RFM69:CSMA:RSSI=-107 18180 ?TSF:MSG:SEND,42-42-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 20189 !TSM:FPAR:NO REPLY 20191 TSM:FPAR 20193 RFM69:SWR:SEND,TO=255,SEQ=1,RETRY=0 20197 RFM69:CSMA:RSSI=-103 20203 ?TSF:MSG:SEND,42-42-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 22212 !TSM:FPAR:NO REPLY 22214 TSM:FPAR 22216 RFM69:SWR:SEND,TO=255,SEQ=2,RETRY=0 22220 RFM69:CSMA:RSSI=-105 22226 ?TSF:MSG:SEND,42-42-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 24236 !TSM:FPAR:NO REPLY 24238 TSM:FPAR 24240 RFM69:SWR:SEND,TO=255,SEQ=3,RETRY=0 24244 RFM69:CSMA:RSSI=-109 24250 ?TSF:MSG:SEND,42-42-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 26259 !TSM:FPAR:FAIL 26261 TSM:FAIL:CNT=2 26263 TSM:FAIL:DIS 26265 TSF:TDI:TSL 26267 RFM69:RSL 36270 TSM:FAIL:RE-INIT 36272 TSM:INIT 36274 RFM69:INIT 36276 RFM69:INIT:PIN,CS=10,IQP=2,IQN=0 36280 RFM69:PTX:LEVEL=5 dBm 36282 TSM:INIT:TSP OK 36286 TSM:INIT:STATID=42 36288 TSF:SID:OK,ID=42 36290 TSM:FPAR 36292 RFM69:SWR:SEND,TO=255,SEQ=0,RETRY=0 36298 RFM69:CSMA:RSSI=-105 36304 ?TSF:MSG:SEND,42-42-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 38316 !TSM:FPAR:NO REPLY 38318 TSM:FPAR 38320 RFM69:SWR:SEND,TO=255,SEQ=1,RETRY=0 38324 RFM69:CSMA:RSSI=-105 38330 ?TSF:MSG:SEND,42-42-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 40339 !TSM:FPAR:NO REPLY 40341 TSM:FPAR 40343 RFM69:SWR:SEND,TO=255,SEQ=2,RETRY=0 40347 RFM69:CSMA:RSSI=-102 40353 ?TSF:MSG:SEND,42-42-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 42362 !TSM:FPAR:NO REPLY 42364 TSM:FPAR 42366 RFM69:SWR:SEND,TO=255,SEQ=3,RETRY=0 42371 RFM69:CSMA:RSSI=-104 42377 ?TSF:MSG:SEND,42-42-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 44386 !TSM:FPAR:FAIL 44388 TSM:FAIL:CNT=3 44390 TSM:FAIL:DIS 44392 TSF:TDI:TSL 44394 RFM69:RSL 54398 TSM:FAIL:RE-INIT 54401 TSM:INIT 54403 RFM69:INIT 54405 RFM69:INIT:PIN,CS=10,IQP=2,IQN=0 54409 RFM69:PTX:LEVEL=5 dBm 54411 TSM:INIT:TSP OK 54415 TSM:INIT:STATID=42 54417 TSF:SID:OK,ID=42 54419 TSM:FPAR 54421 RFM69:SWR:SEND,TO=255,SEQ=0,RETRY=0 54427 RFM69:CSMA:RSSI=-105 54433 ?TSF:MSG:SEND,42-42-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 56442 !TSM:FPAR:NO REPLY 56444 TSM:FPAR 56446 RFM69:SWR:SEND,TO=255,SEQ=1,RETRY=0 56451 RFM69:CSMA:RSSI=-104 56457 ?TSF:MSG:SEND,42-42-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 58466 !TSM:FPAR:NO REPLY 58468 TSM:FPAR 58470 RFM69:SWR:SEND,TO=255,SEQ=2,RETRY=0 58474 RFM69:CSMA:RSSI=-104 58480 ?TSF:MSG:SEND,42-42-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 60489 !TSM:FPAR:NO REPLY 60491 TSM:FPAR 60493 RFM69:SWR:SEND,TO=255,SEQ=3,RETRY=0 60497 RFM69:CSMA:RSSI=-102 60504 ?TSF:MSG:SEND,42-42-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 62513 !TSM:FPAR:FAIL 62515 TSM:FAIL:CNT=4 62517 TSM:FAIL:DIS 62519 TSF:TDI:TSL 62521 RFM69:RSL 72525 TSM:FAIL:RE-INIT! -
:tada: :tada: :tada:
You were right; there was a minuscule piece of wire strand between two contacts and after removing it all is fine now.
Also checked all the radio's again which is easy now I have a working configuration and there was indeed one defective radio module.
Thanks everyone for unblocking me! -
