  3. [SOLVED] Need help with ESP8266 MQTT Gateway (RFM69HW radio)
18 Posts 4 Posters 1.9k Views 3 Watching
  • W
    W
    willemx
    wrote on last edited by willemx
    Thank you for your setup example. It is nearly identical to my setup (only I use RFM69HW's).
    The only thing I can think of now is that the radio modules must be defective, but I have no means to test this) So I ordered a new batch of RFM69's and hope for the best...
    [Edit]
    I see that you do not use the following defines as instructed in link text:
    #define MY_RFM69_IRQ_PIN D1
    #define MY_RFM69_IRQ_NUM MY_RFM69_IRQ_PIN
    #define MY_RFM69_CS_PIN D8
    I have tried both with and without these defines, but it makes no difference.
    • electrikE
      electrikE
      electrik
      Did you try to add a capacitor next to the power pins?
      • W
        W
        willemx
        Yes, I added a capacitor to both radio's.
        tekkaT 1 Reply Last reply
        • W willemx
          tekkaT
          tekkaT
          tekka
          @willemx And you have 868Mhz modules?
          • W
            W
            willemx
            Yes, that is what I ordered and also it is marked on the radio PCB's.
            • W willemx
              tekkaT
              tekkaT
              tekka
              @willemx Can you try with the new rfm69 driver & debug verbose mode on both, node & gw - i.e.
              #define MY_RFM69_NEW_DRIVER
              #define MY_DEBUG_VERBOSE_RFM69
              and post the debug logs here.
              • W
                W
                willemx
                config on WEMOS D1 gateway:
                #define MY_RADIO_RFM69
                #define MY_IS_RFM69HW
                log:
                --- Miniterm on /dev/cu.SLAB_USBtoUART  9600,8,N,1 ---
                --- Quit: Ctrl+C | Menu: Ctrl+T | Help: Ctrl+T followed by Ctrl+H ---
                0�~?�4�Ҷ␞��␄OAqr��62 MCO:BGN:INIT GW,CP=RPNGE---,FQ=80,REL=255,VER=2.3.2
                119 TSF:LRT:OK
                135 TSM:INIT
                148 TSF:WUR:MS=0
                166 RFM69:INIT
                scandone
                state: 0 -> 2 (b0)
                state: 2 -> 3 (0)
                state: 3 -> 5 (10)
                add 0
                aid 3
                cnt
                connected with TOUTATIS, channel 2
                dhcp client start...
                ip:192.168.178.68,mask:255.255.255.0,gw:192.168.178.1
                383 RFM69:INIT:PIN,CS=15,IQP=5,IQN=5
                423 RFM69:PTX:LEVEL=5 dBm
                450 !RFM69:INIT:SANCHK FAIL
                479 !TSM:INIT:TSP FAIL
                503 TSM:FAIL:CNT=1
                523 TSM:FAIL:DIS
                540 TSF:TDI:TSL
                557 RFM69:RSL
                pm open,type:2 0
                10573 TSM:FAIL:RE-INIT
                10597 TSM:INIT
                10612 RFM69:INIT
                10630 RFM69:INIT:PIN,CS=15,IQP=5,IQN=5
                10673 RFM69:PTX:LEVEL=5 dBm
                10702 !RFM69:INIT:SANCHK FAIL
                10734 !TSM:INIT:TSP FAIL
                10760 TSM:FAIL:CNT=2
                10781 TSM:FAIL:DIS
                10801 TSF:TDI:TSL
                10820 RFM69:RSL
                20838 TSM:FAIL:RE-INIT
                20862 TSM:INIT
                20877 RFM69:INIT
                20895 RFM69:INIT:PIN,CS=15,IQP=5,IQN=5
                20938 RFM69:PTX:LEVEL=5 dBm
                20967 !RFM69:INIT:SANCHK FAIL
                20999 !TSM:INIT:TSP FAIL
                21025 TSM:FAIL:CNT=3
                21047 TSM:FAIL:DIS
                21066 TSF:TDI:TSL
                21085 RFM69:RSL
                31103 TSM:FAIL:RE-INIT
                31127 TSM:INIT
                31142 RFM69:INIT
                31160 RFM69:INIT:PIN,CS=15,IQP=5,IQN=5
                31203 RFM69:PTX:LEVEL=5 dBm
                31232 !RFM69:INIT:SANCHK FAIL
                31264 !TSM:INIT:TSP FAIL
                31290 TSM:FAIL:CNT=4
                31312 TSM:FAIL:DIS
                31332 TSF:TDI:TSL
                31350 RFM69:RSL
                41368 TSM:FAIL:RE-INIT
                41392 TSM:INIT
                41407 RFM69:INIT
                41425 RFM69:INIT:PIN,CS=15,IQP=5,IQN=5
                41468 RFM69:PTX:LEVEL=5 dBm
                41497 !RFM69:INIT:SANCHK FAIL
                41529 !TSM:INIT:TSP FAIL
                41555 TSM:FAIL:CNT=5
                41577 TSM:FAIL:DIS
                41596 TSF:TDI:TSL
                41615 RFM69:RSL
                51633 TSM:FAIL:RE-INIT
                51657 TSM:INIT
                51672 RFM69:INIT
                51690 RFM69:INIT:PIN,CS=15,IQP=5,IQN=5
                51733 RFM69:PTX:LEVEL=5 dBm
                51762 !RFM69:INIT:SANCHK FAIL
                51794 !TSM:INIT:TSP FAIL
                51820 TSM:FAIL:CNT=6
                51842 TSM:FAIL:DIS
                51861 TSF:TDI:TSL
                51880 RFM69:RSL
                61898 TSM:FAIL:RE-INIT
                61922 TSM:INIT
                61937 RFM69:INIT
                61955 RFM69:INIT:PIN,CS=15,IQP=5,IQN=5
                61998 RFM69:PTX:LEVEL=5 dBm
                62027 !RFM69:INIT:SANCHK FAIL
                62059 !TSM:INIT:TSP FAIL
                62085 TSM:FAIL:CNT=7
                62107 TSM:FAIL:DIS
                62126 TSF:TDI:TSL
                62145 RFM69:RSL
                122163 TSM:FAIL:RE-INIT
                122188 TSM:INIT
                122204 RFM69:INIT
                122223 RFM69:INIT:PIN,CS=15,IQP=5,IQN=5
                122267 RFM69:PTX:LEVEL=5 dBm
                122298 !RFM69:INIT:SANCHK FAIL
                122330 !TSM:INIT:TSP FAIL
                122357 TSM:FAIL:CNT=7
                122380 TSM:FAIL:DIS
                122401 TSF:TDI:TSL
                122421 RFM69:RSL
                182439 TSM:FAIL:RE-INIT
                182464 TSM:INIT
                182480 RFM69:INIT
                182499 RFM69:INIT:PIN,CS=15,IQP=5,IQN=5
                182543 RFM69:PTX:LEVEL=5 dBm
                182574 !RFM69:INIT:SANCHK FAIL
                182606 !TSM:INIT:TSP FAIL
                182633 TSM:FAIL:CNT=7
                182656 TSM:FAIL:DIS
                182677 TSF:TDI:TSL
                182697 RFM69:RSL
                242716 TSM:FAIL:RE-INIT
                242741 TSM:INIT
                242757 RFM69:INIT
                242776 RFM69:INIT:PIN,CS=15,IQP=5,IQN=5
                242820 RFM69:PTX:LEVEL=5 dBm
                242851 !RFM69:INIT:SANCHK FAIL
                242883 !TSM:INIT:TSP FAIL
                242910 TSM:FAIL:CNT=7
                242933 TSM:FAIL:DIS
                242954 TSF:TDI:TSL
                242974 RFM69:RSL
                302992 TSM:FAIL:RE-INIT
                303017 TSM:INIT
                303033 RFM69:INIT
                303052 RFM69:INIT:PIN,CS=15,IQP=5,IQN=5
                303096 RFM69:PTX:LEVEL=5 dBm
                303127 !RFM69:INIT:SANCHK FAIL
                303159 !TSM:INIT:TSP FAIL
                303186 TSM:FAIL:CNT=7
                303209 TSM:FAIL:DIS
                303230 TSF:TDI:TSL
                303250 RFM69:RSL
                log from Arduino Pro Mini sensor node:
                 __  __       ____
                        |___/                      2.3.2
                16 MCO:BGN:INIT NODE,CP=RPNNA---,FQ=8,REL=255,VER=2.3.2
                28 TSM:INIT
                28 TSF:WUR:MS=0
                30 RFM69:INIT
                32 RFM69:INIT:PIN,CS=10,IQP=2,IQN=0
                36 RFM69:PTX:LEVEL=5 dBm
                38 TSM:INIT:TSP OK
                40 TSM:INIT:STATID=42
                45 TSF:SID:OK,ID=42
                47 TSM:FPAR
                47 RFM69:SWR:SEND,TO=255,SEQ=0,RETRY=0
                53 RFM69:CSMA:RSSI=-104
                59 ?TSF:MSG:SEND,42-42-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                2066 !TSM:FPAR:NO REPLY
                2068 TSM:FPAR
                2070 RFM69:SWR:SEND,TO=255,SEQ=1,RETRY=0
                2074 RFM69:CSMA:RSSI=-107
                2080 ?TSF:MSG:SEND,42-42-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                4089 !TSM:FPAR:NO REPLY
                4091 TSM:FPAR
                4093 RFM69:SWR:SEND,TO=255,SEQ=2,RETRY=0
                4098 RFM69:CSMA:RSSI=-105
                4104 ?TSF:MSG:SEND,42-42-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                6113 !TSM:FPAR:NO REPLY
                6115 TSM:FPAR
                6117 RFM69:SWR:SEND,TO=255,SEQ=3,RETRY=0
                6121 RFM69:CSMA:RSSI=-106
                6127 ?TSF:MSG:SEND,42-42-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                8136 !TSM:FPAR:FAIL
                8138 TSM:FAIL:CNT=1
                8140 TSM:FAIL:DIS
                8142 TSF:TDI:TSL
                8142 RFM69:RSL
                18145 TSM:FAIL:RE-INIT
                18147 TSM:INIT
                18149 RFM69:INIT
                18151 RFM69:INIT:PIN,CS=10,IQP=2,IQN=0
                18155 RFM69:PTX:LEVEL=5 dBm
                18157 TSM:INIT:TSP OK
                18161 TSM:INIT:STATID=42
                18163 TSF:SID:OK,ID=42
                18165 TSM:FPAR
                18167 RFM69:SWR:SEND,TO=255,SEQ=0,RETRY=0
                18173 RFM69:CSMA:RSSI=-107
                18180 ?TSF:MSG:SEND,42-42-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                20189 !TSM:FPAR:NO REPLY
                20191 TSM:FPAR
                20193 RFM69:SWR:SEND,TO=255,SEQ=1,RETRY=0
                20197 RFM69:CSMA:RSSI=-103
                20203 ?TSF:MSG:SEND,42-42-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                22212 !TSM:FPAR:NO REPLY
                22214 TSM:FPAR
                22216 RFM69:SWR:SEND,TO=255,SEQ=2,RETRY=0
                22220 RFM69:CSMA:RSSI=-105
                22226 ?TSF:MSG:SEND,42-42-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                24236 !TSM:FPAR:NO REPLY
                24238 TSM:FPAR
                24240 RFM69:SWR:SEND,TO=255,SEQ=3,RETRY=0
                24244 RFM69:CSMA:RSSI=-109
                24250 ?TSF:MSG:SEND,42-42-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                26259 !TSM:FPAR:FAIL
                26261 TSM:FAIL:CNT=2
                26263 TSM:FAIL:DIS
                26265 TSF:TDI:TSL
                26267 RFM69:RSL
                36270 TSM:FAIL:RE-INIT
                36272 TSM:INIT
                36274 RFM69:INIT
                36276 RFM69:INIT:PIN,CS=10,IQP=2,IQN=0
                36280 RFM69:PTX:LEVEL=5 dBm
                36282 TSM:INIT:TSP OK
                36286 TSM:INIT:STATID=42
                36288 TSF:SID:OK,ID=42
                36290 TSM:FPAR
                36292 RFM69:SWR:SEND,TO=255,SEQ=0,RETRY=0
                36298 RFM69:CSMA:RSSI=-105
                36304 ?TSF:MSG:SEND,42-42-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                38316 !TSM:FPAR:NO REPLY
                38318 TSM:FPAR
                38320 RFM69:SWR:SEND,TO=255,SEQ=1,RETRY=0
                38324 RFM69:CSMA:RSSI=-105
                38330 ?TSF:MSG:SEND,42-42-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                40339 !TSM:FPAR:NO REPLY
                40341 TSM:FPAR
                40343 RFM69:SWR:SEND,TO=255,SEQ=2,RETRY=0
                40347 RFM69:CSMA:RSSI=-102
                40353 ?TSF:MSG:SEND,42-42-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                42362 !TSM:FPAR:NO REPLY
                42364 TSM:FPAR
                42366 RFM69:SWR:SEND,TO=255,SEQ=3,RETRY=0
                42371 RFM69:CSMA:RSSI=-104
                42377 ?TSF:MSG:SEND,42-42-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                44386 !TSM:FPAR:FAIL
                44388 TSM:FAIL:CNT=3
                44390 TSM:FAIL:DIS
                44392 TSF:TDI:TSL
                44394 RFM69:RSL
                54398 TSM:FAIL:RE-INIT
                54401 TSM:INIT
                54403 RFM69:INIT
                54405 RFM69:INIT:PIN,CS=10,IQP=2,IQN=0
                54409 RFM69:PTX:LEVEL=5 dBm
                54411 TSM:INIT:TSP OK
                54415 TSM:INIT:STATID=42
                54417 TSF:SID:OK,ID=42
                54419 TSM:FPAR
                54421 RFM69:SWR:SEND,TO=255,SEQ=0,RETRY=0
                54427 RFM69:CSMA:RSSI=-105
                54433 ?TSF:MSG:SEND,42-42-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                56442 !TSM:FPAR:NO REPLY
                56444 TSM:FPAR
                56446 RFM69:SWR:SEND,TO=255,SEQ=1,RETRY=0
                56451 RFM69:CSMA:RSSI=-104
                56457 ?TSF:MSG:SEND,42-42-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                58466 !TSM:FPAR:NO REPLY
                58468 TSM:FPAR
                58470 RFM69:SWR:SEND,TO=255,SEQ=2,RETRY=0
                58474 RFM69:CSMA:RSSI=-104
                58480 ?TSF:MSG:SEND,42-42-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                60489 !TSM:FPAR:NO REPLY
                60491 TSM:FPAR
                60493 RFM69:SWR:SEND,TO=255,SEQ=3,RETRY=0
                60497 RFM69:CSMA:RSSI=-102
                60504 ?TSF:MSG:SEND,42-42-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                62513 !TSM:FPAR:FAIL
                62515 TSM:FAIL:CNT=4
                62517 TSM:FAIL:DIS
                62519 TSF:TDI:TSL
                62521 RFM69:RSL
                72525 TSM:FAIL:RE-INIT!
                • W willemx
                  log:
                  119 TSF:LRT:OK
                  135 TSM:INIT
                  148 TSF:WUR:MS=0
                  166 RFM69:INIT
                  scandone
                  state: 0 -> 2 (b0)
                  state: 2 -> 3 (0)
                  state: 3 -> 5 (10)
                  add 0
                  aid 3
                  cnt
                  503 TSM:FAIL:CNT=1
                  523 TSM:FAIL:DIS
                  540 TSF:TDI:TSL
                  557 RFM69:RSL
                  pm open,type:2 0
                  10597 TSM:INIT
                  10612 RFM69:INIT
                  10781 TSM:FAIL:DIS
                  10801 TSF:TDI:TSL
                  10820 RFM69:RSL
                  20862 TSM:INIT
                  20877 RFM69:INIT
                  21047 TSM:FAIL:DIS
                  21066 TSF:TDI:TSL
                  21085 RFM69:RSL
                  31127 TSM:INIT
                  31142 RFM69:INIT
                  31312 TSM:FAIL:DIS
                  31332 TSF:TDI:TSL
                  31350 RFM69:RSL
                  41392 TSM:INIT
                  41407 RFM69:INIT
                  41577 TSM:FAIL:DIS
                  41596 TSF:TDI:TSL
                  41615 RFM69:RSL
                  51657 TSM:INIT
                  51672 RFM69:INIT
                  51842 TSM:FAIL:DIS
                  51861 TSF:TDI:TSL
                  51880 RFM69:RSL
                  61922 TSM:INIT
                  61937 RFM69:INIT
                  62107 TSM:FAIL:DIS
                  62126 TSF:TDI:TSL
                  62145 RFM69:RSL
                  122188 TSM:INIT
                  122204 RFM69:INIT
                  122380 TSM:FAIL:DIS
                  122401 TSF:TDI:TSL
                  122421 RFM69:RSL
                  182464 TSM:INIT
                  182480 RFM69:INIT
                  182656 TSM:FAIL:DIS
                  182677 TSF:TDI:TSL
                  182697 RFM69:RSL
                  242741 TSM:INIT
                  242757 RFM69:INIT
                  242933 TSM:FAIL:DIS
                  242954 TSF:TDI:TSL
                  242974 RFM69:RSL
                  303017 TSM:INIT
                  303033 RFM69:INIT
                  303209 TSM:FAIL:DIS
                  303230 TSF:TDI:TSL
                  303250 RFM69:RSL
                   __  __       ____
                          |___/                      2.3.2
                  28 TSM:INIT
                  28 TSF:WUR:MS=0
                  30 RFM69:INIT
                  38 TSM:INIT:TSP OK
                  45 TSF:SID:OK,ID=42
                  47 TSM:FPAR
                  2068 TSM:FPAR
                  4091 TSM:FPAR
                  6115 TSM:FPAR
                  8136 !TSM:FPAR:FAIL
                  8138 TSM:FAIL:CNT=1
                  8140 TSM:FAIL:DIS
                  8142 TSF:TDI:TSL
                  8142 RFM69:RSL
                  18147 TSM:INIT
                  18149 RFM69:INIT
                  18165 TSM:FPAR
                  20191 TSM:FPAR
                  22214 TSM:FPAR
                  24238 TSM:FPAR
                  26263 TSM:FAIL:DIS
                  26265 TSF:TDI:TSL
                  26267 RFM69:RSL
                  36272 TSM:INIT
                  36274 RFM69:INIT
                  36290 TSM:FPAR
                  38318 TSM:FPAR
                  40341 TSM:FPAR
                  42364 TSM:FPAR
                  44390 TSM:FAIL:DIS
                  44392 TSF:TDI:TSL
                  44394 RFM69:RSL
                  54401 TSM:INIT
                  54403 RFM69:INIT
                  54419 TSM:FPAR
                  56444 TSM:FPAR
                  58468 TSM:FPAR
                  60491 TSM:FPAR
                  62517 TSM:FAIL:DIS
                  62519 TSF:TDI:TSL
                  62521 RFM69:RSL
                  tekkaT
                  tekkaT
                  tekka
                  wrote on last edited by tekka
                  @willemx said in Need help with ESP8266 MQTT Gateway (RFM69HW radio):
                  There is a problem with the rfm69 module and/or wiring on your GW - can you exchange the rfm69 module with the one from the node and post the logs?
                  • W
                    W
                    willemx
                    :tada: :tada: :tada:
                    You were right; there was a minuscule piece of wire strand between two contacts and after removing it all is fine now.
                    Also checked all the radio's again which is easy now I have a working configuration and there was indeed one defective radio module.
                    Thanks everyone for unblocking me!
                    • W willemx
                      tekkaT
                      tekkaT
                      tekka
                      @willemx Excellent! Have fun! :+1:
