  3. Relay node hangs sometimes when toggling a fan
10 Posts 4 Posters 6.3k Views 3 Watching
  • C
    C
    chris021
    I have a sensor node driving a fan and sometimes when toggling the relay the node locks up. I am using a nano board and when it locks up the TX led stays solid.
    The relay board is opto isolated. I have done some research about the interference that can be caused by a relay switching a motor, but I don't understand the solutions and given its 240v I don't want to make changes to the 240 side unless I fully understand them.
    I have tried swapping out the radio, the nano and the relay.
    I have not been able to reproduce the fault when the fan is disconnected.
    My skills are quite basic so any simple advice would be very much appreciated!
    Chris021
      Do you feed the relay from your arduino?
      • C
        C
        chris021
        I have D3 signal low to trigger the relay. The same 5V source powers the relay, but this works fine if no load is connected.
        • C chris021
          BulldogLowellB
          BulldogLowellB
          BulldogLowell
          what kind of power source are you using?
          C 1 Reply Last reply
          • T
            TimO
            I've the same problem with a 4 relay board. After a few times switching on and off, the Atmega hangs.
            Especially if more than one relay on the board is switched.
            I'm currently swithing the power source.
              C
              C
              chris021
              @BulldogLowell im using one of these onto the 5v pin of the board:
              http://www.aliexpress.com/item/5-pcs-AC-DC-85V-265V-700mA-Isolated-Switching-Power-Board-Module-Industrial-Power-Supply-Built/1260239970.html
              I have also tried feeding it via USB of a 2.1 amp supply with the same results.
              • BulldogLowellB
                BulldogLowellB
                BulldogLowell
                So you are powering both the relays and the arduino in parallel from the transformer?
                have you tried isolating the arduino's power from the transformer with a capacitor?
                the power surge of the relays (even though you have an opto-isolator from arduino to relays) may cause issues for the arduino.
                perhaps start with a regular 4.7µF across the Vin and ground of the arduino
                • C
                  C
                  chris021
                  its worth a try, however this works 100% fine when there is not a fan connected :) I might try a different AC device to see if that is just as reliable as no AC device connected.
                  • C chris021
                    BulldogLowellB
                    BulldogLowellB
                    BulldogLowell
                    motors draw a tremendous amount of current when they start... Try isolating the arduino's power from the transformer, or using the capacitor.
                      C
                      C
                      chris021
                      @BulldogLowell I have powered it off an external battery pack. Same story!
