  2. Announcements
  3. 💬 Connecting the Radio
162 Posts 49 Posters 109.3k Views 40 Watching
  • D
    dmonty
    wrote on last edited by dmonty
    #148
    After running NRF24L01+ for a few years I recently decided to upgrade to several NRF24L01+PA+LNA (Antenna version) using the link from this page. Initially the performance was worse. Fail to find gateway, fail to send data and lots of NACKs. However eventually I was able to get them working. Below is a summary of tweaks and suggestions from various Mysensor Forum posts that helped stabilize my sensor network.
    1. Add 47uf capacitor between 3v and ground pin on the transceiver.
    2. Add plastic-wrap then a tinfoil shield as per other threads. Tinfoil needs to to touch the base of the antenna (ground).
    3. My 5V switching power supply to the Arduino Nano was causing problems. Some sort of noise on the wire? When I disconnected the transformer and powered the arduino by laptop usb, the signal was much more reliable. So I added a 1000uf capacitor between ground and 5V coming from the transformer which filtered out the noise coming from the power supply. This is probably not applicable to battery powered devices.
    4. Use static node addressing for each node - automatic addressing sometimes randomly make bad routing decisions bypassing repeater nodes and choosing far away nodes.
      // Far-from-gateway sensor node
      #define MY_NODE_ID 2
      // Parent is a repeater node
      #define MY_PARENT_NODE_ID 1
    5. Lower the power on the transceiver. Try each power level reboot the node and pay attention to: Setup speed, how many NACKs.
      // RF24_PA_MIN = -18dBm;
      // RF24_PA_LOW = -12dBm;
      // RF24_PA_HIGH = -6dBm;
      // RF24_PA_MAX = 0dBm
      #define MY_RF24_PA_LEVEL (RF24_PA_LOW)
    6. Run the RF24 scanner example for a long time to find a channel that is free from noise. I ran it for a day to pick up neighbourhood noise and loaded the results into a spreadsheet to graph. Set the clearest channel on all my nodes. e.g.
      #define MY_RF24_CHANNEL (105)
    7. In domoticz I lowered the ACK time from 1200 to 400 to avoid broadcast storms/collisions. On the nodes after each send or receive add a "wait(LONG_WAIT);" to allow ACKs to settle between transmissions ( e.g. 500ms).
    8. Run a ping-pong test between two battery powered mobile nodes to find optimal locations for your gateway, repeaters and sensors. Find the outer limits and keep the nodes well within those limits. Try not to place a node at the outer range limit, add repeaters. Sometimes moving a few feet in one direction can have a big difference.
    D 1 Reply Last reply
    • alowhumA
      alowhumA
      alowhum
      @dmonty which hardware did you use? It sounds like you tried the old cheap model without shielding.
      There are way better modules out there now which will give you far less trouble.
        Agreed, the shielded modules can run at full power without any problem
        • alowhumA alowhum
          dmonty
          @alowhum @gohan - I used the non-shielded module found in the "Shopping Guide" on this page: https://www.mysensors.org/build/connect_radio. Used bought from the seller that the link took me to.
          The Connecting the Radio page get's you up and running. Would be nice if the "Shopping Guide" - grouped optimal matching components into a plug-n-play style "Shopping Cart". e.g. Optimal recommended component groups for:
          1. Gateway node.
          2. Repeater node.
          3. Sensor node.
          a) usb powered.
          b) transformer powered.
          c) battery powered.
          d) solar powered.
          I think my next experiment may be to pick up the 3v regulated power sockets to see if they will help in increasing the power and range as I've read the 3.3v regulator on the Arduino Nano is not very good at powering the radio.
          • alowhumA
            alowhumA
            alowhum
            #152
            That shopping guide (heck, most examples on the site) is often out of date.
            I'd recommend checking out this thread:
            https://forum.mysensors.org/topic/9668/cdebyte-s-new-nrf24-modules-are-great-and-cheap/26
            For your nodes I'd highly recommend getting the "nano wireless board" from places like aliexpress. The radios just plug right into it.
            For the Raspberry Pi there is also a really easy to use 'hat' that allows you to plug the NRF24 directly into it:
            https://forum.mysensors.org/topic/9696/i-got-a-plug-and-play-nrf24-shield-for-the-pi-on-aliexpress
            • F
              F
              FlyingDomotic
              Concerning RF24 Plus datasheet, it seems that a more recent version is available at https://infocenter.nordicsemi.com/pdf/nRF24L01P_PS_v1.0.pdf?cp=8_4_0_0
              • F FlyingDomotic
                Thanks @FlyingDomotic
                I have updated the page.
                • D dmonty
                  dmonty
                  #155
                  A journal update on NRF24L01+PA+LNA (Antenna version). After 4-5 months two of them stopped transmitting. I had also purchase and installed the 3.3v regulator base socket to help improve overall transmission reliability.
                  Loaded the RF24 library GettingStarted example onto two arduinos connected to laptop and a desktop. Changed the code to match MySensors pinout and data-rate, along with a free channel found by the RF24 scanner example.
                  RF24 radio(9,10);
                  ...snip...
                    radio.begin();
                    radio.setDataRate(RF24_250KBPS);
                    radio.setChannel(120);
                    //radio.setPALevel(RF24_PA_MIN);
                    radio.setPALevel(RF24_PA_LOW);
                    //radio.setPALevel(RF24_PA_HIGH);
                    //radio.setPALevel(RF24_PA_MAX);
                  I Moved laptop to far edges of the range and tried various power levels for NRF2L01 as well as the PA+LNA. Sketch default is RF24_PA_LOW which turns out to have the farthest range with the least packet loss and fastest turn around time packet time. I also cycled through the various radios to weed out the ones that were week. Even with the 3.3v base socket, a capacitor helps as well as cellophane+tinfoil on the PA LNA modules.
                  I then put one of the arduinos onto a battery pack and placed it next to each of my sensors. Then used the laptop to see packet loss next to repeater nodes and gateway. When near the edge of the range moving the antenna a few feet in different directions will cause packet loss. When a sensor is at the edge it is better to move radios closer to each other or a add a repeater. I thought PA LNA would be better in all locations but it turns out that the cheaper base radios sometimes perform better.
                  gohanG 1 Reply Last reply
                  • D dmonty
                    RF24 radio(9,10);
                    ...snip...
                      radio.begin();
                    @dmonty did you use the shielded radio module?
                      dmonty
                      @gohan said in 💬 Connecting the Radio:
                      Yes they are shielded.
                      I found another way to find optimal sensor location using an on/off loop script as a ping. Start the ping running then move the antenna to find best mount point location.
                      To find the strongest location it helps to find the weak-signal boundaries where packets are lost, then make sure the antenna is on the inside of the boundary. Move the antenna:
                      • X+, X-
                      • Y+, Y-
                      • Z+, Z-
                      #!/bin/sh
                      # Desc: Domoticz ping script to help find optimal location for sensor antenna.
                      # Auth: Dean Montgomery
                      # Date: April 21, 2020
                      # Url of domoticz server.
                      HOST="http://192.168.0.1:8080"
                      # ID=14 is device idx of a light switch found on the Divices page of domoticz.
                      ID=14
                      while true; do
                        CMD="${HOST}/json.htm?type=command&param=switchlight&idx=${ID}&switchcmd="
                        echo "=== ON ==="
                        wget -q -O - "${CMD}On"
                        sleep 1
                        echo "=== OFF ==="
                        wget -q -O - "${CMD}Off"
                        sleep 1
                      done
                      It may help to include a dummy ping light switch in all sensor nodes dedicated for this purpose.
                      • C
                        C
                        cloolalang
                        Tips for connecting the LoRa Radios:
                        1. Use de-coupling capacitor on power supplies (as per above other radios).
                        2. Carefully select: MY_RFM95_TX_POWER_DBM and MY_RFM95_MAX_POWER_LEVEL_DBM as Semtech spec states +20dBm output power is only for 1% duty cycle operations, and some modules (AI-Thinker RA-02) are only rated as +18dbm.
                        3. If you build a LoRa radio gateway using an ESP32 (for example), take care to provide a separate, low-noise 3.3V power supply to the radio as the on-board voltage regulator may not be able to supply enough current at the higher RF output power levels.
                        • BearWithBeardB
                          BearWithBeardB
                          BearWithBeard
                          wrote on last edited by BearWithBeard
                          #159
                          Since I already (half-heartedly) posted drawings of some RFM modules I created a while ago in another thread, I might as well put a little RFM69 / RFM9x infographic or cheat sheet together and share it with everyone. It's supposed to give beginners a quick overview over the available MySensors-compatible HopeRF modules.
                          If you guys mind that I included the MySensors logo and mascot, please let me know and I'll remove it ASAP.
                          • sundberg84S
                            sundberg84S
                            Connection diagram/circuit between RFM module and atmega328p-au TQFP footprint.
                            • sundberg84S sundberg84
                              tssk
                              I would like to ask about the radio module connection - I am using SX1276 and I connect it the same way as described by @sundberg84 said in 💬 Connecting the Radio except I additionally connect also RST (NRESET) pin according to this https://github.com/sandeepmistry/arduino-LoRa/blob/master/README.md#semtech-sx1276777879-wiring
                              Is it necessary?
                              • J
                                J
                                jenspr
                                I was wondering about the lengths for the antennas mentioned on this page.
                                For 868Mhz is mentioned a length of 82.2 mm on this page. The length most often mentioned over the internet - as first result of the 1/4 wave calculation - is 86,5mm.
                                Searching a little deeper through the internet, i found that the antenna should be "a little shorter". Then they end up with around -1cm shorter or something around or more.
                                One page mentioned the physically effect that the wave is moving in chopper around 5% slower as the theoratical speed. If i substract 5% of 86,5mm i end up with the here mentioned 82,2mm.
                                I was very suprised about the different "approaches" for such a basic thing as antenna length every single . As most of the application over the internet seem to work somehow with all that different lengths, it seems to be just a fine-tuning thing.
                                Anyway, i think it would be nice to mention this details here because most people will wonder about the 82,2mm in the first view...
                                best regards
                                Jens
