  3. I got a plug-and-play NRF24 shield for the Pi on Aliexpress
9 Posts 5 Posters 4.8k Views 4 Watching
  • alowhumA
    alowhumA
    alowhum
    I want to give workshops with MySensors in which I want to make connecting things as simple as possible. That's why I bought this "Raspi Wireless Shield v1.0" from Aliexpress:
    https://www.aliexpress.com/item/Wireless-Rapspberry-Pie-Rpi-Shield-Board-For-Raspberry-Pi-Support-Zigbee-Xbee-NRF24L01-NRF24L01-RFM12B-D/32858434375.html
    The short version
    I traced the pins to their origin, as they are not perfectly connected to the same pins MySensors normally uses.
    NRF24 -> PI GPIO -> PI PIN
    IRQ = ?? unconnected?
    MO = io10 = 19 (normal)
    CSN = io8 = 24 (normal)
    VCC = 3.3v (normal)
    MI = io9 = 21 (normal)
    SCK = io11 = 23 (normal)
    CE = io18 = 12 (different!)
    GND = GND (normal)
    The board also supports plugging in the RFM12B 433Mhz transceiver. That thing is another story for another thread.
    More details
    It's a mysterious shield: and learning more about it took some detective work. The shield itself has some markings: a nice metalic "GEEKROOM" logo (found nothing on that..), and an almost invisible "ukonline2000" logo as well. That last name is from ukonline2000.com which seems to be a Chinese website with Raspberry Pi news. The earliest mention of the board I found was this one.
    There are a lot of pictures on SmartDuino. There's also an Instructables page that only adds to the confusion because they plugged in the board the wrong way in the first picture.
    It also seems to be called the "wireless picobber", including on Amazon.
    • alowhumA
      alowhumA
      alowhum
      In order to use this board you only need to add this parameter to the configure command:
      --my-rf24-ce-pin=12
      The board also has a built-in multicolor LED. I'll see what happens when I use this:
      --my-leds-rx-pin=32 or --my-leds-rx-pin=15
      Probably nothing, since it should in theory be driven via PWM af 50hz.
      • alowhumA alowhum
        --my-rf24-ce-pin=12
        @alowhum you could use MY_INDICATION_HANDLER to pwm the leds if you want to.
        • alowhumA
          alowhumA
          alowhum
          @mfalkvidd Sounds interesting! Could you explain that a bit more? The page you link to doesn't offer any details on what it is.
          YveauxY 1 Reply Last reply
          • alowhumA alowhum
            YveauxY
            YveauxY
            @alowhum https://www.google.nl/search?q=MY_INDICATION_HANDLER+site%3Amysensors.org
            • elysionE
              elysionE
              elysion
              wrote on last edited by elysion
              Did you get the LEDs to work @alowhum? From the previous messages I gather all you need in order to get the shield to work is to include the configuration flag. Is this correct? Bought the shield, because I wanted to build a more robust setup without dupont cables everywhere.
              elysionE 1 Reply Last reply
              • elysionE elysion
                elysionE
                elysionE
                elysion
                FYI for anyone who finds this thread:
                I installed the shield on a Raspberry Pi 3 and used --my-leds-rx-pin=15 --my-rf24-ce-pin=12 config parameters. The network seems to work and the red LED is blinking. I have not verified whether the LED blinks when MySensors daemon receives a message, but I would assume it does and does not just blink randomly.
                All in all this shield seems like quite a nice way to install the NRF24 radio to a Raspberry Pi, so I would highly recommend it over Dupont cables.
                • puskyerP
                  puskyerP
                  puskyer
                  Hello
                  Not sure if this will be helpfull, I have a module/breakout board that looks exactly the one above, but both the CE and CSN pins are different.
                  CE (3) my board = gpio21 = pin 13
                  should be = gpio17 = pin 11
                  CSN(4) my board = gpio18 = pin 12
                  should be = gpio8 = pin 24
                  So I found info from the following link: link text
                  So it seem the raspberry pi SPIDEV0 by default has 2 CSN pins configured ( 7 and 8 ) and the SPI driver in the kernel uses GPIOS toggled by software, rather than hardware. So, this means that any GPIO can be used for CSN, and it can support more then two.
                  Also based on the link all of the setup for the SPI driver is defined in the device tree, and we can use device tree overlays stored in /boot to dynamically configure the device tree.
                  The following is my example spi-cs-extend.dts file to create SPIDEV with CSN pins, on GPIO 8, 7, 18. (18 is the GPIO for my RF24 breakout board)
                  To compile it to a binary I used the following command:
                  dtc -@ -I dts -O dtb -o spi-cs-extend.dtbo spi-cs-extend.dts
                  Then I placeed the new spi-cs-extend.dtbo into /boot/overlays/ and added the following line to the /boot/config.txt file.
                  dtoverlay=spi-cs-extend.
                  After rebooting, I had a /dev/spidev0.2 which now allows me to communicate with the RF24L01 breakout board.
                  my spi-cs-extend.dts file
                  /dts-v1/;
                  /plugin/;
                          compatible = "brcm,bcm2835";
                          fragment@0 {
                                  target = <&spi0_cs_pins>;
                                  frag0: __overlay__ {
                                          brcm,pins = <8 7 18>;
                          fragment@1 {
                                  target = <&spi0>;
                                  frag1: __overlay__ {
                                          #address-cells = <1>;
                                          #size-cells = <0>;
                                          cs-gpios = <&gpio 8 1>, <&gpio 7 1>, <&gpio 18 1>;
                                          status = "okay";
                                          spidev0_2: spidev@2 {
                                                  compatible = "spidev";
                                                  reg = <2>;
                                                  #size-cells = <0>;
                                                  spi-max-frequency = <125000000>;
                  • puskyerP
                    puskyerP
                    puskyer
                    UPDATE: if at one point you need to use GPIO18 for something other then RF24L01 then you have to delete the spi-cs-extend.dtbo file from the /boot/overlays/ and then reboot.
