  3. Help needed to setup a RFM69 & ESP8266 Gateaway on Adafruit Feather Huzzah
35 Posts 6 Posters 3.5k Views 4 Watching
  • H Offline
    H Offline
    hlehoux
    Hello, i'm trying to setup a gateaway on ESP8266 like explained in https://www.mysensors.org/build/esp8266_gateway but i don't have a NodeMCU or Wemos D1 Mini.
    I have an Adafruit Huzzah Feather and i can't figure out what pins to use for connecting to DIO0 and NSS on the RFM69 even though my sketch compiles and uploads correctly .
    Anyone can help, or have a working GatewayESP8266.ino for the Huzzah ?
    Many thanks !
    • H Offline
      H Offline
      hlehoux
      Here is what i have tried:
      I try using GPIO 2 and 15 to pilot the RFM69
      here an extract of my GatewayESP8266.ino
      #define MY_BAUD_RATE 9600
      //#define MY_RADIO_RF24
      #define MY_RADIO_RFM69
      #define MY_IS_RFM69HW // Omit if your RFM is not "H"
      #define MY_RFM69_IRQ_PIN 2
      #define MY_RFM69_IRQ_NUM MY_RFM69_IRQ_PIN
      #define MY_RFM69_CS_PIN 15 // NSS. Use MY_RFM69_SPI_CS for older versions (before 2.2.0)
         pinMode(MY_RFM69_IRQ_PIN, OUTPUT);
         pinMode(MY_RFM69_CS_PIN, OUTPUT);
        digitalWrite(MY_RFM69_IRQ_PIN, HIGH);
      delay(1000);
      digitalWrite(MY_RFM69_IRQ_PIN, LOW);
      delay(1000);
      What's going wrong is i need to unplug the wire to GPIO2 at boot time unless it won't boot
      then if i do that and replug the wire after boot, TFM is not initialized properly and
      i get this log:
      MCO:BGN:INIT GW,CP=RRNGE---,FQ=80,REL=255,VER=2.3.2
      114 TSF:LRT:OK
      130 TSM:INIT
      143 TSF:WUR:MS=0
      163 TSM:INIT:TSP OK
      184 TSM:INIT:GW MODE
      206 TSM:READY:ID=0,PAR=0,DIS=0
      238 MCO:REG:NOT NEEDED
      scandone
      1311 GWT:TIN:CONNECTING...
      2339 GWT:TIN:CONNECTING...
      scandone
      state: 0 -> 2 (b0)
      state: 2 -> 3 (0)
      state: 3 -> 5 (10)
      add 0
      aid 2
      connected with TPLINK_BUREAU, channel 1
      dhcp client start...
      cnt
      3168 GWT:TIN:CONNECTING...
      ip:192.168.1.50,mask:255.255.255.0,gw:192.168.1.1
      4329 GWT:TIN:CONNECTING...
      4357 GWT:TIN:IP: 192.168.1.50
      4389 MCO:BGN:STP
      pm open,type:2 0
      14407 MCO:BGN:INIT OK,TSP=1
      14436 TSM:READY:NWD REQ
      15462 ?TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=20,pt=0,l=0,sg=0,ft=0,st=OK:
      My knowlegde in electronics is level zero unfortunalty
      The adafruit Huzzah documentation states that
      GPIO #2, is also used to detect boot-mode. It also is connected to the blue LED that is near the WiFi antenna. It has a pullup resistor connected to it, and you can use it as any output (like #0) and blink the blue LED.
      So i thought i could wire directly GPIO2 to DIO0 on the RFM69 like explained https://www.mysensors.org/build/connect_radio but obviously i do something wrong
      Please Help :-)
      • H Offline
        H Offline
        hlehoux
        I guess this means i finally managed to get it working:
        4131 MCO:BGN:STP
        4133 MCO:BGN:INIT OK,TSP=1
        4135 TSM:READY:NWD REQ
        4139 ?TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=20,pt=0,l=0,sg=0,ft=0,st=OK:
        pm open,type:2 0
        30149 TSF:MSG:READ,5-5-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
        30155 TSF:MSG:BC
        30157 TSF:MSG:FPAR REQ,ID=5
        30159 TSF:PNG:SEND,TO=0
        30161 TSF:CKU:OK
        30163 TSF:MSG:GWL OK
        30641 TSF:MSG:SEND,0-0-5-5,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
        32650 TSF:MSG:READ,5-5-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
        32655 TSF:MSG:PINGED,ID=5,HP=1
        • H hlehoux
          4131 MCO:BGN:STP
          pm open,type:2 0
          30155 TSF:MSG:BC
          30161 TSF:CKU:OK
          Nice work @hlehoux
          Is there any information we could add to the radio connection page to help other Feather users?
          H 1 Reply Last reply
            Nice work @hlehoux
            H Offline
            H Offline
            hlehoux
            @mfalkvidd
            Hello, certainly yes; anyhow, my setup is quite experimental yet:
            • my antenna setup is quite bad, i loose radio messages or don't receive Ack from the gateway (my bad, i have 868 MHz RFM69 and ordered antennas for 433 MHz)
            • i can confirm it works with NSS on pin GPIO#15 and IRQ_PIN on GPIO#0 orGPIO#2
            • i have not resolved yet the problem of GPIO#0 and GPIO#2 being used by ESP8266 to detect boot-mode so you have to connect the pin after booting which is very annoying
              There are articles like this one https://www.instructables.com/id/ESP8266-Using-GPIO0-GPIO2-as-inputs/ but i'm quite newbie in electronics...
            I will post more details when my config is better.
            • H hlehoux
              @mfalkvidd
              @hlehoux is there a reason you can't use gpio5 for irq? That's what I used on a different esp board when verifying the instructions on https://www.mysensors.org/build/connect_radio
              H 2 Replies Last reply
                H Offline
                H Offline
                hlehoux
                @mfalkvidd Well i'm not sure, on [huzzah pinout](link url) GPIO#4 and GPIO#5 are described about I2C SDA & SCL and GPIO #12/13/14 are the same as SCK/MOSI/MISO so i thought would be better not to use them.
                I will try and report back.
                Seems to me (first try) that GPIO#2 works well, provided you connect it both to VCC (it has a pullup resistor ) to avoid boot-mode and to IRQ
                  H Offline
                  H Offline
                  hlehoux
                  @mfalkvidd thank you for pointing this to me. I confirm gpio5 works well for IRQ. I read too many articles about how to use gpio0 or gpio2 !
                  Anyway i still get very bad transmission ratio, even with very close distance and after buying antennas the good size for my 868 MHz RFM69s
                  Can some of you guys point me to help on how to troubleshoot transmissions and/or bad antenna setup for the RFM69, for a newbie like me ?
                  Thank you
                  • electrikE Offline
                    electrikE Offline
                    electrik
                    Can you switch on MY_DEBUG_VERBOSE_RFM69 in your node and post the output?
                    Also post the sketch please.
                    • H Offline
                      H Offline
                      hlehoux
                      wrote on last edited by hlehoux
                      Thank you for offering help!
                      Here is the output of my node "AT Startup" with MY_DEBUG_VERBOSE_RFM69
                       __  __       ____
                              |___/                      2.3.2
                      16 MCO:BGN:INIT NODE,CP=RPNNA---,FQ=8,REL=255,VER=2.3.2
                      28 TSM:INIT
                      28 TSF:WUR:MS=0
                      30 RFM69:INIT
                      32 RFM69:INIT:PIN,CS=10,IQP=2,IQN=0
                      36 RFM69:PTX:LEVEL=5 dBm
                      38 TSM:INIT:TSP OK
                      40 TSF:SID:OK,ID=1
                      43 TSM:FPAR
                      45 RFM69:SWR:SEND,TO=255,SEQ=0,RETRY=0
                      51 RFM69:CSMA:RSSI=-108
                      55 ?TSF:MSG:SEND,1-1-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                      2064 !TSM:FPAR:NO REPLY
                      2066 TSM:FPAR
                      2068 RFM69:SWR:SEND,TO=255,SEQ=1,RETRY=0
                      2072 RFM69:CSMA:RSSI=-109
                      2078 ?TSF:MSG:SEND,1-1-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                      2838 RFM69:SAC:SEND ACK,TO=0,RSSI=-30
                      2842 RFM69:CSMA:RSSI=-111
                      2848 TSF:MSG:READ,0-0-1,s=255,c=3,t=8,pt=1,l=1,sg=0:0
                      2854 TSF:MSG:FPAR OK,ID=0,D=1
                      4087 TSM:FPAR:OK
                      4087 TSM:ID
                      4089 TSM:ID:OK
                      4091 TSM:UPL
                      4093 RFM69:SWR:SEND,TO=0,SEQ=3,RETRY=0
                      4098 RFM69:CSMA:RSSI=-108
                      4304 !RFM69:SWR:NACK
                      4306 RFM69:SWR:SEND,TO=0,SEQ=4,RETRY=1
                      4311 RFM69:CSMA:RSSI=-107
                      4517 !RFM69:SWR:NACK
                      4519 RFM69:SWR:SEND,TO=0,SEQ=4,RETRY=2
                      4524 RFM69:CSMA:RSSI=-108
                      4730 !RFM69:SWR:NACK
                      4732 RFM69:SWR:SEND,TO=0,SEQ=4,RETRY=3
                      4737 RFM69:CSMA:RSSI=-107
                      4923 RFM69:SWR:ACK,FROM=0,SEQ=4,RSSI=-74
                      4927 RFM69:ATC:ADJ TXL,cR=-74,tR=-78..-82,TXL=5
                      4931 RFM69:PTX:LEVEL=4 dBm
                      4935 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
                      5156 RFM69:SAC:SEND ACK,TO=0,RSSI=-29
                      5160 RFM69:CSMA:RSSI=-108
                      5167 TSF:MSG:READ,0-0-1,s=255,c=3,t=25,pt=1,l=1,sg=0:1
                      5173 TSF:MSG:PONG RECV,HP=1
                      5175 TSM:UPL:OK
                      5177 TSM:READY:ID=1,PAR=0,DIS=1
                      5181 RFM69:SWR:SEND,TO=0,SEQ=5,RETRY=0
                      5185 RFM69:CSMA:RSSI=-109
                      5392 !RFM69:SWR:NACK
                      5394 RFM69:SWR:SEND,TO=0,SEQ=6,RETRY=1
                      5398 RFM69:CSMA:RSSI=-106
                      5605 !RFM69:SWR:NACK
                      5607 RFM69:SWR:SEND,TO=0,SEQ=6,RETRY=2
                      5611 RFM69:CSMA:RSSI=-107
                      5818 !RFM69:SWR:NACK
                      5820 RFM69:SWR:SEND,TO=0,SEQ=6,RETRY=3
                      5824 RFM69:CSMA:RSSI=-111
                      6031 !RFM69:SWR:NACK
                      6033 RFM69:SWR:SEND,TO=0,SEQ=6,RETRY=4
                      6037 RFM69:CSMA:RSSI=-109
                      6244 !RFM69:SWR:NACK
                      6246 !TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=NACK:0100
                      7464 RFM69:SAC:SEND ACK,TO=0,RSSI=-29
                      7471 RFM69:CSMA:RSSI=-107
                      7475 TSF:MSG:READ,0-0-1,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                      7481 RFM69:SWR:SEND,TO=0,SEQ=7,RETRY=0
                      7487 RFM69:CSMA:RSSI=-108
                      7694 !RFM69:SWR:NACK
                      7696 RFM69:SWR:SEND,TO=0,SEQ=8,RETRY=1
                      7700 RFM69:CSMA:RSSI=-105
                      7907 !RFM69:SWR:NACK
                      7909 RFM69:SWR:SEND,TO=0,SEQ=8,RETRY=2
                      7913 RFM69:CSMA:RSSI=-107
                      8120 !RFM69:SWR:NACK
                      8122 RFM69:SWR:SEND,TO=0,SEQ=8,RETRY=3
                      8126 RFM69:CSMA:RSSI=-108
                      8333 !RFM69:SWR:NACK
                      8335 RFM69:SWR:SEND,TO=0,SEQ=8,RETRY=4
                      8339 RFM69:CSMA:RSSI=-106
                      8546 !RFM69:SWR:NACK
                      8548 !TSF:MSG:SEND,1-1-0-0,s=255,c=0,t=17,pt=0,l=5,sg=0,ft=1,st=NACK:2.3.2
                      8556 RFM69:SWR:SEND,TO=0,SEQ=8,RETRY=0
                      8560 RFM69:CSMA:RSSI=-106
                      8767 !RFM69:SWR:NACK
                      8769 RFM69:SWR:SEND,TO=0,SEQ=9,RETRY=1
                      8773 RFM69:CSMA:RSSI=-108
                      8980 !RFM69:SWR:NACK
                      8982 RFM69:SWR:SEND,TO=0,SEQ=9,RETRY=2
                      8986 RFM69:CSMA:RSSI=-108
                      9193 !RFM69:SWR:NACK
                      9195 RFM69:SWR:SEND,TO=0,SEQ=9,RETRY=3
                      9199 RFM69:CSMA:RSSI=-107
                      9406 !RFM69:SWR:NACK
                      9408 RFM69:SWR:SEND,TO=0,SEQ=9,RETRY=4
                      9412 RFM69:CSMA:RSSI=-106
                      9619 !RFM69:SWR:NACK
                      9621 !TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=2,st=NACK:0
                      Presentation
                      11628 RFM69:SWR:SEND,TO=0,SEQ=9,RETRY=0
                      11634 RFM69:CSMA:RSSI=-110
                      11841 !RFM69:SWR:NACK
                      11843 RFM69:SWR:SEND,TO=0,SEQ=10,RETRY=1
                      11847 RFM69:CSMA:RSSI=-108
                      12056 !RFM69:SWR:NACK
                      12058 RFM69:SWR:SEND,TO=0,SEQ=10,RETRY=2
                      12062 RFM69:CSMA:RSSI=-108
                      12271 !RFM69:SWR:NACK
                      12273 RFM69:SWR:SEND,TO=0,SEQ=10,RETRY=3
                      12277 RFM69:CSMA:RSSI=-110
                      12486 !RFM69:SWR:NACK
                      12488 RFM69:SWR:SEND,TO=0,SEQ=10,RETRY=4
                      12492 RFM69:CSMA:RSSI=-106
                      12701 !RFM69:SWR:NACK
                      12703 !TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=11,pt=0,l=13,sg=0,ft=3,st=NACK:RFM69 Sensor
                      12711 RFM69:SWR:SEND,TO=0,SEQ=10,RETRY=0
                      12718 RFM69:CSMA:RSSI=-108
                      12924 !RFM69:SWR:NACK
                      12926 RFM69:SWR:SEND,TO=0,SEQ=11,RETRY=1
                      12931 RFM69:CSMA:RSSI=-106
                      13139 !RFM69:SWR:NACK
                      13142 RFM69:SWR:SEND,TO=0,SEQ=11,RETRY=2
                      13146 RFM69:CSMA:RSSI=-107
                      13355 !RFM69:SWR:NACK
                      13357 RFM69:SWR:SEND,TO=0,SEQ=11,RETRY=3
                      13361 RFM69:CSMA:RSSI=-106
                      13570 !RFM69:SWR:NACK
                      13572 RFM69:SWR:SEND,TO=0,SEQ=11,RETRY=4
                      13576 RFM69:CSMA:RSSI=-109
                      13785 !RFM69:SWR:NACK
                      13787 !TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=4,st=NACK:1.0
                      13795 RFM69:SWR:SEND,TO=0,SEQ=11,RETRY=0
                      13799 RFM69:CSMA:RSSI=-111
                      14006 !RFM69:SWR:NACK
                      14008 RFM69:SWR:SEND,TO=0,SEQ=12,RETRY=1
                      14012 RFM69:CSMA:RSSI=-105
                      14219 !RFM69:SWR:NACK
                      14221 RFM69:SWR:SEND,TO=0,SEQ=12,RETRY=2
                      14225 RFM69:CSMA:RSSI=-106
                      14432 !RFM69:SWR:NACK
                      14434 RFM69:SWR:SEND,TO=0,SEQ=12,RETRY=3
                      14438 RFM69:CSMA:RSSI=-107
                      14645 !RFM69:SWR:NACK
                      14647 RFM69:SWR:SEND,TO=0,SEQ=12,RETRY=4
                      14651 RFM69:CSMA:RSSI=-107
                      14858 !RFM69:SWR:NACK
                      14860 !TSF:MSG:SEND,1-1-0-0,s=0,c=0,t=23,pt=0,l=0,sg=0,ft=5,st=NACK:
                      14866 RFM69:SWR:SEND,TO=0,SEQ=12,RETRY=0
                      14872 RFM69:CSMA:RSSI=-109
                      15079 !RFM69:SWR:NACK
                      15081 RFM69:SWR:SEND,TO=0,SEQ=13,RETRY=1
                      15085 RFM69:CSMA:RSSI=-105
                      15292 !RFM69:SWR:NACK
                      15294 RFM69:SWR:SEND,TO=0,SEQ=13,RETRY=2
                      15298 RFM69:CSMA:RSSI=-107
                      15505 !RFM69:SWR:NACK
                      15507 RFM69:SWR:SEND,TO=0,SEQ=13,RETRY=3
                      15511 RFM69:CSMA:RSSI=-106
                      15718 !RFM69:SWR:NACK
                      15720 RFM69:SWR:SEND,TO=0,SEQ=13,RETRY=4
                      15724 RFM69:CSMA:RSSI=-109
                      15931 !RFM69:SWR:NACK
                      15933 !TSF:MSG:SEND,1-1-0-0,s=1,c=0,t=0,pt=0,l=0,sg=0,ft=6,st=NACK:
                      15939 MCO:REG:REQ
                      15941 RFM69:SWR:SEND,TO=0,SEQ=13,RETRY=0
                      15947 RFM69:CSMA:RSSI=-105
                      16154 !RFM69:SWR:NACK
                      16156 RFM69:SWR:SEND,TO=0,SEQ=14,RETRY=1
                      16160 RFM69:CSMA:RSSI=-109
                      16367 !RFM69:SWR:NACK
                      16369 RFM69:SWR:SEND,TO=0,SEQ=14,RETRY=2
                      16373 RFM69:CSMA:RSSI=-108
                      16580 !RFM69:SWR:NACK
                      16582 RFM69:SWR:SEND,TO=0,SEQ=14,RETRY=3
                      16586 RFM69:CSMA:RSSI=-107
                      16793 !RFM69:SWR:NACK
                      16795 RFM69:SWR:SEND,TO=0,SEQ=14,RETRY=4
                      16799 RFM69:CSMA:RSSI=-105
                      17006 !RFM69:SWR:NACK
                      17008 !TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=7,st=NACK:2
                      17016 !TSM:READY:UPL FAIL,SNP
                      And while executing loop() every 2 seconds:
                      Loop
                      478496 RFM69:SWR:SEND,TO=0,SEQ=80,RETRY=0
                      478502 RFM69:CSMA:RSSI=-107
                      478707 !RFM69:SWR:NACK
                      478709 RFM69:SWR:SEND,TO=0,SEQ=81,RETRY=1
                      478715 RFM69:CSMA:RSSI=-108
                      478922 !RFM69:SWR:NACK
                      478924 RFM69:SWR:SEND,TO=0,SEQ=81,RETRY=2
                      478930 RFM69:CSMA:RSSI=-108
                      479137 !RFM69:SWR:NACK
                      479139 RFM69:SWR:SEND,TO=0,SEQ=81,RETRY=3
                      479145 RFM69:CSMA:RSSI=-105
                      479352 !RFM69:SWR:NACK
                      479354 RFM69:SWR:SEND,TO=0,SEQ=81,RETRY=4
                      479361 RFM69:CSMA:RSSI=-104
                      479526 RFM69:SWR:ACK,FROM=0,SEQ=81,RSSI=-90
                      479533 RFM69:ATC:ADJ TXL,cR=-90,tR=-78..-82,TXL=11
                      479537 RFM69:PTX:LEVEL=12 dBm
                      479541 TSF:MSG:SEND,1-1-0-0,s=1,c=1,t=16,pt=2,l=2,sg=0,ft=1,st=OK:1
                      Loop
                      481548 RFM69:SWR:SEND,TO=0,SEQ=81,RETRY=0
                      481554 RFM69:CSMA:RSSI=-109
                      481761 !RFM69:SWR:NACK
                      481763 RFM69:SWR:SEND,TO=0,SEQ=82,RETRY=1
                      481769 RFM69:CSMA:RSSI=-109
                      481976 !RFM69:SWR:NACK
                      481978 RFM69:SWR:SEND,TO=0,SEQ=82,RETRY=2
                      481984 RFM69:CSMA:RSSI=-106
                      482191 !RFM69:SWR:NACK
                      482193 RFM69:SWR:SEND,TO=0,SEQ=82,RETRY=3
                      482199 RFM69:CSMA:RSSI=-105
                      482406 !RFM69:SWR:NACK
                      482408 RFM69:SWR:SEND,TO=0,SEQ=82,RETRY=4
                      482414 RFM69:CSMA:RSSI=-108
                      482621 !RFM69:SWR:NACK
                      482623 !TSF:MSG:SEND,1-1-0-0,s=1,c=1,t=16,pt=2,l=2,sg=0,ft=0,st=NACK:1
                      Loop
                      484630 RFM69:SWR:SEND,TO=0,SEQ=82,RETRY=0
                      484636 RFM69:CSMA:RSSI=-109
                      484841 !RFM69:SWR:NACK
                      484843 RFM69:SWR:SEND,TO=0,SEQ=83,RETRY=1
                      484849 RFM69:CSMA:RSSI=-107
                      485056 !RFM69:SWR:NACK
                      485058 RFM69:SWR:SEND,TO=0,SEQ=83,RETRY=2
                      485064 RFM69:CSMA:RSSI=-108
                      485271 !RFM69:SWR:NACK
                      485273 RFM69:SWR:SEND,TO=0,SEQ=83,RETRY=3
                      485279 RFM69:CSMA:RSSI=-105
                      485486 !RFM69:SWR:NACK
                      485488 RFM69:SWR:SEND,TO=0,SEQ=83,RETRY=4
                      485494 RFM69:CSMA:RSSI=-107
                      485662 RFM69:SWR:ACK,FROM=0,SEQ=83,RSSI=-88
                      485666 RFM69:ATC:ADJ TXL,cR=-88,tR=-78..-82,TXL=12
                      485672 RFM69:PTX:LEVEL=13 dBm
                      485675 TSF:MSG:SEND,1-1-0-0,s=1,c=1,t=16,pt=2,l=2,sg=0,ft=1,st=OK:1
                      And my Sketch :
                      #define MY_DEBUG_VERBOSE
                      #define MY_DEBUG_VERBOSE_RFM69
                      //#define MY_DEBUG_VERBOSE_RFM69_REGISTERS
                      #define MY_RFM69_NEW_DRIVER
                      //#define MY_RFM69_ATC_MODE_DISABLED
                      //#define MY_RFM69_TX_POWER_DBM 20
                      //#define MY_REPEATER_FEATURE
                      //#define MY_NODE_ID 5
                      #define OPEN 1
                      // Initialize motion message
                      MyMessage msg(1, V_TRIPPED);
                      uint8_t value = OPEN;
                        pinMode(LED_BUILTIN, OUTPUT);
                        Serial.println("Presentation");
                        sendSketchInfo("RFM69 Sensor ", "1.0");
                          present(0, S_CUSTOM);
                          present(1, S_DOOR);
                        Serial.println("Loop");
                        digitalWrite(LED_BUILTIN, HIGH);   // turn the LED on (HIGH is the voltage level)
                        delay(1000);                       // wait for a second
                        digitalWrite(LED_BUILTIN, LOW);    // turn the LED off by making the voltage LOW
                        //sendHeartbeat();
                        send(msg.set(OPEN));
                      • H Offline
                        H Offline
                        hlehoux
                        I'm also reading a few posts like this one trying to understand a bit more ....
                        • electrikE Offline
                          electrikE Offline
                          electrik
                          Are you sure about ask your hardware versions? I bought rfm69 modules and I thought they were the HW version but they turned out to be the normal ones.
                          So important is
                          • module version
                          • frequency
                          It looks like even with a high rssi your reception is not good. But maybe I interpret this the wrong way. Can I've of the developers or more experienced help with the analysis?
                          • H Offline
                            H Offline
                            hlehoux
                            Thank you @electrik
                            My intent is to use RFM69HW 868Mhz
                            I compared with photos on the internet like here
                            mine is:
                            as far as i understand my reading my RSSI values seem to tell my signal is very weak and noisy ?
                            I tried to provide the pwr to the rfm69 with an external source instead of the esp8266 but i was not better.
                            hakha4H electrikE 2 Replies Last reply
                            • H hlehoux
                              Thank you @electrik
                              mine is:
                              hakha4H Offline
                              hakha4H Offline
                              hakha4
                              @hlehoux Hi!
                              I had quite alot of trouble with NRF24 modules with shaky connections despite doing everything that has been discussed in forum with power supply etc and have ordered a bunch of RFM69's to hopefully improve this according to others in forum claiming better stability with RFM''s. Haven't tested yet but reading this is a bit dissapointing.
                              One thing though. Readings in log shows very high RSSI values and if it is measured in dBm this is very bad. The lower value the better I believe. Antenna issue ?
                              • H hlehoux
                                Thank you @electrik
                                mine is:
                                electrikE Offline
                                electrikE Offline
                                electrik
                                @hlehoux can you take a photo from the back also? There should be a table telling which one it is exactly.
                                @hakha4 said in Help needed to setup a RFM69 & ESP8266 Gateaway on Adafruit Feather Huzzah:
                                Antenna issue ?
                                You could be right.
                                What antenna do you have?
                                • H Offline
                                  H Offline
                                  hlehoux
                                  Hello, here are 2 photos
                                  one from the back:
                                  I'm not sure what the "W" means, i read chinese copy don't have it ?
                                  one from the antenna:
                                  It should be the good size for 868 MHz
                                  I don't use "ground plane" or sort of, would this explain so bad RSSI ?
                                  Thank you again for your help and patience
                                  hakha4H S 2 Replies Last reply
                                  • hakha4H hakha4
                                    @hlehoux Hi!
                                    H Offline
                                    H Offline
                                    hlehoux
                                    @hakha4 i also have several NRF24 nodes and gateaway
                                    After trying several antenna/tranceiver, i recommend using
                                    "E01-ML01DP5 Long Range SPI nRF24L01P 2.4Ghz 100mW SMA Antenna IoT Wireless Transceiver Transmitter Receiver nRF24L01P RF Module"
                                    as a repeater
                                    It gives far better range results
                                    Anyway i wanted to try RFM69 to avoid having many repeaters
                                    • electrikE Offline
                                      electrikE Offline
                                      electrik
                                      The modules correspond to what it should be.
                                      It looks like your ground is connected to the ANT pin on the picture, on the bottom side of the PCB?
                                      • H hlehoux
                                        one from the back:
                                        hakha4H Offline
                                        hakha4H Offline
                                        hakha4
                                        @hlehoux Hi!
                                        W means the low power output variant (+13dBm). There is another version named 'HW' which give a higher transmission output (+20 dBM). As elektik pointed out, check out the solder of the antenna. Did the antenna come presoldered or you did it yourself?
                                        Another option for the coiled antenna is a straight copper wire (8,6 cm long) that gives better transmission according to many sources. Google! theres's alot information about this
                                        electrikE 1 Reply Last reply
                                        • hakha4H hakha4
                                          @hlehoux Hi!
                                          electrikE Offline
                                          electrikE Offline
                                          electrik
                                          There is a black spot on the PCB after "69H" and after the "W" so this is the RFM69HW
                                          12.0k
