  3. Help needed to setup a RFM69 & ESP8266 Gateaway on Adafruit Feather Huzzah
35 Posts 6 Posters 4.8k Views 4 Watching
  • H hlehoux
    @mfalkvidd
    Hello, certainly yes; anyhow, my setup is quite experimental yet:
    • my antenna setup is quite bad, i loose radio messages or don't receive Ack from the gateway (my bad, i have 868 MHz RFM69 and ordered antennas for 433 MHz)
    • i can confirm it works with NSS on pin GPIO#15 and IRQ_PIN on GPIO#0 orGPIO#2
    • i have not resolved yet the problem of GPIO#0 and GPIO#2 being used by ESP8266 to detect boot-mode so you have to connect the pin after booting which is very annoying
      There are articles like this one https://www.instructables.com/id/ESP8266-Using-GPIO0-GPIO2-as-inputs/ but i'm quite newbie in electronics...
    I will post more details when my config is better.
    @hlehoux is there a reason you can't use gpio5 for irq? That's what I used on a different esp board when verifying the instructions on https://www.mysensors.org/build/connect_radio
    H 2 Replies Last reply
      H
      H
      hlehoux
      @mfalkvidd Well i'm not sure, on [huzzah pinout](link url) GPIO#4 and GPIO#5 are described about I2C SDA & SCL and GPIO #12/13/14 are the same as SCK/MOSI/MISO so i thought would be better not to use them.
      I will try and report back.
      Seems to me (first try) that GPIO#2 works well, provided you connect it both to VCC (it has a pullup resistor ) to avoid boot-mode and to IRQ
        H
        H
        hlehoux
        @mfalkvidd thank you for pointing this to me. I confirm gpio5 works well for IRQ. I read too many articles about how to use gpio0 or gpio2 !
        Anyway i still get very bad transmission ratio, even with very close distance and after buying antennas the good size for my 868 MHz RFM69s
        Can some of you guys point me to help on how to troubleshoot transmissions and/or bad antenna setup for the RFM69, for a newbie like me ?
        Thank you
        • electrikE
          electrikE
          electrik
          Can you switch on MY_DEBUG_VERBOSE_RFM69 in your node and post the output?
          Also post the sketch please.
          • H
            H
            hlehoux
            wrote on last edited by hlehoux
            Thank you for offering help!
            Here is the output of my node "AT Startup" with MY_DEBUG_VERBOSE_RFM69
             __  __       ____
                    |___/                      2.3.2
            16 MCO:BGN:INIT NODE,CP=RPNNA---,FQ=8,REL=255,VER=2.3.2
            28 TSM:INIT
            28 TSF:WUR:MS=0
            30 RFM69:INIT
            32 RFM69:INIT:PIN,CS=10,IQP=2,IQN=0
            36 RFM69:PTX:LEVEL=5 dBm
            38 TSM:INIT:TSP OK
            40 TSF:SID:OK,ID=1
            43 TSM:FPAR
            45 RFM69:SWR:SEND,TO=255,SEQ=0,RETRY=0
            51 RFM69:CSMA:RSSI=-108
            55 ?TSF:MSG:SEND,1-1-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
            2064 !TSM:FPAR:NO REPLY
            2066 TSM:FPAR
            2068 RFM69:SWR:SEND,TO=255,SEQ=1,RETRY=0
            2072 RFM69:CSMA:RSSI=-109
            2078 ?TSF:MSG:SEND,1-1-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
            2838 RFM69:SAC:SEND ACK,TO=0,RSSI=-30
            2842 RFM69:CSMA:RSSI=-111
            2848 TSF:MSG:READ,0-0-1,s=255,c=3,t=8,pt=1,l=1,sg=0:0
            2854 TSF:MSG:FPAR OK,ID=0,D=1
            4087 TSM:FPAR:OK
            4087 TSM:ID
            4089 TSM:ID:OK
            4091 TSM:UPL
            4093 RFM69:SWR:SEND,TO=0,SEQ=3,RETRY=0
            4098 RFM69:CSMA:RSSI=-108
            4304 !RFM69:SWR:NACK
            4306 RFM69:SWR:SEND,TO=0,SEQ=4,RETRY=1
            4311 RFM69:CSMA:RSSI=-107
            4517 !RFM69:SWR:NACK
            4519 RFM69:SWR:SEND,TO=0,SEQ=4,RETRY=2
            4524 RFM69:CSMA:RSSI=-108
            4730 !RFM69:SWR:NACK
            4732 RFM69:SWR:SEND,TO=0,SEQ=4,RETRY=3
            4737 RFM69:CSMA:RSSI=-107
            4923 RFM69:SWR:ACK,FROM=0,SEQ=4,RSSI=-74
            4927 RFM69:ATC:ADJ TXL,cR=-74,tR=-78..-82,TXL=5
            4931 RFM69:PTX:LEVEL=4 dBm
            4935 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
            5156 RFM69:SAC:SEND ACK,TO=0,RSSI=-29
            5160 RFM69:CSMA:RSSI=-108
            5167 TSF:MSG:READ,0-0-1,s=255,c=3,t=25,pt=1,l=1,sg=0:1
            5173 TSF:MSG:PONG RECV,HP=1
            5175 TSM:UPL:OK
            5177 TSM:READY:ID=1,PAR=0,DIS=1
            5181 RFM69:SWR:SEND,TO=0,SEQ=5,RETRY=0
            5185 RFM69:CSMA:RSSI=-109
            5392 !RFM69:SWR:NACK
            5394 RFM69:SWR:SEND,TO=0,SEQ=6,RETRY=1
            5398 RFM69:CSMA:RSSI=-106
            5605 !RFM69:SWR:NACK
            5607 RFM69:SWR:SEND,TO=0,SEQ=6,RETRY=2
            5611 RFM69:CSMA:RSSI=-107
            5818 !RFM69:SWR:NACK
            5820 RFM69:SWR:SEND,TO=0,SEQ=6,RETRY=3
            5824 RFM69:CSMA:RSSI=-111
            6031 !RFM69:SWR:NACK
            6033 RFM69:SWR:SEND,TO=0,SEQ=6,RETRY=4
            6037 RFM69:CSMA:RSSI=-109
            6244 !RFM69:SWR:NACK
            6246 !TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=NACK:0100
            7464 RFM69:SAC:SEND ACK,TO=0,RSSI=-29
            7471 RFM69:CSMA:RSSI=-107
            7475 TSF:MSG:READ,0-0-1,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
            7481 RFM69:SWR:SEND,TO=0,SEQ=7,RETRY=0
            7487 RFM69:CSMA:RSSI=-108
            7694 !RFM69:SWR:NACK
            7696 RFM69:SWR:SEND,TO=0,SEQ=8,RETRY=1
            7700 RFM69:CSMA:RSSI=-105
            7907 !RFM69:SWR:NACK
            7909 RFM69:SWR:SEND,TO=0,SEQ=8,RETRY=2
            7913 RFM69:CSMA:RSSI=-107
            8120 !RFM69:SWR:NACK
            8122 RFM69:SWR:SEND,TO=0,SEQ=8,RETRY=3
            8126 RFM69:CSMA:RSSI=-108
            8333 !RFM69:SWR:NACK
            8335 RFM69:SWR:SEND,TO=0,SEQ=8,RETRY=4
            8339 RFM69:CSMA:RSSI=-106
            8546 !RFM69:SWR:NACK
            8548 !TSF:MSG:SEND,1-1-0-0,s=255,c=0,t=17,pt=0,l=5,sg=0,ft=1,st=NACK:2.3.2
            8556 RFM69:SWR:SEND,TO=0,SEQ=8,RETRY=0
            8560 RFM69:CSMA:RSSI=-106
            8767 !RFM69:SWR:NACK
            8769 RFM69:SWR:SEND,TO=0,SEQ=9,RETRY=1
            8773 RFM69:CSMA:RSSI=-108
            8980 !RFM69:SWR:NACK
            8982 RFM69:SWR:SEND,TO=0,SEQ=9,RETRY=2
            8986 RFM69:CSMA:RSSI=-108
            9193 !RFM69:SWR:NACK
            9195 RFM69:SWR:SEND,TO=0,SEQ=9,RETRY=3
            9199 RFM69:CSMA:RSSI=-107
            9406 !RFM69:SWR:NACK
            9408 RFM69:SWR:SEND,TO=0,SEQ=9,RETRY=4
            9412 RFM69:CSMA:RSSI=-106
            9619 !RFM69:SWR:NACK
            9621 !TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=2,st=NACK:0
            Presentation
            11628 RFM69:SWR:SEND,TO=0,SEQ=9,RETRY=0
            11634 RFM69:CSMA:RSSI=-110
            11841 !RFM69:SWR:NACK
            11843 RFM69:SWR:SEND,TO=0,SEQ=10,RETRY=1
            11847 RFM69:CSMA:RSSI=-108
            12056 !RFM69:SWR:NACK
            12058 RFM69:SWR:SEND,TO=0,SEQ=10,RETRY=2
            12062 RFM69:CSMA:RSSI=-108
            12271 !RFM69:SWR:NACK
            12273 RFM69:SWR:SEND,TO=0,SEQ=10,RETRY=3
            12277 RFM69:CSMA:RSSI=-110
            12486 !RFM69:SWR:NACK
            12488 RFM69:SWR:SEND,TO=0,SEQ=10,RETRY=4
            12492 RFM69:CSMA:RSSI=-106
            12701 !RFM69:SWR:NACK
            12703 !TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=11,pt=0,l=13,sg=0,ft=3,st=NACK:RFM69 Sensor
            12711 RFM69:SWR:SEND,TO=0,SEQ=10,RETRY=0
            12718 RFM69:CSMA:RSSI=-108
            12924 !RFM69:SWR:NACK
            12926 RFM69:SWR:SEND,TO=0,SEQ=11,RETRY=1
            12931 RFM69:CSMA:RSSI=-106
            13139 !RFM69:SWR:NACK
            13142 RFM69:SWR:SEND,TO=0,SEQ=11,RETRY=2
            13146 RFM69:CSMA:RSSI=-107
            13355 !RFM69:SWR:NACK
            13357 RFM69:SWR:SEND,TO=0,SEQ=11,RETRY=3
            13361 RFM69:CSMA:RSSI=-106
            13570 !RFM69:SWR:NACK
            13572 RFM69:SWR:SEND,TO=0,SEQ=11,RETRY=4
            13576 RFM69:CSMA:RSSI=-109
            13785 !RFM69:SWR:NACK
            13787 !TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=4,st=NACK:1.0
            13795 RFM69:SWR:SEND,TO=0,SEQ=11,RETRY=0
            13799 RFM69:CSMA:RSSI=-111
            14006 !RFM69:SWR:NACK
            14008 RFM69:SWR:SEND,TO=0,SEQ=12,RETRY=1
            14012 RFM69:CSMA:RSSI=-105
            14219 !RFM69:SWR:NACK
            14221 RFM69:SWR:SEND,TO=0,SEQ=12,RETRY=2
            14225 RFM69:CSMA:RSSI=-106
            14432 !RFM69:SWR:NACK
            14434 RFM69:SWR:SEND,TO=0,SEQ=12,RETRY=3
            14438 RFM69:CSMA:RSSI=-107
            14645 !RFM69:SWR:NACK
            14647 RFM69:SWR:SEND,TO=0,SEQ=12,RETRY=4
            14651 RFM69:CSMA:RSSI=-107
            14858 !RFM69:SWR:NACK
            14860 !TSF:MSG:SEND,1-1-0-0,s=0,c=0,t=23,pt=0,l=0,sg=0,ft=5,st=NACK:
            14866 RFM69:SWR:SEND,TO=0,SEQ=12,RETRY=0
            14872 RFM69:CSMA:RSSI=-109
            15079 !RFM69:SWR:NACK
            15081 RFM69:SWR:SEND,TO=0,SEQ=13,RETRY=1
            15085 RFM69:CSMA:RSSI=-105
            15292 !RFM69:SWR:NACK
            15294 RFM69:SWR:SEND,TO=0,SEQ=13,RETRY=2
            15298 RFM69:CSMA:RSSI=-107
            15505 !RFM69:SWR:NACK
            15507 RFM69:SWR:SEND,TO=0,SEQ=13,RETRY=3
            15511 RFM69:CSMA:RSSI=-106
            15718 !RFM69:SWR:NACK
            15720 RFM69:SWR:SEND,TO=0,SEQ=13,RETRY=4
            15724 RFM69:CSMA:RSSI=-109
            15931 !RFM69:SWR:NACK
            15933 !TSF:MSG:SEND,1-1-0-0,s=1,c=0,t=0,pt=0,l=0,sg=0,ft=6,st=NACK:
            15939 MCO:REG:REQ
            15941 RFM69:SWR:SEND,TO=0,SEQ=13,RETRY=0
            15947 RFM69:CSMA:RSSI=-105
            16154 !RFM69:SWR:NACK
            16156 RFM69:SWR:SEND,TO=0,SEQ=14,RETRY=1
            16160 RFM69:CSMA:RSSI=-109
            16367 !RFM69:SWR:NACK
            16369 RFM69:SWR:SEND,TO=0,SEQ=14,RETRY=2
            16373 RFM69:CSMA:RSSI=-108
            16580 !RFM69:SWR:NACK
            16582 RFM69:SWR:SEND,TO=0,SEQ=14,RETRY=3
            16586 RFM69:CSMA:RSSI=-107
            16793 !RFM69:SWR:NACK
            16795 RFM69:SWR:SEND,TO=0,SEQ=14,RETRY=4
            16799 RFM69:CSMA:RSSI=-105
            17006 !RFM69:SWR:NACK
            17008 !TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=7,st=NACK:2
            17016 !TSM:READY:UPL FAIL,SNP
            And while executing loop() every 2 seconds:
            Loop
            478496 RFM69:SWR:SEND,TO=0,SEQ=80,RETRY=0
            478502 RFM69:CSMA:RSSI=-107
            478707 !RFM69:SWR:NACK
            478709 RFM69:SWR:SEND,TO=0,SEQ=81,RETRY=1
            478715 RFM69:CSMA:RSSI=-108
            478922 !RFM69:SWR:NACK
            478924 RFM69:SWR:SEND,TO=0,SEQ=81,RETRY=2
            478930 RFM69:CSMA:RSSI=-108
            479137 !RFM69:SWR:NACK
            479139 RFM69:SWR:SEND,TO=0,SEQ=81,RETRY=3
            479145 RFM69:CSMA:RSSI=-105
            479352 !RFM69:SWR:NACK
            479354 RFM69:SWR:SEND,TO=0,SEQ=81,RETRY=4
            479361 RFM69:CSMA:RSSI=-104
            479526 RFM69:SWR:ACK,FROM=0,SEQ=81,RSSI=-90
            479533 RFM69:ATC:ADJ TXL,cR=-90,tR=-78..-82,TXL=11
            479537 RFM69:PTX:LEVEL=12 dBm
            479541 TSF:MSG:SEND,1-1-0-0,s=1,c=1,t=16,pt=2,l=2,sg=0,ft=1,st=OK:1
            Loop
            481548 RFM69:SWR:SEND,TO=0,SEQ=81,RETRY=0
            481554 RFM69:CSMA:RSSI=-109
            481761 !RFM69:SWR:NACK
            481763 RFM69:SWR:SEND,TO=0,SEQ=82,RETRY=1
            481769 RFM69:CSMA:RSSI=-109
            481976 !RFM69:SWR:NACK
            481978 RFM69:SWR:SEND,TO=0,SEQ=82,RETRY=2
            481984 RFM69:CSMA:RSSI=-106
            482191 !RFM69:SWR:NACK
            482193 RFM69:SWR:SEND,TO=0,SEQ=82,RETRY=3
            482199 RFM69:CSMA:RSSI=-105
            482406 !RFM69:SWR:NACK
            482408 RFM69:SWR:SEND,TO=0,SEQ=82,RETRY=4
            482414 RFM69:CSMA:RSSI=-108
            482621 !RFM69:SWR:NACK
            482623 !TSF:MSG:SEND,1-1-0-0,s=1,c=1,t=16,pt=2,l=2,sg=0,ft=0,st=NACK:1
            Loop
            484630 RFM69:SWR:SEND,TO=0,SEQ=82,RETRY=0
            484636 RFM69:CSMA:RSSI=-109
            484841 !RFM69:SWR:NACK
            484843 RFM69:SWR:SEND,TO=0,SEQ=83,RETRY=1
            484849 RFM69:CSMA:RSSI=-107
            485056 !RFM69:SWR:NACK
            485058 RFM69:SWR:SEND,TO=0,SEQ=83,RETRY=2
            485064 RFM69:CSMA:RSSI=-108
            485271 !RFM69:SWR:NACK
            485273 RFM69:SWR:SEND,TO=0,SEQ=83,RETRY=3
            485279 RFM69:CSMA:RSSI=-105
            485486 !RFM69:SWR:NACK
            485488 RFM69:SWR:SEND,TO=0,SEQ=83,RETRY=4
            485494 RFM69:CSMA:RSSI=-107
            485662 RFM69:SWR:ACK,FROM=0,SEQ=83,RSSI=-88
            485666 RFM69:ATC:ADJ TXL,cR=-88,tR=-78..-82,TXL=12
            485672 RFM69:PTX:LEVEL=13 dBm
            485675 TSF:MSG:SEND,1-1-0-0,s=1,c=1,t=16,pt=2,l=2,sg=0,ft=1,st=OK:1
            And my Sketch :
            #define MY_RADIO_RFM69
            #define MY_IS_RFM69HW
            #define MY_DEBUG_VERBOSE
            #define MY_DEBUG_VERBOSE_RFM69
            //#define MY_DEBUG_VERBOSE_RFM69_REGISTERS
            #define MY_RFM69_NEW_DRIVER
            //#define MY_RFM69_ATC_MODE_DISABLED
            //#define MY_RFM69_TX_POWER_DBM 20
            //#define MY_REPEATER_FEATURE
            //#define MY_NODE_ID 5
            #define OPEN 1
            // Initialize motion message
            MyMessage msg(1, V_TRIPPED);
            uint8_t value = OPEN;
              pinMode(LED_BUILTIN, OUTPUT);
              Serial.println("Presentation");
              sendSketchInfo("RFM69 Sensor ", "1.0");
                present(0, S_CUSTOM);
                present(1, S_DOOR);
              Serial.println("Loop");
              digitalWrite(LED_BUILTIN, HIGH);   // turn the LED on (HIGH is the voltage level)
              delay(1000);                       // wait for a second
              digitalWrite(LED_BUILTIN, LOW);    // turn the LED off by making the voltage LOW
              //sendHeartbeat();
              send(msg.set(OPEN));
            • H
              H
              hlehoux
              I'm also reading a few posts like this one trying to understand a bit more ....
              • electrikE
                electrikE
                electrik
                Are you sure about ask your hardware versions? I bought rfm69 modules and I thought they were the HW version but they turned out to be the normal ones.
                So important is
                • module version
                • frequency
                It looks like even with a high rssi your reception is not good. But maybe I interpret this the wrong way. Can I've of the developers or more experienced help with the analysis?
                • H
                  H
                  hlehoux
                  Thank you @electrik
                  My intent is to use RFM69HW 868Mhz
                  I compared with photos on the internet like here
                  mine is:
                  as far as i understand my reading my RSSI values seem to tell my signal is very weak and noisy ?
                  I tried to provide the pwr to the rfm69 with an external source instead of the esp8266 but i was not better.
                  hakha4H electrikE 2 Replies Last reply
                  • H hlehoux
                    Thank you @electrik
                    mine is:
                    hakha4H
                    hakha4H
                    hakha4
                    @hlehoux Hi!
                    I had quite alot of trouble with NRF24 modules with shaky connections despite doing everything that has been discussed in forum with power supply etc and have ordered a bunch of RFM69's to hopefully improve this according to others in forum claiming better stability with RFM''s. Haven't tested yet but reading this is a bit dissapointing.
                    One thing though. Readings in log shows very high RSSI values and if it is measured in dBm this is very bad. The lower value the better I believe. Antenna issue ?
                    H 1 Reply Last reply
                    • H hlehoux
                      Thank you @electrik
                      mine is:
                      electrikE
                      electrikE
                      electrik
                      @hlehoux can you take a photo from the back also? There should be a table telling which one it is exactly.
                      @hakha4 said in Help needed to setup a RFM69 & ESP8266 Gateaway on Adafruit Feather Huzzah:
                      Antenna issue ?
                      You could be right.
                      What antenna do you have?
                      • H
                        H
                        hlehoux
                        Hello, here are 2 photos
                        one from the back:
                        I'm not sure what the "W" means, i read chinese copy don't have it ?
                        one from the antenna:
                        It should be the good size for 868 MHz
                        I don't use "ground plane" or sort of, would this explain so bad RSSI ?
                        Thank you again for your help and patience
                        hakha4H scalzS 2 Replies Last reply
                        • hakha4H hakha4
                          @hlehoux Hi!
                          H
                          H
                          hlehoux
                          @hakha4 i also have several NRF24 nodes and gateaway
                          After trying several antenna/tranceiver, i recommend using
                          "E01-ML01DP5 Long Range SPI nRF24L01P 2.4Ghz 100mW SMA Antenna IoT Wireless Transceiver Transmitter Receiver nRF24L01P RF Module"
                          as a repeater
                          It gives far better range results
                          Anyway i wanted to try RFM69 to avoid having many repeaters
                          • electrikE
                            electrikE
                            electrik
                            The modules correspond to what it should be.
                            It looks like your ground is connected to the ANT pin on the picture, on the bottom side of the PCB?
                            • H hlehoux
                              one from the back:
                              hakha4H
                              hakha4H
                              hakha4
                              @hlehoux Hi!
                              W means the low power output variant (+13dBm). There is another version named 'HW' which give a higher transmission output (+20 dBM). As elektik pointed out, check out the solder of the antenna. Did the antenna come presoldered or you did it yourself?
                              Another option for the coiled antenna is a straight copper wire (8,6 cm long) that gives better transmission according to many sources. Google! theres's alot information about this
                              electrikE 1 Reply Last reply
                              • hakha4H hakha4
                                @hlehoux Hi!
                                electrikE
                                electrikE
                                electrik
                                There is a black spot on the PCB after "69H" and after the "W" so this is the RFM69HW
                                • H hlehoux
                                  one from the back:
                                  #21
                                  @hlehoux
                                  unfortunately, lot of devboards have non-optimized gnd plane for RF, especially for subghz (small or splitted gnd plane by routes..).
                                  Moreover, devboard+dupont cable+external rf module is not ideal.
                                  With rfm69, you should get a nice range.
                                  Though, why on one of your picture, antenna seems shorted to gnd??
                                  Imho I would have chosen something else than esp8266 (esp32??) in your case, but your choice :)
                                  To check if this is related to your gnd plane and your build is ok, you could also try to hook two straight wires as a dipole antenna to your radio (one to ANA, the other to GND in opposite direction will replace a ground plane). Google for examples, it's simple to try
                                  electrikE H 2 Replies Last reply
                                  • scalzS scalz
                                    @hlehoux
                                    electrikE
                                    electrikE
                                    electrik
                                    @scalz
                                    Could you explain how to read these rssi reports, and how to adjust the configuration of the nodes so the reliability goes up?
                                    I know there is a setting RFM69_TARGET_RSSI_DBM but it is not clear for me how to use this exactly.
                                    scalzS 1 Reply Last reply
                                    • electrikE electrik
                                      H
                                      H
                                      hlehoux
                                      @electrik Thank you! What you see is the "head" of the pliers i used to hold the RFM69. I will check again my soldering but definitly ANT and ground should not be connected
                                      • scalzS scalz
                                        @hlehoux
                                        H
                                        H
                                        hlehoux
                                        @scalz Thank you very much!
                                        Unfortunatly, the antenna seems shorted to ground only because this is the "head" of the pliers i used to take the photo.
                                        i use esp8266 because i received for free a lot of many adafruit huzzah feathers :-)
                                        i will try your suggestion to hook two straight wires as a dipole antenna and report if this is better.
                                        For sure my "development" setup is devboard+dupont cable+external rf and this should not be the final version ; anyway loosing 50% of messages with distance of 1 meter is disappointing.
                                        hakha4H 1 Reply Last reply
                                        • H hlehoux
                                          hakha4H
                                          hakha4H
                                          hakha4
                                          @hlehoux Here is a useful link how to do that: https://learn.sparkfun.com/tutorials/rfm69hcw-hookup-guide/the-antenna
