  3. [Solved] How to adjust MySBootloader files to compile other EN & CSN pins different channel and external 8MHz crystal
26 Posts 2 Posters 3.3k Views 2 Watching
  • JoeridemanJ Joerideman
    Allright one step further.
    		// set pin mode: MOSI,SCLK,CE,CSN = OUTPUT, MISO = INPUT (=> all on same port)
    		SPI_DDR = _BV(SPI_MOSI) | _BV(SPI_SCLK) | _BV(CE_PIN) | _BV(PB2) | ~_BV(SPI_MISO);
    		CSN_DDR = _BV(CSN_PIN);
    And now I can use the serial upload :).
    No luck seeing any chatter though. To be sure, I just watch commando's that come in in MySController ?
    tekkaT
    tekkaT
    tekka
    @Joerideman I'm not quite sure how setting the master SPI mode should fix the serial upload issue...What exactly are you referring to? Serial upload via FTDI adapter or FOTA (=firmware over the air) update via RF24?
    • JoeridemanJ
      JoeridemanJ
      Joerideman
      @tekka I can use an FTDI device now for standard uploading of the sketch. The non OTA way.
      What do you mean with the master SPI mode? Is that because of the fuses that I tried to change?
      I have watch the MyScontroller Debug window and the messages. But I only see a presentation at some point, and than it is started.
      tekkaT 1 Reply Last reply
        tekkaT
        tekkaT
        tekka
        @Joerideman Setting PB2 as output ensures that the SPI runs in master mode which is essential for a correct communication between the ATmega328 and the RF24 radio.
        However, after setting PB2 you report:
        which is not related to SPI (serial upload uses the UART interface).
        Please provide debug logs / screenshots / whatever you have for further troubleshooting...
        • JoeridemanJ
          JoeridemanJ
          Joerideman
          wrote on last edited by Joerideman
          @tekka But that setting somehow made a difference.
          Nevermind here is the debug info from the gateway.
          When I restart the node, it takes a few seconds before information starts rolling in.
          10:15:48.219 -> 312137 TSF:MSG:READ,1-1-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
          10:15:48.252 -> 312197 TSF:MSG:BC
          10:15:48.287 -> 312216 TSF:MSG:FPAR REQ,ID=1
          10:15:48.321 -> 312246 TSF:PNG:SEND,TO=0
          10:15:48.355 -> 312272 TSF:CKU:OK
          10:15:48.355 -> 312291 TSF:MSG:GWL OK
          10:15:49.434 -> 313336 TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
          10:15:50.208 -> 314109 TSF:MSG:READ,1-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
          10:15:50.242 -> 314169 TSF:MSG:PINGED,ID=1,HP=1
          10:15:50.309 -> 314212 TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=OK:1
          10:15:50.376 -> 314285 TSF:MSG:READ,1-1-0,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
          10:15:50.443 -> 314352 TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
          10:15:50.510 -> 314428 TSF:MSG:READ,1-1-0,s=255,c=0,t=17,pt=0,l=5,sg=0:2.3.2
          10:15:50.576 -> 314493 TSF:MSG:READ,1-1-0,s=255,c=3,t=6,pt=1,l=1,sg=0:0
          10:15:50.712 -> 314642 GWT:RFC:C=0,MSG=1;255;3;0;6;M
          10:15:50.780 -> 314683 TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=6,pt=0,l=1,sg=0,ft=0,st=OK:M
          10:15:50.847 -> 314755 TSF:MSG:READ,1-1-0,s=255,c=3,t=11,pt=0,l=19,sg=0:4channel 24V dimmer
          10:15:50.914 -> 314836 TSF:MSG:READ,1-1-0,s=255,c=3,t=12,pt=0,l=4,sg=0:2.00
          10:15:50.982 -> 314900 TSF:MSG:READ,1-1-0,s=1,c=0,t=4,pt=0,l=0,sg=0:
          10:15:51.083 -> 315013 TSF:MSG:READ,1-1-0,s=255,c=3,t=26,pt=1,l=1,sg=0:2
          10:15:51.152 -> 315080 TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=27,pt=1,l=1,sg=0,ft=0,st=OK:1
          10:15:51.220 -> 315153 TSF:MSG:READ,1-1-0,s=1,c=1,t=2,pt=2,l=2,sg=0:0
          10:15:51.287 -> 315211 TSF:MSG:READ,1-1-0,s=1,c=2,t=3,pt=0,l=0,sg=0:
          Here is the serial output from the node at the same time.
          10:15:48.154 ->
          10:15:48.154 ->  __  __       ____
          10:15:48.154 -> |  \/  |_   _/ ___|  ___ _ __  ___  ___  _ __ ___
          10:15:48.221 -> | |\/| | | | \___ \ / _ \ `_ \/ __|/ _ \| `__/ __|
          10:15:48.221 -> | |  | | |_| |___| |  __/ | | \__ \  _  | |  \__ \
          10:15:48.221 -> |_|  |_|\__, |____/ \___|_| |_|___/\___/|_|  |___/
          10:15:48.221 ->         |___/                      2.3.2
          10:15:48.221 ->
          10:15:48.221 -> 16 MCO:BGN:INIT NODE,CP=RNNNA---,FQ=8,REL=255,VER=2.3.2
          10:15:48.221 -> 28 TSM:INIT
          10:15:48.221 -> 28 TSF:WUR:MS=0
          10:15:48.221 -> 36 TSM:INIT:TSP OK
          10:15:48.221 -> 38 TSM:INIT:STATID=1
          10:15:48.221 -> 40 TSF:SID:OK,ID=1
          10:15:48.221 -> 43 TSM:FPAR
          10:15:48.221 -> 47 ?TSF:MSG:SEND,1-1-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
          10:15:49.404 -> 1271 TSF:MSG:READ,0-0-1,s=255,c=3,t=8,pt=1,l=1,sg=0:0
          10:15:49.404 -> 1277 TSF:MSG:FPAR OK,ID=0,D=1
          10:15:50.144 -> 2056 TSM:FPAR:OK
          10:15:50.144 -> 2056 TSM:ID
          10:15:50.144 -> 2058 TSM:ID:OK
          10:15:50.144 -> 2060 TSM:UPL
          10:15:50.179 -> 2068 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
          10:15:50.246 -> 2170 TSF:MSG:READ,0-0-1,s=255,c=3,t=25,pt=1,l=1,sg=0:1
          10:15:50.314 -> 2177 TSF:MSG:PONG RECV,HP=1
          10:15:50.314 -> 2179 TSM:UPL:OK
          10:15:50.314 -> 2181 TSM:READY:ID=1,PAR=0,DIS=1
          10:15:50.314 -> 2187 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
          10:15:50.449 -> 2314 TSF:MSG:READ,0-0-1,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
          10:15:50.449 -> 2322 TSF:MSG:SEND,1-1-0-0,s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=OK:2.3.2
          10:15:50.449 -> 2332 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0
          10:15:50.754 -> 2656 TSF:MSG:READ,0-0-1,s=255,c=3,t=6,pt=0,l=1,sg=0:M
          10:15:50.754 -> 2664 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=11,pt=0,l=19,sg=0,ft=0,st=OK:4channel 24V dimmer
          10:15:50.788 -> 2676 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=12,pt=0,l=4,sg=0,ft=0,st=OK:2.00
          10:15:50.788 -> 2686 TSF:MSG:SEND,1-1-0-0,s=1,c=0,t=4,pt=0,l=0,sg=0,ft=0,st=OK:
          10:15:51.093 -> 2994 MCO:REG:REQ
          10:15:51.093 -> 2996 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
          10:15:51.126 -> 3063 TSF:MSG:READ,0-0-1,s=255,c=3,t=27,pt=1,l=1,sg=0:1
          10:15:51.160 -> 3069 MCO:PIM:NODE REG=1
          10:15:51.160 -> 3074 MCO:BGN:STP
          10:15:51.160 -> 3080 TSF:MSG:SEND,1-1-0-0,s=1,c=1,t=2,pt=2,l=2,sg=0,ft=0,st=OK:0
          10:15:51.260 -> 3186 TSF:MSG:SEND,1-1-0-0,s=1,c=2,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
          10:15:51.593 -> 3520 MCO:BGN:INIT OK,TSP=1
            10:15:48.154 ->
            10:15:48.221 ->
            tekkaT
            tekkaT
            tekka
            @Joerideman There is no sign of the bootloader here - can you confirm that your GW is listening on channel 122?
            • JoeridemanJ
              JoeridemanJ
              Joerideman
              @tekka how? They are talking with each other ones everything has started. Does that not mean the gateway is on the same channel?
              This is the code of my node: I set the channel to 122 right?
                combinatie van mysensors en adafruits pwm library
               versie 2. basis werking
               versie2.1 Betere response op de controller. Requests voor de
              //########## mysensors instellingen
              #define MY_NODE_ID 1
              #define MY_RF24_CHANNEL (122)
              #define MY_RF24_CE_PIN 8
              #define MY_RF24_CS_PIN 9
              #define MY_RADIO_RF24
              //#define MY_RADIO_NRF5_ESB
              //#define MY_RADIO_RFM95
              #define SN "4channel 24V dimmer"
              #define SV "2.00"
              //#define LED_PIN 3      // Arduino pin attached to MOSFET Gate pin // niet relevant. Dimmen gaat via i2c
              #define FADE_DELAY 10  // Delay in ms for each percentage fade up/down (10ms = 1s full-range dim)
              #define LED_TYPE S_DIMMER
              #define AMOUNT_OF_LED 1
              byte LED_CURRENTLEVEL[] = {0, 0, 0, 0, 0};
              byte LedCurrentStep[] = {0, 0, 0, 0, 0};
              byte LedTempCurrentStep[] = {0, 0, 0, 0, 0};
              byte LED_TOLEVEL[] = {0, 0, 0, 0, 0};
              byte LedToStep[] = {0, 0, 0, 0, 0};
              byte LED_Status[] = {0, 0, 0, 0, 0}; //all off
              byte ledUpdate[] = {0, 0, 0, 0, 0};
              bool updateLED = false;
              byte sensorId = 1;
              MyMessage dimmerMsg(sensorId, V_PERCENTAGE); // was ooit V_Dimmer
              MyMessage lightMsg(sensorId, V_STATUS); //on or off was ooit V_LIGHT
              #include <Adafruit_PWMServoDriver.h>
              // called this way, it uses the default address 0x40
              //Adafruit_PWMServoDriver pwm = Adafruit_PWMServoDriver();
              // you can also call it with a different address you want
              Adafruit_PWMServoDriver pwm = Adafruit_PWMServoDriver(0x40);
              // you can also call it with a different address and I2C interface
              //Adafruit_PWMServoDriver pwm = Adafruit_PWMServoDriver(0x40, &Wire);
              int lichtwaarde[141] = {0, 1, 1, 1, 1, 1, 1, 1, 1, 2, 2, 2, 2, 2, 2, 2, 2, 2, 3, 3, 3, 3, 3, 4, 4, 4, 4, 5, 5, 5, 5, 6, 6, 7, 7, 7, 8, 8, 9, 9, 10, 11, 11, 12, 13, 14, 14, 15, 16, 17, 18, 20, 21, 22, 23, 25, 26, 28, 30, 32, 34, 36, 38, 40, 43, 46, 48, 51, 55, 58, 62, 66, 70, 74, 79, 84, 89, 94, 100, 106, 113, 120, 128, 136, 144, 153, 163, 173, 184, 195, 207, 220, 234, 249, 264, 281, 298, 317, 337, 358, 380, 404, 429, 456, 485, 515, 547, 581, 618, 656, 697, 741, 787, 837, 889, 944, 1003, 1066, 1133, 1204, 1279, 1359, 1444, 1534, 1630, 1732, 1840, 1955, 2077, 2207, 2345, 2491, 2647, 2812, 2988, 3175, 3373, 3584, 3808, 4046, 4096};
                 Dimmable LED initialization method
                sendSketchInfo(SN, SV);
                //Present nodes
                for (sensorId = 1; sensorId < (AMOUNT_OF_LED + 1) ; sensorId++) { //
                  present(sensorId, LED_TYPE);
                  wait(300);
                //###### Mysensors Setup
                // Pull the gateway's current dim level - restore light level upon node power-up
                for (sensorId = 1; sensorId < (AMOUNT_OF_LED + 1); sensorId++) {
                  send(lightMsg.set(0));
                      wait(100);
                  request( sensorId, V_PERCENTAGE );
                  wait(300);
                //###### PWM setup
                pwm.begin();
                pwm.setPWMFreq(1600);  //
                // if you want to really speed stuff up, you can go into 'fast 400khz I2C' mode
                // some i2c devices dont like this so much so if you're sharing the bus, watch
                // out for this!
                Wire.setClock(400000);
                for (int i = 0; i < 4; i++) { //zet alles uit
                  pwm.setPin((i), lichtwaarde[0]);
              void loop() {// de eerste 4 aansluitingen
                if ((ledUpdate[1] + ledUpdate[2] + ledUpdate[3] + ledUpdate[4]) > 0) {
                  fade();
                  wait(15);
                  int tempStatus = ( 1 <= atoi (message.data)) ? 1 : 0;
                  //Serial.print("V type Message data = ");
                  //Serial.println(tempStatus);
                  if (tempStatus > LED_Status[message.sensor]) {
                    ledUpdate[message.sensor] = true;
                    if (LED_CURRENTLEVEL[message.sensor] == 0) {
                      LED_CURRENTLEVEL[message.sensor] = 70;
                      LedToStep[message.sensor] = map(LED_CURRENTLEVEL[message.sensor], 0, 100, 0, 140);
                      Serial.print("ledtostep = ");
                      Serial.println(LedToStep[message.sensor] );
                    else if (LED_CURRENTLEVEL[message.sensor] > 0) {
                      LedCurrentStep[message.sensor] = 0;
                      Serial.print("ledtostep2 = ");
                  else if (tempStatus < LED_Status[message.sensor]) {
                    //Led gaat uit
                    LedToStep[message.sensor] = 0;
                    LedTempCurrentStep[message.sensor] = LedCurrentStep[message.sensor];
                  sensorId = message.sensor;
                  LED_Status[message.sensor] = tempStatus; //de status
                  send(lightMsg.set(LED_Status[message.sensor]));
                else if (message.type == V_PERCENTAGE) {
                  Serial.print("v percentage Message data = ");
                  Serial.println(atoi( message.data ));
                  if (LED_CURRENTLEVEL[message.sensor] != atoi(message.data)) {
                    LED_CURRENTLEVEL[message.sensor] = (100 <= atoi( message.data )) ? 100 : atoi( message.data ); //de level
                    if (LedToStep[message.sensor] != 0) {
                    //LED_Status[message.sensor] = 1;
                     // sensorId = message.sensor;
                      //send(lightMsg.set(LED_Status[message.sensor]));
                    request( sensorId, V_STATUS );
                               send(dimmerMsg.set(LED_CURRENTLEVEL[message.sensor]));
              void fade() {
                //als de status van een led == true. Dan de fade.
                for (int ledNumber = 1; ledNumber <= AMOUNT_OF_LED; ledNumber++) {
                  if (ledUpdate[ledNumber] == true) {
                    if (LedTempCurrentStep[ledNumber] == 0 && LED_Status[ledNumber] == 0) {
                      //Serial.println("fade0");
                      //do nothing
                    else if (LedCurrentStep[ledNumber] < LedToStep[ledNumber] && LED_Status[ledNumber] == 1) {
                      //Serial.println("fade1");
                      //increase light
                      LedCurrentStep[ledNumber]++;
                      pwm.setPin((ledNumber - 1), lichtwaarde[LedCurrentStep[ledNumber]]);
                    else if (LedTempCurrentStep[ledNumber] > LedToStep[ledNumber] && LED_Status[ledNumber] == 0) {
                      //turn off  but remember the last lightlevel
                      //Serial.println("fade2");
                      LedTempCurrentStep[ledNumber]--;
                      pwm.setPin((ledNumber - 1), lichtwaarde[LedTempCurrentStep[ledNumber]]);
                    else if (LedCurrentStep[ledNumber] > LedToStep[ledNumber] && LED_Status[ledNumber] == 1) {
                      //decrease light
                      //Serial.println("fade3");
                      LedCurrentStep[ledNumber]--;
                    if (LedCurrentStep[ledNumber] == LedToStep[ledNumber]) {
                      ledUpdate[ledNumber] = false;
                      //Serial.println("fade4");
                      //Serial.println("fade5");
                      //Serial.println("fade6");
                #define SV "2.00"
                byte sensorId = 1;
                  //Present nodes
                    wait(300);
                        wait(100);
                    wait(300);
                  //###### PWM setup
                  pwm.begin();
                  // out for this!
                    fade();
                    wait(15);
                      //Led gaat uit
                void fade() {
                        //do nothing
                        //increase light
                        //decrease light
                tekkaT
                tekkaT
                tekka
                @Joerideman That looks alright! Just out of curiosity, if you use the bootloader with the default settings (channel, ce/csn assignment), do you see a difference in the debug log?
                • JoeridemanJ
                  JoeridemanJ
                  Joerideman
                  I used the 8MHZ int RC one
                  log node:
                  12:09:50.469 -> ⸮& ⸮⸮⸮⸮⸮AGC`⸮48⸮C⸮⸮⸮⸮⸮{}
                  12:09:50.469 -> 2058 TSM:FPAR
                  12:09:50.469 -> 2062 ?TSF:MSG:SEND,1-1-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                  12:09:50.469 ->
                  12:09:50.469 ->  __  __       ____
                  12:09:50.469 -> |  \/  |_   _/ ___|  ___ _ __  ___  ___  _ __ ___
                  12:09:50.469 -> | |\/| | | | \___ \ / _ \ `_ \/ __|/ _ \| `__/ __|
                  12:09:50.469 -> | |  | | |_| |___| |  __/ | | \__ \  _  | |  \__ \
                  12:09:50.469 -> |_|  |_|\__, |____/ \___|_| |_|___/\___/|_|  |___/
                  12:09:50.469 ->         |___/                      2.3.2
                  12:09:50.469 ->
                  12:09:50.469 -> 16 MCO:BGN:INIT NODE,CP=RNNNA---,FQ=8,REL=255,VER=2.3.2
                  12:09:50.469 -> 28 TSM:INIT
                  12:09:50.469 -> 28 TSF:WUR:MS=0
                  12:09:50.469 -> 36 TSM:INIT:TSP OK
                  12:09:50.469 -> 38 TSM:INIT:STATID=1
                  12:09:50.469 -> 40 TSF:SID:OK,ID=1
                  12:09:50.469 -> 43 TSM:FPAR
                  12:09:50.469 -> 47 ?TSF:MSG:SEND,1-1-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                  12:09:52.420 -> 2056 !TSM:FPAR:NO REPLY
                  12:09:52.420 -> 2058 TSM:FPAR
                  12:09:52.420 -> 2062 ?TSF:MSG:SEND,1-1-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                  12:09:54.367 -> 4071 !TSM:FPAR:NO REPLY
                  12:09:54.367 -> 4073 TSM:FPAR
                  12:09:54.367 -> 4077 ?TSF:MSG:SEND,1-1-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                  12:09:56.349 -> 6086 !TSM:FPAR:NO REPLY
                  12:09:56.349 -> 6088 TSM:FPAR
                  12:09:56.383 -> 6092 ?TSF:MSG:SEND,1-1-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                  12:09:58.338 -> 8101 !TSM:FPAR:FAIL
                  12:09:58.338 -> 8103 TSM:FAIL:CNT=1
                  12:09:58.338 -> 8105 TSM:FAIL:DIS
                  12:09:58.338 -> 8108 TSF:TDI:TSL
                  12:10:08.065 -> 18112 TSM:FAIL:RE-INIT
                  12:10:08.065 -> 18114 TSM:INIT
                  12:10:08.098 -> 18120 TSM:INIT:TSP OK
                  12:10:08.098 -> 18122 TSM:INIT:STATID=1
                  12:10:08.098 -> 18126 TSF:SID:OK,ID=1
                  12:10:08.098 -> 18128 TSM:FPAR
                  12:10:08.098 -> 18132 ?TSF:MSG:SEND,1-1-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                  12:10:10.054 -> 20142 !TSM:FPAR:NO REPLY
                  12:10:10.054 -> 20144 TSM:FPAR
                  12:10:10.088 -> 20148 ?TSF:MSG:SEND,1-1-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                  12:10:12.042 -> 22157 !TSM:FPAR:NO REPLY
                  12:10:12.042 -> 22159 TSM:FPAR
                  12:10:12.075 -> 22163 ?TSF:MSG:SEND,1-1-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                  12:10:14.024 -> 24172 !TSM:FPAR:NO REPLY
                  12:10:14.024 -> 24174 TSM:FPAR
                  12:10:14.024 -> 24178 ?TSF:MSG:SEND,1-1-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                  12:10:14.290 -> 24473 TSF:MSG:READ,0-0-1,s=255,c=3,t=8,pt=1,l=1,sg=0:0
                  12:10:14.323 -> 24479 TSF:MSG:FPAR OK,ID=0,D=1
                  12:10:16.012 -> 26187 TSM:FPAR:OK
                  12:10:16.012 -> 26189 TSM:ID
                  12:10:16.012 -> 26189 TSM:ID:OK
                  12:10:16.012 -> 26191 TSM:UPL
                  12:10:16.012 -> 26200 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
                  12:10:16.111 -> 26302 TSF:MSG:READ,0-0-1,s=255,c=3,t=25,pt=1,l=1,sg=0:1
                  12:10:16.146 -> 26308 TSF:MSG:PONG RECV,HP=1
                  12:10:16.146 -> 26312 TSM:UPL:OK
                  12:10:16.146 -> 26314 TSM:READY:ID=1,PAR=0,DIS=1
                  12:10:16.146 -> 26320 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
                  12:10:16.247 -> 26447 TSF:MSG:READ,0-0-1,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                  12:10:16.282 -> 26456 TSF:MSG:SEND,1-1-0-0,s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=OK:2.3.2
                  12:10:16.282 -> 26466 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0
                  12:10:16.521 -> 26703 TSF:MSG:READ,0-0-1,s=255,c=3,t=6,pt=0,l=1,sg=0:M
                  12:10:16.554 -> 26716 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=11,pt=0,l=19,sg=0,ft=0,st=OK:4channel 24V dimmer
                  12:10:16.554 -> 26730 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=12,pt=0,l=4,sg=0,ft=0,st=OK:2.00
                  12:10:16.554 -> 26742 TSF:MSG:SEND,1-1-0-0,s=1,c=0,t=4,pt=0,l=0,sg=0,ft=0,st=OK:
                  12:10:16.858 -> 27049 MCO:REG:REQ
                  12:10:16.858 -> 27052 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
                  12:10:16.926 -> 27121 TSF:MSG:READ,0-0-1,s=255,c=3,t=27,pt=1,l=1,sg=0:1
                  12:10:16.926 -> 27127 MCO:PIM:NODE REG=1
                  12:10:16.926 -> 27129 MCO:BGN:STP
                  12:10:16.926 -> 27136 TSF:MSG:SEND,1-1-0-0,s=1,c=1,t=2,pt=2,l=2,sg=0,ft=0,st=OK:0
                  12:10:17.029 -> 27246 TSF:MSG:SEND,1-1-0-0,s=1,c=2,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
                  12:10:17.368 -> 27580 MCO:BGN:INIT OK,TSP=1
                  12:10:38.436 -> 49125 TSF:MSG:READ,0-0-255,s=255,c=3,t=20,pt=0,l=0,sg=0:
                  12:10:38.436 -> 49131 TSF:MSG:BC
                  12:10:39.446 -> 50141 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=21,pt=1,l=1,sg=0,ft=0,st=OK:0
                    log node:
                    12:09:50.469 ->
                    12:09:50.469 ->
                    tekkaT
                    tekkaT
                    tekka
                    wrote on last edited by tekka
                    @Joerideman The bootloader doesn't generate serial debug output, would be helpful to see the GW debug log
                    • JoeridemanJ
                      JoeridemanJ
                      Joerideman
                      @tekka Allright I am home again :-).
                      Here is the sketch I use for the gateway. It comes out of the examples folder from mysensors. I think Debug is enabled. But for 5-6 seconds after resetting the node, I get nothing out of the gateway.
                       * Copyright (C) 2013-2019 Sensnology AB
                       * Full contributor list: https://github.com/mysensors/MySensors/graphs/contributors
                       * Version 1.0 - Henrik Ekblad
                       * Contribution by tekka,
                       * Contribution by Ivo Pullens (ESP8266 support)
                       * The EthernetGateway sends data received from sensors to the WiFi link.
                       * VERA CONFIGURATION:
                       * E.g. If you want to use the default values in this sketch enter: 192.168.178.66:5003
                       * LED purposes:
                       * - RX (green) - blink fast on radio message received. In inclusion mode will blink fast only on presentation received
                       * - ERR (red) - fast blink on error during transmission error or receive crc error
                       * See https://www.mysensors.org/build/connect_radio for wiring instructions.
                       * If you are using a "barebone" ESP8266, see
                       * https://www.mysensors.org/build/esp8266_gateway#wiring-for-barebone-esp8266
                       * Inclusion mode button:
                      #define MY_BAUD_RATE 57600
                      #define MY_GATEWAY_ESP8266
                      #define MY_WIFI_SSID "-------"
                      #define MY_WIFI_PASSWORD "---------"
                      // passed to the DHCP server if not static.
                      #define MY_HOSTNAME "Mysensors_GW"
                      // Enable UDP communication
                      //#define MY_USE_UDP  // If using UDP you need to set MY_CONTROLLER_IP_ADDRESS below
                      #define MY_PORT 5003
                      // Enable inclusion mode
                      // Set blinking period
                      // #define MY_DEFAULT_LED_BLINK_PERIOD 300
                      // Flash leds on rx/tx/err
                      #include <ArduinoOTA.h>
                      	ArduinoOTA.onStart([]() {
                      		Serial.println("ArduinoOTA start");
                      	ArduinoOTA.onEnd([]() {
                      		Serial.println("\nArduinoOTA end");
                      	ArduinoOTA.onProgress([](unsigned int progress, unsigned int total) {
                      		Serial.printf("OTA Progress: %u%%\r", (progress / (total / 100)));
                      	ArduinoOTA.onError([](ota_error_t error) {
                      		Serial.printf("Error[%u]: ", error);
                      		if (error == OTA_AUTH_ERROR) {
                      			Serial.println("Auth Failed");
                      		} else if (error == OTA_BEGIN_ERROR) {
                      			Serial.println("Begin Failed");
                      		} else if (error == OTA_CONNECT_ERROR) {
                      			Serial.println("Connect Failed");
                      		} else if (error == OTA_RECEIVE_ERROR) {
                      			Serial.println("Receive Failed");
                      		} else if (error == OTA_END_ERROR) {
                      			Serial.println("End Failed");
                      	ArduinoOTA.begin();
                      	ArduinoOTA.handle();
                      • JoeridemanJ
                        JoeridemanJ
                        Joerideman
                        @tekka I used an rf24 sniffer. I tested if it received signals on channel 122 when I just upload my sketch. This works.
                        No signal in over 5 minutes time after resetting the node. only signal came from the gateway itself.
                          tekkaT
                          tekkaT
                          tekka
                          @Joerideman Yeah, I assume something is wrong with the bootloader configuration. Can you zip and upload all bootloader files (or the entire folder) you are using with all the settings and modifications you did?
                          • JoeridemanJ
                            JoeridemanJ
                            Joerideman
                            @tekka Here is a link to my onedrive: https://1drv.ms/u/s!ArHxoBCXZ0wDiKRLceoqlgchv1r_GQ?e=RvboMa
                            It holds a zip archive.
                              tekkaT
                              tekkaT
                              tekka
                              @Joerideman Thanks, I again had a quick look at your HW.h file and found the issue:
                              SPI_DDR and CSN_DDR are both pointing at DDRB:
                              // SPI communication
                              #define SPI_PORT	PORTB	//
                              #define SPI_DDR		DDRB	//
                              and
                              #elif defined(SPI_PINS_CE8_CSN9)
                              	#define CSN_PORT	PORTB	// port for CSN
                              	#define CSN_DDR		DDRB	// DDR for CSN
                              	#define	CSN_PIN		PB1		// Arduino Pin 9 <-> Bit 1 of port B
                              Thus, setting CSN_DDR = _BV(CSN_PIN) you overwrite SPI_DDR. Comment out the second line and add _BV(CSN_PIN) to SPI_DDR:
                              SPI_DDR = _BV(SPI_MOSI) | _BV(SPI_SCLK) | _BV(CE_PIN) | _BV(PB2) |  _BV(CSN_PIN);
                              //CSN_DDR = _BV(CSN_PIN);
                              • JoeridemanJ
                                JoeridemanJ
                                Joerideman
                                @tekka
                                Is this the only adjustment that I needed to make?
                                at this point there is no fota and somewhere in the past days Serial update using the uart has also been destroyed again. I think I should restart with a clean download and start again. I am afraid I changed things I should not have,
                                The log from running make. I notice now that some parts are failed. But I do not know what that means. I do not remember if this was alway the case. This might be a clue that something went wrong.
                                G:\OneDrive\Arduino\mysensors\MySensorsBootloaderRF24-development>make
                                rm *.o
                                process_begin: CreateProcess(NULL, rm *.o, ...) failed.
                                make (e=2): Het systeem kan het opgegeven bestand niet vinden.
                                make: [clean] Fout 2 (genegeerd)
                                rm *.elf
                                process_begin: CreateProcess(NULL, rm *.elf, ...) failed.
                                rm *.hex
                                process_begin: CreateProcess(NULL, rm *.hex, ...) failed.
                                "C:/Program Files (x86)/Atmel/Studio/7.0/toolchain/avr8/avr8-gnu-toolchain/bin/avr-objcopy" -O ihex -R .eeprom MYSBootloader.elf MYSBootloader.hex
                                "C:/Program Files (x86)/Atmel/Studio/7.0/toolchain/avr8/avr8-gnu-toolchain/bin/avr-size" MYSBootloader.elf
                                   text    data     bss     dec     hex filename
                                   2032       6      71    2109     83d MYSBootloader.elf
                                With a fresh download of all the files without any changes to the make file I get this:
                                It says in dutch "make (e=2) the system can not find the file specified"
                                rm *.o
                                rm *.elf
                                rm *.hex
                                "C:/Program Files (x86)/Atmel/Studio/7.0/toolchain/avr8/avr8-gnu-toolchain/bin/avr-gcc" -I"C:/Program Files (x86)/Atmel/Studio/7.0/toolchain/avr8/avr8-gnu-toolchain/avr/include/avr          " -funsigned-char -funsigned-bitfields -DF_CPU=16000000L -DBAUD_RATE=115200 -Os -ffunction-sections -fdata-sections -fpack-struct -fshort-enums -mrelax -Wall -Wextra -Wundef -pedantic -mmcu=atmega328p -c -std=gnu99 -MD -MP -MF "MYSBootloader.d" -MT"MYSBootloader.d" -MT"MYSBootloader.o"  MYSBootloader.c -o MYSBootloader.o
                                In file included from Core.h:40:0,
                                                 from MYSBootloader.c:81:
                                HW.h:51:4: warning: #warning is a GCC extension
                                   #warning BAUD_RATE error greater than 2%
                                HW.h:51:4: warning: #warning BAUD_RATE error greater than 2% [-Wcpp]
                                "C:/Program Files (x86)/Atmel/Studio/7.0/toolchain/avr8/avr8-gnu-toolchain/bin/avr-gcc" -nostartfiles -Wl,-s -Wl,-static -Wl,-Map=".map" -Wl,--start-group -Wl,--end-group -Wl,--gc-sections -mrelax -Wl,-section-start=.text=0x7800 -mmcu=atmega328p   -o MYSBootloader.elf MYSBootloader.o -lm
                                  @tekka
                                  rm *.o
                                  rm *.elf
                                  rm *.hex
                                  rm *.o
                                  rm *.elf
                                  rm *.hex
                                  tekkaT
                                  tekkaT
                                  tekka
                                  #21
                                  @Joerideman You can ignore that warning (it is related to rm not being found).
                                  Can you try this .hex file: CE=8, CSN=9, CLK=8MHz, BAUD=57600, RF24 channel=122: download file
                                  Please post the log of the bootloader flashing process...
                                  • JoeridemanJ
                                    JoeridemanJ
                                    Joerideman
                                    #22
                                    @tekka
                                    This definetly did something. Further in this post the log from uploading the bootloader and then a serial output from the gateway than the debug output of myScontroller. There is a lot of chatting, but to me it looks like its the same set of messages everytime. I tried assigning the blink message, and than a whole lot more is going on. So maybe there is something about the firmware config file that I don't understand. I put my input at the end of this post.
                                    avrDudess log, because arduino ide doesn't tell me much.
                                    avrdude.exe: set SCK frequency to 1500000 Hz
                                    avrdude.exe: warning: cannot set sck period. please check for usbasp firmware update.
                                    avrdude.exe: AVR device initialized and ready to accept instructions
                                    avrdude.exe: Device signature = 0x1e950f (probably m328p)
                                    avrdude.exe: NOTE: "flash" memory has been specified, an erase cycle will be performed
                                    avrdude.exe: erasing chip
                                    avrdude.exe: reading input file "C:\Users\joeri\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.21\bootloaders\mySensors\MYSBootloader_CE8_CSN9_CH122_8Mhz_57k6.hex"
                                    avrdude.exe: input file C:\Users\joeri\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.21\bootloaders\mySensors\MYSBootloader_CE8_CSN9_CH122_8Mhz_57k6.hex auto detected as Intel Hex
                                    avrdude.exe: writing flash (32762 bytes):
                                    Writing | ################################################## | 100% -0.00s
                                    avrdude.exe: 32762 bytes of flash written
                                    avrdude.exe: verifying flash memory against C:\Users\joeri\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.21\bootloaders\mySensors\MYSBootloader_CE8_CSN9_CH122_8Mhz_57k6.hex:
                                    avrdude.exe: load data flash data from input file C:\Users\joeri\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.21\bootloaders\mySensors\MYSBootloader_CE8_CSN9_CH122_8Mhz_57k6.hex:
                                    avrdude.exe: input file C:\Users\joeri\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.21\bootloaders\mySensors\MYSBootloader_CE8_CSN9_CH122_8Mhz_57k6.hex contains 32762 bytes
                                    avrdude.exe: reading on-chip flash data:
                                    avrdude.exe: verifying ...
                                    avrdude.exe: 32762 bytes of flash verified
                                    avrdude.exe done.  Thank you.
                                    14:12:38.035 -> 562420 TSF:MSG:FPAR REQ,ID=255
                                    14:12:38.035 -> 562426 TSF:CKU:OK,FCTRL
                                    14:12:38.035 -> 562430 TSF:MSG:GWL OK
                                    14:12:38.302 -> 562695 ?TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
                                    14:12:41.067 -> 565447 TSF:MSG:READ,255-255-0,s=255,c=3,t=3,pt=1,l=0,sg=0:0
                                    14:12:41.270 -> 565669 GWT:RFC:C=0,MSG=255;255;3;0;4;1
                                    14:12:41.270 -> 565680 ?TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=4,pt=0,l=1,sg=0,ft=0,st=OK:1
                                    14:12:41.303 -> 565693 TSF:MSG:READ,1-1-255,s=255,c=3,t=7,pt=1,l=1,sg=0:0
                                    14:12:41.303 -> 565703 TSF:MSG:BC
                                    14:12:41.303 -> 565706 TSF:MSG:FPAR REQ,ID=1
                                    14:12:41.303 -> 565711 TSF:CKU:OK,FCTRL
                                    14:12:41.303 -> 565716 TSF:MSG:GWL OK
                                    14:12:41.809 -> 566196 TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
                                    14:12:44.336 -> 568733 TSF:MSG:READ,1-1-255,s=255,c=3,t=7,pt=1,l=1,sg=0:0
                                    14:12:44.336 -> 568743 TSF:MSG:BC
                                    14:12:44.336 -> 568746 TSF:MSG:FPAR REQ,ID=1
                                    14:12:44.370 -> 568751 TSF:CKU:OK,FCTRL
                                    14:12:44.370 -> 568755 TSF:MSG:GWL OK
                                    14:12:44.811 -> 569203 TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
                                    14:12:47.369 -> 571774 TSF:MSG:READ,1-1-0,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                                    14:12:47.404 -> 571789 TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
                                    14:12:47.979 -> 572360 TSF:MSG:READ,1-1-0,s=255,c=4,t=0,pt=6,l=10,sg=0:FFFFFFFFFFFFFE400103
                                    14:12:51.011 -> 575402 TSF:MSG:READ,1-1-0,s=255,c=4,t=0,pt=6,l=10,sg=0:FFFFFFFFFFFFFE400103
                                    14:12:54.042 -> 578443 TSF:MSG:READ,1-1-0,s=255,c=4,t=0,pt=6,l=10,sg=0:FFFFFFFFFFFFFE400103
                                    14:12:57.077 -> 581484 TSF:MSG:READ,1-1-0,s=255,c=4,t=0,pt=6,l=10,sg=0:FFFFFFFFFFFFFE400103
                                    14:13:00.990 -> 585400 TSF:MSG:READ,1-1-255,s=255,c=3,t=7,pt=1,l=1,sg=0:0
                                    14:13:01.024 -> 585410 TSF:MSG:BC
                                    14:13:01.024 -> 585413 TSF:MSG:FPAR REQ,ID=1
                                    14:13:01.024 -> 585418 TSF:PNG:SEND,TO=0
                                    14:13:01.024 -> 585423 TSF:CKU:OK
                                    14:13:01.024 -> 585426 TSF:MSG:GWL OK
                                    14:13:01.763 -> 586161 TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
                                    14:13:04.058 -> 588449 TSF:MSG:READ,1-1-255,s=255,c=3,t=7,pt=1,l=1,sg=0:0
                                    14:13:04.058 -> 588459 TSF:MSG:BC
                                    14:13:04.058 -> 588462 TSF:MSG:FPAR REQ,ID=1
                                    14:13:04.058 -> 588467 TSF:CKU:OK,FCTRL
                                    14:13:04.058 -> 588472 TSF:MSG:GWL OK
                                    14:13:04.795 -> 589179 TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
                                    14:13:07.087 -> 591490 TSF:MSG:READ,1-1-0,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                                    14:13:07.122 -> 591505 TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
                                    14:13:07.696 -> 592077 TSF:MSG:READ,1-1-0,s=255,c=4,t=0,pt=6,l=10,sg=0:FFFFFFFFFFFFFE400103
                                    14:13:10.716 -> 595118 TSF:MSG:READ,1-1-0,s=255,c=4,t=0,pt=6,l=10,sg=0:FFFFFFFFFFFFFE400103
                                    14:13:13.776 -> 598159 TSF:MSG:READ,1-1-0,s=255,c=4,t=0,pt=6,l=10,sg=0:FFFFFFFFFFFFFE400103
                                    14:13:16.814 -> 601201 TSF:MSG:READ,1-1-0,s=255,c=4,t=0,pt=6,l=10,sg=0:FFFFFFFFFFFFFE400103
                                    14:13:20.726 -> 605116 TSF:MSG:READ,1-1-255,s=255,c=3,t=7,pt=1,l=1,sg=0:0
                                    14:13:20.726 -> 605127 TSF:MSG:BC
                                    14:13:20.726 -> 605130 TSF:MSG:FPAR REQ,ID=1
                                    14:13:20.726 -> 605135 TSF:PNG:SEND,TO=0
                                    14:13:20.726 -> 605139 TSF:CKU:OK
                                    14:13:20.726 -> 605142 TSF:MSG:GWL OK
                                    14:13:21.736 -> 606137 TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
                                    14:13:23.771 -> 608165 TSF:MSG:READ,1-1-255,s=255,c=3,t=7,pt=1,l=1,sg=0:0
                                    14:13:23.771 -> 608175 TSF:MSG:BC
                                    14:13:23.771 -> 608179 TSF:MSG:FPAR REQ,ID=1
                                    14:13:23.771 -> 608184 TSF:CKU:OK,FCTRL
                                    14:13:23.805 -> 608188 TSF:MSG:GWL OK
                                    14:13:24.752 -> 609156 TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
                                    14:13:26.808 -> 611207 TSF:MSG:READ,1-1-0,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                                    14:13:26.808 -> 611221 TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
                                    14:13:27.382 -> 611793 TSF:MSG:READ,1-1-0,s=255,c=4,t=0,pt=6,l=10,sg=0:FFFFFFFFFFFFFE400103
                                    14:13:30.445 -> 614834 TSF:MSG:READ,1-1-0,s=255,c=4,t=0,pt=6,l=10,sg=0:FFFFFFFFFFFFFE400103
                                    14:13:31.355 -> 615744 GWT:RFC:C=0,MSG=1;0;3;0;13;0
                                    14:13:31.355 -> 615755 TSF:MSG:SEND,0-0-1-1,s=0,c=3,t=13,pt=0,l=1,sg=0,ft=0,st=OK:0
                                    14:13:33.484 -> 617876 TSF:MSG:READ,1-1-0,s=255,c=4,t=0,pt=6,l=10,sg=0:FFFFFFFFFFFFFE400103
                                    14:13:33.484 -> 617897 GWT:RFC:C=0,MSG=1;0;4;0;1;0100020000082E8B
                                    14:13:33.518 -> 617911 TSF:MSG:SEND,0-0-1-1,s=0,c=4,t=1,pt=6,l=8,sg=0,ft=0,st=OK:0100020000082E8B
                                    14:13:37.427 -> 621833 TSF:MSG:READ,1-1-255,s=255,c=3,t=7,pt=1,l=1,sg=0:0
                                    14:13:37.427 -> 621843 TSF:MSG:BC
                                    14:13:37.461 -> 621847 TSF:MSG:FPAR REQ,ID=1
                                    14:13:37.461 -> 621852 TSF:PNG:SEND,TO=0
                                    14:13:37.461 -> 621856 TSF:CKU:OK
                                    14:13:37.461 -> 621859 TSF:MSG:GWL OK
                                    14:13:37.766 -> 622163 TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
                                    14:13:40.491 -> 624882 TSF:MSG:READ,1-1-0,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                                    14:13:40.491 -> 624897 TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
                                    14:13:41.071 -> 625469 TSF:MSG:READ,1-1-0,s=255,c=4,t=0,pt=6,l=10,sg=0:FFFFFFFFFFFFFE400103
                                    14:13:41.106 -> 625490 GWT:RFC:C=0,MSG=1;0;4;0;1;0100020000082E8B
                                    14:13:41.106 -> 625504 TSF:MSG:SEND,0-0-1-1,s=0,c=4,t=1,pt=6,l=8,sg=0,ft=0,st=OK:0100020000082E8B
                                    14:13:41.994 -> 626377 TSF:MSG:READ,1-1-255,s=255,c=3,t=7,pt=1,l=1,sg=0:0
                                    14:13:41.994 -> 626387 TSF:MSG:BC
                                    14:13:41.994 -> 626391 TSF:MSG:FPAR REQ,ID=1
                                    14:13:41.994 -> 626396 TSF:CKU:OK,FCTRL
                                    14:13:41.994 -> 626400 TSF:MSG:GWL OK
                                    14:13:42.742 -> 627148 TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
                                    14:13:45.017 -> 629426 TSF:MSG:READ,1-1-255,s=255,c=3,t=7,pt=1,l=1,sg=0:0
                                    14:13:45.017 -> 629436 TSF:MSG:BC
                                    14:13:45.051 -> 629439 TSF:MSG:FPAR REQ,ID=1
                                    14:13:45.051 -> 629444 TSF:CKU:OK,FCTRL
                                    14:13:45.051 -> 629449 TSF:MSG:GWL OK
                                    14:13:45.769 -> 630175 TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
                                    14:13:48.074 -> 632467 TSF:MSG:READ,1-1-0,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                                    14:13:48.074 -> 632482 TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
                                    14:13:48.652 -> 633053 TSF:MSG:READ,1-1-0,s=255,c=4,t=0,pt=6,l=10,sg=0:FFFFFFFFFFFFFE400103
                                    14:13:48.687 -> 633072 GWT:RFC:C=0,MSG=1;0;4;0;1;0100020000082E8B
                                    14:13:48.687 -> 633086 TSF:MSG:SEND,0-0-1-1,s=0,c=4,t=1,pt=6,l=8,sg=0,ft=0,st=OK:0100020000082E8B
                                    14:13:52.616 -> 637008 TSF:MSG:READ,1-1-255,s=255,c=3,t=7,pt=1,l=1,sg=0:0
                                    14:13:52.616 -> 637018 TSF:MSG:BC
                                    14:13:52.616 -> 637021 TSF:MSG:FPAR REQ,ID=1
                                    14:13:52.616 -> 637026 TSF:CKU:OK,FCTRL
                                    14:13:52.616 -> 637030 TSF:MSG:GWL OK
                                    14:13:52.753 -> 637147 TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
                                    14:13:55.658 -> 640057 TSF:MSG:READ,1-1-0,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                                    14:13:55.658 -> 640072 TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
                                    14:13:56.234 -> 640643 TSF:MSG:READ,1-1-0,s=255,c=4,t=0,pt=6,l=10,sg=0:FFFFFFFFFFFFFE400103
                                    14:13:56.268 -> 640662 GWT:RFC:C=0,MSG=1;0;4;0;1;0100020000082E8B
                                    14:13:56.268 -> 640676 TSF:MSG:SEND,0-0-1-1,s=0,c=4,t=1,pt=6,l=8,sg=0,ft=0,st=OK:0100020000082E8B
                                    14:13:57.149 -> 641549 TSF:MSG:READ,1-1-255,s=255,c=3,t=7,pt=1,l=1,sg=0:0
                                    14:13:57.149 -> 641559 TSF:MSG:BC
                                    14:13:57.149 -> 641562 TSF:MSG:FPAR REQ,ID=1
                                    14:13:57.183 -> 641567 TSF:CKU:OK,FCTRL
                                    14:13:57.183 -> 641572 TSF:MSG:GWL OK
                                    14:13:57.725 -> 642131 TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
                                    14:14:00.192 -> 644598 TSF:MSG:READ,1-1-255,s=255,c=3,t=7,pt=1,l=1,sg=0:0
                                    14:14:00.192 -> 644608 TSF:MSG:BC
                                    14:14:00.226 -> 644611 TSF:MSG:FPAR REQ,ID=1
                                    14:14:00.226 -> 644616 TSF:CKU:OK,FCTRL
                                    14:14:00.226 -> 644621 TSF:MSG:GWL OK
                                    14:14:00.768 -> 645157 TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
                                    14:14:03.252 -> 647639 TSF:MSG:READ,1-1-0,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                                    14:14:03.252 -> 647654 TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
                                    14:14:03.828 -> 648226 TSF:MSG:READ,1-1-0,s=255,c=4,t=0,pt=6,l=10,sg=0:FFFFFFFFFFFFFE400103
                                    14:14:03.863 -> 648245 GWT:RFC:C=0,MSG=1;0;4;0;1;0100020000082E8B
                                    14:14:03.863 -> 648259 TSF:MSG:SEND,0-0-1-1,s=0,c=4,t=1,pt=6,l=8,sg=0,ft=0,st=OK:0100020000082E8B
                                    14:14:07.782 -> 652181 TSF:MSG:READ,1-1-255,s=255,c=3,t=7,pt=1,l=1,sg=0:0
                                    14:14:07.782 -> 652191 TSF:MSG:BC
                                    14:14:07.782 -> 652195 TSF:MSG:FPAR REQ,ID=1
                                    14:14:07.816 -> 652200 TSF:CKU:OK,FCTRL
                                    14:14:07.816 -> 652204 TSF:MSG:GWL OK
                                    14:14:08.764 -> 653156 TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
                                    14:14:10.836 -> 655230 TSF:MSG:READ,1-1-0,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                                    14:14:10.836 -> 655245 TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
                                    14:14:11.407 -> 655816 TSF:MSG:READ,1-1-0,s=255,c=4,t=0,pt=6,l=10,sg=0:FFFFFFFFFFFFFE400103
                                    14:14:11.441 -> 655836 GWT:RFC:C=0,MSG=1;0;4;0;1;0100020000082E8B
                                    14:14:11.441 -> 655850 TSF:MSG:SEND,0-0-1-1,s=0,c=4,t=1,pt=6,l=8,sg=0,ft=0,st=OK:0100020000082E8B
                                    14:14:12.321 -> 656723 TSF:MSG:READ,1-1-255,s=255,c=3,t=7,pt=1,l=1,sg=0:0
                                    14:14:12.321 -> 656733 TSF:MSG:BC
                                    14:14:12.321 -> 656736 TSF:MSG:FPAR REQ,ID=1
                                    14:14:12.354 -> 656741 TSF:CKU:OK,FCTRL
                                    14:14:12.354 -> 656746 TSF:MSG:GWL OK
                                    14:14:12.723 -> 657119 TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
                                    14:14:15.387 -> 659772 TSF:MSG:READ,1-1-255,s=255,c=3,t=7,pt=1,l=1,sg=0:0
                                    14:14:15.387 -> 659782 TSF:MSG:BC
                                    14:14:15.387 -> 659785 TSF:MSG:FPAR REQ,ID=1
                                    14:14:15.387 -> 659790 TSF:CKU:OK,FCTRL
                                    14:14:15.387 -> 659795 TSF:MSG:GWL OK
                                    14:14:15.759 -> 660145 TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
                                    14:14:18.425 -> 662813 TSF:MSG:READ,1-1-0,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                                    14:14:18.425 -> 662828 TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
                                    14:14:18.998 -> 663400 TSF:MSG:READ,1-1-0,s=255,c=4,t=0,pt=6,l=10,sg=0:FFFFFFFFFFFFFE400103
                                    14:14:19.032 -> 663420 GWT:RFC:C=0,MSG=1;0;4;0;1;0100020000082E8B
                                    14:14:19.032 -> 663433 TSF:MSG:SEND,0-0-1-1,s=0,c=4,t=1,pt=6,l=8,sg=0,ft=0,st=OK:0100020000082E8B
                                    14:14:22.962 -> 667355 TSF:MSG:READ,1-1-255,s=255,c=3,t=7,pt=1,l=1,sg=0:0
                                    14:14:22.962 -> 667365 TSF:MSG:BC
                                    14:14:22.962 -> 667369 TSF:MSG:FPAR REQ,ID=1
                                    14:14:22.962 -> 667374 TSF:CKU:OK,FCTRL
                                    14:14:22.962 -> 667378 TSF:MSG:GWL OK
                                    14:14:23.739 -> 668146 TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
                                    14:14:25.990 -> 670404 TSF:MSG:READ,1-1-0,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                                    14:14:26.023 -> 670419 TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
                                    14:14:26.595 -> 670991 TSF:MSG:READ,1-1-0,s=255,c=4,t=0,pt=6,l=10,sg=0:FFFFFFFFFFFFFE400103
                                    14:14:26.630 -> 671021 GWT:RFC:C=0,MSG=1;0;4;0;1;0100020000082E8B
                                    14:14:26.630 -> 671034 TSF:MSG:SEND,0-0-1-1,s=0,c=4,t=1,pt=6,l=8,sg=0,ft=0,st=OK:0100020000082E8B
                                    14:14:27.504 -> 671908 TSF:MSG:READ,1-1-255,s=255,c=3,t=7,pt=1,l=1,sg=0:0
                                    14:14:27.504 -> 671918 TSF:MSG:BC
                                    14:14:27.504 -> 671921 TSF:MSG:FPAR REQ,ID=1
                                    14:14:27.537 -> 671926 TSF:CKU:OK,FCTRL
                                    14:14:27.537 -> 671930 TSF:MSG:GWL OK
                                    14:14:27.740 -> 672129 TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
                                    14:14:30.571 -> 674957 TSF:MSG:READ,1-1-255,s=255,c=3,t=7,pt=1,l=1,sg=0:0
                                    14:14:30.571 -> 674967 TSF:MSG:BC
                                    14:14:30.571 -> 674970 TSF:MSG:FPAR REQ,ID=1
                                    14:14:30.571 -> 674975 TSF:CKU:OK,FCTRL
                                    14:14:30.571 -> 674979 TSF:MSG:GWL OK
                                    14:14:30.772 -> 675157 TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
                                    14:14:33.599 -> 677998 TSF:MSG:READ,1-1-0,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                                    14:14:33.599 -> 678013 TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
                                    14:14:34.171 -> 678584 TSF:MSG:READ,1-1-0,s=255,c=4,t=0,pt=6,l=10,sg=0:FFFFFFFFFFFFFE400103
                                    14:14:34.205 -> 678604 GWT:RFC:C=0,MSG=1;0;4;0;1;0100020000082E8B
                                    14:14:34.205 -> 678617 TSF:MSG:SEND,0-0-1-1,s=0,c=4,t=1,pt=6,l=8,sg=0,ft=0,st=OK:0100020000082E8B
                                    14:14:35.079 -> 679491 TSF:MSG:READ,1-1-255,s=255,c=3,t=7,pt=1,l=1,sg=0:0
                                    14:14:35.113 -> 679501 TSF:MSG:BC
                                    14:14:35.113 -> 679504 TSF:MSG:FPAR REQ,ID=1
                                    14:14:35.113 -> 679509 TSF:CKU:OK,FCTRL
                                    14:14:35.113 -> 679514 TSF:MSG:GWL OK
                                    14:14:35.720 -> 680127 TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
                                    14:14:38.142 -> 682540 TSF:MSG:READ,1-1-255,s=255,c=3,t=7,pt=1,l=1,sg=0:0
                                    14:14:38.142 -> 682550 TSF:MSG:BC
                                    14:14:38.142 -> 682553 TSF:MSG:FPAR REQ,ID=1
                                    14:14:38.142 -> 682558 TSF:CKU:OK,FCTRL
                                    14:14:38.175 -> 682562 TSF:MSG:GWL OK
                                    14:14:38.748 -> 683153 TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
                                    14:14:41.168 -> 685581 TSF:MSG:READ,1-1-0,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                                    14:14:41.202 -> 685596 TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
                                    14:14:41.772 -> 686167 TSF:MSG:READ,1-1-0,s=255,c=4,t=0,pt=6,l=10,sg=0:FFFFFFFFFFFFFE400103
                                    14:14:41.772 -> 686188 GWT:RFC:C=0,MSG=1;0;4;0;1;0100020000082E8B
                                    14:14:41.807 -> 686202 TSF:MSG:SEND,0-0-1-1,s=0,c=4,t=1,pt=6,l=8,sg=0,ft=0,st=OK:0100020000082E8B
                                    14:14:45.713 -> 690124 TSF:MSG:READ,1-1-255,s=255,c=3,t=7,pt=1,l=1,sg=0:0
                                    14:14:45.713 -> 690134 TSF:MSG:BC
                                    14:14:45.747 -> 690137 TSF:MSG:FPAR REQ,ID=1
                                    14:14:45.747 -> 690142 TSF:CKU:OK,FCTRL
                                    14:14:45.747 -> 690146 TSF:MSG:GWL OK
                                    14:14:46.757 -> 691153 TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
                                    14:14:48.760 -> 693173 TSF:MSG:READ,1-1-0,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                                    14:14:48.793 -> 693187 TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
                                    14:14:49.365 -> 693759 TSF:MSG:READ,1-1-0,s=255,c=4,t=0,pt=6,l=10,sg=0:FFFFFFFFFFFFFE400103
                                    14:14:49.365 -> 693779 GWT:RFC:C=0,MSG=1;0;4;0;1;0100020000082E8B
                                    14:14:49.399 -> 693792 TSF:MSG:SEND,0-0-1-1,s=0,c=4,t=1,pt=6,l=8,sg=0,ft=0,st=OK:0100020000082E8B
                                    14:14:50.274 -> 694666 TSF:MSG:READ,1-1-255,s=255,c=3,t=7,pt=1,l=1,sg=0:0
                                    14:14:50.274 -> 694676 TSF:MSG:BC
                                    14:14:50.274 -> 694679 TSF:MSG:FPAR REQ,ID=1
                                    14:14:50.274 -> 694684 TSF:CKU:OK,FCTRL
                                    14:14:50.274 -> 694689 TSF:MSG:GWL OK
                                    14:14:50.709 -> 695118 TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
                                    14:14:53.313 -> 697715 TSF:MSG:READ,1-1-255,s=255,c=3,t=7,pt=1,l=1,sg=0:0
                                    14:14:53.313 -> 697725 TSF:MSG:BC
                                    14:14:53.313 -> 697728 TSF:MSG:FPAR REQ,ID=1
                                    14:14:53.347 -> 697733 TSF:CKU:OK,FCTRL
                                    14:14:53.347 -> 697737 TSF:MSG:GWL OK
                                    14:14:53.747 -> 698143 TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
                                    14:14:56.350 -> 700756 TSF:MSG:READ,1-1-0,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                                    14:14:56.383 -> 700771 TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
                                    14:14:56.957 -> 701343 TSF:MSG:READ,1-1-0,s=255,c=4,t=0,pt=6,l=10,sg=0:FFFFFFFFFFFFFE400103
                                    14:14:56.957 -> 701362 GWT:RFC:C=0,MSG=1;0;4;0;1;0100020000082E8B
                                    14:14:56.991 -> 701376 TSF:MSG:SEND,0-0-1-1,s=0,c=4,t=1,pt=6,l=8,sg=0,ft=0,st=OK:0100020000082E8B
                                    14:15:00.910 -> 705298 TSF:MSG:READ,1-1-255,s=255,c=3,t=7,pt=1,l=1,sg=0:0
                                    14:15:00.910 -> 705308 TSF:MSG:BC
                                    14:15:00.910 -> 705311 TSF:MSG:FPAR REQ,ID=1
                                    14:15:00.910 -> 705316 TSF:CKU:OK,FCTRL
                                    14:15:00.910 -> 705320 TSF:MSG:GWL OK
                                    14:15:01.750 -> 706141 TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
                                    14:15:03.937 -> 708347 TSF:MSG:READ,1-1-0,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                                    14:15:03.970 -> 708362 TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
                                    14:15:04.543 -> 708933 TSF:MSG:READ,1-1-0,s=255,c=4,t=0,pt=6,l=10,sg=0:FFFFFFFFFFFFFE400103
                                    14:15:04.543 -> 708952 GWT:RFC:C=0,MSG=1;0;4;0;1;0100020000082E8B
                                    14:15:04.576 -> 708966 TSF:MSG:SEND,0-0-1-1,s=0,c=4,t=1,pt=6,l=8,sg=0,ft=0,st=OK:0100020000082E8B
                                    14:15:05.453 -> 709840 TSF:MSG:READ,1-1-255,s=255,c=3,t=7,pt=1,l=1,sg=0:0
                                    14:15:05.453 -> 709850 TSF:MSG:BC
                                    14:15:05.453 -> 709853 TSF:MSG:FPAR REQ,ID=1
                                    14:15:05.453 -> 709858 TSF:CKU:OK,FCTRL
                                    14:15:05.453 -> 709862 TSF:MSG:GWL OK
                                    14:15:05.692 -> 710105 TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
                                    14:15:08.487 -> 712889 TSF:MSG:READ,1-1-255,s=255,c=3,t=7,pt=1,l=1,sg=0:0
                                    14:15:08.487 -> 712899 TSF:MSG:BC
                                    14:15:08.487 -> 712902 TSF:MSG:FPAR REQ,ID=1
                                    14:15:08.520 -> 712907 TSF:CKU:OK,FCTRL
                                    14:15:08.520 -> 712911 TSF:MSG:GWL OK
                                    14:15:08.724 -> 713131 TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
                                    14:15:11.532 -> 715932 TSF:MSG:READ,1-1-0,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                                    14:15:11.532 -> 715947 TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
                                    14:15:12.108 -> 716518 TSF:MSG:READ,1-1-0,s=255,c=4,t=0,pt=6,l=10,sg=0:FFFFFFFFFFFFFE400103
                                    14:15:12.141 -> 716547 GWT:RFC:C=0,MSG=1;0;4;0;1;0100020000082E8B
                                    14:15:12.175 -> 716560 TSF:MSG:SEND,0-0-1-1,s=0,c=4,t=1,pt=6,l=8,sg=0,ft=0,st=OK:0100020000082E8B
                                    14:15:16.094 -> 720482 TSF:MSG:READ,1-1-255,s=255,c=3,t=7,pt=1,l=1,sg=0:0
                                    14:15:16.094 -> 720493 TSF:MSG:BC
                                    14:15:16.094 -> 720496 TSF:MSG:FPAR REQ,ID=1
                                    14:15:16.094 -> 720501 TSF:CKU:OK,FCTRL
                                    14:15:16.094 -> 720505 TSF:MSG:GWL OK
                                    14:15:16.733 -> 721150 TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
                                    14:15:19.137 -> 723531 TSF:MSG:READ,1-1-0,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                                    14:15:19.137 -> 723546 TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
                                    14:15:19.706 -> 724118 TSF:MSG:READ,1-1-0,s=255,c=4,t=0,pt=6,l=10,sg=0:FFFFFFFFFFFFFE400103
                                    14:15:19.740 -> 724138 GWT:RFC:C=0,MSG=1;0;4;0;1;0100020000082E8B
                                    14:15:19.740 -> 724152 TSF:MSG:SEND,0-0-1-1,s=0,c=4,t=1,pt=6,l=8,sg=0,ft=0,st=OK:0100020000082E8B
                                    14:15:20.616 -> 725026 TSF:MSG:READ,1-1-255,s=255,c=3,t=7,pt=1,l=1,sg=0:0
                                    14:15:20.616 -> 725036 TSF:MSG:BC
                                    14:15:20.650 -> 725039 TSF:MSG:FPAR REQ,ID=1
                                    14:15:20.650 -> 725044 TSF:CKU:OK,FCTRL
                                    14:15:20.650 -> 725048 TSF:MSG:GWL OK
                                    14:15:20.718 -> 725117 TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
                                    14:15:23.675 -> 728075 TSF:MSG:READ,1-1-255,s=255,c=3,t=7,pt=1,l=1,sg=0:0
                                    14:15:23.675 -> 728085 TSF:MSG:BC
                                    14:15:23.675 -> 728088 TSF:MSG:FPAR REQ,ID=1
                                    14:15:23.675 -> 728093 TSF:CKU:OK,FCTRL
                                    14:15:23.708 -> 728097 TSF:MSG:GWL OK
                                    14:15:23.742 -> 728142 TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
                                    14:15:26.709 -> 731116 TSF:MSG:READ,1-1-0,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                                    14:15:26.749 -> 731131 TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
                                    14:15:27.288 -> 731702 TSF:MSG:READ,1-1-0,s=255,c=4,t=0,pt=6,l=10,sg=0:FFFFFFFFFFFFFE400103
                                    14:15:27.322 -> 731722 GWT:RFC:C=0,MSG=1;0;4;0;1;0100020000082E8B
                                    14:15:27.322 -> 731736 TSF:MSG:SEND,0-0-1-1,s=0,c=4,t=1,pt=6,l=8,sg=0,ft=0,st=OK:0100020000082E8B
                                    14:15:31.262 -> 735658 TSF:MSG:READ,1-1-255,s=255,c=3,t=7,pt=1,l=1,sg=0:0
                                    14:15:31.262 -> 735668 TSF:MSG:BC
                                    14:15:31.262 -> 735671 TSF:MSG:FPAR REQ,ID=1
                                    14:15:31.262 -> 735676 TSF:CKU:OK,FCTRL
                                    14:15:31.262 -> 735680 TSF:MSG:GWL OK
                                    14:15:31.730 -> 736141 TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
                                    14:15:34.298 -> 738707 TSF:MSG:READ,1-1-0,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                                    14:15:34.333 -> 738722 TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
                                    14:15:34.898 -> 739293 TSF:MSG:READ,1-1-0,s=255,c=4,t=0,pt=6,l=10,sg=0:FFFFFFFFFFFFFE400103
                                    14:15:34.898 -> 739313 GWT:RFC:C=0,MSG=1;0;4;0;1;0100020000082E8B
                                    14:15:34.932 -> 739327 TSF:MSG:SEND,0-0-1-1,s=0,c=4,t=1,pt=6,l=8,sg=0,ft=0,st=OK:0100020000082E8B
                                    14:15:35.808 -> 740200 TSF:MSG:READ,1-1-255,s=255,c=3,t=7,pt=1,l=1,sg=0:0
                                    14:15:35.808 -> 740210 TSF:MSG:BC
                                    14:15:35.808 -> 740213 TSF:MSG:FPAR REQ,ID=1
                                    14:15:35.808 -> 740219 TSF:CKU:OK,FCTRL
                                    14:15:35.808 -> 740223 TSF:MSG:GWL OK
                                    14:15:36.725 -> 741130 TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
                                    14:15:38.844 -> 743249 TSF:MSG:READ,1-1-255,s=255,c=3,t=7,pt=1,l=1,sg=0:0
                                    14:15:38.844 -> 743259 TSF:MSG:BC
                                    14:15:38.844 -> 743262 TSF:MSG:FPAR REQ,ID=1
                                    14:15:38.877 -> 743267 TSF:CKU:OK,FCTRL
                                    14:15:38.877 -> 743272 TSF:MSG:GWL OK
                                    14:15:39.749 -> 744157 TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
                                    14:15:41.874 -> 746290 TSF:MSG:READ,1-1-0,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                                    14:15:41.907 -> 746305 TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
                                    14:15:42.482 -> 746876 TSF:MSG:READ,1-1-0,s=255,c=4,t=0,pt=6,l=10,sg=0:FFFFFFFFFFFFFE400103
                                    14:15:42.482 -> 746897 GWT:RFC:C=0,MSG=1;0;4;0;1;0100020000082E8B
                                    14:15:42.515 -> 746911 TSF:MSG:SEND,0-0-1-1,s=0,c=4,t=1,pt=6,l=8,sg=0,ft=0,st=OK:0100020000082E8B
                                    14:15:43.392 -> 747784 TSF:MSG:READ,1-1-255,s=255,c=3,t=7,pt=1,l=1,sg=0:0
                                    14:15:43.392 -> 747795 TSF:MSG:BC
                                    14:15:43.392 -> 747798 TSF:MSG:FPAR REQ,ID=1
                                    14:15:43.392 -> 747803 TSF:CKU:OK,FCTRL
                                    14:15:43.392 -> 747807 TSF:MSG:GWL OK
                                    14:15:43.697 -> 748106 TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
                                    14:15:46.429 -> 750833 TSF:MSG:READ,1-1-255,s=255,c=3,t=7,pt=1,l=1,sg=0:0
                                    14:15:46.429 -> 750844 TSF:MSG:BC
                                    14:15:46.429 -> 750847 TSF:MSG:FPAR REQ,ID=1
                                    14:15:46.464 -> 750852 TSF:CKU:OK,FCTRL
                                    14:15:46.464 -> 750856 TSF:MSG:GWL OK
                                    14:15:46.733 -> 751135 TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
                                    debug in myscontroller"
                                    22-5-2020 14:33:28	INFO	BL version=259
                                    22-5-2020 14:33:28	INFO	No FW assigned
                                    22-5-2020 14:33:29	TX	1;0;3;0;13;0
                                    22-5-2020 14:33:29	INFO	FW "4ChDimmer" assigned to node 1
                                    22-5-2020 14:34:02	RX	1;255;4;0;0;0A0001005000D4460103
                                    22-5-2020 14:34:02	CHILD	New child discovered, node id=1, child id=internal
                                    22-5-2020 14:34:02	INFO	BL version=259
                                    22-5-2020 14:34:02	INFO	Send FW info to node 1: type=A, version=2, blocks=0x0800, CRC=0x8B2E
                                    22-5-2020 14:34:02	TX	1;0;4;0;1;0A00020000082E8B
                                    22-5-2020 14:34:33	RX	1;255;4;0;0;0A0001005000D4460103
                                    22-5-2020 14:34:33	INFO	BL version=259
                                    22-5-2020 14:34:33	INFO	Send FW info to node 1: type=A, version=2, blocks=0x0800, CRC=0x8B2E
                                    22-5-2020 14:34:33	TX	1;0;4;0;1;0A00020000082E8B
                                    Config file firmware:
                                    10,Blink,1,Blink.ino.hex,blinking example
                                    10,4ChDimmer,2,MS-4chDimmer-v2.hex,dimmer
                                      @tekka
                                      tekkaT
                                      tekkaT
                                      tekka
                                      #23
                                      @Joerideman That looks already much better!
                                      For the sake of completeness, here is the modified MYSBootloader source code.
                                      Try clearing the EEPROM and then re-assign the FW
                                      JoeridemanJ 1 Reply Last reply
                                      • tekkaT tekka
                                        JoeridemanJ
                                        JoeridemanJ
                                        Joerideman
                                        @tekka It's even more better once you try to upload the code without the bootloader included. I just uploaded firmware for the second time over the air!
                                        I am very excited about this :). Alltough I think one I understand changing the bootloader, I could thank you and this community perhaps with an instruction video of all the steps and possible troubleshooting.
                                        But video making is a lot of effort.
                                        Now, one more thing I think. Should it be possible to also upload code via a wired connection and OTA?
                                        Or is the workflow more like this: Normaal bootloader -> create code -> serial wired upload uart/ISP -> debugging ->serial wired upload uart/ISP -> testing -> ota bootloader -> upload final firmware over OTA -> upload occasional firmware update over OTA
                                          tekkaT
                                          tekkaT
                                          tekka
                                          @Joerideman Glad to hear you finally got FOTA working :+1: - generally speaking, you can do both, serial FW uploads and FOTA, however, switching from FOTA to serial updates or vice-versa, you may want to clear the FW checksum stored in the EEPROM as instructed above. If your sketches are rather large or for prototyping/dev, I'd advise you to use the optiboot bootloader as the serial uploads are faster and the optiboot bootloaders uses less flash storage...
