  2. Announcements
  3. đź’¬ Building a Raspberry Pi Gateway
  • Nicolás PotierN
    Nicolás PotierN
    Nicolás Potier
    hi i am trying to install an MQTT type gateway on a raspberry pi 3,
    I configured it as in the example:
    ./configure --my-gateway = mqtt --my-controller-ip-address = 127.0.0.1 --my-mqtt-publish-topic-prefix = mysensors-out --my-mqtt-subscribe-topic-prefix = mysensors-in --my-mqtt-client-id = mygateway1
    Then I do make and it does not generate errors.
    and when i run
    sudo mysgw
    returns the following result, I do not understand what it can be or what it means.
    Apr 10 15:12:21 DEBUG connected to 127.0.0.1
    Apr 10 15:12:22 DEBUG! GWT: RMQ: FAIL
    Apr 10 15:12:22 DEBUG GWT: RMQ: CONNECTING ...
    Apr 10 15:12:22 DEBUG connected to 127.0.0.1
    Apr 10 15:12:23 DEBUG! GWT: RMQ: FAIL
    Apr 10 15:12:23 DEBUG GWT: RMQ: CONNECTING ...
    Apr 10 15:12:23 DEBUG connected to 127.0.0.1
    I appreciate your time to explain this to me please, I am just starting to use Mysensors and it is incredible everything that can be generated.
    Also I want to connect it to Mycontrroller.org to manage my devices from my sensor network with only 1 Gateway, I already downloaded it in my RPI3 and it runs fine, but when I connect or create the mqtt type gateway, it asks me for the broker host and I do not know what to put there, I thought of 127.0.0.1, but after that it tells me that the State is down and an error message with the IP of 127.0.0.1 and I do not know then that I need this. Thanks again for your time to explain this to you.
    • MasMatM
      MasMatM
      MasMat
      wrote on last edited by MasMat
      #1045
      You're not being able to connect to your MQTT broker (Mosquitto or Moqutte as was in mycontroller.org). I havent used mycontroller so I cant help with that.
      I use Mosquitto on the same Rpi (so just install mosquitto and mosquitto-clients). You should secure it but test first without credentials to get going. Remember to create credentials in mosquitto AND reconfig your gw
      Nicolás PotierN 1 Reply Last reply
      • MasMatM MasMat
        Nicolás PotierN
        Nicolás PotierN
        Nicolás Potier
        @MasMat I already managed to configure my gateway it already works with Mycontroller.org, I like the interface of this, but I was thinking if the nodes of my network, which are esp8266 can be configured an operating system like FreeRTOS, TinyOS or ApacHE MyNewt can be configured in my osp and handle all Mysensors processes?
        There is a possibility or it is impossible
        MasMatM 1 Reply Last reply
        • Nicolás PotierN Nicolás Potier
          MasMatM
          MasMatM
          MasMat
          @Nicolás-Potier that's way way over my understanding and fluency with Mysensors. And way off topic, I think.
          • R
            R
            rafal9318
            Hi all,
            I want to launch gateway on RaspberryPi with a RS485 network.
            I downloaded the software (MySensors Library v2.4.0-alpha).
            And i made coniguration:
            ./configure --my-transport=rs485 --my-rs485-serial-port=/dev/ttyUSB0 --my-rs485-baudrate=9600 --my-gateway=serial --my-serial-is-pty --my-serial-port=/dev/ttyUSB20 -my-serial-baudrate=115200 -my-serial-groupname=tty
            I have USB-RS485 (it uses FT232RL) converter connected to the /dev/ttyUSB0.
            On the other side i have Arduino uno with UART-RS485 (MAX485) converter, and a MotionSensorRS485 example on it.
            After i made the program (make), and type sudo ./bin/mysgw, i've got this:
            I'm able to add the hardware in domoticz (serial gateway ttyYSB20, 115200), but it doesn't see nodes.
            Please help.
            • R rafal9318
              Hi all,
              Please help.
              #1049
              @rafal9318 please don't post the same question in multiple threads. Posting in multiple threads means the discussion is split. Important information might be available in one thread, but not the other, which means people have to ask you for that information multiple times. It is a waste of the community members' (including you) time.
              If anyone can help @rafal9318 please respond in https://forum.mysensors.org/topic/11128/raspberrypi-4-as-a-gateway-controller
              R 1 Reply Last reply
                R
                R
                rafal9318
                @mfalkvidd Okey, sorry.
                • E
                  E
                  ej3-martin
                  I’m sorry if this is a newbie question. I have managed to create a controller using MyController on a Raspberry Pi. I have connected a NRF24l01 and created a gateway, and my controller picks up that I have a gateway present, so I assume my wiring is correct.
                  I have started to wire up the status LEDs, and this is where I am confused. I am used to using LEDs on PI, but connecting between he GPIO pin and ground, where the GPIO provides the voltage. The diagram above suggests that they should be permanently connected to the voltage and the GPIO provides the ground connection. Is this correct? And if it is, is it possible to test the LEDs? Thanks in advance.
                  • E ej3-martin
                    MasMatM
                    MasMatM
                    MasMat
                    @ej3-martin My LEDs come on when the Rpi boots (is that what you mean by testing?). Also you can invert the LEDs (on but blink off) if you want. I figured the wiring makes for better power delivery rather than feeding voltage from the GPIO
                    • E
                      E
                      ej3-martin
                      @MasMat I was purely wanting to find a way of testing them, to check my wiring, if they do come on during boot then this is a great way to test. It would also possibly be useful (for those of us less experienced) to have a script to run to check the wiring is correct. I think it much more useful to have them off, and blink on, and it was the wiring that confused me. I will have to see if I can investigate this further.
                      • E ej3-martin
                        Since the pins are configurable before compilation, creating a script that uses the same settings as the compiled code would be pretty hard.
                        The easiest way with existing code is probably to add --my-leds-blinking-inverse to your configure command and start the gateway, as suggested by @MasMat
                        • F
                          F
                          Fear na Boinne
                          Just trying to figure out whether there is a switch or config file option for the channel, or whether the only option to change the channel is truly to recompile?!...
                          Just ran the Poor Man's scanner and channels 1-98 a a garbage mess, so I need to go >> 100, but am surprised the only option there seems to be a recompile?...
                          • F Fear na Boinne
                            @Fear-na-Boinne yes that is correct
                            • F
                              F
                              Fear na Boinne
                              Sorry for the lack of response, life's been crazy... Thanks for the reply, I have since recompiled, but need to make some add'l changes to the sensor sketches, so I want to do all of that at once before I deploy to the new channel... ;)
                              • F Fear na Boinne
                                #1058
                                @Fear-na-Boinne if you want to be able to switch your rpi gateway between the old and the new channel while testing, you could try my patch which allows configurable service name
                                https://github.com/mysensors/MySensors/pull/1421
                                Or just skip running make install so you don’t overwrite the old gateway
                                F 1 Reply Last reply
                                  F
                                  F
                                  Fear na Boinne
                                  @mfalkvidd Just a quick update...
                                  Been extremely busy, so not a lot of time, but when I run the recompiled version (channel 109) gateway and use the existing - known good - sensor sketches with the channel 109 macro declaration included, it doesn't connect at all.
                                  When I run the "old" version of the gateway and the same sensor sketches with channel 109 commented out, it just-works™...
                                  More testing and such due I guess! :(
                                  • H
                                    H
                                    hawtcher
                                    Is it possible to have the RPi4B, that is being used as the Webthings Gateway, also be the My Sensor controller once I add a NRF24L01+ module and follow steps above?
                                    H 1 Reply Last reply
                                    • H hawtcher
                                      H
                                      H
                                      hawtcher
                                      To clarify, I have the Mozilla Webthings Controller and I want to know if I can use the instructions above to make the same RPi4B to be the MySensors gateway. Any help would be greatly appreciated.
                                      • I
                                        I
                                        iguaan
                                        In case someone has similar issue:
                                        Running everything latest up to date.
                                        Raspberry pi zero w with nrf24 connected directly on GPIO and domoticz. Had to have startup delay on mysgw service since domoticz wouldn't or couldn't start automatically on boot.
                                        So i added to:
                                        sudo nano /etc/systemd/system/mysgw.service
                                        [Service]
                                        ExecStartPre=/bin/sleep 10
                                        Maybe 10 seconds is overkill, but at least it works now.
                                        With raspberry pi 3b+ there wasn't that issue.
                                        Also in domoticz had to use raspi ip address, when setting up mysensors LAN gateway address, instead of localhost 127.0.0.1
                                        And myscontroller OTA updates are working too.🙂
                                        • OldSurferDudeO
                                          OldSurferDudeO
                                          OldSurferDude
                                          #1063
                                          I'm new to MySensors. I'm trying to build an MQTT gateway with an nRF24 radio on my RPi 3B+. I follow the instructions here,
                                          My radio is connected with CE on physical pin 15 (GPIO22) and CSN on physical pin 24 (GPIO8) I am confident this works has I was able to run the tMRH20 examples
                                          I follow the instructions here on this web page
                                          I configured with:
                                          ./configure --my-gateway=mqtt --my-controller-ip-address=127.0.0.1 --my-mqtt-publish-topic-prefix=mysensors-out --my-mqtt-subscribe-topic-prefix=mysensors-in --my-mqtt-client-id=mygateway1 --my-transport=rf24
                                          I run make but quickly error with "missing stropts.h" for which I found a fix "sudo touch /usr/include/stropts.h". I run make again after a many warnings it stops with Error 1. The last few lines:
                                          re/Linux/drivers/core/compatibility.o build/hal/architecture/Linux/drivers/core/EthernetClient.o build/hal/architecture/Linux/drivers/core/EthernetServer.o build/hal/architecture/Linux/drivers/core/GPIO.o build/hal/architecture/Linux/drivers/core/interrupt.o build/hal/architecture/Linux/drivers/core/IPAddress.o build/hal/architecture/Linux/drivers/core/noniso.o build/hal/architecture/Linux/drivers/core/Print.o build/hal/architecture/Linux/drivers/core/SerialPort.o build/hal/architecture/Linux/drivers/core/SoftEeprom.o build/hal/architecture/Linux/drivers/core/SPIDEV.o build/hal/architecture/Linux/drivers/core/StdInOutStream.o build/hal/architecture/Linux/drivers/core/Stream.o build/examples_linux/mysgw.o build/hal/architecture/Linux/drivers/BCM/bcm2835.o build/hal/architecture/Linux/drivers/BCM/BCM.o build/hal/architecture/Linux/drivers/BCM/RPi.o build/hal/architecture/Linux/drivers/BCM/SPIBCM.o build/hal/architecture/Linux/drivers/BCM/Wire.o
                                          /usr/bin/ld: build/examples_linux/mysgw.o: in function `.LANCHOR1':
                                          /home/appian3344/MySensors/./hal/architecture/Linux/drivers/core/config.h:39: multiple definition of `conf'; build/hal/architecture/Linux/drivers/core/config.o:/home/appian3344/MySensors/hal/architecture/Linux/drivers/core/config.h:39: first defined here
                                          collect2: error: ld returned 1 exit status
                                          make: *** [Makefile:80: bin/mysgw] Error 1
                                          OK, what didn't I do right?
                                          With your input, this post could be even better đź’—
