  3. RaspberryPi 4 as a gateway/controller
4 Posts 1 Posters 963 Views 1 Watching
  • R
    R
    rafal9318
    wrote on last edited by rafal9318
    Hi All,
    I want to make my Raspberry Pi a gateway of MySensors RS485 networ and controller of home automation using Domoticz.
    Hardware i've got:
    1. Raspberry Pi 4 (2GB RAM)
    2. Converter USB <-> RS485 (it uses FTDI FR232RL chip) connected to the RPI
    3. Converter RS485 <-> UART (MAX485)
    4. Arduino Uno
    I was trying to use this tutorial: https://www.mysensors.org/build/raspberry
    But i think, i'm making something wrong.
    After i connect the USB converter to the RPI i've got this answers:
    1. ls -l /dev/tty* (images -> attachment: RPI1)
    2. ls -l /dev/serial* (images -> attachment: RPI2)
    3. ls -l /dev/serial/by-id/ (images -> attachment: RPI3)
    What parameters should i use to configure this system correctly ?
    I tried:
    ./configure --my-transport=rs485 --my-gateway=serial --my-serial-is-pty --my-serial-port=/dev/ttyUSB0 --my-serial-baudrate=115200
    And:
    ./configure --my-transport=rs485 --my-gateway=serial --my-serial-is-pty --my-serial-port=usb-FTDI_FT232R_USB_UART_A50285BI-if00-port0 --my-serial-baudrate=115200
    And what should i type in examples_linux/mysgw.cpp file (preprocessor definitions)? (images -> attachment: RPI4)
    I made (make command) both configurations, and i've got the same ./bin/mysgw logs messages. (images -> attachment: RPI5)
    To the RS485 network, i connected RS485 node example (MotionSensorRS485)
    And at the end, how to cofigure domoticz hardware, when i want to use raspberry pi gateway?
    R 1 Reply Last reply
    • R rafal9318
      Hi All,
      Hardware i've got:
      4. Arduino Uno
      I tried:
      And:
      R
      R
      rafal9318
      Okey, i know more.
      So, I programmed Arduino using MotionSensorRS485 example.
      And using monitor COM tool, i see this in arduino logs:
      And by using this command:
      ./configure --my-gateway=serial --my-serial-is-pty --my-serial-port=/dev/ttyUSB020
      im saying RaspberryPi to create the gateway that commucnicates with controller using virtual serial port (/dev/ttyUSB020),
      and i think that by editing file examples_linux/mygw.cpp i'm choosing serial port for RS485 network (sensors network).
      After i add the hardware to the domoticz controller, i've got this:
      but still node is unknown.
      Please help.
      • R
        R
        rafal9318
        I checked the frames. And when i coneccted USB-RS485 to the computer i've got this in Realterm:
        And next in python script on Raspbeery Pi i've got this:
        So, i think the communication beetwen Raspberry Pi and Arduino is working (through USB-RS485 converter).
        How should looks the frame of presentation, and sendSketchInfo ?
        • R
          R
          rafal9318
          I bought second arduino uno.
          And, first Arduino has example MotionSensorRS485,
          second Arduino has example GetwaySerialRS485.
          And i have got the same situation. So even Gateway on Arduino doesn't see MotionSensor.
          Next test i made, i disconnected MAX485 converters, and i connected UART pins from first arduino to the second one (UART = Rx(8) <-> Tx(9), Tx(9)<->Rx(8)) and GND. And i have got the same result. Gateway doesn't see sensor.
