  2. Announcements
  • Nicolás PotierN Nicolás Potier
    @MasMat I already managed to configure my gateway it already works with Mycontroller.org, I like the interface of this, but I was thinking if the nodes of my network, which are esp8266 can be configured an operating system like FreeRTOS, TinyOS or ApacHE MyNewt can be configured in my osp and handle all Mysensors processes?
    There is a possibility or it is impossible
    MasMatM
    MasMatM
    MasMat
    @Nicolás-Potier that's way way over my understanding and fluency with Mysensors. And way off topic, I think.
    • R
      R
      rafal9318
      Hi all,
      I want to launch gateway on RaspberryPi with a RS485 network.
      I downloaded the software (MySensors Library v2.4.0-alpha).
      And i made coniguration:
      ./configure --my-transport=rs485 --my-rs485-serial-port=/dev/ttyUSB0 --my-rs485-baudrate=9600 --my-gateway=serial --my-serial-is-pty --my-serial-port=/dev/ttyUSB20 -my-serial-baudrate=115200 -my-serial-groupname=tty
      I have USB-RS485 (it uses FT232RL) converter connected to the /dev/ttyUSB0.
      On the other side i have Arduino uno with UART-RS485 (MAX485) converter, and a MotionSensorRS485 example on it.
      After i made the program (make), and type sudo ./bin/mysgw, i've got this:
      I'm able to add the hardware in domoticz (serial gateway ttyYSB20, 115200), but it doesn't see nodes.
      Please help.
      • R rafal9318
        Hi all,
        Please help.
        #1049
        @rafal9318 please don't post the same question in multiple threads. Posting in multiple threads means the discussion is split. Important information might be available in one thread, but not the other, which means people have to ask you for that information multiple times. It is a waste of the community members' (including you) time.
        If anyone can help @rafal9318 please respond in https://forum.mysensors.org/topic/11128/raspberrypi-4-as-a-gateway-controller
        R 1 Reply Last reply
          R
          R
          rafal9318
          @mfalkvidd Okey, sorry.
          • E
            E
            ej3-martin
            I’m sorry if this is a newbie question. I have managed to create a controller using MyController on a Raspberry Pi. I have connected a NRF24l01 and created a gateway, and my controller picks up that I have a gateway present, so I assume my wiring is correct.
            I have started to wire up the status LEDs, and this is where I am confused. I am used to using LEDs on PI, but connecting between he GPIO pin and ground, where the GPIO provides the voltage. The diagram above suggests that they should be permanently connected to the voltage and the GPIO provides the ground connection. Is this correct? And if it is, is it possible to test the LEDs? Thanks in advance.
            MasMatM 1 Reply Last reply
            • E ej3-martin
              MasMatM
              MasMatM
              MasMat
              @ej3-martin My LEDs come on when the Rpi boots (is that what you mean by testing?). Also you can invert the LEDs (on but blink off) if you want. I figured the wiring makes for better power delivery rather than feeding voltage from the GPIO
              • E
                E
                ej3-martin
                @MasMat I was purely wanting to find a way of testing them, to check my wiring, if they do come on during boot then this is a great way to test. It would also possibly be useful (for those of us less experienced) to have a script to run to check the wiring is correct. I think it much more useful to have them off, and blink on, and it was the wiring that confused me. I will have to see if I can investigate this further.
                • E ej3-martin
                  Since the pins are configurable before compilation, creating a script that uses the same settings as the compiled code would be pretty hard.
                  The easiest way with existing code is probably to add --my-leds-blinking-inverse to your configure command and start the gateway, as suggested by @MasMat
                  • F
                    F
                    Fear na Boinne
                    Just trying to figure out whether there is a switch or config file option for the channel, or whether the only option to change the channel is truly to recompile?!...
                    Just ran the Poor Man's scanner and channels 1-98 a a garbage mess, so I need to go >> 100, but am surprised the only option there seems to be a recompile?...
                    • F Fear na Boinne
                      @Fear-na-Boinne yes that is correct
                      • F
                        F
                        Fear na Boinne
                        Sorry for the lack of response, life's been crazy... Thanks for the reply, I have since recompiled, but need to make some add'l changes to the sensor sketches, so I want to do all of that at once before I deploy to the new channel... ;)
                        • F Fear na Boinne
                          #1058
                          @Fear-na-Boinne if you want to be able to switch your rpi gateway between the old and the new channel while testing, you could try my patch which allows configurable service name
                          https://github.com/mysensors/MySensors/pull/1421
                          Or just skip running make install so you don’t overwrite the old gateway
                          F 1 Reply Last reply
                            F
                            F
                            Fear na Boinne
                            @mfalkvidd Just a quick update...
                            Been extremely busy, so not a lot of time, but when I run the recompiled version (channel 109) gateway and use the existing - known good - sensor sketches with the channel 109 macro declaration included, it doesn't connect at all.
                            When I run the "old" version of the gateway and the same sensor sketches with channel 109 commented out, it just-worksâ„¢...
                            More testing and such due I guess! :(
                            • H
                              H
                              hawtcher
                              Is it possible to have the RPi4B, that is being used as the Webthings Gateway, also be the My Sensor controller once I add a NRF24L01+ module and follow steps above?
                              H 1 Reply Last reply
                              • H hawtcher
                                H
                                H
                                hawtcher
                                To clarify, I have the Mozilla Webthings Controller and I want to know if I can use the instructions above to make the same RPi4B to be the MySensors gateway. Any help would be greatly appreciated.
                                • I
                                  I
                                  iguaan
                                  In case someone has similar issue:
                                  Running everything latest up to date.
                                  Raspberry pi zero w with nrf24 connected directly on GPIO and domoticz. Had to have startup delay on mysgw service since domoticz wouldn't or couldn't start automatically on boot.
                                  So i added to:
                                  sudo nano /etc/systemd/system/mysgw.service
                                  [Service]
                                  ExecStartPre=/bin/sleep 10
                                  Maybe 10 seconds is overkill, but at least it works now.
                                  With raspberry pi 3b+ there wasn't that issue.
                                  Also in domoticz had to use raspi ip address, when setting up mysensors LAN gateway address, instead of localhost 127.0.0.1
                                  And myscontroller OTA updates are working too.🙂
                                  • OldSurferDudeO
                                    OldSurferDudeO
                                    OldSurferDude
                                    #1063
                                    I'm new to MySensors. I'm trying to build an MQTT gateway with an nRF24 radio on my RPi 3B+. I follow the instructions here,
                                    My radio is connected with CE on physical pin 15 (GPIO22) and CSN on physical pin 24 (GPIO8) I am confident this works has I was able to run the tMRH20 examples
                                    I follow the instructions here on this web page
                                    I configured with:
                                    ./configure --my-gateway=mqtt --my-controller-ip-address=127.0.0.1 --my-mqtt-publish-topic-prefix=mysensors-out --my-mqtt-subscribe-topic-prefix=mysensors-in --my-mqtt-client-id=mygateway1 --my-transport=rf24
                                    I run make but quickly error with "missing stropts.h" for which I found a fix "sudo touch /usr/include/stropts.h". I run make again after a many warnings it stops with Error 1. The last few lines:
                                    re/Linux/drivers/core/compatibility.o build/hal/architecture/Linux/drivers/core/EthernetClient.o build/hal/architecture/Linux/drivers/core/EthernetServer.o build/hal/architecture/Linux/drivers/core/GPIO.o build/hal/architecture/Linux/drivers/core/interrupt.o build/hal/architecture/Linux/drivers/core/IPAddress.o build/hal/architecture/Linux/drivers/core/noniso.o build/hal/architecture/Linux/drivers/core/Print.o build/hal/architecture/Linux/drivers/core/SerialPort.o build/hal/architecture/Linux/drivers/core/SoftEeprom.o build/hal/architecture/Linux/drivers/core/SPIDEV.o build/hal/architecture/Linux/drivers/core/StdInOutStream.o build/hal/architecture/Linux/drivers/core/Stream.o build/examples_linux/mysgw.o build/hal/architecture/Linux/drivers/BCM/bcm2835.o build/hal/architecture/Linux/drivers/BCM/BCM.o build/hal/architecture/Linux/drivers/BCM/RPi.o build/hal/architecture/Linux/drivers/BCM/SPIBCM.o build/hal/architecture/Linux/drivers/BCM/Wire.o
                                    /usr/bin/ld: build/examples_linux/mysgw.o: in function `.LANCHOR1':
                                    /home/appian3344/MySensors/./hal/architecture/Linux/drivers/core/config.h:39: multiple definition of `conf'; build/hal/architecture/Linux/drivers/core/config.o:/home/appian3344/MySensors/hal/architecture/Linux/drivers/core/config.h:39: first defined here
                                    collect2: error: ld returned 1 exit status
                                    make: *** [Makefile:80: bin/mysgw] Error 1
                                    OK, what didn't I do right?
                                      I configured with:
                                      @OldSurferDude loos like it could be the same problem as https://github.com/mysensors/MySensors/pull/1454
                                      In that case, applying the suggested fix manually, or using the development branch (where the fix is already included) should work.
                                      OldSurferDudeO 1 Reply Last reply
                                        OldSurferDudeO
                                        OldSurferDudeO
                                        OldSurferDude
                                        @mfalkvidd I implemented your suggestion of running the development branch. This didn't work for a different reason. Below my questions is what I did.
                                        Questions:
                                        o Is the gateway trying to connect to a controller such as Home Assistant (HA)?
                                        o The IP address of 127.0.0.1 implies the controller is on the same machine. Would the gateway connect to a docker containerized HA?
                                        o What example programs will connect to the RF24 radio side of the gateway? We could start off with a simple ONoff switch and progress to that node controlling a relay on another node. (passing the request through an MQTT broker?)
                                        o Note that I made the assumption that the gateway doesn't distinguish between wired ethernet or WiFi. Is that a good assumption?
                                        Hardware RPi 3B+, nRF24 wired with CE to physical pin 15
                                        OS: Raspbian GNU/Linux 11 (bullseye)
                                        It is assumed that deleting the MySensors folder will uninstall the existing master branch. (probably a bad assumption)
                                        1. sudo rm -r MySensors
                                        2. git clone https://github.com/mysensors/MySensors.git --branch development
                                        3. cd MySensors
                                        4. ./configure --my-gateway=mqtt --my-controller-ip-address=127.0.0.1 --my-mqtt-publish-topic-prefix=mysensors-out --my-mqtt-subscribe-topic-prefix=mysensors-in --my-mqtt-client-id=mygateway1 --my-transport=rf24
                                          note: It is stated that the default configuration is ethernet port 5003 (./configure --my-gateway=ethernet --my-port=5003)
                                          It is assumed that the software doesn't distinguish between ethernet and WiFi
                                        5. make
                                          many compiler warnings
                                        6. Start gateway with
                                          sudo ./bin/mysgw
                                          which results in:
                                          Apr 04 12:12:37 INFO Config file /etc/mysensors.conf does not exist, creating new file.
                                          Apr 04 12:12:37 INFO Starting gateway...
                                          Apr 04 12:12:37 INFO Protocol version - 2.4.0-alpha
                                          Apr 04 12:12:37 INFO EEPROM file /etc/mysensors.eeprom does not exist, creating new file.
                                          Apr 04 12:12:37 DEBUG MCO:BGN:INIT GW,CP=RNNGL---,FQ=NA,REL=0,VER=2.4.0-alpha
                                          Apr 04 12:12:37 DEBUG TSF:LRT:OK
                                          Apr 04 12:12:37 DEBUG TSM:INIT
                                          Apr 04 12:12:37 DEBUG TSF:WUR:MS=0
                                          Apr 04 12:12:37 DEBUG TSM:INIT:TSP OK
                                          Apr 04 12:12:37 DEBUG TSM:INIT:GW MODE
                                          Apr 04 12:12:37 DEBUG TSM:READY:ID=0,PAR=0,DIS=0
                                          Apr 04 12:12:37 DEBUG MCO:REG:NOT NEEDED
                                          Apr 04 12:12:37 DEBUG MCO:BGN:STP
                                          Apr 04 12:12:37 DEBUG MCO:BGN:INIT OK,TSP=1
                                          followed by repeating:
                                          Apr 04 12:12:37 DEBUG GWT:RMQ:CONNECTING...
                                          Apr 04 12:12:37 ERROR connect: Connection refused
                                          Apr 04 12:12:37 ERROR failed to connect
                                          Apr 04 12:12:38 DEBUG !GWT:RMQ:FAIL
                                          Apr 04 12:12:38 DEBUG TSM:READY:NWD REQ
                                          Apr 04 12:12:40 DEBUG ?TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=20,pt=0,l=0,sg=0,ft=0,st=OK:
                                        Assumed that it failed to connect to an MQTT broker and the my-controller-ip-address is a broker address
                                        Changed the --my-controller-ip-address to that of my MQTT broker (It is assumed that the default MQTT port is used)
                                        repeat step 4. with the change and step 5. and 6.
                                        no joy same output
                                        Restarted with step 1 with changes
                                        no joy same output
                                        E 1 Reply Last reply
                                        • mfalkviddM
                                          @OldSurferDude said in 💬 Building a Raspberry Pi Gateway:
                                          Yes, a controller or a mqtt broker.
                                          I think it depends on how the docker is set up, but I don't have enough knowledge about docker to say for sure.
                                          You could build any of the nodes on the build page, or use https://github.com/mysensors/MySensors/tree/development/examples/MockMySensors or just create a local sensor on the gateway (if you don't need to test the nrf24 communication).
                                          In the case of the Raspberry Pi gateway yes. It will use the Pi's networking, regardless of type.
