  3. RF 433 MHz sensor to control RF sockets.
22 Posts 10 Posters 18.9k Views 4 Watching
  • L lasso
    Hek, thank for your response. I have to send two information to node (and from node): RF433 code and period. I would like to avoid sending this information in two messages (e.g. as V_VAR1 and V_VAR2), so I joined this informations in one by using class String. Maybe do You have idea how to avoid String class in this program?
    @lasso
    atoi, strcpy, itoa
    L 1 Reply Last reply
      @lasso
      atoi, strcpy, itoa
      L
      L
      lasso
      wrote on last edited by lasso
      OK, I stopped using String Class, but program works in the same way.On start Arduino, program works well and I can get and send RF433 codes. After some pushes a button on RF433 remote, LED on Arduino (pin 13) turns off and then I can't send messages from gateway to node, but I can still get codes of buttons on gateway from node. I think that, maybe this problem is connected with interrupts because NRF24 and receiver RF433 modules are using interrupts. IRQ pin from NRF24 module is connected to pin 2 (int.0) in Arduino Pro Mini and data pin from receiver RF433 module is connected to pin 3 (int.1) in Arduino.
      @hek Do You have any idea why this program doesn't work properly?
          #include <Relay.h>
          #include <EEPROM.h>
          #include <RF24.h>
          #include <RemoteReceiver.h>
          #include <RemoteTransmitter.h>
          #define TRANSMITTER_PIN 8
          #define RECEIVER_INTERRUPT 1
          #define RF433_CHILD_ID 0
          Sensor gw;
            gw.begin(28);
            gw.sendSketchInfo("RF433", "1.0");
            gw.sendSensorPresentation(RF433_CHILD_ID, S_IR);
            RemoteReceiver::init(RECEIVER_INTERRUPT, 3, getRfMessage);
            if (gw.messageAvailable()) {
              message_s message = gw.getMessage();
              sendRfMessage(message);
          void sendRfMessage(message_s message) {
            if (message.header.messageType==M_SET_VARIABLE &&
                message.header.type==V_IR_SEND) {
               char sendingRfCode[7];
               char sendingRfPeriod[4];
               strncpy(sendingRfCode, message.data, 6);
               strncpy(sendingRfPeriod, message.data+6, 3);
               sendingRfCode[6] = 0;
               sendingRfPeriod[3] = 0;
               Serial.println(atol(sendingRfCode));
               Serial.println(atol(sendingRfPeriod));
               RemoteReceiver::disable();
               interrupts();
               delay(200);
               RemoteTransmitter::sendCode(TRANSMITTER_PIN, atol(sendingRfCode), atol(sendingRfPeriod), 3);
               RemoteReceiver::enable();
          void getRfMessage(unsigned long incomingRfCode, unsigned int incomingRfPeriod){
            char gettingRfMessage[10];
            sprintf(gettingRfMessage, "%lu%u", incomingRfCode, incomingRfPeriod);
            Serial.println(incomingRfCode);
            Serial.println(incomingRfPeriod);
            Serial.println(gettingRfMessage);
            gw.sendVariable(RF433_CHILD_ID, V_IR_RECEIVE, gettingRfMessage);
            delay(200);
        wrote on last edited by hek
        yup, in the example you attach it to INT1 (=GPIO pin 3).
        You can safely detach IRQ pin from radio if you want. It is not used for anything right now.
        Or change RECEIVER_INTERRUPT to 0 and attach receiver to GPIO pin 2.
        • L
          L
          lasso
          @hek
          I detached IRQ pin from pin 2 in Arduino and attached to pin 2 data line from RF433 receiver. After that, I changed RECEIVER_INTERRUPT to 0. Program works in the same way. The problem has not been solved.
            If I understand the RemoteReceiver code correctly your callback will be called in an interrupt. This means you should do as little as possible there. Definetly not serial print or send any data over radio.
            I propose you just save the incoming values and a new flag like this:
            setup() {
                RemoteReceiver::init(RECEIVER_INTERRUPT, 3, newRf);
            volatile bool receivedNew = false;
            volatile unsigned long incomingRfCode;
            volatile unsigned int incomingRfPeriod;
            void newRf(unsigned long _incomingRfCode, unsigned int _incomingRfPeriod){
                 incomingRfCode = _incomingRfCode;
                 incomingRfPeriod = _incomingRfPeriod;
                 receivedNew=true;
            And in you main loop check if received new is true.
            loop() {
                 if(receivedNew) {
                     getRfMessage(incomingRfCode, incomingRfPeriod);
            Note this is not tested and should just give you an hint how to handle it without doing lots of stuff when executing inside an interrupt.
            • L
              L
              lasso
              @hek
              Wow it's working :+1:. Hek thank you very much, you are the master :D
              This is working code:
              #include <Relay.h>
              #include <EEPROM.h>
              #include <RF24.h>
                  Sensor gw;
                    gw.begin(28);
                     delay(200);
                    if(receivedNew) {
                       interrupts();
                       delay(200);
                       receivedNew=true;
              S 1 Reply Last reply
              • D
                donnib
                @lasso Are you learning the codes with the receiver inorder to know what to send to them ? I would really like to react on my 433mhz sensors i have for doors and i am interested how to do that and i found your post and i am trying to figure out if i could use some of this code for that purpose, what's your take on that ?
                • D
                  dayve218
                  any idea about this?
                  variable or field 'sendRfMessage' declared void
                  • D
                    dayve218
                    wrote on last edited by dayve218
                    @lasso @hek
                    • T
                      Terence Faul
                      Did you ever get this working?
                      What pins did you attache the transmitter to and what pin did you attach the receiver to?
                      Is that the latest code?
                      • G
                        G
                        gebir
                        this is my version "Home Easy Plug-in switch (HE877)". scatch.
                        Arduino emulates remote control Elro AB440
                        AVI, thanks for the inspiration.
                        https://codebender.cc/sketch:92208
                        • L lasso
                          @hek
                          #include <Relay.h>
                          #include <EEPROM.h>
                          #include <RF24.h>
                              Sensor gw;
                                gw.begin(28);
                                 delay(200);
                                if(receivedNew) {
                                   interrupts();
                                   delay(200);
                                   receivedNew=true;
                          Straydog
                          @lasso Like to try your RF 433 Mhz Sensor sketch but can't find a working instance od Relay.h.
                          Can you help?
                          • C
                            C
                            cdr
                            "can't find a working instance od Relay.h."
                            Having the same issue here, perhaps it's for version 1.3 of mysensors?
                            hekH 1 Reply Last reply
                            • C cdr
                              @cdr
                              Yes, 1.3 had a Realy-class.
                              • alowhumA
                                alowhumA
                                alowhum
                                #22
                                Does anyone have a working version of this for 2.x?
