  3. Gateway Uno R3 + W5100 Ethernet Shield for Uno not working.
34 Posts 3 Posters 2.4k Views 3 Watching
  • pw44P Offline
    pw44P Offline
    pw44
    Hya,
    My network:
    192.168.80.1 -> 0.0.0.0 (gateway)
    192.168.80.4 (dns, dhcp)
    192.168.80.20 -> mysensors gateway
    not plugged the radio yet.
    after assembling the pack Uno R3 + W5100 Ethernet Shield for Uno, i flashed the following sketch:
    #define MY_RADIO_RF24
    //#define MY_RADIO_NRF5_ESB
    //#define MY_RADIO_RFM95
    #define MY_GATEWAY_W5100
    #define MY_W5100_SPI_EN 4
    // radio on the same spi bus.
    #define MY_SOFTSPI
    #ifndef MY_RF24_CE_PIN
    #define MY_RF24_CE_PIN 5
    #ifndef MY_RF24_CS_PIN
    #define MY_RF24_CS_PIN 6
    // Enable UDP communication
    //#define MY_USE_UDP  // If using UDP you need to set MY_CONTROLLER_IP_ADDRESS or MY_CONTROLLER_URL_ADDRESS below
    #define MY_IP_ADDRESS 192,168,80,20
    #define MY_IP_GATEWAY_ADDRESS 192,168,80,4
    #define MY_PORT 5003
    //#define MY_CONTROLLER_URL_ADDRESS "my.controller.org"
    // Note that most of the Arduino examples use  "DEAD BEEF FEED" for the MAC address.
    #define MY_MAC_ADDRESS 0x00, 0x40, 0xFD, 0xEF, 0x35, 0x75
    // Enable inclusion mode
    // Set blinking period
    // Flash leds on rx/tx/err
    #define MY_DEFAULT_ERR_LED_PIN 7  // Error led pin
    #define MY_DEFAULT_RX_LED_PIN  8  // Receive led pin
    #define MY_DEFAULT_TX_LED_PIN  9  // Transmit led pin
    #if defined(MY_USE_UDP)
    #include <EthernetUdp.h>
    #include <Ethernet.h>
    Upload to Uno R3 was successful, and plunging to the ethernet switch, only green led on the RJ45 lights, arp does not shows the mac address defined and ip defined does not pings.
    May i ask for help in order to solve?
    Thx in advance.
    • pw44P pw44
      Hya,
      My network:
      #define MY_SOFTSPI
      Thx in advance.
      Welcome to the forum @pw44
      If you don't want to connect the radio, you'll need to disable the use of the radio like this:
      //#define MY_RADIO_RF24
      Otherwise, MySensors will be unable to initialize the radio and will therefore not proceed.
      The debug log will give you more details. If you haven't already, see https://forum.mysensors.org/topic/666/read-this-first-it-could-save-you-a-lot-of-time/ for the most common problems and how to troubleshoot them.
      pw44P 1 Reply Last reply
        pw44P Offline
        pw44P Offline
        pw44
        @mfalkvidd
        Thank you for answering, and helping to solve. Having the radio module plugged, it worked.
        How to define it as a dhcp client instead of setting a fixed ip address, having only the mac address defined?
        Thx in advance!
        • pw44P pw44
          @mfalkvidd
          Thx in advance!
          @pw44 comment out this part
            pw44P Offline
            pw44P Offline
            pw44
            @mfalkvidd
            Thx, man!
            and to set the hostname? tried MY_HOSTNAME "MySensorsGW" , but no luck :-(
            • pw44P pw44
              @mfalkvidd
              Thx, man!
              @pw44 what type of hostname are you referring to?
              • mfalkviddM Offline
                To expand, there are two types of hostnames often used: a mDNS hostname and a hostname option in the DHCP request.
                The reason MY_HOSTNAME doesn't have any effect is that MY_HOSTNAME is only supported by ESP8266 and ESP32. I'll amend the documentation to include that information.
                Some additional info: https://forum.arduino.cc/index.php?topic=622543.0
                  pw44P Offline
                  pw44P Offline
                  pw44
                  @mfalkvidd , thank you.
                  no problem, host name can be assined by dhcp.
                  problem is that commenting out the ip address, letting dhcp take care produces:
                  $ arp
                  Address HWtype HWaddress Flags Mask Iface
                  192.168.80.115 (incomplete) enp2s0
                  @mfalkvidd said in Gateway Uno R3 + W5100 Ethernet Shield for Uno not working.:
                  hostname to identify itself
                  got it.
                  • pw44P pw44
                    $ arp
                    got it.
                    @pw44 which machine are you running the arp command on? The router?
                    Is 192.168.80.115 the IP the router assigned to the MySensors gateway?
                      Pull request for documentation update: https://github.com/mysensors/MySensors/pull/1428
                      Updated documentation: https://ci.mysensors.org/job/MySensors/job/MySensors/job/PR-1428/3/execution/node/4/ws/MySensors/Documentation/html/group__GatewaySettingGrpPub.html#gabdbabf2e3d82fb5c9aa24caecb23a8af
                        pw44P Offline
                        pw44P Offline
                        pw44
                        my server (dnsmasq, dhcp server) - 192.168.80.4
                        adsl + router - 192.168.80.1
                        mysensor gateway - 192.168.80.115 assigned by 192.168.80.4 (dhcp server)
                        with fixed ip address it worked, but i guess maybe udp is not active at mysensors gateway.
                        • pw44P pw44
                          @pw44 the dhcp communication uses udp of course, but after that the MySensors gateway will use tcp unless MY_USE_UDP is defined.
                          The gateway doesn't respond to icmp ping?
                          Next step would be to check the gateway's debug log.
                            pw44P Offline
                            pw44P Offline
                            pw44
                            if MY_USER_UDP is commented out, i understand that no UPD is enabled from start, correct?
                            enabling MY_USER_UDP requires #define MY_CONTROLLER_IP_ADDRESS 192, 168, 178, 254
                            and #define MY_CONTROLLER_URL_ADDRESS "my.controller.org"
                            by enabling fixed ip, none of both is required, which is something not very clear for me.
                            • pw44P pw44
                              @pw44 which controller are you using? Why do you want to use udp for the connection to the controller?
                                pw44P Offline
                                pw44P Offline
                                pw44
                                @mfalkvidd
                                no controller yet. i need to make the gateway at least be recognized by the network, either way.
                                udp, for dhcp.
                                • pw44P pw44
                                  @mfalkvidd
                                  udp, for dhcp.
                                  @pw44 yes the MySensors gateway will of course use udp for dhcp. You don't need to do anything special to enable udp for dhcp.
                                  • pw44P Offline
                                    pw44P Offline
                                    pw44
                                    nothing is working :-(
                                    #define MY_SOFTSPI
                                    //#define MY_IP_ADDRESS 192,168,80,15
                                    //#define MY_IP_GATEWAY_ADDRESS 192,168,80,1
                                    serial monitor output:
                                    30055 TSM:FAIL:RE-INIT
                                    30057 TSM:INIT
                                    30063 !TSM:INIT:TSP FAIL
                                    30065 TSM:FAIL:CNT=4
                                    30067 TSM:FAIL:DIS
                                    30069 TSF:TDI:TSL
                                    0 MCO:BGN:INIT GW,CP=RNNGA---,FQ=16,REL=255,VER=2.3.2
                                    4 TSM:INIT
                                    5 TSF:WUR:MS=0
                                    11 !TSM:INIT:TSP FAIL
                                    13 TSM:FAIL:CNT=1
                                    15 TSM:FAIL:DIS
                                    16 TSF:TDI:TSL
                                    10019 TSM:FAIL:RE-INIT
                                    10021 TSM:INIT
                                    10028 !TSM:INIT:TSP FAIL
                                    10030 TSM:FAIL:CNT=2
                                    10032 TSM:FAIL:DIS
                                    10034 TSF:TDI:TSL
                                    20037 TSM:FAIL:RE-INIT
                                    20039 TSM:INIT
                                    20045 !TSM:INIT:TSP FAIL
                                    20047 TSM:FAIL:CNT=3
                                    20049 TSM:FAIL:DIS
                                    20051 TSF:TDI:TSL
                                    30057 TSM:INIT
                                    30067 TSM:FAIL:DIS
                                    30069 TSF:TDI:TSL
                                    40072 TSM:FAIL:RE-INIT
                                    40074 TSM:INIT
                                    40080 !TSM:INIT:TSP FAIL
                                    40082 TSM:FAIL:CNT=5
                                    40084 TSM:FAIL:DIS
                                    40086 TSF:TDI:TSL
                                    50089 TSM:FAIL:RE-INIT
                                    50092 TSM:INIT
                                    50098 !TSM:INIT:TSP FAIL
                                    50100 TSM:FAIL:CNT=6
                                    50102 TSM:FAIL:DIS
                                    50104 TSF:TDI:TSL
                                    60107 TSM:FAIL:RE-INIT
                                    60109 TSM:INIT
                                    60115 !TSM:INIT:TSP FAIL
                                    60118 TSM:FAIL:CNT=7
                                    60120 TSM:FAIL:DIS
                                    60122 TSF:TDI:TSL
                                    120125 TSM:FAIL:RE-INIT
                                    120127 TSM:INIT
                                    120133 !TSM:INIT:TSP FAIL
                                    120136 TSM:FAIL:CNT=7
                                    120138 TSM:FAIL:DIS
                                    120139 TSF:TDI:TSL
                                    180142 TSM:FAIL:RE-INIT
                                    180144 TSM:INIT
                                    180150 !TSM:INIT:TSP FAIL
                                    180153 TSM:FAIL:CNT=7
                                    180155 TSM:FAIL:DIS
                                    180156 TSF:TDI:TSL
                                    4 TSM:INIT
                                    5 TSF:WUR:MS=0
                                    13 TSM:FAIL:CNT=1
                                    15 TSM:FAIL:DIS
                                    16 TSF:TDI:TSL
                                    10021 TSM:INIT
                                    10032 TSM:FAIL:DIS
                                    10034 TSF:TDI:TSL
                                    20039 TSM:INIT
                                    20049 TSM:FAIL:DIS
                                    20051 TSF:TDI:TSL
                                    30057 TSM:INIT
                                    30067 TSM:FAIL:DIS
                                    30069 TSF:TDI:TSL
                                    there must be something i'm not being able to figure out....
                                    dhcp served by dnsmasq. all other devices work without problem.
                                    • pw44P pw44
                                      #define MY_SOFTSPI
                                      30057 TSM:INIT
                                      30067 TSM:FAIL:DIS
                                      30069 TSF:TDI:TSL
                                      4 TSM:INIT
                                      5 TSF:WUR:MS=0
                                      13 TSM:FAIL:CNT=1
                                      15 TSM:FAIL:DIS
                                      16 TSF:TDI:TSL
                                      10021 TSM:INIT
                                      10032 TSM:FAIL:DIS
                                      10034 TSF:TDI:TSL
                                      20039 TSM:INIT
                                      20049 TSM:FAIL:DIS
                                      20051 TSF:TDI:TSL
                                      30057 TSM:INIT
                                      30067 TSM:FAIL:DIS
                                      30069 TSF:TDI:TSL
                                      40074 TSM:INIT
                                      40084 TSM:FAIL:DIS
                                      40086 TSF:TDI:TSL
                                      50092 TSM:INIT
                                      50102 TSM:FAIL:DIS
                                      50104 TSF:TDI:TSL
                                      60109 TSM:INIT
                                      60120 TSM:FAIL:DIS
                                      60122 TSF:TDI:TSL
                                      120127 TSM:INIT
                                      120138 TSM:FAIL:DIS
                                      120139 TSF:TDI:TSL
                                      180144 TSM:INIT
                                      180155 TSM:FAIL:DIS
                                      180156 TSF:TDI:TSL
                                      4 TSM:INIT
                                      5 TSF:WUR:MS=0
                                      13 TSM:FAIL:CNT=1
                                      15 TSM:FAIL:DIS
                                      16 TSF:TDI:TSL
                                      10021 TSM:INIT
                                      10032 TSM:FAIL:DIS
                                      10034 TSF:TDI:TSL
                                      20039 TSM:INIT
                                      20049 TSM:FAIL:DIS
                                      20051 TSF:TDI:TSL
                                      30057 TSM:INIT
                                      30067 TSM:FAIL:DIS
                                      30069 TSF:TDI:TSL
                                      @pw44 the log shows that the gateway is unable to initialize the nrf24 radio module. This prevents the gateway code from reaching the dhcp section.
                                      Double-check the nrf24 wiring. If you can, replace the radio module. If that doesn't help, post detailed photos of the wiring and we'll try to spot what could be wrong.
                                        Also, are you sure the w5100 shield you are using is capable of managing the SPI_EN signal?
                                        • pw44P Offline
                                          pw44P Offline
                                          pw44
                                          these are the real photos of the setup.
                                          wire codes are the same as the build instructions ;-)
                                          managing the SPI_EN signal? tried with and without, no changes.
                                          IMG_6520.JPG IMG_6521.JPG IMG_6522.JPG IMG_6523.JPG IMG_6524.JPG IMG_6525.JPG IMG_6526.JPG
                                          Y 1 Reply Last reply
                                          12.1k
