  3. Gateway Uno R3 + W5100 Ethernet Shield for Uno not working.
34 Posts 3 Posters 3.0k Views 3 Watching
  • mfalkviddM
    Pull request for documentation update: https://github.com/mysensors/MySensors/pull/1428
    Updated documentation: https://ci.mysensors.org/job/MySensors/job/MySensors/job/PR-1428/3/execution/node/4/ws/MySensors/Documentation/html/group__GatewaySettingGrpPub.html#gabdbabf2e3d82fb5c9aa24caecb23a8af
      @pw44 which machine are you running the arp command on? The router?
      Is 192.168.80.115 the IP the router assigned to the MySensors gateway?
      pw44P
      pw44P
      pw44
      @mfalkvidd said in Gateway Uno R3 + W5100 Ethernet Shield for Uno not working.:
      my server (dnsmasq, dhcp server) - 192.168.80.4
      adsl + router - 192.168.80.1
      mysensor gateway - 192.168.80.115 assigned by 192.168.80.4 (dhcp server)
      with fixed ip address it worked, but i guess maybe udp is not active at mysensors gateway.
      • pw44P pw44
        @pw44 the dhcp communication uses udp of course, but after that the MySensors gateway will use tcp unless MY_USE_UDP is defined.
        The gateway doesn't respond to icmp ping?
        Next step would be to check the gateway's debug log.
        pw44P 1 Reply Last reply
          pw44P
          pw44P
          pw44
          if MY_USER_UDP is commented out, i understand that no UPD is enabled from start, correct?
          enabling MY_USER_UDP requires #define MY_CONTROLLER_IP_ADDRESS 192, 168, 178, 254
          and #define MY_CONTROLLER_URL_ADDRESS "my.controller.org"
          by enabling fixed ip, none of both is required, which is something not very clear for me.
          • pw44P pw44
            @pw44 which controller are you using? Why do you want to use udp for the connection to the controller?
              pw44P
              pw44P
              pw44
              @mfalkvidd
              no controller yet. i need to make the gateway at least be recognized by the network, either way.
              udp, for dhcp.
              • pw44P pw44
                @mfalkvidd
                udp, for dhcp.
                @pw44 yes the MySensors gateway will of course use udp for dhcp. You don't need to do anything special to enable udp for dhcp.
                • pw44P
                  pw44P
                  pw44
                  nothing is working :-(
                  #define MY_RADIO_RF24
                  //#define MY_RADIO_NRF5_ESB
                  //#define MY_RADIO_RFM95
                  #define MY_GATEWAY_W5100
                  #define MY_W5100_SPI_EN 4
                  // radio on the same spi bus.
                  #define MY_SOFTSPI
                  #ifndef MY_RF24_CE_PIN
                  #define MY_RF24_CE_PIN 5
                  #ifndef MY_RF24_CS_PIN
                  #define MY_RF24_CS_PIN 6
                  // Enable UDP communication
                  //#define MY_USE_UDP  // If using UDP you need to set MY_CONTROLLER_IP_ADDRESS or MY_CONTROLLER_URL_ADDRESS below
                  //#define MY_IP_ADDRESS 192,168,80,15
                  //#define MY_IP_GATEWAY_ADDRESS 192,168,80,1
                  #define MY_PORT 5003
                  //#define MY_CONTROLLER_URL_ADDRESS "my.controller.org"
                  // Note that most of the Arduino examples use  "DEAD BEEF FEED" for the MAC address.
                  #define MY_MAC_ADDRESS 0x00, 0x40, 0xFD, 0xEF, 0x35, 0x75
                  // Enable inclusion mode
                  // Set blinking period
                  // Flash leds on rx/tx/err
                  #define MY_DEFAULT_ERR_LED_PIN 7  // Error led pin
                  #define MY_DEFAULT_RX_LED_PIN  8  // Receive led pin
                  #define MY_DEFAULT_TX_LED_PIN  9  // Transmit led pin
                  #if defined(MY_USE_UDP)
                  #include <EthernetUdp.h>
                  #include <Ethernet.h>
                  serial monitor output:
                  30055 TSM:FAIL:RE-INIT
                  30057 TSM:INIT
                  30063 !TSM:INIT:TSP FAIL
                  30065 TSM:FAIL:CNT=4
                  30067 TSM:FAIL:DIS
                  30069 TSF:TDI:TSL
                  0 MCO:BGN:INIT GW,CP=RNNGA---,FQ=16,REL=255,VER=2.3.2
                  4 TSM:INIT
                  5 TSF:WUR:MS=0
                  11 !TSM:INIT:TSP FAIL
                  13 TSM:FAIL:CNT=1
                  15 TSM:FAIL:DIS
                  16 TSF:TDI:TSL
                  10019 TSM:FAIL:RE-INIT
                  10021 TSM:INIT
                  10028 !TSM:INIT:TSP FAIL
                  10030 TSM:FAIL:CNT=2
                  10032 TSM:FAIL:DIS
                  10034 TSF:TDI:TSL
                  20037 TSM:FAIL:RE-INIT
                  20039 TSM:INIT
                  20045 !TSM:INIT:TSP FAIL
                  20047 TSM:FAIL:CNT=3
                  20049 TSM:FAIL:DIS
                  20051 TSF:TDI:TSL
                  30057 TSM:INIT
                  30067 TSM:FAIL:DIS
                  30069 TSF:TDI:TSL
                  40072 TSM:FAIL:RE-INIT
                  40074 TSM:INIT
                  40080 !TSM:INIT:TSP FAIL
                  40082 TSM:FAIL:CNT=5
                  40084 TSM:FAIL:DIS
                  40086 TSF:TDI:TSL
                  50089 TSM:FAIL:RE-INIT
                  50092 TSM:INIT
                  50098 !TSM:INIT:TSP FAIL
                  50100 TSM:FAIL:CNT=6
                  50102 TSM:FAIL:DIS
                  50104 TSF:TDI:TSL
                  60107 TSM:FAIL:RE-INIT
                  60109 TSM:INIT
                  60115 !TSM:INIT:TSP FAIL
                  60118 TSM:FAIL:CNT=7
                  60120 TSM:FAIL:DIS
                  60122 TSF:TDI:TSL
                  120125 TSM:FAIL:RE-INIT
                  120127 TSM:INIT
                  120133 !TSM:INIT:TSP FAIL
                  120136 TSM:FAIL:CNT=7
                  120138 TSM:FAIL:DIS
                  120139 TSF:TDI:TSL
                  180142 TSM:FAIL:RE-INIT
                  180144 TSM:INIT
                  180150 !TSM:INIT:TSP FAIL
                  180153 TSM:FAIL:CNT=7
                  180155 TSM:FAIL:DIS
                  180156 TSF:TDI:TSL
                  4 TSM:INIT
                  5 TSF:WUR:MS=0
                  13 TSM:FAIL:CNT=1
                  15 TSM:FAIL:DIS
                  16 TSF:TDI:TSL
                  10021 TSM:INIT
                  10032 TSM:FAIL:DIS
                  10034 TSF:TDI:TSL
                  20039 TSM:INIT
                  20049 TSM:FAIL:DIS
                  20051 TSF:TDI:TSL
                  30057 TSM:INIT
                  30067 TSM:FAIL:DIS
                  30069 TSF:TDI:TSL
                  there must be something i'm not being able to figure out....
                  dhcp served by dnsmasq. all other devices work without problem.
                  • pw44P pw44
                    #define MY_SOFTSPI
                    30057 TSM:INIT
                    30067 TSM:FAIL:DIS
                    30069 TSF:TDI:TSL
                    4 TSM:INIT
                    5 TSF:WUR:MS=0
                    13 TSM:FAIL:CNT=1
                    15 TSM:FAIL:DIS
                    16 TSF:TDI:TSL
                    10021 TSM:INIT
                    10032 TSM:FAIL:DIS
                    10034 TSF:TDI:TSL
                    20039 TSM:INIT
                    20049 TSM:FAIL:DIS
                    20051 TSF:TDI:TSL
                    30057 TSM:INIT
                    30067 TSM:FAIL:DIS
                    30069 TSF:TDI:TSL
                    40074 TSM:INIT
                    40084 TSM:FAIL:DIS
                    40086 TSF:TDI:TSL
                    50092 TSM:INIT
                    50102 TSM:FAIL:DIS
                    50104 TSF:TDI:TSL
                    60109 TSM:INIT
                    60120 TSM:FAIL:DIS
                    60122 TSF:TDI:TSL
                    120127 TSM:INIT
                    120138 TSM:FAIL:DIS
                    120139 TSF:TDI:TSL
                    180144 TSM:INIT
                    180155 TSM:FAIL:DIS
                    180156 TSF:TDI:TSL
                    4 TSM:INIT
                    5 TSF:WUR:MS=0
                    13 TSM:FAIL:CNT=1
                    15 TSM:FAIL:DIS
                    16 TSF:TDI:TSL
                    10021 TSM:INIT
                    10032 TSM:FAIL:DIS
                    10034 TSF:TDI:TSL
                    20039 TSM:INIT
                    20049 TSM:FAIL:DIS
                    20051 TSF:TDI:TSL
                    30057 TSM:INIT
                    30067 TSM:FAIL:DIS
                    30069 TSF:TDI:TSL
                    @pw44 the log shows that the gateway is unable to initialize the nrf24 radio module. This prevents the gateway code from reaching the dhcp section.
                    Double-check the nrf24 wiring. If you can, replace the radio module. If that doesn't help, post detailed photos of the wiring and we'll try to spot what could be wrong.
                    • mfalkviddM
                      Also, are you sure the w5100 shield you are using is capable of managing the SPI_EN signal?
                      • pw44P
                        pw44P
                        pw44
                        these are the real photos of the setup.
                        wire codes are the same as the build instructions ;-)
                        managing the SPI_EN signal? tried with and without, no changes.
                        IMG_6520.JPG IMG_6521.JPG IMG_6522.JPG IMG_6523.JPG IMG_6524.JPG IMG_6525.JPG IMG_6526.JPG
                        • pw44P pw44
                          #21
                          @pw44 you seem to have the same w5100 shield as i have. Try removing the sd card.
                          If that doesn't work, try my fix here : https://forum.mysensors.org/topic/9732/arduino-uno-with-ethernet-shield-w5100-not-working/10
                          • YveauxY Yveaux
                            pw44P
                            pw44P
                            pw44
                            @Yveaux
                            Thanks for the reply, removing the sd card or applying your fix did not change the problem.
                            • pw44P pw44
                              @Yveaux
                              @pw44 why are spi clk/miso/mosi connected to A0.. 2 ¿
                              • YveauxY Yveaux
                                pw44P
                                pw44P
                                pw44
                                @Yveaux
                                @Yveaux said in Gateway Uno R3 + W5100 Ethernet Shield for Uno not working.:
                                as described in https://www.mysensors.org/build/ethernet_gateway
                                • pw44P pw44
                                  @Yveaux
                                  #25
                                  @pw44 said in Gateway Uno R3 + W5100 Ethernet Shield for Uno not working.:
                                  Yes, but the sketch just below it has
                                  //#define MY_W5100_SPI_EN 4
                                  You actually have enabled this line, which causes the arduino to use hardware spi. And hardware spi uses different pins for clk/miso/mosi.
                                  You wired for software spi, so comment that line as in the example.
                                  pw44P 2 Replies Last reply
                                  • YveauxY Yveaux
                                    pw44P
                                    pw44P
                                    pw44
                                    @Yveaux
                                    thanks man, you're right. commenting out
                                    solved it.
                                    now, debug shows:
                                    4 MCO:BGN:BFR
                                    6 TSM:INIT
                                    7 TSF:WUR:MS=0
                                    13 TSM:INIT:TSP OK
                                    15 TSM:INIT:GW MODE
                                    16 TSM:READY:ID=0,PAR=0,DIS=0
                                    19 MCO:REG:NOT NEEDED
                                    696 GWT:TIN:IP=192.168.80.9
                                    1699 MCO:BGN:STP
                                    1701 MCO:BGN:INIT OK,TSP=1
                                    1703 TSM:READY:NWD REQ
                                    1709 ?TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=20,pt=0,l=0,sg=0,ft=0,st=OK:
                                    just another question: does the 3.3v line from Uno R# enough power to handle the RF24 radio?
                                    Thx in advance!
                                    • YveauxY Yveaux
                                      pw44P
                                      pw44P
                                      pw44
                                      @Yveaux and regardin IRQ from RF24, is it necessary to connect to pin2 of UNO R3?
                                      • pw44P pw44
                                        @pw44 no
                                        The IRQ pin is only required to be connected if the MY_RX_MESSAGE_BUFFER_FEATURE is defined in the sketch. Using this feature is recommended for high traffic nodes or gateways. Enabling it will result in better throughput but will require some additional memory to keep the message in memory before processing.
                                        More information: https://www.mysensors.org/build/connect_radio and MY_RX_MESSAGE_BUFFER_FEATURE
                                          @pw44 no
                                          pw44P
                                          pw44P
                                          pw44
                                          @mfalkvidd
                                          thank for the answer.
                                          i guess the UNO R3 is capable to do it, so, i tried
                                          #define MY_RX_MESSAGE_BUFFER_FEATURE
                                          #define MY_RF24_IRQ_PIN 3
                                          and got the following error:
                                          #error RF24 IRQ usage cannot be used with Soft SPI
                                          Any hint? The idea is having something like 80 nodes when all is done.
                                          Thx
