  3. Get string data
Get string data
10 Posts 4 Posters 4.3k Views 2 Watching
  • C Offline
    C Offline
    C.r.a.z.y.
    String sentData = ""
    send: 51-51-0-0 s=1,c=1,t=2,pt=2,l=2,st=ok:1
    How can i put this serial monitor print to sentData ?
    C B 2 Replies Last reply
    • C C.r.a.z.y.
      C Offline
      C Offline
      C.r.a.z.y.
      Is it impossible?
      H 1 Reply Last reply
      • C C.r.a.z.y.
        Is it impossible?
        H Offline
        H Offline
        @C.r.a.z.y.
        Sorry, I don't understand.
        • C C.r.a.z.y.
          B Offline
          B Offline
          BulldogLowell
          are you looking to log these serial outputs as Strings?
          C 1 Reply Last reply
          • B BulldogLowell
            C Offline
            C Offline
            C.r.a.z.y.
            @BulldogLowell Yes :+1:
            • C Offline
              C Offline
              C.r.a.z.y.
              Maybe i am asking wrong;
              If there is "fail"
              send: 51-51-0-0 s=1,c=1,t=2,pt=2,l=2,st=fail:0
              it will reboot
              if (re.indexOf("fail") >=0)
              asm volatile (" jmp 0"); //reboot
              Why i need this; because i cant turn on or off my lights when sketch failed.
              F 1 Reply Last reply
              • C C.r.a.z.y.
                If there is "fail"
                it will reboot
                F Offline
                F Offline
                funky81
                @C.r.a.z.y.
                sorry for asking this, but is this the code for reboot?
                does it work?
                • C Offline
                  C Offline
                  C.r.a.z.y.
                  Maybe one day someone will use this;
                  **When sketch fails second push will work without gateway and it will restart
                  debouncer.update();
                  value = debouncer.read();
                  if (value != oldValue && value==0) {
                  if (re!="1")
                  int oku=digitalRead(RELAY_PIN);
                  if(oku==1)
                  digitalWrite(RELAY_PIN,0);
                  digitalWrite(RELAY_PIN,1);
                  gw.send(msg.set(state?false:true),true); // Send new state and request ack back
                  re="";
                  oldValue = value;
                  state = message.getBool();
                  gw.saveState(CHILD_ID, state);
                  re=String(message.sensor);
                  • C C.r.a.z.y.
                    debouncer.update();
                    if (re!="1")
                    if(oku==1)
                    re="";
                    oldValue = value;
                    F Offline
                    F Offline
                    funky81
                    @C.r.a.z.y. Thanks for the code, very useful, coz I've found out is that i have to restart my pro mini every couple of days...
                    • F funky81
                      C Offline
                      C Offline
                      C.r.a.z.y.
                      @funky81 Hek can make better but he didnt understand as you see :-1:
                      12.2k
