  3. building the Ethernet gateway
12 Posts 6 Posters 4.9k Views 5 Watching
  • E evertos
    Hellow there I'm new to mysensors and I'm trying to create the Ethernet gateway.
    I use the following products:
    • Nano V3.0 ATmega328P 5V
    • list itemKeyestudio W5100_POE_PiA Netwerk Module
    • NRF24L01+PA+LNA 1100-meter long-distance
    I was not be able to following the wiring structure because the W5100 has a differend pin Layout. I found the following picture and connect the W5100 as described:
    http://arduino-info.wikispaces.com/Ethernet
    I did follow the guide but I can't get it working, I'm not able to get an IP address. I did test the Nano, with the "blink" script this is working so this should be fine.
    Script:
     * Version 1.0 - Henrik EKblad
     * LED purposes:
    #define MY_GATEWAY_W5100
    //#define MY_W5100_SPI_EN 4
    // radio on the same spi bus.
    #define MY_SOFTSPI
    #ifndef MY_RF24_CE_PIN
    #define MY_RF24_CE_PIN 5
    #ifndef MY_RF24_CS_PIN
    #define MY_RF24_CS_PIN 6
    // Enable to UDP
    //#define MY_USE_UDP
    //#define MY_IP_ADDRESS 192,168,0,199   // If this is disabled, DHCP is used to retrieve address
    #define MY_PORT 5003
    // Enable inclusion mode
    // Set blinking period
    // Flash leds on rx/tx/err
    #if defined(MY_USE_UDP)
    #include <EthernetUdp.h>
    #include <Ethernet.h>
    please help...
    Thank you in advance,
    Welcome to the MySensors community @evertos !
    I took the liberty to add the code markup for the sketch. This makes it much easier to read here in the forum. Please use it next time.
    The wiring looks good.
    Could you post the serial debug output?
    • E evertos
      Script:
       * LED purposes:
      #define MY_SOFTSPI
      // Enable to UDP
      please help...
      TerrenceT
      TerrenceT
      Terrence
      @evertos I can't help but notice there is no code in your setup or loop.
      gohanG 1 Reply Last reply
      • TerrenceT Terrence
        @Terrence for gateway you don't need code in setup and loop
        TerrenceT 1 Reply Last reply
          TerrenceT
          TerrenceT
          Terrence
          wrote on last edited by Terrence
          @gohan Thank you for pointing that out. Just getting started in MS.
          • E
            E
            evertos
            Hi!
            Thank you all for the fast response, I'm in the middle of buying a house so I will test this as soon as possible.
            Thank you for the response!
            • E
              E
              evertos
              wrote on last edited by evertos
              Good afternoon all,
              I did some more testing and finally, got an IP address and I'm able to ping the gateway, but it looks like that the gateway keeps restarting.
              I'm using OpenHab to communicate, and OpenHab is not been able to get the Gateway version.
              Did some one got the same version (2.1.1 ) Up and running with OpenHab?
              Evert
              Serial Gateway Log
              ##0;255;3;0;9;MCO:BGN:INIT GW,CP=RNNGA--,VER=2.1.1
              0;255;3;0;9;TSM:INIT
              0;255;3;0;9;TSF:WUR:MS=0
              0;255;3;0;9;TSM:INIT:TSP OK
              0;255;3;0;9;TSM:INIT:GW MODE
              IP: 192.168.0.201
              0;255;3;0;9;Eth: connect
              IP: 192.168.0.201
              IP: 192.168.0.201
              • E evertos
                Good afternoon all,
                Evert
                Serial Gateway Log
                IP: 192.168.0.201
                IP: 192.168.0.201
                IP: 192.168.0.201
                BulldogLowellB
                BulldogLowellB
                BulldogLowell
                @evertos
                I had the restart problem, and tried the advice here regarding the Arduino IDE's Board Manager.
                • E
                  E
                  evertos
                  Thank you for all the answers just got the INternet Gateway working
                  Just downgrade the Arduino IDE to: 1.6.8. (Arduino program)
                  Als for other beginners, as soon as you upload an "Mysensors", switch to 11520 baund on the Serial Monitor.
                  I did test my cheap Arduino clone with the basic ethernet script and this is using another baund on the serial monitor. I know it is stupid but this also cost me a couple of nights before I realize that this was my first problem.
                  Thank you all for the answers!
                    If you set the default baud rate in myconfig.h you should have all sensors and gateway running the same (of course you don't have to specify it in the sketch)
                    • pw44P
                      pw44P
                      pw44
                      wrote on last edited by pw44
                      Hi All,
                      for the mysensors the gateway i decided also to give a try with ENC28J60 Ethernet module, RF24 and arduino nano.
                      The code i used is:
                      #define MY_RADIO_RF24
                      // When ENC28J60 is connected we have to move CE/CSN pins for NRF radio
                      #define MY_GATEWAY_ENC28J60
                      // Gateway IP address
                      #define MY_IP_ADDRESS 192,168,80,9
                      #define MY_IP_GATEWAY_ADDRESS 192,168,80,1
                      #define MY_MAC_ADDRESS 0x00, 0x40, 0xFD, 0xEF, 0x35, 0x70
                      //#define MY_CONTROLLER_IP_ADDRESS 192, 168, 80, 4
                      // If MQTT, uncomment the follwoing:
                      //#define MY_GATEWAY_MQTT_CLIENT
                      //#define MY_MQTT_CLIENT_ID "mysnsg1"
                      //#define MY_MQTT_USER "admin"
                      //#define MY_MQTT_PASSWORD "bucleta01"
                      //#define MY_CONTROLLER_URL_ADDRESS "mysnsg1.wollny.com.br"
                      //#define MY_PORT 1883
                      //#define MY_MQTT_PUBLISH_TOPIC_PREFIX "mysnsg1-out"
                      //#define MY_MQTT_SUBSCRIBE_TOPIC_PREFIX "mysnsg1-in"
                      #define MY_DEFAULT_TX_LED_PIN  9  // the PCB, on board LED
                      #include <UIPEthernet.h>
                      on the monitor, i read:
                      0 MCO:BGN:INIT GW,CP=RNNGA---,FQ=16,REL=255,VER=2.3.2
                      4 TSM:INIT0 MCO:BGN:INIT GW,CP=RNNGA---,FQ=16,REL=255,VER=2.3.2
                      4 TSM:INIT
                      5 TSF:WUR:MS=0
                      12 TSM:INIT:TSP OK
                      13 TSM:INIT:GW MODE
                      15 TSM:READY:ID=0,PAR=0,DIS=0
                      18 MCO:REG:NOT NEEDED
                      71 GWT:TIN:IP=192.168.80.9
                      1074 MCO:BGN:STP
                      1075 MCO:BGN:INIT OK,TSP=1
                      1078 TSM:READY:NWD REQ
                      1083 ?TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=20,pt=0,l=0,sg=0,ft=0,st=OK:
                      4 TSM:INIT
                      5 TSF:WUR:MS=0
                      12 TSM:INIT:TSP OK
                      13 TSM:INIT:GW MODE
                      1074 MCO:BGN:STP
                      13182 GWT:TSA:ETH OK
                      13190 GWT:RFC:MSG=0;255;3;0;2;
                      23293 GWT:RFC:MSG=0;255;3;0;2;
                      33400 GWT:RFC:MSG=0;255;3;0;2;
                      43508 GWT:RFC:MSG=0;255;3;0;2;
                      53615 GWT:RFC:MSG=0;255;3;0;2;
                      63723 GWT:RFC:MSG=0;255;3;0;2;
                      73830 GWT:RFC:MSG=0;255;3;0;2;
                      83937 GWT:RFC:MSG=0;255;3;0;2;
                      94044 GWT:RFC:MSG=0;255;3;0;2;
                      104153 GWT:RFC:MSG=0;255;3;0;2;
                      114259 GWT:RFC:MSG=0;255;3;0;2;
                      124366 GWT:RFC:MSG=0;255;3;0;2;
                      134474 GWT:RFC:MSG=0;255;3;0;2;
                      144581 GWT:RFC:MSG=0;255;3;0;2;
                      154689 GWT:RFC:MSG=0;255;3;0;2;
                      164798 GWT:RFC:MSG=0;255;3;0;2;
                      174905 GWT:RFC:MSG=0;255;3;0;2;
                      185013 GWT:RFC:MSG=0;255;3;0;2;
                      195324 GWT:RFC:MSG=0;255;3;0;2;
                      205228 GWT:RFC:MSG=0;255;3;0;2;
                      215334 GWT:RFC:MSG=0;255;3;0;2;
                      225441 GWT:RFC:MSG=0;255;3;0;2;
                      235549 GWT:RFC:MSG=0;255;3;0;2;
                      245657 GWT:RFC:MSG=0;255;3;0;2;
                      255970 GWT:RFC:MSG=0;255;3;0;2;
                      265872 GWT:RFC:MSG=0;255;3;0;2;
                      275980 GWT:RFC:MSG=0;255;3;0;2;
                      286088 GWT:RFC:MSG=0;255;3;0;2;
                      296196 GWT:RFC:MSG=0;255;3;0;2;
                      306302 GWT:RFC:MSG=0;255;3;0;2;
                      316411 GWT:RFC:MSG=0;255;3;0;2;
                      326518 GWT:RFC:MSG=0;255;3;0;2;
                      336625 GWT:RFC:MSG=0;255;3;0;2;
                      346733 GWT:RFC:MSG=0;255;3;0;2;
                      357048 GWT:RFC:MSG=0;255;3;0;2;
                      366948 GWT:RFC:MSG=0;255;3;0;2;
                      377056 GWT:RFC:MSG=0;255;3;0;2;
                      387163 GWT:RFC:MSG=0;255;3;0;2;
                      397270 GWT:RFC:MSG=0;255;3;0;2;
                      407377 GWT:RFC:MSG=0;255;3;0;2;
                      417485 GWT:RFC:MSG=0;255;3;0;2;
                      427592 GWT:RFC:MSG=0;255;3;0;2;
                      437701 GWT:RFC:MSG=0;255;3;0;2;
                      447807 GWT:RFC:MSG=0;255;3;0;2;
                      457916 GWT:RFC:MSG=0;255;3;0;2;
                      468024 GWT:RFC:MSG=0;255;3;0;2;
                      478131 GWT:RFC:MSG=0;255;3;0;2;
                      488238 GWT:RFC:MSG=0;255;3;0;2;
                      498345 GWT:RFC:MSG=0;255;3;0;2;
                      for testing, i installed also mycontroller, but seams there is no interaction.
                      also trying to make it dhcp (commenting out the ip line), does not work (complie error).
                      beside that, disconnecting the usb cabe makes it becomes unresponsive to ping, even powered and connected to the ethernet cable.
                      Home Assistant Core also does not connect to it.
                      Thx in advance for any help.
                      • pw44P pw44
                        Hi All,
                        The code i used is:
                        4 TSM:INIT
                        5 TSF:WUR:MS=0
                        12 TSM:INIT:TSP OK
                        13 TSM:INIT:GW MODE
                        1074 MCO:BGN:STP
                        4 TSM:INIT
                        5 TSF:WUR:MS=0
                        12 TSM:INIT:TSP OK
                        13 TSM:INIT:GW MODE
                        1074 MCO:BGN:STP
                        If someone tries to help @pw44, please respond in https://forum.mysensors.org/topic/11213/mysensor-gateway-with-enc28j60-ethernet-doubts to avoid confusion and double work.
