  3. NodeManager
  4. BME280/BMP280 high consumption when sleeping
11 Posts 4 Posters 2.2k Views 4 Watching
  • B bbastos
    First, I'd like to thank you all for the hard working building mysensors and nodemanager. This's an incredible and motivanting way of learn and build DIY iot devices even by beginners like me. So my big thank you!
    About my problem, I'm getting 0.50mA when sleeping using BME280/BMP280, just arduino(pro mini) and radio gives me 5uA. I've tried to power the sensor from digital pins using PowerManager power(5,6), but i'm still getting 0.50mA when sleeping.
    It seems like the i2c bus is not being disabled when enter on sleep mode.
    rvendrameR
    rvendrameR
    rvendrame
    @bbastos , welcome to mySensors. Try to add these lines before the sleep():
    digitalWrite( A4 , LOW );
    digitalWrite( A5 , LOW );
    Stills unclear why, but it worked for me at least.
    Reference: https://forum.mysensors.org/post/99876
    ESP8266 GW + mySensors 2.3.2
    Alexa / Google Home
    B 1 Reply Last reply
    • TRS-80T
      TRS-80T
      TRS-80
      I am still one of the newer people around here, so I could be off base, but my first thought was "how are you measuring that?"
      • rvendrameR rvendrame
        B
        B
        bbastos
        @rvendrame said in BME280/BMP280 high comsumption when sleeping:
        Thank you @rvendrame! I'll surely try, the only problem is that I don't have control over sleep function, it's encapsulated in nodemager. I'll try to find the best place to put the code you've sugested.
        • TRS-80T TRS-80
          B
          B
          bbastos
          @TRS-80 said in BME280/BMP280 high comsumption when sleeping:
          You need to put the digital multimeter in series with your circuit +- like this:
          Please don't mind the bad quality pictures.
            Memphis007
            Looks like you're using the 5v version of the bme280, there's an extra 3.3v regulator on this board, this could be the culprit.
            • M Memphis007
              B
              B
              bbastos
              wrote on last edited by bbastos
              @Memphis007 said in BME280/BMP280 high comsumption when sleeping:
              I really didn't paid too much attention when buying. I've taken better pictures of bme280 and bmp280, would you mind help me identifying?
              Is there any way to modify the 5v version to works with 3.3v?
              • TRS-80T
                TRS-80T
                TRS-80
                wrote on last edited by TRS-80
                Second picture, left one, middle left of board, large component with 3 leads looks like a regulator to me.
                If you bought on Ali, you should have detailed purchase records, take a close look at them it should state 5v or 3.3v pretty clearly.
                • B
                  B
                  bbastos
                  Either way, using mysensors library directly with @rvendrame tips I was able to get 7uA during sleep.
                  //#define MY_REPEATER_FEATURE
                  #define MY_NODE_ID 100
                  //#define MY_PARENT_NODE_ID
                  #include <Adafruit_Sensor.h>
                  #include <Adafruit_BME280.h> // I had to change I2C address in library for 0x76 (line 32)
                  Adafruit_BME280 bme; // I2C
                  #define CHILD_ID_HUM 0
                  #define CHILD_ID_TEMP 1
                  #define CHILD_ID_PRESS 2
                  // MyMessage to controler
                  MyMessage msgT1(CHILD_ID_TEMP, V_TEMP);
                  MyMessage msgP1(CHILD_ID_PRESS, V_PRESSURE);
                  MyMessage msgF1(CHILD_ID_PRESS, V_FORECAST);
                  MyMessage msgH1(CHILD_ID_HUM, V_HUM);
                    sendSketchInfo("BME280 Test", "1.0");
                    present(CHILD_ID_PRESS, S_BARO);
                    present(CHILD_ID_HUM, S_HUM);
                    //GND
                    pinMode(5,OUTPUT);
                    digitalWrite(5, LOW);
                    //VCC
                    pinMode(6,OUTPUT);
                    digitalWrite(6, HIGH);
                    //Baudrate
                    Serial.begin(9600);
                    //BME280 init
                    initBme280();
                    //Initial reading
                    serverUpdate();
                    initBme280();
                    serverUpdate();
                    //delay(200);
                    digitalWrite(6, LOW);
                    digitalWrite(SDA, LOW); // disable internal pullup
                    digitalWrite(SCL, LOW);  // disable internal pullup
                    sleep(60000); //sleep 1 minute
                  void initBme280() {
                    if (!bme.begin(0x76)) {
                      Serial.println("Could not find a valid BME280 sensor, check wiring!");
                      while (1);
                  // used to read sensor data and send it to controller
                  void serverUpdate() {
                    double T, P, H;
                    T=bme.readTemperature();
                    P=bme.readPressure()/100.0;
                    H=bme.readHumidity();
                    delay(10);
                    send(msgT1.set(T, 1));
                    send(msgP1.set(P, 1));
                    send(msgH1.set(H,1));
                     // unmark for debuging
                    Serial.print("T = \t"); Serial.print(T, 1); Serial.print(" C\t");
                    Serial.print("P = \t"); Serial.print(P, 1); Serial.print(" mBar\t");
                    Serial.print("H = \t"); Serial.print(H, 1); Serial.print(" %\t");
                  • TRS-80T
                    TRS-80T
                    TRS-80
                    @bbastos said in BME280/BMP280 high comsumption when sleeping:
                    7uA during sleep
                    Sounds pretty good to me!
                    You calling it done then? :)
                    • TRS-80T TRS-80
                      7uA during sleep
                      B
                      B
                      bbastos
                      7uA during sleep
                      Yes, it`s pretty good! But I'd like to use nodemanager on my nodes, it's so much easier :grin: I'll open an issue on nodemanager's github.
                      Thank you so much for the help!
