  3. NodeManager
  4. BME280/BMP280 high consumption when sleeping
11 Posts 4 Posters 2.0k Views 4 Watching
  • B Offline
    B Offline
    bbastos
    wrote on last edited by bbastos
    First, I'd like to thank you all for the hard working building mysensors and nodemanager. This's an incredible and motivanting way of learn and build DIY iot devices even by beginners like me. So my big thank you!
    About my problem, I'm getting 0.50mA when sleeping using BME280/BMP280, just arduino(pro mini) and radio gives me 5uA. I've tried to power the sensor from digital pins using PowerManager power(5,6), but i'm still getting 0.50mA when sleeping.
    It seems like the i2c bus is not being disabled when enter on sleep mode.
    R 1 Reply Last reply
    • B bbastos
      R Offline
      R Offline
      rvendrame
      @bbastos , welcome to mySensors. Try to add these lines before the sleep():
      digitalWrite( A4 , LOW );
      digitalWrite( A5 , LOW );
      Stills unclear why, but it worked for me at least.
      Reference: https://forum.mysensors.org/post/99876
      ESP8266 GW + mySensors 2.3.2
      Alexa / Google Home
      B 1 Reply Last reply
      • TRS-80T Offline
        TRS-80T Offline
        TRS-80
        I am still one of the newer people around here, so I could be off base, but my first thought was "how are you measuring that?"
        • R rvendrame
          B Offline
          B Offline
          bbastos
          @rvendrame said in BME280/BMP280 high comsumption when sleeping:
          Thank you @rvendrame! I'll surely try, the only problem is that I don't have control over sleep function, it's encapsulated in nodemager. I'll try to find the best place to put the code you've sugested.
          • TRS-80T TRS-80
            B Offline
            B Offline
            bbastos
            @TRS-80 said in BME280/BMP280 high comsumption when sleeping:
            You need to put the digital multimeter in series with your circuit +- like this:
            Please don't mind the bad quality pictures.
            • M Offline
              M Offline
              Memphis007
              Looks like you're using the 5v version of the bme280, there's an extra 3.3v regulator on this board, this could be the culprit.
              • M Memphis007
                B Offline
                B Offline
                bbastos
                @Memphis007 said in BME280/BMP280 high comsumption when sleeping:
                I really didn't paid too much attention when buying. I've taken better pictures of bme280 and bmp280, would you mind help me identifying?
                Is there any way to modify the 5v version to works with 3.3v?
                • TRS-80T Offline
                  TRS-80T Offline
                  TRS-80
                  wrote on last edited by TRS-80
                  Second picture, left one, middle left of board, large component with 3 leads looks like a regulator to me.
                  If you bought on Ali, you should have detailed purchase records, take a close look at them it should state 5v or 3.3v pretty clearly.
                  • B Offline
                    B Offline
                    bbastos
                    Either way, using mysensors library directly with @rvendrame tips I was able to get 7uA during sleep.
                    //#define MY_REPEATER_FEATURE
                    #define MY_NODE_ID 100
                    //#define MY_PARENT_NODE_ID
                    #include <Adafruit_Sensor.h>
                    #include <Adafruit_BME280.h> // I had to change I2C address in library for 0x76 (line 32)
                    Adafruit_BME280 bme; // I2C
                    #define CHILD_ID_HUM 0
                    #define CHILD_ID_TEMP 1
                    #define CHILD_ID_PRESS 2
                    // MyMessage to controler
                    MyMessage msgT1(CHILD_ID_TEMP, V_TEMP);
                    MyMessage msgP1(CHILD_ID_PRESS, V_PRESSURE);
                    MyMessage msgF1(CHILD_ID_PRESS, V_FORECAST);
                    MyMessage msgH1(CHILD_ID_HUM, V_HUM);
                      sendSketchInfo("BME280 Test", "1.0");
                      present(CHILD_ID_PRESS, S_BARO);
                      present(CHILD_ID_HUM, S_HUM);
                      //GND
                      pinMode(5,OUTPUT);
                      digitalWrite(5, LOW);
                      //VCC
                      pinMode(6,OUTPUT);
                      digitalWrite(6, HIGH);
                      //Baudrate
                      Serial.begin(9600);
                      //BME280 init
                      initBme280();
                      //Initial reading
                      serverUpdate();
                      initBme280();
                      serverUpdate();
                      //delay(200);
                      digitalWrite(6, LOW);
                      digitalWrite(SDA, LOW); // disable internal pullup
                      digitalWrite(SCL, LOW);  // disable internal pullup
                      sleep(60000); //sleep 1 minute
                    void initBme280() {
                      if (!bme.begin(0x76)) {
                        Serial.println("Could not find a valid BME280 sensor, check wiring!");
                        while (1);
                    // used to read sensor data and send it to controller
                    void serverUpdate() {
                      double T, P, H;
                      T=bme.readTemperature();
                      P=bme.readPressure()/100.0;
                      H=bme.readHumidity();
                      delay(10);
                      send(msgT1.set(T, 1));
                      send(msgP1.set(P, 1));
                      send(msgH1.set(H,1));
                       // unmark for debuging
                      Serial.print("T = \t"); Serial.print(T, 1); Serial.print(" C\t");
                      Serial.print("P = \t"); Serial.print(P, 1); Serial.print(" mBar\t");
                      Serial.print("H = \t"); Serial.print(H, 1); Serial.print(" %\t");
                    • TRS-80T Offline
                      TRS-80T Offline
                      TRS-80
                      @bbastos said in BME280/BMP280 high comsumption when sleeping:
                      7uA during sleep
                      Sounds pretty good to me!
                      You calling it done then? :)
                      • TRS-80T TRS-80
                        7uA during sleep
                        B Offline
                        B Offline
                        bbastos
                        7uA during sleep
                        Yes, it`s pretty good! But I'd like to use nodemanager on my nodes, it's so much easier :grin: I'll open an issue on nodemanager's github.
                        Thank you so much for the help!
