  2. Announcements
  3. 💬 Servo Control Actuator
14 Posts 8 Posters 5.2k Views 8 Watching
  • Duncan PullenD
    Duncan PullenD
    Duncan Pullen
    I had issues with this sketch only doing what looked like 90° of motion when using a slider.
    Turned out, it was doing 100°.
    To rectify change the myservo.write line to:
    myservo.write(SERVO_MAX + (SERVO_MIN-SERVO_MAX)/100 * 1.8 * val); // sets the servo position 0-180
    • A
      anno
      how, what and is it possible to control 2 servo's, on pin 3 and 4 of 1 arduino?
      • A
        Albert P
        hello, Im getting following error during compilation this examle (latest libraries)
        \libraries\Servo\avr\Servo.cpp.o (symbol from plugin): In function `ServoCount':
        (.text+0x0): multiple definition of `__vector_11'
        • A Albert P
          @albert-p thanks for reporting.
          Which board are you using?
          How did you install the servo lib? From which source?
          • A
            Andrzej
            hello. I have a problem with this sketch. After restart, the servo moves only once, then the whole system locks.
            • A Andrzej
              @Andrzej what does the node's debug output say?
              • A
                Andrzej
                • A
                  Andrzej
                  nothing, node is blocked, i think this is due to servos time measurement in sketch, but when i replace servo with led, led blinks. I'm using MYSController
                  skywatchS 1 Reply Last reply
                  • A Andrzej
                    skywatchS
                    skywatchS
                    skywatch
                    @Andrzej Maybe power related - what power supply are you using and are you connecting servo to arduio for it's power?
                    A 1 Reply Last reply
                    • skywatchS skywatch
                      Andrzej
                      @skywatch, wow, you were right, I remembered such a basic thing, thank you for your help
                      12.5k
