  2. Announcements
  3. 💬 Servo Control Actuator
14 Posts 8 Posters 5.1k Views 8 Watching
    This thread contains comments for the article "Servo Control Actuator" posted on MySensors.org.
    • jonazperzzonJ
      jonazperzzonJ
      jonazperzzon
      Im trying to get this sketch do make continuos motion..I have hacked the Futada S3002 for this but I cant get my head around editiing the sketch for it.Help?
      • jonazperzzonJ
        jonazperzzonJ
        jonazperzzon
        Sorry, Futaba S3003 is the servo
        • jonazperzzonJ
          jonazperzzonJ
          jonazperzzon
          Sorry for being a noob...#define DETACH_DELAY was the answer
          • Duncan PullenD
            Duncan PullenD
            Duncan Pullen
            I had issues with this sketch only doing what looked like 90° of motion when using a slider.
            Turned out, it was doing 100°.
            To rectify change the myservo.write line to:
            myservo.write(SERVO_MAX + (SERVO_MIN-SERVO_MAX)/100 * 1.8 * val); // sets the servo position 0-180
            • A
              anno
              how, what and is it possible to control 2 servo's, on pin 3 and 4 of 1 arduino?
              • A
                Albert P
                hello, Im getting following error during compilation this examle (latest libraries)
                \libraries\Servo\avr\Servo.cpp.o (symbol from plugin): In function `ServoCount':
                (.text+0x0): multiple definition of `__vector_11'
                • A Albert P
                  @albert-p thanks for reporting.
                  Which board are you using?
                  How did you install the servo lib? From which source?
                  • A
                    Andrzej
                    hello. I have a problem with this sketch. After restart, the servo moves only once, then the whole system locks.
                    • A Andrzej
                      @Andrzej what does the node's debug output say?
                      • A
                        Andrzej
                        • A
                          Andrzej
                          nothing, node is blocked, i think this is due to servos time measurement in sketch, but when i replace servo with led, led blinks. I'm using MYSController
                          skywatchS 1 Reply Last reply
                          • A Andrzej
                            skywatchS
                            skywatchS
                            skywatch
                            @Andrzej Maybe power related - what power supply are you using and are you connecting servo to arduio for it's power?
                            A 1 Reply Last reply
                            • skywatchS skywatch
                              Andrzej
                              @skywatch, wow, you were right, I remembered such a basic thing, thank you for your help
