  3. Domoticz
  4. Domoticz weather sensor presentation
3 Posts 3 Posters 1.4k Views 3 Watching
  • I
    I
    iguaan
    I have created a weather sensor which has hum, temp, baro, predicition and lux.
    Aslo i have attached there another ds temp sensor (for node internal temp).
    Problem is that when i update fw over ota or reboot node, it'll occasionally detect sensors all mixed up:
    temp/hum, temp, baro/temp/hum etc... Also when it does that, not all the data will be updated on combined sensros.
    Is there a way to present the sensors to domticz so, that it recognises 1 combined weather sensor and then others.
    I have tried with all different Sensor ID's 1-4, lux id5 and internal temp id6.
    Also tried with giving same sensor ID number to hum, temp, baro and predicition.
    Domoticz detects it as a combined sensor, but it doesn't update all values after initial value has been sent.
    If i monitor the data on myscontroller, all the variables are updating on the node.
    • nagelcN
      nagelcN
      nagelc
      I had a similar problem with weather sensors, but it was a while ago and Domoticz has been updated since then.
      I was presenting temp, hum, baro. Domoticz always assumed it was a weather sensor if I presented the baro -- and the humidity wouldn't update. It didn't matter if I used separate child IDs or the same one.
      I really only wanted temperature and humidity, so I quit presenting the baro and the Domoticz temp/hum has always worked well.
      I just assumed I was doing something wrong, but your problem sounds similar. Maybe it's a Domoticz bug.
      • G
        G
        grumpazoid
        I use a BME280 sensor for outside and some 18b20's for inside. Domoticz works with these without problems but I do not use OTA - not figured that out yet :disappointed_relieved: :laughing: I had to cut out all the weather prediction code on for the BME280 to make it run on a pro mini 3.3 but Domoticz has basic prediction built in.
        Raspberry Pi 3B - Domoticz + Node Red
        Arduino Pro Mini 3.3V - W5100 Ethernet, Nrf24
        Arduino Mega, RFLink 433Mhz
        Sonoff/ESP8266/Tasmota switches
